Target Clearance - White-top Duracell battery 4-packs (EDIT) now $3.65 (Duraloops)
202 posts / 0 new
Backpacker Light
Last seen: 4 months 1 week ago
Target has both AA and AAA White-top Made in Japan “Duraloops” on clearance (half off) for $6.08 each.
These are of course the re-branded Eneloops. Time to stock up!
The lighter the brighter the better.
Edited by: Backpacker Light on 08/11/2013 - 00:45
fishmaniac
fishmaniac's picture
Last seen: 7 years 2 months ago
Cool..hopefully its on sale over here on the best coast. Big Smile
Thanks for lookin out…
vuanhquoc
vuanhquoc's picture
Last seen: 4 years 4 months ago
this is still depends on location, i got 3 set yesterday for $6.08, and this morning went to a different store and it was $8.05.
vuanhquoc
vuanhquoc's picture
it does, got 3 set yesterday and 2 more this morning for my old man
fishmaniac
Thanks for letting me know so fast…Mr. “I got 3 yesterday”. Flat Stare
Big Smile
vuanhquoc
vuanhquoc's picture
:bigsmile: i bumped into it while shopping back to school for my brother. shouldda made a thread. my bad :bigsmile:
fishmaniac
Haha…just messin wicha.
Why $6.08? Is that targets clearance code – $.08?
vuanhquoc
vuanhquoc's picture
50%off, original price is $12.19
FlashPilot
FlashPilot's picture
Last seen: 6 hours 24 min ago
Check your date codes. All duraloops from target have been +4 years old (which is why they are unloading them). Some older.
vuanhquoc
vuanhquoc's picture
all of mine were from july 15, 2012, i gues that’s not bad? also would you guys recommended to charge these AA with I4 intellicharger?
gerald_clark
gerald_clark's picture
Last seen: 2 years 10 months ago
I bought 3 packs of each. They checked out at 1.325 Volts or higher out of the package.
They had more, but my wife was standing there and she had the charge card.
Backpacker Light
vuanhquoc wrote:
all of mine were from july 15, 2012, i guess that’s not bad?
Did you get that date from the embossed code on the seam of the battery? How do you read that code?
Backpacker Light
You can charge the AA’s in the I4 with no problem’s, even a single cell.
But the charge rate is fairly high for AAA’s, so you need to do at least two cell’s at a time, and place them in paired slots #1 and #3 or #2 and #4 (left to right).
ohaya
Last seen: 1 month 2 days ago
Aren’t the paired channels in the newer i4 chargers changed to 1&2 and 3&4? I thought I’d read that in one of HKJ’s reviews, or maybe it was just for the Jetbeam i4 pro?
Edit: This was the review I was referring to:
http://www.candlepowerforums.com/vb/showthread.php?352459-Jetbeam-i4-PRO-Intellicharger-Review-Current-Voltage-Comparisons-for-Li-ion-amp-NiMH
From that review:
Quote:
The other change is in regards of the paired charging bays. As before, there remain only two independent charging channels. This means that you can charge two cells at full current (i.e. 750mA x 2), or four cells at reduced effective current (i.e., 375mA x 4). But what has changed is the relative positioning of the paired bays.
Before, on the i4 V2, the paired bays were #1 & #3, and #2 & #4 (i.e., if you put cells in those two paired bays simultaneously, the charging current was split between the cells). Now, on the i4 PRO the paired bays are side-by-side (i.e., #1 & #2 are paired, as are #3 & #4). Truth be told, I find this new pairing more intuitive (i.e., cells side-by-side are paired, not spaced apart). But ultimately, any such arrangement is arbitrary. What really matters is to have this pairing clearly spelt out somewhere, either in the manual – or preferably – on the unit itself. Unfortunately, there are still no markings as to how the bays are paired. I found out by directly measuring it, but most would only be able to figure it out by noticing that some pairings took longer to charge than others.
vuanhquoc
vuanhquoc's picture
the datecode were stamp on the back of the package under the bar code not on batteries. “2G15J1” . i tried to look for some kind of code on battery but couldn’t find any.
leaftye
Last seen: 1 year 1 month ago
My Target had lots of them for $6.08.  AAA's for the same price too.
