blue and green XP-E2, output tests
57 posts / 0 new
djozz
djozz's picture
Last seen: 5 hours 6 min ago
These tests were done already a month ago (sorry for the delay), but tonight I was finally in the right mood to type in the data, make the graph and do this write-up (I like the testing itself but it always takes some courage for me to digest the numbers and make them into edible graphs Tired ). Thanks go to MRsDNF for donating me the red and blue XP-E2 (from Cutter, red is bin P3, blue is bin M3), and to telephoneman for the green XP-E2 (from Mouser, bin is R2), they were not easily available to me (in the meantime the red XP-E2 is at intl-outdoor).
As usual, the measurements were done with the leds mounted on copper boards clamped to a big aluminum block, the led wires were directly connected to a power supply for testing. The leds were facing up, with a small OP-reflector on top. Light bounced back from the ceiling was measured with a lux-meter. (These might have been the last leds I have tested this way, for the next one I will try my new integrating sphere Smile )
Note that the output is an out-of-the-reflector measurement, so less light is measured compared to bare led measurements (15%? depending on the reflector, in any case: for all my 3535-size led measurements in the past I have used one and the same reflector).
Note also that I did the usual calculation to convert ceiling bounce lux-numbers into lumens, but for colour leds these lumen numbers are not something to rely on because the cheap lux-meters we use are probably increasingly inaccurate when going farther away from the center of the visible spectrum. so especially the red and blue lumen numbers are doubtful. This means that although the shapes and trends (like at which current the output tops out) in the graphs are as accurate as for white leds, the absolute lumens I trust much less.
On top of all this uncertainty, I find the output of the green led unexpectedly on the low side. In fact, I tested the green die of the XML-colour better than the green XP-E2, even though the XML-colour has an 'older' type striped green die (the xpe2 blue and green dies are dotted, like the white xpe2 leds). I guess this is real, but there's always a small chance that the reflow did not go well (not enough solder under the thermal path), or perhaps the led was a bad one, who knows, I'm not going to redo the test, this will have to do.
Here's the graph, I hope it is useful to some of you Smile . For comparison, I included the red XP-E2 results that I already posted about earlier:
Edited by: djozz on 06/28/2014 - 20:14
CRX
CRX's picture
Last seen: 14 min 58 sec ago
Thanks for this
MRsDNF
MRsDNF's picture
Last seen: 18 hours 56 min ago
Thanks djozz. Do you have any idea where you would use the blue led. I have a red one in a C12 and it sorta weirds me out when walking with it.
penumbra
penumbra's picture
the blue ? on your dashboard on strobe on the highway by night ? 0:)
djozz
djozz's picture
Not sure where the blue led comes in handy, I have no use for any of these colour leds exept that I find them huge fun. Teleponeman told me that he likes green leds for hunting, while others use red leds. But blue I don't know.
(I used the red light from my xml-colour flashlight succesfully a few months ago as a safelight in the darkroom I made for a photo-project at the school I'm working in, it worked very well: good visibilty while the photographic paper was hardly sensitive to it.)
Cereal_killer
Cereal_killer's picture
Blue is good for blood tracking, wether in your hunting gear or first aid /trauma kit for finding the source of wounds.
Also, blue (especially royal blue) makes many things fluoresce without the hazards of UV.
nofearek9
nofearek9's picture
Last seen: 3 weeks 2 hours ago
thanks for the results ,I hope intl-outdoor will get the rest colors soon
RaceR86
RaceR86's picture
Last seen: 4 years 4 months ago
Yesterday I took my Red XP-E2 in use. I had to delay putting it in use due to the contest build. But now im back to normal modding. I have no idea what to use the red emitter for. Buts its a good amount of red at 2,5A. Wink
Thank you so much for doing these tests. Makes it so much easier for everybody to know how hard we want to push the various emitters and what to expect in terms of output. Not that I plan to order these from Cutter, but its interesting to see. Smile
oh.. thanks to MRsDNF`s wife too. Big Smile We love her.  Love
Beer
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
islisis
Last seen: 4 years 3 months ago
thanks again for these tests djozz. and yes it would be great if intl-outdoor could sell these colours on noctigons!
MRsDNF
MRsDNF's picture
This is the second thread that has mentioned MRSDNF. I'm not sure what is going on here. She is a terrific women to her kids and she loves them more than anything else in this universe. Anyway I'll pass your message on.Wink
Fritz t. Cat
Fritz t. Cat's picture
I find those results vary strange, because there is so much difference between the XP-Es and the XP-E2s, and the XP-E graphs are far from other output graphs I have seen. Is it really possible to generate so much light at 0.1 A, or does that violate the conservation of energy?
