17mm/22mm MTN-MAXlp - Low-Profile 1A-4A Programmable Buck Driver + 22mm MTN-MAX
227 posts / 0 new
RMM
RMM's picture
Last seen: 1 year 8 months ago
Keep at it and you'll get it running.  Remember: no pressure on the traces if you go over them with an iron.  Pressure and heat is how traces get lifted.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
n10sivern
n10sivern's picture
Last seen: 11 hours 26 min ago
hey richard, I downloaded the file to have stencils made. The top stencil is just fine, but I can’t get the bottom stencil to work out. There is no bottom cream file.
Three tomatoes are walking down the street- a poppa tomato, a momma tomato, and a little baby tomato. Baby tomato starts lagging behind. Poppa tomato gets angry, goes over to the baby tomato, and smooches him… and says, Catch up.
RMM
RMM's picture
n10sivern wrote:
hey richard, I downloaded the file to have stencils made. The top stencil is just fine, but I can't get the bottom stencil to work out. There is no bottom cream file.
Probably not.  You have to go out of your way to have proper cream files made for everything, and I certainly haven't done it and probably won't.  I don't use stencils.  I've tried them and really don't like them.
RMM
RMM's picture
n10sivern, did you ever get yours running?
pilotdog68
pilotdog68's picture
Last seen: 6 months 4 days ago
RMM I know you’re busy (especially lately) but have you had a chance to test the HP version?
RMM
RMM's picture
pilotdog68 wrote:
RMM I know you're busy (especially lately) but have you had a chance to test the HP version?
Yes, and I think that its viability is questionable without some further thought.  I built one running at 5.5A and ran it quite a bit in my UF-1405.  While it didn't burn up, somewhere along the line it lost the moonlight mode level which told me that something was starting to get fried.  I tried cranking up the PWM level and it still wouldn't come back.  This tells me that the driver would eventually fail and that a redesign is needed if a reliable 5A+ is to be obtained.  I'm guessing that the buck IC or FET is slightly fried, but I haven't had a chance to play with it since then.
I decided that these high-power buck drivers could really benefit from a 4-layer board, both thermally and to electrically.  A standard Eagle license is pretty expensive, but for me my time to learn a new program (KiCad) that can do 4-layer boards for free would be more expensive than the money paid.  I don't need multiple schematic sheets or autorouter, so it wasn't too ridiculous, but it still wasn't cheap.  I designed a new 4-layer board with a lot more thermal transfer capability which I'm hoping will do the trick.  They just shipped so hopefully I'll get around to trying one next week.
n10sivern
n10sivern's picture
I haven’t had time to fool with it. I’m going to try on Thursday.
pilotdog68
Thanks for the update RMM. My 1405 is patiently waiting, but my wallet needs time to recharge anyways so no hurry.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 4 months ago
oh man…how did I miss this!!!
Awesome!
Kloepper Knife Works
Last seen: 5 years 6 months ago
RMM wrote:
Yes, and I think that its viability is questionable without some further thought.  I built one running at 5.5A and ran it quite a bit in my UF-1405.  While it didn’t burn up, somewhere along the line it lost the moonlight mode level which told me that something was starting to get fried.  I tried cranking up the PWM level and it still wouldn’t come back.  This tells me that the driver would eventually fail and that a redesign is needed if a reliable 5A+ is to be obtained.  I’m guessing that the buck IC or FET is slightly fried, but I haven’t had a chance to play with it since then.
I decided that these high-power buck drivers could really benefit from a 4-layer board, both thermally and to electrically.  A standard Eagle license is pretty expensive, but for me my time to learn a new program (KiCad) that can do 4-layer boards for free would be more expensive than the money paid.  I don’t need multiple schematic sheets or autorouter, so it wasn’t too ridiculous, but it still wasn’t cheap.  I designed a new 4-layer board with a lot more thermal transfer capability which I’m hoping will do the trick.  They just shipped so hopefully I’ll get around to trying one next week.
First off, good luck with the move. I hope everything goes well. Secondly, I’m very excited to hear that you think you can get it to 5A reliably with the new board and some time investigating. If you end up getting it to the point where you’re happy I promise to buy them if you put them up for sale. They’d be perfect for insane XP-G2 builds.
Just got my first boards assembled and tested from your batch with the masking issue. I think I’m going to like using guppydrive from now on, it’s going to save having so many divers around with different programming that I have to keep track of.
Keep up the excellent work you’ve always displayed here, this place truly wouldn’t be the same without you.
n10sivern
n10sivern's picture
I agree. BLF wouldn’t be BLF without Richard. He’s a good resource, good guy, good products, and good BLF’er.
Tom E
Tom E's picture
Last seen: 7 min 13 sec ago
Hope the 22's are available soon - great for a JAX Z1.
RMM
RMM's picture
I'll get 'em posted up soon.  They are pretty much ready to go.  I've got some sitting here.
