Noctigon KR4, 5A constant current+DD is for sale.
806 posts / 0 new
boomermax
Last seen: 4 months 4 days ago
I’m confused by the pictures. They show with and without stainless bezel?
Rusty4x4
Last seen: 2 weeks 3 days ago
The stainless bezel is an option
ToyKeeper
ToyKeeper's picture
Last seen: 1 min 54 sec ago
Just answering a few questions really quick…
… but I’ll post a lot more details soon in a review.
charwinger21 wrote:
Hank Wang wrote:
alex64 wrote:
Has the latest version of Anduril from TK with the improved stepdown?
It’s with the latest anduril ui from TK.
TK updates it so quickly that it’s hard to tell what the latest is Silly
Personally, I’m looking for at least version 420 from 2019-05-22 …
If I understand correctly, it ships with a revision from 2019-06-17. Like, two days ago. I spent the weekend fine-tuning the thermal regulation. The D4 is difficult to regulate since it has so much power in such a small space!
Ryzbor wrote:
Wil the Ramping IOS V2 be there as a optional choice? Not everyone likes Anduril.
No, RampingIOS V2 has not been ported to the new driver.
It should be relatively easy to port RampingIOS V3, but it hasn’t been done yet either.
Regardless, most basics in Anduril are the same. It even has compile-time options now to change the on/off timing, since that was something a lot of people have strong feelings about.
nick779 wrote:
do these lights actually have muggle mode or no?
Yes. It was removed for a while, but people wanted it back… and with a light as hot as the D4, I can understand why. So it has muggle mode now.
  • 6 clicks: enter/exit muggle mode
  • 7 clicks: change aux LED brightness
  • 7 clicks (but hold last click): change aux LED color
Man Without Shadow wrote:
Will there be an Aux LED rainbow option? multi colored?
Yes. One of the colors is “rainbow”. Another color is “voltage”, to indicate the battery status.
Klayking
Klayking's picture
Wow, sounds fantastic. Thanks for the info TK!
Rusty4×4 wrote:
Will the 18350 tube from a D4v1 fit on the D4v2?
My 219C D4v1’s 18350 tube won’t even fit on my XP-L HI D4v1…
pennzy
pennzy's picture
Last seen: 51 sec ago
Klayking wrote:
That is a good question, though from my experience I have found Anduril to operate just like Ramping IOS V2 if you only use the relevant button presses.
I have found the simple shortcut to directly ramp down instead of having to guess the ramp direction to be an incredibly useful addition in Anduril however.
What is the short cut to directly ramp down?
amishbill
amishbill's picture
Last seen: 3 weeks 5 days ago
You mean like a slow color shift around the color wheel rainbow? A continuous color rotation like that would be both weird and cool.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
Klayking
Klayking's picture
Click, click and hold it. Do a double click but don’t let go of the button at the end until you want to stop ramping down. It’s the same as ramping up, except with a quick click before you hold the button.
HONDARIDER
HONDARIDER's picture
Last seen: 1 week 12 hours ago
Ouch, I put together an order and it came to $57 and it was with the SST-20 version, 18350 and 18500 tubes as well as the SS bezel. May be a couple of weeks before I can order one of these. I really don’t use these types of lights much but they make for a great collectable.
wolfstyle
Last seen: 3 days 15 hours ago
Order placed. Will be replacing my D4V1 as my EDC.
contactcr
Last seen: 7 hours 33 min ago
Anyone know if this new anodizing is smooth or the rough texture?
Man Without Shadow
Man Without Shadow's picture
Last seen: 5 hours 17 min ago
Well…just several colors…Lexel had some boards with like green/pink/ and blue…or whatever
Pictures of the rainbow LED option and voltage LED option would be nice…
TK’s Anduril on D4S “breathes”…so a breathing rainbow would be neato!
Thank you!
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
sukanta
Last seen: 2 months 3 days ago
varbos wrote:
Has it got reverse battery protection now ?
@Hank please update. This is very important as I am planning to gift to my Father in law.
Sukanta
Firelight2
Firelight2's picture
Last seen: 3 hours 31 min ago
Looks great. Multi-colored bezel aux LEDs without having to change the aux board! Plus Anduril and knurling! Ordered two.
I notice the switch appears to be exactly the same as on the v1. It is not recessed. Guess I’ll mod the switch soon as it arrives.
Man Without Shadow
Thank you!
Ohhhh…maybe I misunderstood…ALL of those colors will be on the board and are selectable? As well as a “rainbow” and “voltage” mode using the multi colors?
thanks!
TheShadowGuy
RGB is making its way from PCs to flashlights. Will we ever escape?!
… I need one, haha.
shinysideup
Well… I ordered two! Dark grey with SST20 5000K and dark grey with SST20 4000K and two stainless steel bezels. My D4S and D18 have the 4000K and I really like the throw/tint.
One question… How does the voltage aux light readout work? What do I see when I configure the aux LEDs to the voltage setting? Cheers.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 8 hours 4 min ago
Igor wrote:
What is the difference between SST20 and XPL-HI?
And also between the 10622 and 10623 Carclo optics?
Thank you.
All SST-20s are throwier/higher candela per lumen than the X-PL HI.