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
Cereal_killer
Question about the red XP-E2:
Why does the red E2 die have lines like a 1st generation die but both the blue and green E2’s have 2nd gen die’s (with dots)?
Manual Man
Last seen: 2 years 7 months ago
Edit: half asleep, NVM.
On another note I find it interesting that the red LED did so much better then the green LED, it has always been my understanding green was the more efficient one, part of the reason being that the human eye is better at picking up green light vs red.
Hikelite
Last seen: 3 weeks 6 days ago
Have you experience those uses of the Blue? I have read a lot on this matter and that seems to be the answere all over. However on CPF some people said they used Blue in the above mentioned situations and was not useful at all.
Hikelite
According to the datasheets:
Blue M3 - 45.7lumens @ 350mA
Red P3 - 73.9lumens @ 350mA
Green R2 - 114lumens @ 350mA
What is very interesting how the tests shows Blue being the brightest then Red and then Green, quite the opposite to the specs I wrote above from the CREE datasheets. However that order it best observed at 2A rather than 350mA, 2A not being a current which CREE would recommend.  At 1A it would be another order Blue the brightest, Red and Green Equal.
Maybe the response of the lightmeter is different for these pure color LEDs.
Cereal_killer
Just want to share these pic’s here in this thread to
Red and green XP-E2’s dedomed threw an aspheric (blue is XT-E) unknown current (ramping UI)
Red 1.8A
Full power (1.8A each)
Cereal_killer
Yes sir, of course they would say that lol. It’s not like magic or like a fluorescent material that’s going to glow, I’ve explained it before… Its hard to describe, it’s like a bright dark hole if that makes and sense. Since the colors we see are light reflected back and there’s no red light to reflect back off blood when using a blue LED you don’t see red but the blue light makes the blood shine nice and bright so its like a bright shiny dark spot.
Ive used it hunting quite a bit and also used one last summer when two of my dogs got in a really really bad fight and I needed to clean all the blood out of the yard, I can tell you from personal experience, this isn’t just something that should work based on theory, it really does work and quite well.
Tom E
Tom E's picture
Last seen: 45 min ago
I know this is an old thread, but valuable none-the-less! Thanx djozz! Couple of Q's:
  • I know you have a much better light meter than most of us, not sure what meter you used to do these tests?
  • with my cheap meter, I definitely measured green brighter than red with both XML color LED's and XP-E2's. Any chance you can re-visit the green test?
Fyi... First I ordered color XP-E2's from DigiKey, the realized later these are bin rated, and Mouser has better ones Frown. So, I ordered various top bin color XP-E2's from Mouser and just got them in. The bin specs were quite good:
Red - P3 (same as DigiKey, same as yours)
Blue - M3 (Mouser - same as your)
Green - R3 (Mouser - 1 up from yours)
Royal Blue - 37 (Mouser - whatever this bin means)
Red-Orange - Q4 (Mouser)
Amber - Q4 (Mouser)
I mounted a green R3 and red-orange Q4 on 16 mm Noctigons and built up pills for a UF-1504 to run at 2.48A (6*350mA 7135 + 1 380mA 7135). My intention is max throw. Measuring with my $35 light meter, I got the following for lumens in full flood, throw in full zoom-in:
Green R3 in UF-1405, 2.48A:            211 lumens (@30 secs), 160 kcd (800 meters)
Red-Orange Q4 in UF-1405, 2.48A:   119 lumens (@30 secs), 85 kcd (583 meters)
 The lumens are pretty low - could be the poor aspheric flood mode of the light/lens, not sure...
 In use outdoors, the green in full zoom is like a laser beam, while the red-orange's beam can hardly be made out. Lighting up a tree about 80 meters away though, the red-orange looks pretty darn bright compared to the green, maybe about the same (double the kcd though isn't much difference). Also note the red-orange looks pretty much exactly like red I've seen on other LED's/flashlights - I could not tell the difference. The red-orange's dye looks exactly like a red dye in both color and having the lines on it (like a XP-E/XM-L, etc.).
 The cheap spare pills available for the 1405's is great by the way for testing/comparing. I bought 2 UF-1405 hosts and 2 spare aluminum pills from GearBest. The pills were $1.50 when I ordered - now see them listed at $2.50 (should have ordered more). The aluminum pills fit great and actually have more threads than the brass stock ones.
n10sivern
n10sivern's picture
Last seen: 2 hours 56 min ago
In the 1504, running a red XP-E2 P3 at 2.4A, I was able to see with my naked eye objects at 400 yards. I tested the green too but I hate using green to hunt so I don’t even recall how well it did. Green seems to be affected so much more by fog and moisture and dust.
