Yezl Y3 - a picture breakdown
345 posts / 0 new
Mitko
Mitko's picture
Last seen: 1 year 4 weeks ago
Yeah i tried those and they are absolutely the same as Efest 4200( real capasity is 4300-4450 actualy, at 5a load)….i think they could be rebranded Efest cause its absolutely the same, i bought them only once 6 months ago but the shipping time took forever
I tested so far Enerpower 4700 mAh , all Efest and Keepower 26650 models, Trustfire too, have several Ultrafire and i dont wanna talk about , i have currently even Sony US26650FTC1 3000mAh LiFePo4- the best considering high amps is Efest 4200
Those Panasonic 26650 in Aliexpress seems to be fakes, at least 2 that i bought were
shrick
shrick's picture
Last seen: 1 month 1 day ago
Thanks Mitko. May I ask what device you use to test your cells?
Mitko
Mitko's picture
Selfmade one, well am i a power engineer Smile Its actualy quite simple
Plus, you can always test a battery on a DD driver fresh started, at 4v, at 3.8 and so on, thats the method i used before i made one
Hey Tom, i just saw Kaidomain has a 58.6mm AR glass, have you tested it?
Tom E
Tom E's picture
Last seen: 4 hours 40 min ago
Mitko wrote:
Hey Tom, i just saw Kaidomain has a "58.6mm AR glass":http://www.kaidomain.com/product/details.S023037, have you tested it?
Ohhh - I am so freak'n spoiled by UCL's and UCLp's, I find disappointment in all the other so called AR lens (cheap ones) out there. I'm with Dale on this. I did try pretty much all of them CNQ, KD, IOS, FT, etc.. - All are beaten by Chris's at flashlightlens.com.
Think CNQ had the Y3's - tried those, maybe not the KD's specifically, not sure.
willie
willie's picture
Last seen: 2 weeks 4 days ago
Put an UCLp, de-domed XM-L2 U4 1C, resistor mod, extension for two 26650 and am please with the cost/power ratio on this flashlight. Only gripe is the dedome is almost too incandescent yellow, dedomed it with acetone.
aw73
Last seen: 3 weeks 2 days ago
its been awhile since i have been on here, but i noticed that yall say that the drivers have changed a bit. are there differences in the ones from GB and CN?
aw73
are you using 6v led?
i am running 6v xhp50 with this driver and resistor mod and its around 3.8 amps with 2 cells. with one cell, xml2 and resistor mod i could only get 3 amps.
willie
willie's picture
The way I understand it the Y3 is a buck driver. I am close to 2.8A with TWO cells at the tail which after losses it should be close 5A to the XM-L2 emitter. To unleash the capabilities of this driver add a third cell. In my case three cells only increased weight and capacity. I am running 3 26700 King Kongs on my HX 1175B1 driver with the MT-G2 witb a tail cap reading of 4.6A and imagine that works out close to 6.5A. But I claim not to be an expert. Wink
aw73
my Y3 has always been different. the driver in mine doesnt buck. never have understood why. i have burnt a couple of xml2s trying to run 2 cells. that is why i got the 6v xhp50 in it. i was having trouble with my meter but i retested it at the tail and it is 4.27 amps with 2 not fully charged 18650s.
aw73
if it says 2.8 at the tail it will probably be less at the led unless im missing something, am i?
Barkuti
Barkuti's picture
Last seen: 6 hours 47 min ago
Quick question fellows: tube thread size?
I've been looking for an extension tube which I could lego with, they're selling this Y3's extension tube at FastTech, yet no one has answered my inquiry there yet.
It seems to be M31×1, comfirmation?
Cheers Party
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Keanu Reeves may need your help. Join his Telegram channel here.
MRsDNF
MRsDNF's picture
It seems to match the picture here. I haven’t heard of copies of this light being made.
https://www.fasttech.com/products/0/10011236/4183400-yezl-y3-led-flashlight
Tom E
Tom E's picture
If you are think'n of using it for another light, I dunno what M31x1 means, or how to verify it. I got Y3 extension tubes, but not from FastTech, so dunno if it would help.
Barkuti
Barkuti's picture
Tom E:
ISO metric screw thread @Wikipedia
In essence, M31×1 is a metric screw thread designation equal to a male thread of 31mm outer diameter and 1mm of thread pitch.
Cheers Party
