Tint, Binning, and CRI Explained (For XM-L LEDs)
103 posts / 0 new
scaru
scaru's picture
Last seen: 1 year 8 months ago
I figured I'd make a guide related to XM-Ls and tint, binning, CRI, and all the other details I can think of. Smile
Tint
There are 3 basic tints.
Cool White is a very pure white and is what most lights are. This generally has a low CRI (color rendition index) and will not show colors that well. Some people say that it is to blue. It is generally around 6000k.
Neutral White is considered to be one of the better tints as it still seems fairly white, but does have a higher CRI. It tends however to be slightly tan colored rather than a pure white. It is generally around 5000k
Warm White is on the extreme end, it is very yellow like the color of a incandescent bulb. It has the highest CRI so it is great for outside but inside it can get annoying when white wall hunting. It is generally around 3000k.
The tint is defined by a number followed by a letter, an example of this would be 3C. If the number is a 0, 1, or 2 then it is most likely cool white. If the number is a 3, or 4 then it is most likely a neutral white. If the number is from 5 to 8 then it is most likely a warm white. The reason I say most likely is because I am not specifying the letter.
Note: Going off the the Cree datasheets 5 is NW, but I find it to be much wamer than neutral.
To determine what the tint is like one can refer to this image.
To get an idea of what different kelvin ratings are like one can refer to this chart which shows them more clearly than the above one.
Brightness Bins
For XM-Ls the brightness bins range from S4 (which is the least efficient) to U3 which is the most efficient. The order is S4, S5, S6, T2, T3, T4, T5, T6, U2, then U3. Most lights are a T6 bin unless otherwise specified.
In between bins there is an approximate 12% difference in brightness but depending on the efficiency of the LEDs it can be as little as 0% and as much as 26%. These are both extreme examples based on the fact that a bin can vary as much as 7% and there is a 12% average difference between different bins.
Part of the reason that there is a variation in efficiency is due to the amount of phosphor on top of the LED die. The purpose of the phosphor is to convert the blue light produced by the LED to a more white or yellow light. Naturally as the amount of phosphor increases less light passes through it. This is why a warm white LED is going to be a lower bin than a cool white.
Below someone asked the question of why a blue LED does not produce as much light as a white LED even though theoretically there should be more light. After some research on the topic I found out that this is because the eye is very sensitive to white or yellow light, but very insensitive to blue light.
So sadly, we will most likely never be able to get a 1000 lumen 10 watt blue LED.
Recently, (December 2012) cree released the XM-L2, which is approximately 20% more efficient than the original XM-L. This means that a XM-L2 T6 is approximately as efficient as a XM-L U3. Unless it is specified, the light does not contain a XM-L2.
Interpreting The Specs of a LED
So now we know the basics of how a LED is rated now. So let's say you see XM-L T3 7B for sale. Now you know that will be less efficient, warm white, and an XM-L.
CRI
CRI stands for Color Rendering Index. The CRI of sunlight is 100, the CRI of our average CW LED is closer to 65. NW is approximately 75 and some WWs get to 80. Naturally you want as high of a CRI rating as possible so it is easier to distinguish between different colors.
A high CRI does not always mean it has a low kelvin rating, but it generally does. Nichia makes great Hi-CRI (high CRI) LEDs. Currently the most powerful one they make is the Nichia 219. It is slightly less powerful then a XP-G, is NW (5000k), and has a CRI rating of 92.
Links to XM-Ls-Based on Tint
Locating a XM-L with the tint you want can often be hard so I am going to paste links to a few different ones here.
XM-L 0D: 1
XM-L U2 1A: 1, 2, 3, 4
XM-L U2 1B: 1, 2, 3,
XM-L U2 1C: 1, 2
XM-L U2 2B: 1,
XM-L2 T6 3C: 1
XM-L 3C: 1, 2, 3
XM-L 3B: 1, 2,
XM-L 5B: 1,
XM-L 5C: 1, 2,
XM-L 7C: 1
Edited by: scaru on 01/26/2013 - 00:48
ryansoh3
ryansoh3's picture
Last seen: 3 weeks 19 hours ago
I like the way this is going, thanks Scaru.
I haven’t seen many NW U2/U3 XM-L’s before… could you point out where I could get a XM-L U2 3C?
Merry Christmas. :santa:
BLF ≠ B-grade Flashlight Forum
scaru
scaru's picture
ryansoh3 wrote:
I like the way this is going, thanks Scaru. I haven't seen many NW U2/U3 XM-L's before... could you point out where I could get a XM-L U2 3C? Merry Christmas. :santa:
So far there aren't any, (I'll change that example) but a XM-L2 T6 3C would be equivalent to a XM-L U3 3C.
eebowler
eebowler's picture
Last seen: 5 days 12 hours ago
Subscribed! Thank you for the chart scaru!
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
Tecmo
Tecmo's picture
Last seen: 11 months 2 weeks ago
If they left off the phosphor completely, how high would the bin be, and what shade of blue?
ryansoh3
ryansoh3's picture
It would be just like their blue XM-L series, at approximately 450-465nm.
The colored versions of XM-L’s are here: http://www.cree.com/led-components-and-modules/products/xlamp/arrays-dir...
I don’t think they have color bins though.
scaru
scaru's picture
I truthfully do not know, I can tell you when I have taken the phosphor off the LED in the past (while dedoming) it becomes a deep blue.
Based on that chart, I would say it was around 8000k. (general estimate)
Edit:
As ryan pointed out, their blue XM-L is 450-465 nm so it would be a royal blue.
However, for what ever reason it seems that the blue LED in their colored XM-L is much less efficient than a white one. So now I am doubting myself. Sad The white die produces 100 lumens at 350 mah and the blue one produces 13.9 lumens at 350 mah.