Three tomatoes are walking down the street- a poppa tomato, a momma tomato, and a little baby tomato. Baby tomato starts lagging behind. Poppa tomato gets angry, goes over to the baby tomato, and smooches him… and says, Catch up.
Tom E
Tom E's picture
n10sivern wrote:
In the 1504, running a red XP-E2 P3 at 2.4A, I was able to see with my naked eye objects at 400 yards. I tested the green too but I hate using green to hunt so I don't even recall how well it did. Green seems to be affected so much more by fog and moisture and dust.
Updated my posted with throw distances. Ok - cool! Glad to hear you have a red in a 1504. Practical use/results right now seems to be the best - not sure how red's are handled in my light meter. I thought the red looked better outdoors than on my meter.
I'm using the green just for kicks - freaks people out when you shine it in the sky where there's always 1-2 planes in our area. It's hard to convince them it's not a laser.
Have you de-domed a red or any color XP-E2? Wondering if they come out same way as the whites - better throw, less lumens. Can't recall seeing it posted.
n10sivern
n10sivern's picture
I posted it in a thread where I tested a bunch of LED’s. I did get more kcd but not as significant as white LED’s.
Tom E
Tom E's picture
Ahh - ok, sounds familiar now so I probably forgot it. If you can locate it, or if you got any #'s saved, would appreciate it. Interested bout tint shift, if any, too.
n10sivern
n10sivern's picture
It’s buried in here somewhere. I don’t recall any tint shift. I do recall that dedoming the red was a real PITA and required a fair amount of heat. The dome just didn’t want to let go.
Tom E
Tom E's picture
Ohhh yes, stupid me. Forgot you did al those 1504 tests! Interesting read in the thread, btw...
djozz
djozz's picture
@Tom: it must be fun to have a 1504 pill for every colour.Smile
I used my chinese Tondaj luxmeter still, in these colour XP-E2 tests. I see I did make a reservation for a wavelength error in the OP at the time, but it is even worse than I thought then: compared to my high quality luxmeter, the Tondaj reads 4 times (!!) too high in blue, 20% high in red, green is about right (as is neutral white btw, see my 'luxmeters, thoughts and findings' thread).
Ronin42
Ronin42's picture
So the revised graph looks like…
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
djozz
djozz's picture
Ronin42 wrote:
So the revised graph looks like...
Morally, you are right, but I would have dive into the excel- sheet again for that, it takes time, effort, and it is boring Innocent.  This is a hobby, with in my case limited time, and I like it to be as much fun as I get away with.
Apart from that, the most interesting aspects of the graphs for me are the current/output behaviour and the output relative to other leds of the same wavelength , The absolute lumenvalues are of less interest, I think.
Sirius9
Sirius9's picture
Last seen: 2 weeks 3 days ago
Maybe this will be interesting to someone.
I was preparing some red XP-E2 leds, dedoming them and I managed to rip of one bond wire from emitter, I tested it later and it still worked with one wire only but it was pulling only 1,9A out of ~2,4A that driver can deliver. Tested same driver on undamaged emitter and I got 2,4A as expected and anticipated. So, not all is lost if you screw up one bond wire on a emitter Smile
pflexpro
It’s not really surprising that the green emitter falls off so much at higher drive currents. The thermal resistance for green is 15°C/W. Other colored emitters have a thermal resistance of 5-9°C. The unusual results is the plot for the red emitter…even though, red will typically have lower initial efficiency, with a thermal resistance of only 5°C/W, it should have pushed very well.
So much of the issue with determining the output of colored emitters (and varying tints of white emitters) is the spectral sensitivity of the light meter. Since green is near the center of the photopic luminous efficiency curve, it can be measured without much adjustment. Red and blue have to be factored heavily to determine come close to actual luminous flux using a CIE filtered meter.
djozz
djozz's picture
Apart from the thermal resistance, there is a inherent effect of led type: red led output suffers way more from heating up than green and blue
Btw, in later tests I used a better luxmeter, one that does have a much better colour filter. It does not overrate blue and red so much.
Buwuve
Buwuve's picture
Last seen: 3 years 1 month ago
I think here are some users, who can help me Smile
A friend asked me a longer time ago to build him a green LED flashlight for hunting.
I combined a green Cree XP-E LED, alu base, dedomed it, use 3x 7135 AMC driver and a Convoy C8. Now he asked if I could modd it a little bit more. After this, I soldered another 7135 AMC on the driver and use a 4x 7135 driver with a UF T20. Both worked well.
He uses it for 20-25 minutes nonstop. Has anyone tested the older green XP-E with 1,75A or 2,1A for round about 25 minutes in one of these flashlights?
Light up the darkness.
