COURUI DO1 'Big Head' (Black/GRAY NOW AVAILABLE) $29.99 @ Gearbest ( use coupon: gbcourui) A long-throw modder's light!
567 posts / 0 new
tatasal
Last seen: 3 hours 8 sec ago
You guys are all correct. That’s all sadly true.
DB Custom
DB Custom's picture
Last seen: 5 days 12 hours ago
And the men who hold high places
Must be the ones to start
To mold a new reality
Closer to the heart
tatasal
@18sixfifty
I’ll be waiting for the gray version so maybe perhaps another 10 or more days (China National Day) before my unit is sent directly to your address in the USA. Stay tuned.
M4D M4X
M4D M4X's picture
Last seen: 2 months 1 day ago
i skipped gray (cause i am really bad at “being patient” Wink )
maybe i try to bake it to change the black ano …
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
FmC
FmC's picture
Last seen: 7 months 4 weeks ago
Spent a few hours modding my grey Courui today, setting it up with an XP-G2 & the Noctigon 32mm MCPCB.
Even with the 32mm board, the flat base of the reflector (which is 26mm wide) partially covers the solder pads.
If you want the reflector to sit flush, & you are using a smaller board, you will need to get creative.....
G0OSE
G0OSE's picture
Last seen: 1 day 50 min ago
Waiting for mine to be shipped, hopefully soon.
Being a bit of a newbie here, and up for doing some light modding (at first) – what would you guys say are the ‘must do’s’ to get this baby upgraded to a better, safer spec without changing too many bits. ie, does the whole thing just need a rewire?
I’m not talking modding the actual led or driver yet or anything too drastic, I just want to do what they should have done in the first place, so to speak.
I did have a look at the teardown thread etc, but would appreciate some advice for a beginner. One of the main points they seemed to skimped on is the cable quality?
Thanks Smile
DB Custom
DB Custom's picture
G0Ose, if I was gonna do one thing I’d address the ground issue in the tailcap. Make sure the inner trace where the springs are mounted have a more direct path to the outer trace where the screws ground it. That alone will give you better throughput.
G0OSE
G0OSE's picture
Thanks, do you mean the braided wire bits?
I did see that somewhere , but for the life of me can’t find where…
FmC
FmC's picture
G0OSE wrote:
Waiting for mine to be shipped, hopefully soon. Being a bit of a newbie here, and up for doing some light modding (at first) – what would you guys say are the ‘must do’s’ to get this baby upgraded to a better, safer spec without changing too many bits. ie, does the whole thing just need a rewire? I’m not talking modding the actual led or driver yet or anything too drastic, I just want to do what they should have done in the first place, so to speak. I did have a look at the teardown thread etc, but would appreciate some advice for a beginner. One of the main points they seemed to skimped on is the cable quality? Thanks Smile
The wire thickness is marginal, but at the stock current, it’s probably not holding too much back.
If you want to upgrade to a ‘better spec’, the mods all go hand-in-hand; Resistor mod to stock driver(very easy), which then necessitates thicker wiring, & then a copper MCPCB.
Even though there’s a few mod threads going for this light, I’m planning on posting another thread when mine is finished.
DB Custom
DB Custom's picture
Not braided wire in the springs, but addressing the top of the pcb the springs are mounted on…inside the tail cap. Courui used a very thin wire to join the 2 traces, almost like a fuse. I scraped mask off in 3 places adjacent to the springs and soldered copper sheet between the traces, giving it a much more solid ground for the current to flow through. This made a big difference, as my hot rodding attempts were only getting 4A through. After doing this, it’s over 6A. Don’t remember exactly the amperage and am not at my desk to check, but the tail pcb set-up was holding it back.
G0OSE
G0OSE's picture
Ah, the bit some people have put a thicker wire on? you mean the three dots in a triangle (sorry to sound like a complete idiot)
DB Custom
DB Custom's picture
See where the spring pads are on the inner trace? I just cut bits of copper sheet and used solder paste to join the outer trace to that pad directly, in each spot. A thick wire at each point would work similarly. Or one really thick wire. Or a copper “washer” cut to go all the way around the board with the screws going through it. Anything to make ground more capable of carrying current.
All dependent on how much current you plan to run.
I put an MT-G2 in one of my Courui’s and it wanted to run at 13A and over 4000 lumens, limited it in the UI to allow 3030 lumens for better thermal control. Smile If/when I get a copper pill for it from Buck, I’ll pull the limitations. (re-flash the MCU)
tatasal
You guys talking about modding this light, (or any light for that matter) and with accompanying pics will eventually lead me to start my modding hobby. So far I have been in the ‘pleasure of owning one’ yet. And thanks, btw, for the discussions.