Bosses Son
Bosses Son's picture
Last seen: 6 years 5 months ago
Hey Richard, I’ve done 4 layer in eagle. I found it wasn’t really necessary but it’s fun just to build a 4 layer board for oshpark. I learned a lot in that process. The 2 middle layers, I was dead set that I needed them. But in the end you can route around with some ingenuity and get away with a 2 layer board. The thing with osh is they don’t allow you to make connects to the two middle layers exclusively. You have to drill all the way through the board. So it’s kind of limited. Maybe another fab could do it, but found if play around enough, you can route it all on a 2 layer board.
They have the 4 layer rule file in oshpark help but you’ll need a license for eagle 6+ I believe. I would love to tell you what I do but I’m trying to keep it under wraps until finished with my project. I been working on making it smaller (no diode) and running into all the issues. Plus moving from tiny13a to better chips.
RMM
RMM's picture
I already have a 4 layer board in hand. What you're referring to are blind vias. The 4 layer board has nothing to do with routing in this case  but instead is for thermal performance.
I understand replacing diodes with p channel FETs, but there's a reason why switching converters never use one instead of the flyback diode. It's not because of cost. Do you know why?
Bosses Son
Yeah osh can’t do it.. But thermally, yeah can see your point it’s not for everyone.. There’s a lot to the thermal side of things. Your dealing with this kind of heat I don’t think any amount of copper on the board can do the trick. You have to be able to conduct it to the pill. Look to your parts, they have to be capable also. Like the tiny has 125C rated chips and check the rest. The max is fine- I mean pushing 11 amps through the fet here. The trick to thermals is getting key parts to the ring and dumping it all into the pill.. Guess doping would work too but I found it’s not needed.
The diode on mine at least is a size thing. I have to mill out some of the pill currently. The pfet is supposed to be more efficient too. I just don’t like the pfet is twice the resistance of the n. I might fit two in and see how that goes first. I’m a ways out myself.
RMM
RMM's picture
I'll get the 22mm posted up and shared tomorrow.  I've had it running in a few lights for a while.  Here's one at ~6A, using an external inductor (deep pill) into an XM-L2 (the external inductor lowers overall resistance and definitely heat in the driver).  It can also use a Coilcraft SMD inductor.  The 22mm is single-sided, which makes building the driver a little less time consuming.
DavidEF
DavidEF's picture
Last seen: 3 weeks 15 hours ago
RMM wrote:
I’ll get the 22mm posted up and shared tomorrow.  I’ve had it running in a few lights for a while.  Here’s one at ~6A, using an external inductor (deep pill) into an XM-L2 (the external inductor lowers overall resistance and definitely heat in the driver).  It can also use a Coilcraft SMD inductor.  The 22mm is single-sided, which makes building the driver a little less time consuming.
A 6 amp buck driver! I NEED one of those! Or maybe a few! :bigsmile:
- The YKK Philosophy
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 days 17 hours ago
Cool! What lights did you have it running in? Or what lights will it fit?
KB1428 “Live Life WOT
RMM
RMM's picture
That one is in an X6 clone flashlight, but I've also put it in the Supfire L3.  FYI, you can't run the newer XM-L2s at 6A. 5A or so is about it for most of them.
cajampa
Last seen: 5 years 3 months ago
What is a X6 clone? I never heard of that before & with a 22mm driver, where are they available?
RMM
RMM's picture
I bought them on closeout a while ago from a company here in the US, so I don't know where you can get them now.  They are unmarked and have a pretty decent build quality.
Tom E
Tom E's picture
5A is fine for my use - planning on driving a de-domed XP-G2 - on single cells, just can't get any amps out of them - Vf is way too high. So the 2 cell buck might be ideal.
cajampa
Ok, and because you use your buck driver in it, i assume they are a X6 clone but with a 2 battery body. So are you going sell some of those in your shop soon?
They sound like an interesting candidate for a XHP build for example Wink
RMM
RMM's picture
No, I am not going to sell them.  I can't get these anymore because they were a closeout item.  I bought them to use as some test lights.  I would use an L3 before these because it takes 26650s.
KawiBoy1428
RMM wrote:
That one is in an X6 clone flashlight, but I’ve also put it in the Supfire L3.  FYI, you can’t run the newer XM-L2s at 6A. 5A or so is about it for most of them.
Yeah I know. I poofed a few on the Super Driver remember? But I have some oldy but goody xml2’ U2’s that work. What about the XPL’s, they should do fine?
RMM
RMM's picture
Added the 22mm boards to the OP.
Tom E
Tom E's picture
Ordered the 22's - now I just got to figure out parts.
RMM
RMM's picture
Just an update on the 4-layer 17mm board:  Ran it in my UF-1405 for about an hour straight on high at 5.5A with no step down and it didn't die, so it is probably about ready to be released.  I'll probably clean up a few things on it then release it. Measuring the MAX and FET with a thermocouple it is obvious that the 4-layer board conducts the heat away from the critical components better than the 2-layer board.
n10sivern
n10sivern's picture
So is this a new board just for higher current or a replacement for the 4A one too?
