COURUI DO1 'Big Head' (Black/GRAY NOW AVAILABLE) $29.99 @ Gearbest ( use coupon: gbcourui) A long-throw modder's light!
567 posts / 0 new
wight
DBCstm wrote:
The parasitic drain can be completely eliminated by putting a clicky switch in the tail cap.
I really really like my Courui’s, but this mod alone is the cat’s meow as far as the big head is concerned, flat out does away with the parasitic drain potential and keeps your cells ready to go.
This is one of the lights I could never let go…
I don’t like that solution because that’s one more thing to keep up with and operating a pair of switches located at opposite ends of the flashlight is dumb/lame/annoying/confusing/physically difficult/pick-as-many-as-you-want. It gets even worse if you are using a firmware such as the stock one where you could turn it off in firmware and forget to operate the tailswitch. Or if someone else needs to turn the light on (or off!) and sees the highly visible side-button (or they’ve seen you operating it with that) and doesn’t know or remember about the tail switch lockout. So for better or worse I’m really not a big fan of this approach!
[A series conversion is the worst case scenario at the same drain current since it has less mAh.] With a series conversion reducing the parasitic drain to 0.1mA total would take us to the point where 3000mAh batteries would be flat in 3.4 years. No need for a tail-clicky-mod there!
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
DB Custom
DB Custom's picture
Last seen: 4 days 4 hours ago
But of course, some of the most popular lights use this approach. The SupBeams do it, the Convoy L4, other larger Convoys, it's a fact of life. And you don't have to turn off the clicky at the tail unless you're gonna store it for a while.
Worst case scenario is needing a light and finding the batteries unable to cope with your needs due to a lack of charge.
Having a positive mechanical lockout in the tail also prevents accidental e-switch engagement when in a backpack or otherwise being transported. Wink
In the real world, perfection simply doesn't exist.
I don't know how to do all that fancy electronic wizardry, so modifying the big head in that way is beyond me. I can, however, drill a hole.
Edit: Also the tail clicky provides an instant off, in some tricky situations where that is necessary.
EditII: As an aside, immediately after proudly proclaiming this accomplishment the cats meow, you said my efforts were dumb and lame. Sad My sails are shredded and my pride boat is dead in the water now. Thank you.
Silly (yanking your chain, but seriously, some might cave under such criticism)
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 9 months ago
I to prefer the dual switch setup for all the reasons Dale sited. Using my driver and Tterev3’s ultimate flashlight code (with my mod to wake up in primary) the tail switch is not only a lockout switch but allows momentary use (in ANY brightness level!). This gives you the option of using the light in either grip (since when powered on the side switch also offers true momentary use).
Werner
Werner's picture
Last seen: 2 years 3 weeks ago
It would be easy to Build a momentary driver with no parasitic drain…
Just a diode, a FET and maybe some resistors needed…
The switch powers the controller on over a FET, after that the controller powers himself with pulling up the same FET. Just a diode and some resistors needed to detect the momentary action
Voltage detection resistors behind all that
And voila a zero standby momentary driver…
Should also work as reversevoltage detection, so just an additional FET and maybe resitors needed…
wight
Fair enough! I didn’t intend for it to be taken as criticism of what you are doing now so much as I intended it to be an explanation of why we shouldn’t be satisfied with the status quo. Your post was, after all, intended as a counter point to Werner’s post on parasitic drain – right? Mine is just a counterpoint to your counterpoint. Wink
You mean that with your tweaked version of Ttrev3’s firmware I could signal using either the momentary on the side or a forward clicky on the back? And still have modes?
wight
I think I proposed a similar idea in the Knucklehead Buck Driver Discussion Thread somewhere. I know I never prototyped it, but as far as I could tell it sounds totally viable. My suggestion was slightly different since it was intended to work with a LD2981/MIC5235/LT1761 style voltage regulator. I think I had a pulldown resistor keeping the SHDN pin low. I figured that a zener+resistor could be hooked up behind the normally-open momentary pushbutton and power the MCU whenever it was depressed. The MCU’s first instruction would be to latch an output to pull up the SHDN pin on the voltage regulator.
jmpaul320
jmpaul320's picture
Last seen: 3 months 4 weeks ago
Mine arrived today!
Tracking number never updated though lol.
Although I am sure it made a difference in the shipping speed… I have to look when exactly I ordered, but I think it took around 2 weeks.
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
tatasal
Last seen: 3 hours 17 min ago
jmpaul320 wrote:
Mine arrived today!
Parcels coming from China’s shipping and tracking nowadays are crazy, isn’t it? While some are complaining of ‘Delivered’ status in their tracking but did not receive any, yours is the opposite.
Well, I’d rather have the latter than the former! haha
jmpaul320
jmpaul320's picture
you guys might want to inspect the light before you fire it up
i removed the tail cap section to replace the tiny wire with a larger one today and all three screws were loose (the ones that hold the contact plate in)
turns out they are TOO short to grab the threads on the other side.