Off to go do some more research, now I am wondering whether the phosphor is needed to convert it to light in the visible spectrum.
mattthemuppet
Last seen: 5 days 9 hours ago
nice run through scaru. Only niggle is that CW Cree LEDs are generally 65CRI, although the newer XM-L2 CW seem to be 70CRI. NW and warmer are 75CRI, one reason so many people like them over CW Smile
gords1001
gords1001's picture
Last seen: 2 months 4 days ago
Added to the mod reference guide, this is brilliant, thanks scaru. 8)
scaru
scaru's picture
mattthemuppet wrote:
nice run through scaru. Only niggle is that CW Cree LEDs are generally 65CRI, although the newer XM-L2 CW seem to be 70CRI. NW and warmer are 75CRI, one reason so many people like them over CW :)
Just changed it! Thanks. Smile
ChiggerPepi
ChiggerPepi's picture
Last seen: 18 hours 41 sec ago
This is what you’re looking for:
XM-L2 T6 5000k NW
scaru
scaru's picture
Added a list of links to buy different XM-Ls based on tint.
ryansoh3
ryansoh3's picture
Thanks for the link.
Mouser’s shipping is $20 for an $8 LED, so I think I’ll wait for FastTech to stock them. Smile
MRsDNF
MRsDNF's picture
Last seen: 1 hour 52 min ago
Thanks scaru for the effort. I understand simple.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
Slim Pickens
Slim Pickens's picture
Last seen: 3 months 4 days ago
Thanks scaru! I vote that this should be stickied…
apt323
apt323's picture
Last seen: 2 days 3 hours ago
Thank you scaru! Very well written. Nice reference and links!
Thank you
AlexGT
AlexGT's picture
Last seen: 11 min 59 sec ago
Thanks a lot for doing this Scaru, I like the way you put links to vendors of each of the tints available, I think this thread should be stickied
Boro
Last seen: 2 hours 10 min ago
Thank you!
Tecmo
Tecmo's picture
Edit:
That’s what I don’t understand. If it is more blue and brighter the less phosphor, why are blue xml dimmer? I don’t think there is any way to “redome” an led after stripping the phosphor is there?
scaru
scaru's picture
Edit:
That's what I don't understand. If it is more blue and brighter the less phosphor, why are blue xml dimmer? I don't think there is any way to "redome" an led after stripping the phosphor is there?
I doubt one could do it without losing even more light.
scaru
scaru's picture
Just found an explanation on wikipedia.
"For example, the efficiency of a typical...yellow phosphor based white LED ranges from 3 to 5 times the efficiency of the original blue LED because of the greater luminous efficacy of yellow compared to blue light."
Basically, human eyes are much more sensitive to white (or yellow) light which is the cause of all this.
The blue light produced is at 450 nm while the white light (after going through the phosphor)  is around 575-600. So if you look at the graph, the human eye is very sensitive to white light, but not the blue light.
So now I understand it. Big Smile
gords1001
gords1001's picture
I do too, but its already in the one stop mod reference shop, so easy to find. Wink
Rusty Joe
Rusty Joe's picture
Last seen: 1 week 1 day ago
Excellent resource. Now if you could do one on the meaning of “XM-L” vs “XP-G” etc. It would be neat to know more behind the naming and designation of each.
Eat Once a Day - Lose Weight - Feel Great!
www.omad.info
scaru
scaru's picture
Rusty Joe wrote:
Excellent resource. Now if you could do one on the meaning of "XM-L" vs "XP-G" etc. It would be neat to know more behind the naming and designation of each.
What do you mean? The number of bond wires, size, efficiency, etc? Maybe if I get a chance I'll do that but this one was prompted by a few people PMing me in the past about tint, along with Nitro's question about where to get a neutral LED.
What surprises me is I was able to do 90% of this with out having to look anything up, I guess that's what happens when I spend so much time here.
gords1001
gords1001's picture
scaru wrote:
What do you mean? The number of bond wires, size, efficiency, etc? Maybe if I get a chance I’ll do that but this one was prompted by a few people PMing me in the past about tint, along with Nitro’s question about where to get a neutral LED.
What surprises me is I was able to do 90% of this with out having to look anything up, I guess that’s what happens when I spend so much time here.
I’m beginning to worry about how much I soak up on something I take an interest in, six months ago, I didn’t know what an xm-l was….know I’m growing bored of them…not bored as in not using them, just want to play with other things, I’m going backwards though, starting playing with xp-g’s etc. Bothering about modes and tint more than total output.
Sometimes a q5 in a suitable host with a good 1.4a driver is more usefull than an over driven xm-l lumen monster.
I’m a heretic, stone me :*
scaru
scaru's picture
Ok, a comparison LED post is in the works.
Ouchyfoot
Ouchyfoot's picture
Last seen: 2 days 16 hours ago
I think I’m in the same boat as you. I have drawers full of lumens and sheer output isn’t a real big deal to me any more. I’m now more drawn to different tints and their visual relation with different beam profiles. If I see a flashlight with a choice of an XP-G 4C – 450Lm or an XM-L U2 – 800Lm, I will probably go with the XP-G 4C.
Ouchyfoot
Ouchyfoot's picture
…And thanks so much Scaru. I hope you don’t mind that I copied and pasted your post right into my Evernote flashlight file.
scaru
scaru's picture
Ouchyfoot, I don't mind in the least and am happy to be able to contribute back to the forum in this way. Smile
Ouchyfoot
Ouchyfoot's picture
I noticed you don’t have any links for 4C tints, which is my favorite right now, although I have yet to try a 5C.
gords1001
gords1001's picture
The bad thing is, I should get a p60 host, build many pills, then its half scientific. That’s not going to happen though, I just don’t like p60’s so common sense is out the window…
