Lumintop BLF GT --> BLF GT90 conversion !
36 posts / 0 new
Funtastic
Funtastic's picture
Last seen: 1 day 5 hours ago
I just received my SBT90.2 kit and the mcpcb screw holes are too big for the original screws, what should I do?
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
Unloco
Unloco's picture
Last seen: 5 hours 35 min ago
https://budgetlightforum.com/comment/1700076#comment-1700076
Take care that the heads of the screws do not protrude from the surface of the centering gasket otherwise it will dent the reflector (it happened to a friend).
Texas_Ace
Texas_Ace's picture
Last seen: 5 days 15 hours ago
The 2 simplest options would be to either use a washer with the stock screws or get some screws with a larger head.
If you are in a real pinch sticking several layers of paper on the screw, trim to size and then screwing it in should work, Also should help center the screw as the paper gives.
Depending on how oversized the hole is this can work well or not at all, I have done this in the past on holes just slightly too large.
dthrckt
dthrckt's picture
Last seen: 2 weeks 15 hours ago
I’m only seeing the gt70 conversion on nealsgadgets and lumintoponline. Is the gt90 conversion still available?
Texas_Ace
Texas_Ace's picture
Would not surprise me if it was not sold anymore.