DB Custom
DB Custom's picture
The pcb is spaced deeper into the tail cap with 1/4” thick copper risers to accommodate the double 18350’s in each bay.
G0OSE
G0OSE's picture
Thankyou for that Dale Beer
tatasal
With the kind permission of FmC, he has this mod on the Courui using XP-G2:
http://budgetlightforum.com/node/34524
Thanks
G0OSE
G0OSE's picture
Yes I saw that, thanks! subscribed.
Gearbest stalling a little over dispatch, been 4 days ‘processing’ and had some weird email from them saying -
‘Thank you very much for your recent communication.We sincerely apologize for any inconvenience that may have been caused.
We have informed our colleague to test the item and speed the shipment up already , could you wait for 1-2 workdays more?’
Do they normally test them before shipping? (or is this just another way of saying they are oos), all seems to be taking a bit of time, always the way when you want something though I suppose! Big Smile
Got a broken STL-V6 here waiting for a new driver too from HK which is taking a while. Remains to be seen if it works as I couldn’t find the original one anywhere, ended up getting this – 8.4V SST-50 5-Mode Memory Circuit Board for LED Flashlights Torch
tatasal
As stated in the op, GB should start shipping out the lights (except the gray versions) by Sept. 29th, Shenzhen-time.
Edit: I have edited the title of this thread and copied the “Big Head” nickname as aptly coined by FmC’s thread: http://budgetlightforum.com/node/34524
G0OSE
G0OSE's picture
Ah, sorry in my rush didn’t see that.
I’d also be interested to know what batteries you guys plan to use in this? I have ordered a nitecore d4 charger but wanted some input on what protected cells to get and from where?
I have read quite a bit so far but it all gets a bit deep… lol.
Pulsar13
Pulsar13's picture
Last seen: 11 months 1 week ago
Where's the gray version?
tatasal
The first ‘prognosis’ of the gray version was about 10 working days from last week’s announcement, then with the China National Holiday (holiweek?) to start Oct. 1…well, we know the usual effect.. Don’t just hold your horses, perhaps let them go back to the barn to rest. Haha
I will keep this thread informed on every pertinent information available. I’m with you with the gray version too, btw.
tatasal
The first batch of 33 lights will be shipped today.
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 9 months ago
Well then I must of got lucky and been one of the first ones out, I received my shipping notice around 16:00EST 9/28.
I added a Y3 extension to the order threw customer service so maybe that’s why it went out already.
Edit, can we expect mail to sit during the holiday or will it actually continue to move?
BTW my 3s conversion / totally new buck driver is coming along great, there is a thread about it in the custom mod/DIY section called “buck driver component selection” by tterev3 if you want to watch the progress and see the preliminary spec’s.
tatasal
Cheerios!
Werner
Werner's picture
Last seen: 2 years 3 weeks ago
I got a shipping Notification 10 hours ago.
G0OSE
G0OSE's picture
Nice, mine’s on it’s way too.
bugsy36
bugsy36's picture
Well then I must of got lucky and been one of the first ones out, I received my shipping notice around 16:00EST 9/28. I added a Y3 extension to the order threw customer service so maybe that's why it went out already. Edit, can we expect mail to sit during the holiday or will it actually continue to move? BTW my 3s conversion / totally new buck driver is coming along great, there is a thread about it in the custom mod/DIY section called "buck driver component selection" by tterev3 if you want to watch the progress and see the preliminary spec's.
It all depends on the shipper and its location when the holiday starts. If it is a Chinese company it will definitely sit if it has not left the port. They usually, unless using surface mail, work 10x harder to make up for the lost volume so until they hit the weight barrier they double the efforts.
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
Cereal_killer
Hey guys, for anyone who has a courui already, perhaps you’ve seen my thread on the brand new design buck driver I’m making. Anyway I could really use the measurements of the factory driver so I can get to work. Can anyone help me out?
Also if someone has one they don’t mind not using for a few weeks or so I could do an even better job if I had a driver in hand, I would gladly supply you with one of the first ones I get together in return for you sending me yours now.
tatasal
@Cereal_killer:
I have added the link you posted in the OP. Buck driver design – component selection example
http://budgetlightforum.com/node/34461
tatasal
For easier reference to all modders/enthusiasts, the thread below is now added/consolidated in the op:
Teardown and Mod Thread of Courui XML2 Aka “Big Head 3×18650 Side-Switch Thrower” (by LinusHofmann)
http://budgetlightforum.com/node/26701 Beer
