Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
1351 posts / 0 new
led4power
led4power's picture
Last seen: 19 hours 14 min ago
Saul, Marc, I answered over PM.
Saul Good
Last seen: 1 month 13 hours ago
Thanks, Neven. I appreciate the confirmation that it did indeed ship. I must have accidentally deleted the order confirmation email in spam. Thanks for your time and diligent work!
TMaxxJJ
Last seen: 41 min 7 sec ago
Do you know if your Q8 boards are going to be available?
I knew I should have placed an order a couple of weeks ago when I was thinking about it!
Marc E
Last seen: 1 week 14 hours ago
You have indeed. Thank you, much appreciated Smile
Superstocker
Superstocker's picture
Last seen: 9 hours 11 min ago
Neven,
I just received my order yesterday. Everything looks great. Sorry you had to shutdown again but I’m glad business is going well. The new boards you mention do those include the quads in 3030 and 4040?
led4power
led4power's picture
3030 tripe and quad yes, 4040 3x/4x possibly (DTP Cu).
TMaxxJJ
How about the Q8 boards Neven?
Superstocker
Cool! Thanks Neven!
led4power
led4power's picture
PM sent.
gravelmonkey
Last seen: 2 min 14 sec ago
Installed the X6 Luxeon Quad! And LD-B4 12A driver- Beautiful!
One question, on highest mode the light flashes 4 times and steps down to quite a low mode after about 10 seconds, is this a mis-configured temp stepdown or something?
Thanks in advance!
led4power
led4power's picture
Probably it's OTP (default is ~55-60C), you can modify/disable it following instructions from datasheet.
Chatika vas Paus
Last seen: 1 hour 14 min ago
Neven, when your store will be open again, will there be new drivers available that were mentioned some time ago?
led4power
led4power's picture
I can't precisely tell when since I'm still in process of opening LLC. What can I tell is that I can't "transfer" stuff (LEDs,PCBs etc.) I currently have to LLC, so that sucks, I will at the beginning only have new stuff (MCPCBs, Osram LEDs, LD-x4 drivers). I'm working on drivers (lack of time as usual).
CNCman
CNCman's picture
Last seen: 10 hours 39 min ago
led4power.com …….. not opening / working……… Tired
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Never give up, Never surrender. Make someone Smile today.
hodor
hodor's picture
Last seen: 40 min 31 sec ago
Post #1315 :
led4power wrote:
Store is closed for now (probably by 1st July), similar thing happened like last year – income limit. I have one big customer and plan was to open LLC in February mainly because of that customer, but due to virus pandemic it was not possible (till now) to open LLC, so I had no choice but to process all orders over workshop/self-employed. This basically means store will be closed until I open LLC, good % of products (which was on clearance sale) will not be available anymore. The main reason for that I can’t sell stuff/products which are not bought over LLC account, I must check if it’s possible to “transfer” some of that stuff to LLC before registration…
gravelmonkey
led4power wrote:
Probably it’s OTP (default is ~55-60C), you can modify/disable it following instructions from datasheet.
Disabled it and it worked fine, so I wondered if the board needed better contact with the spacer.
Sanded the legs of the optic a tiny bit, to make sure they were not ‘bottoming out’ before pressing down on the mpcb. Cleaned and re-applied heat transfer compound.
With temp regulation on, light now works for 1min+ before it gets too hot and steps down, all good Thumbs Up
led4power
led4power's picture
LD-A4/B4 use external NTC sensor for temp. measurement, so driver contact with spacer is not important. Is seems that LED PCB did reach ~60C, which is not too surprising, but if flashlight itself was relatively cold that would mean bad thermal contact somewhere (LED PCB - spacer, or spacer - host, or both). So I would check if there is enough thermal paste, maybe you have aluminum burr/dust from drilling between spacer and host which prevents proper thermal contact etc.
treellama
Last seen: 13 min 19 sec ago
I wonder if there is a way to leave the item descriptions online without the store. I had trouble getting a triple Luxeon MZ working on a MOSX PCB until I found in the Google cache I needed to bridge the MOSFET footprint.
led4power
led4power's picture
Only way is to manually change stock qty of all items to 0.
Agro
Agro's picture
Last seen: 2 min 58 sec ago
As I learn about drivers sometimes there’s a thing that surprises me.
This happened with LD4 recently.
5mΩ resistance is quite low considering that you probably need to sense current somehow.
I wonder if you do this with a really low value resistor or use some other sensing technique or sidestep this in an entirely different way.
I know that the exact construction of LD4 is a trade secret and I don’t ask you to reveal any special sauce but if this actual thing is not something special it would be great to read it.
led4power
led4power's picture
5mOhm driver resistance is accomplished by using 1mOhm sense resistor (nothing special about it), FET adds about 3-3.5mOhm, traces 0.5-1mOhm. LD-2/3/4 design comes from era when XM-L2 and XP-G2 were most popular LEDs, and they both have very high Vf, so driver with lower resistance allowed higher output on max. mode. But there is always trade-off, in this case lower resolution on low currents.
These days basically all good emitters have quite low Vf and there is no need for such low parasitic/internal resistance (that's why my next drivers will have 10mOhm sense resistor for 5Amp driver).
Agro
Agro's picture
I see, thanks for the explanation. Smile
MascaratumB
MascaratumB's picture
Last seen: 1 min 23 sec ago
Neven, some time ago I installed one of yours 9A driver on a 14500 flashlight, powering 3x XP-G2 Leds.
It worked fine until some weeks ago, and I just wanted to perceive what may have happened.
What happens now is that it only works with 2 modes, like Moonlight and Turbo, no matter how many times I click, I can’t enter the programming mode.
Could it be some component that “burned” or got damaged, and that originated this inability to have more modes or enter the programming?
BTW, the host is a Jaxman E3 and I am using a forward clicky switch.
Thanks in advance!
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
led4power
led4power's picture
 PM sent.
MascaratumB
led4power wrote:
 PM sent.
Thanks Neven, PM replied! Thumbs Up
Chatika vas Paus
Triple in Jax E3? How did you do that?
MascaratumB
Yup! Smile
I would say with lots of time and effort, but I did it this way :
http://budgetlightforum.com/comment/1471476#comment-1471476 Wink
Unheard
Last seen: 18 sec ago
What happened to the website? I cannot access led4power.com anymore since some time (weeks, I’d say). The problem might be on my side, but don’t know how to fix it.
Chatika vas Paus
Post #1315:
led4power wrote:
Store is closed for now (probably by 1st July), similar thing happened like last year – income limit. I have one big customer and plan was to open LLC in February mainly because of that customer, but due to virus pandemic it was not possible (till now) to open LLC, so I had no choice but to process all orders over workshop/self-employed. This basically means store will be closed until I open LLC, good % of products (which was on clearance sale) will not be available anymore. The main reason for that I can’t sell stuff/products which are not bought over LLC account, I must check if it’s possible to “transfer” some of that stuff to LLC before registration.
Unheard
Mentioned even on this page! Overlooked it Facepalm
Thanks!