The 5000K is not high-CRI but basically matches the output (and efficiency IIRC) of XPL HI.
4000/3000K SST-20 is about 25% lower output but are high-CRI. So a bit more heat, lower max output at turn on and less efficient when matched for output against the others but high-CRI with EXCELLENT red rendering.
X-PL HI almost always has a good tint, either below the BBL (rosy) or right on it (little to no ugly green). SST-20 is greener at low power levels, pretty good at ~500ish and rosy at turbo or close to it. Personally I’ve been happy with the 4000K SST-20s as they’ve been no more or less green than almost all the other high-CRI emitters I’ve tried (219B and E21A being the exceptions).
So just to confirm, the V2 will have the version of Anduril with additional 60 lumen lockout mode and option to set mode memory to a specific output?
bquinlan
Last seen: 12 hours 42 min ago
This looks great! I love the multi-colored AUX lights.
My one disappointment is the original driver. This would be a perfect EDC light with a few more 7135 chips. I would really like to see a FET+3 like the D4S or, ideally something more like a FET+8 or FET+7+1.
I hope Hank will implement something like that before too long. {fingers crossed}
—Bob Q
vinte77
Last seen: 8 hours 33 min ago
Are the ss bezel, magnetic tail caps, and battery tubes going to be available for sale separately? For those of us who want to swap out some parts with v2 parts.
Tally-ho
Tally-ho's picture
Last seen: 1 week 3 days ago
lawallac
lawallac's picture
Last seen: 2 days 19 hours ago
Got my 2 ordered early this morning. I never get anything in CW so I got a grey one in the sst20 6500k with the magnetic tail. I’ve been really happy with the output and the throw of the sst20s vs the crees. I’m a really big fan of the 3000K, so I got one of those too but w/o magnetic tail. I hope to carry the 3000k more and don’t want to worry about the magnet erasing credit card magnetic strips in the ones that have it.
northbeard
Last seen: 11 hours 51 min ago
Love this version of the light, Hank. The multi-colour aux LEDs are probably going to drive me slightly nuts – and maybe require a matching set of D4v2s, one for each hand…
A question on the battery type though: Is a Samsung 30Q enough for this light, or would one of the Sony VTC6 be better? I have a VTC6 in my current D4 and it seems to work extremely well. It would be easy to get the battery shipped in the light, saving the normally userous shipping for LiIon batteries into Canada. But if a different battery would power the light for longer, I can deal with it.
Rusty4x4
I don’t think Hank can ship batteries to canada even in a light
Omega_17
Last seen: 3 hours 4 min ago
Same cells, with same chemistry and ratings. The Sony is slightly longer.
But you can get better capacity cells for slightly longer run-time. 3600mAh instead of 3000mAh but you also have to look at the Continuous Discharge Rating (higher amps mean higher output but less run-time if you use turbo or unregulated output)
saypat
saypat's picture
Last seen: 9 hours 32 min ago
hoping the aux LEDs on this are adjustable in brightness like those on the FF lights. Also waiting to see about thread compatibility with the D4 v1.
exciting flashlight times!
Kingjohn
Kingjohn's picture
Last seen: 1 month 6 days ago
Hank Wang wrote:
Ratus wrote:
Quote:
7 aux LED colors options which is selectable through config UI,
So each light has all the aux colors?
I’m thinking that “main LED tint x 7 aux color x 3 body colors” would be way too many sku’s for anyone to stock.
Each light has all the colors, you can choose any color by any time through ui.
Damn…. I must have one…..
I will wait for the recently ordered D4 with 3000K and decide if I get a D4 V2 with 3k or a 4k then….
Lexel
Lexel's picture
Last seen: 1 hour 15 min ago
so is the Aux board with a second MCU that controls the colors?
and the main MCU uses serial data to set the Aux MCU?
or Attiny 1634 MCU with more pins to control 3 aux LED channels?
djozz wrote:
The led is nothing special, not much bigger than a single-colour aux led. But you have to adress the three colours separately to do the colour mixing and get those different colours, so the aux board and MCU must support that (occupies more pins).
Leds must be something like this:
you can simply put 3 0402s together smaller than such a 0606 LED size
and if you want go crazy use 0201 LEDs
Kingjohn
Kingjohn's picture
Klayking wrote:
KevinZA1988 wrote:
That’s a deal breaker for me.
I don’t think it’s quite a deal breaker for me, but it’s certainly a reason to keep using my FW3A. It’s the primary reason I keep using my FW3A instead of my D4, even slightly moreso than the fact it runs Anduril.
On the bright side, with Anduril on the new D4 I should be able to cap the ramp at something reasonable like 300 lumens to limit how much power I fritter away. The new option to make it always switch on at any desired level (such as max regulated) will be really useful too.
Is there somewhere a comparison between the FET and the 7135 efficiency? (for different power levels)
Or can someone just write some general numbers?
chinooker
chinooker's picture
Last seen: 7 hours 57 min ago
OK Got my sand ordered….
Bring on the D4SV2. Cash
Gunga
Gunga's picture
Last seen: 3 hours 26 min ago
Can someone explain how aux leds are implemented? Do they turn on when the light is off? Like a lit tailcap? Or is it a mode during use?
I’d want them pretty dim if the former.