I went across the street to my local hardware store and got replacement screws that are a hair longer and that fir just fine… cost 0.50$ lol
I also measured the lens to be 72mm x 2mm +/-0.1mm
flashlight lens sells a UCLp 73mm x 2.25mm that should fit… if it doesnt its plastic and easy to sand down 1mm on the side
just replacing the wire on the tail cap and then adding copper braids and replacing the driver wires with 22ga ones added over 120 OTF lumen.
Best wish, May
Tmart service team
DavidEF
DavidEF's picture
Last seen: 2 weeks 2 days ago
Thanks for the heads up! I was hoping to just use this light for a day or two before having to crack it open. Oh well!
By the way, my tracking info says “Origin Post is Preparing Shipment, We have received notice that the originating post is preparing to dispatch this mail piece.” This is crazy slow. It hasn’t left the “Origin Post” yet? |(
- The YKK Philosophy
Fragarach
Last seen: 2 years 10 months ago
I seem to have ordered one of these at some point in the last few weeks and forgotten about it .. just got a random email from gb saying my order has shipped..
Maybe I shouldn’t browse forums after midnight.
I seem to order random things.
I have enough knowledge to be dangerous at whatever I do.
I ask obscure questions to become less dangerous not more.
EDC Mini Mag + Victorinox Mini on keys, TN12 on belt.
-=TMiV=-
tatasal
Fragarach wrote:
I seem to have ordered one of these at some point in the last few weeks and forgotten about it .. just got a random email from gb saying my order has shipped.. Maybe I shouldn’t browse forums after midnight. I seem to order random things.
haha! You just lightened me up.
DavidEF
DavidEF's picture
I have a solution for you. Change all your contact info, shipping info, everything except billing info on all flashlight related online stores to my info! Then, when you unknowingly buy a flashlight after midnight, you’ll never have to hear about it, and that will make you feel much better. 0:)
Cereal_killer
You mean that with your tweaked version of Tterev3’s firmware I could signal using either the momentary on the side or a forward clicky on the back? And still have modes?
Exactly. its such a versatile FW I will NEVER use any of the AVR momentary FW’s again, there’s no reason to, UFLC does everything you can possible want. Now that we have it written in C on the tiny little 10F322 this is my go to FW for any momentary light (any my go to drivers since there is also not clicky FW for the 10F)
Oh BTW the UFLC has code for THERMAL turbo regulation!
wight
If there was a writeup on this firmware I guess I missed it. Link me?
Cereal_killer
All FW related info and video demo’s can be found in my BLF _PIC driver thread and have been updated as of just now, there is no thread specifically on just the code.
wight
tatasal wrote:
The gray version is expected to be delivered perhaps tomorrow. Until it is in the hands of GB shall it be officially announced, with the corresponding SKU of that model.
I’m still on the lookout for the gray version!
tatasal
After a couple of days of delays, the gray version’s sku will be posted within today in GB’s website. Stay tuned.
gearbest
gearbest's picture
Hi guys,
So sorry for the delay of the gray version, here is one contrast pic for the black and gray, and we will post the sku of gray version on our site later Wink
tatasal
Announcement: Oct. 15, 2014
The Gray version is now available. Same product link: http://www.gearbest.com/led-flashlights/pp_85126.html
*just click on the Black – Gray box your color of choice (seen below the regular price and just above the “Add to Cart”)
Take note that the Gray version has two modes only (High-Low) and has no strobe
Edit (Oct 16): “A long press on the switch ~2secs activates a hidden strobe”. (http://budgetlightforum.com/node/26701) by LinusHofmann
Stittville Ed
Stittville Ed's picture
Last seen: 4 months 1 week ago
No color choice on your site.
Like the no strobe for the gray.
tatasal
Stittville Ed wrote:
No color choice on your site. Like the no strobe for the gray.
please try on the link again: http://www.gearbest.com/led-flashlights/pp_101690.html and check it out
downlinx
downlinx's picture
Last seen: 7 months 4 weeks ago
dang i should really buy the grey, i am really digging the color.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
Tom E
Tom E's picture
Last seen: 11 min 24 sec ago
The gray option shows and works for me, but the promo code does not work for the gray version -- only works for the black version. Needs to be fixed... ?
Stittville Ed
OK it has the Gray box now.
Thanks
tatasal
Tom E wrote:
The gray option shows and works for me, but the promo code does not work for the gray version — only works for the black version. Needs to be fixed… ?
Yeah, you are correct, it does not work now. The gray has just been uploaded about an hour ago. It’s almost 9 in the evening Shenzhen-time now I don’t know if anyone at Gearbest can still fix it.
garrybunk
garrybunk's picture
Last seen: 2 weeks 4 days ago
Sweeet!!!!  Just waiting for the coupon code to work!
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
Tom E
Tom E's picture
No prob - I'll wait. Ordering a gray COURUI and a C108S for $14.35 on a timed promo, and using up my pts for another $1 and change... Smile
tatasal
@ Tom E
Thanks for posting about the glitch about the non-acceptance of the coupon code on the gray version.
Although I have just sent a pm to CSgearbest, I’m not confident it can be fixed now as it’s already 9:13 in the evening, Shenzhen.
Tomorrow then.
Pulsar13
Pulsar13's picture
Last seen: 11 months 1 week ago
Finally. So glad I waited for gray, much better looker IMO.
Any holster recommendation for this light?
