[Alibaba Adventure] GT-FC40: XHP35 HI's Bigger Sister, with 90+ CRI
51 posts / 0 new
rngwn
rngwn's picture
Last seen: 2 days 22 hours ago
After my unsuccessful attempt in finding a high CRI 5mm LEDs for Djozz's C01, I continued my search. Now, I've found what appears to be a bigger version of XHP35 HI.
Here's the FC40. The Die size is equal to the XHP70, but the LES is 5*5mm. The LED is rated at 40W, and produces 3000-3200lm at 90+ CRI and CCT range of 5000k-5500k. (Note. I told them to make a 95 CRI sample for me, this one may actually be 95 CRI, assuming that the company messed up the label. I'm currently reaching out to the company about the label. Meanwhile, I will just assume the worse for now.)
Here's the light comparison between the FC40 and the XHP70.2 @5500k CCT at low-ish output due to lack of heatsink. Subjectively, the FC40 appears less green but more bluish (which is to be expected due to higher average CCT)
The company also provided binning chart and claims that they can assure that the LEDs made for me will always have A5 tint for 5000-5500k CCT.
I now ordered a pair of H2-Cs along with a pair of Sofirn C8s hosts. I will put these CREE's and GT's LEDs into one each and properly compare the light. Now I'm waiting for the host to arrive.
 Side-by-side beamshot
Link to sign up & participate in GB "http://budgetlightforum.com/node/68713":http://budgetlightforum.com/node/68713
Edited by: rngwn on 09/04/2019 - 09:30
rngwn
rngwn's picture
I am currently having 10 of these. I will keep at least 2 for myself. Another 2 will be sent to Djozz for testing.
Caleb
Caleb's picture
Last seen: 4 hours 38 min ago
Very interesting…
hodor
hodor's picture
Last seen: 34 min 11 sec ago
Ooo interesting indeed! Can they make them slightly warmer? C4/A4 could be very promising.
rngwn
rngwn's picture
I think they can make A4 bins. But the next time I will have to buy at least 70pcs/CCT. I plan to sell these anyway so I can ask them if they can. The C3/C4 bins is unlikely though, I asked them once and they said they are not making those.
The price isn't exactly cheap either, the ex-work price is comparable, if not slightly more than XHP70.2's, and so is the retail price should I sell one. That obviously means I can afford to buy one CCT's at a time. I should open a vote to see which CCT's you want first and second. Although there was a poll by Clemence and that 5000k's are the most popular color followed by 4000k's.
Nevertheless I will make sure that they can make 95+ CRI so it differentiates well enough from the XHP70's and justifies the higher price. They don't charge much more for better CRI though (though it costs lm/w to do it).
SKV89
Last seen: 5 hours 42 min ago
Very interesting, looks like it has 16 dies in there. Is it a 12V emitter? A good high output hi cri emitter is currently non existent so hopefully this will fill the gap.
rngwn
rngwn's picture
Yes, it is a 12v emitter. The XHP70 besides it is also a 12v version with 90+ CRI
and yes, I’m a CRI nut
1stein
1stein's picture
Last seen: 1 hour 24 min ago
Undomed large LED. Very interesting. Very.
HONDARIDER
HONDARIDER's picture
Last seen: 5 months 2 days ago
Are these for sale currently?
Agro
Agro's picture
Last seen: 2 min 38 sec ago
Interesting. Smile
The maker is Getian, right?
Tally-ho
Tally-ho's picture
Last seen: 1 month 1 week ago
I would be interested in a few FC40 A4 (prefered) or C4. I’m a little bit concerned about its longivity considering the weird finish.
I also would like to mod an Astrolux MF04S with an XHP70 (.B) 3000-3500K CRI90 (min), have you seen something like this on alibaba ?
mattlward
mattlward's picture
Last seen: 14 hours 45 min ago
The A4 bin might be a good one.
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
rngwn
rngwn's picture
Agro wrote:
Interesting. Smile The maker is Getian, right?
Yes
rngwn
rngwn's picture
I can tell that the finish is Silicone. The gold substrate is blue LED and then they put the phosphor-laden silicone on top.
Well, I can sell the remaining 6 4 of these for $12/ea (excl. shippimg). Just mind that these are meant for ‘beta testing’ and I have seen no hard numbers yet.
edit: Loucas took 2 of these. There are 4 left to be either sold or given away for public review.
rngwn
rngwn's picture
It’s on Aliexpress. The very CREE that I used in comparison was the 90+ CRI 5000k version bought from HotRed Store. The very same store also sells 6500k and 3000k variants. You get to choose voltage, too.
uhh, nevermind, the 90CRI version only available there in 5000k.
You might try your luck here, but it’s 1000pcs minimum order.
https://www.alibaba.com/product-detail/X-Lamp-XHP70-2-Extreme-High_60828634180.html?spm=a2700.galleryofferlist.normalList.93.1d572b9f12NxYb
rngwn
rngwn's picture
Update:
The manufacturer says the CRI is indeed 95, and they won’t make the label for 95 CRI.