Date code: 2H21J1
2=2012
H=August
21=21st day
August 21, 2012
The low mode should be lower.
fishmaniac
Ok got me some from 2012. They have a reflective green strip around the battery. There were some from 2009, 2011 and 2012. The others had no green stripe.
Yeah, but like flash said watch ur dates.
Aftrburnr
Last seen: 11 months 1 week ago
You can save an additional 5% if you use ur Target card Wink Picked up some myself today. I counted about 25 packs of aa & about 15 of aaa at the store I went to. I thought the packs in plastic package were newer but now I see they’re not. So, I’ll go exchange the ones I got from 2010 for newer. I bet the older ones from 2010 would still be just fine tho. Thanks again & GOOD CATCH!
gearjunkie
Last seen: 3 years 9 months ago
Thanks for the heads up. I bought a couple of packs from the nearest Super Target for the price listed by the OP. They have the green strip around the cell so I assume that these are the 2012 versions.  I plan to include them with my flashlight gifts to friends and relatives.
If you are interested in Duraloops and don't have a Target nearby, Tanga is selling 2 4-packs for $12.99 with free shipping. I do not know which versions they are selling though.
vuanhquoc
vuanhquoc's picture
how’s the number on the date code for 2010? is it 10? or 0? i assumed if it was 2009, it would be 9 in the front am i correct?
Aftrburnr
9 = 2009
0 = 2010
1 = 2011
2 = 2012
I actually forgot about the date codes on the packs I read about a few years ago lol
vuanhquoc
vuanhquoc's picture
hmm so what if it was 3?
Dimbo The Blinky
Dimbo The Blinky's picture
Last seen: 3 months 3 days ago
As of a few minutes ago, the Target on Harbison Blvd., Irmo had 3. Now they have one and I have two; date code = 2I01J1. They had no AAA, and many-many empty pegs on their display (clearing stock in general).
THANK YOU for the tip!
Dim
“There is no darkness but ignorance.”
gearjunkie
leaftye wrote:
If you are interested in Duraloops and don’t have a Target nearby, Tanga is selling 2 4-packs for $12.99 with free shipping. I do not know which versions they are selling though.
What’s the first number in the date code?
The ones I bought all starts with 2.
leaftye
gearjunkie wrote:
What's the first number in the date code?
Great, all your batteries were manufactured in 2012.
2013.  Is that what you got?  I'm tempted to go back and look for 2013's, but then I might actually buy them.  Must resist...resolve weakening...
Aftrburnr
I’m going to go exchange mine. They’ll prolly think I’m crazy but I’ll tell em it’s like buying bread or milk for date code, ya want the freshest from what’s on the shelf hehe
Strick9
Strick9's picture
Last seen: 1 month 4 weeks ago
Thanks for the tip… grabbed 4-packs of AAs (that’s all they had).
The date codes (?) are different from what everyone else here is describing:
3 of them have: 3059868100 and 1 has: 2350868100.
All have the white top, green stripe, and “Made in Japan”.
tallboybass
tallboybass's picture
That’s what the code looked like in my store. They were $8.53 too…no sale.
mfpmax
mfpmax's picture
Last seen: 5 years 7 months ago
That’s cheaper than regular of $12 or so LOL
Wilson
Wilson's picture
Last seen: 10 months 3 weeks ago
The Costco price for Eneloops (when they have them) is:
$20 for 10 pieces AA (averages out to 4 pieces for $8) and includes 2 plastic cases
$20 for 12 pieces AAA (averages out to 4 pieces for $6.67) and includes 2 plastic cases.
Inquire…Choose…Proceed
33696933
33696933's picture
Last seen: 7 years 1 month ago
my local store had plenty, use a 1.50 coupon on each = 4.58 each pack