They have yet to confirm if they can produce the A4 Bin. So, don’t hold your breath for that.
Nevermind, they said they can do A4 or even C2, if there are enough people interested in.
DavidEF
DavidEF's picture
Last seen: 1 week 3 days ago
Why do you call it a bigger version of XHP35 HI? Why not just say it’s like a XHP-70 HI? Anyway, I’m eager to see what the “collimated” beam from these look like compared to the XHP-70 when you finish the Sofirn C8 builds. Will you also de-dome the XHP-70 to compare with both LEDs being domeless? Innocent
- The YKK Philosophy
SKV89
This sounds exciting. If everything test out well, perhaps we can get MTN or Kaidomain interested to buy in the quantities they need and we can just buy from them.
rngwn
rngwn's picture
The reason I was reluctant to call that a XHP70 HI is that the given spec wasn’t as efficient as the XHP70.2. By estimate it should be about 20lm/w behind at the same CRI.
By the way, just want to let you know that I also plan to later buy these in bulk to make part of the living, and also gain funding to hunt for another product.
DavidEF
DavidEF's picture
No problem with the reduced efficiency. We expect that with all high CRI variants. If you check CREE specs, you can often find that their high CRI versions of emitters are at least one or two brightness bins lower than their low CRI version of the same emitter. In other words, the high CRI version just isn’t available in the highest brightness bins. Same with low CCT (warm) versions. They can’t make them as bright as higher CCT (colder) versions, so the highest brightness bins just aren’t available in the low CCT versions of their emitters.
rngwn
rngwn's picture
I see I underestimated the lm/w lost going from 90 to 95 CRI, so let’s see the calculation:
Based on GeTian’s previous product I sampled:
Going from 70 to 90 CRI – you lose 20lm/w
Going from 90 to 95 CRI – you lose another 20lm/w
And based on CREE’s datasheet:
Going from 70 to 90 CRI will cost you 21-25lm/w
Assuming that you lose the same 20lm/w for CREE’s to go from 90 to 95 CRI:
You would look at 70-90 lm/w for the theoretical 95+ CRI version of CREE’s XHP70.2 (or 2200-2900 lm at maximum rated power)
hodor
hodor's picture
What would be good drivers/flashlights for these LEDs? I only have 3v drivers/flashlights atm so don’t know much about others.
Looking forward to the tests!
rngwn wrote:
Update: Nevermind, they said they can do A4 or even C2, if there are enough people interested in.
I would be very interested in C4 but have a feeling A4 will be more popular.
rngwn
rngwn's picture
The readily available driver are the ones that used to drive the XHP35’s, but it’s only driving the LED at 1A so you would be seriously underdrive these LED (though not necessarily a bad thing).
On the other hand, these are 40w LEDs so running these on full tilt in flashlights with poor thermal dissipation could very well be a recipe for disaster.
rngwn
rngwn's picture
I created a thread for GB/WTS here:
SKV89
Shouldn’t you wait for Djozz test results before posting the groupbuy? Most people are not going to buy without seeing what they are getting.
rngwn
rngwn's picture
I should be able to at least do a proper beamshot and side-by-side comparison against CREE’s on a flashlight this week, provided I won’t destroy the driver.
I could always let Djozz chime in later. Djozz’s result should turn up next two weeks.
Also, the manufacturer seems quite confident about CRI values of this thing. They did said something along the line of “see it for yourself”.
SKV89
I have no doubt it will reach 95CRI however I’m more interested in the tint at different currents and output at different currents.
rngwn
rngwn's picture
I guess this week’s beam shot should serve as some kind of appetizer on the tint and output on one specific current. Wink
rngwn
rngwn's picture
I have both of them in a C8s host today.
I got beamshots too. Unfortunately, I only have one high drain 18650, and my setup trips the overcurrent protection of other batteries. I can only give you the individual beamshot for the moment.
All the shots are taken at 5500k WB. I took this with a smartphone camera which annoyingly messes with the exposure setting.
XHP70’s Beam shot
FC40’s Beam shot — Again, This looks much less green than XHP70’s 90CRI, but a bit cooler.
Additionally, the H2-C I ordered are not the same. One of them operates in 1-mode, the other operates in 5-mode. Annoying, but it’s only the best shot I have at this. I probably don’t want to go through the trouble of sanding down the driver and coat it with nail polish again.
Anyway, let’s light up an entire room.
SKV89
The tint looks great compared with the greenish XHP70.2. Let’s see how output and efficiency test out.
hasddie293
hasddie293's picture
Last seen: 11 months 3 days ago
I’ll wait for the test result but sound promising…see the beamshot…I don’t know if this is “going to be next new”…wow, Love
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
