17mm/22mm MTN-MAXlp - Low-Profile 1A-4A Programmable Buck Driver + 22mm MTN-MAX
227 posts / 0 new
RMM
RMM's picture
MRsDNF wrote:
Can the 22mm version of this driver be used with an electronic switch?
Yes, if it is programmed to use one.  The quiescent current drain isn't super high (lower than zener mod), but it still isn't ideal for use as a momentary driver without a lockout of some sort.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
ImA4Wheelr
Last seen: 1 month 4 days ago
I finally read this thread since back when the OP was just getting built.  Exciting driver for sure.
Have you let the laser folks at LPF know about this driver?  I think it would get a lot of attention.  They spend big money on drivers that don't seem nearly as nice as this one.  Especially considering the ability to customize the UI.
Does 4 layer mean thicker copper in one layer or 4 separate layers that are isolated from each other for more tighter layout of components?
MRsDNF
MRsDNF's picture
Last seen: 2 months 4 days ago
Thanks RMM. I was going to use it in conjunction with a tailcap switch so it would be locked out. Its a little late now though as the driver is in the mail somewhere. I should of asked the question at the time.
ImA4Wheelr
^ I imagine you could wire a momentary switch to the Reset Pin (Pin 1) with just about any FW.  I don't know if the OTC feature will work that way though.
RMM
RMM's picture
It would work, except that you can't even hardly see that pin on that MCU unless it is specifically broken out.
RMM
RMM's picture
I haven't talked to anyone at LPF about the driver.  Honestly, I don't know much about the laser diodes and what specific requirements they may have.  I know that they are expensive devices in comparison to our LEDs.
The Oshpark 4-layer boards are the same thickness (1 oz.) on the outside layers, and half thickness (0.5 oz) on the inside layers.  The advantage is that you can run a complete pour in the middle layers to take better advantage of thermal vias by using the vias to spread heat directly to the copper in the middle layers which can then more easily transfer the heat into the fiberglass PCB and to the exposed copper around the edges of the driver.  I had drivers that were dying after extended use with the two layer board that are still kicking despite lots of extended full power runs without a timer in the same light at the same power level with otherwise the same components.  With my thermocouple I measure a 10C-20C difference in the component temperature and a corresponding increase in PCB temperature.  I wanted to build a driver that was tough enough to handle lots of use and abuse as long as it had a decent thermal connection to the pill--it had better, given the price of the components alone.
ImA4Wheelr
^ I haven't been active at LPF in quite some time.  I'll post a link to this thread over there and also to your complete build product page and just tell them I don't know how well it would work with most laser diodes, but it sounds promising.  It does sound interesting.  I have a couple laser diodes I've been wanting to use.  I will probably use this driver for them.
Not sure I understand the 4 layer thing, but I sounds like a very good thing.  Thanks for developing it.  Definitely the way I will go when I get or make one of these neat drivers.
Well, hopefully MRsDNF will have enough of the board's contact pad exposed to solder a thin wire to.  Momentary switches can use very thin wires.
MRsDNF
MRsDNF's picture
When I get the driver I'll have a look and see if I can nut out what you guys are talking about. Thanks for the help.
RMM
RMM's picture
OK guys, here is the 4-Layer PCB at Oshpark; from MTN.
Parts kit.  The parts needed are the same, except I can only recommend using Coilcraft XAL6060 inductors at these drive levels and there are 2x diodes instead of one.  The second diode basically just heatsinks the first, but it works.  The second input capacitor is optional.  After reflow, fill the exposed copper on the FET's drain pad with solder for increased thermal conductivity and decreased electrical resistance.
pilotdog68
pilotdog68's picture
Ordered.
RMM
RMM's picture
Here are some pictures for those you looking to build your own.  The regular (non-HP) version is pretty much the same, so you can use these to guide you with it as well.
bibihang
bibihang's picture
Last seen: 17 hours 2 min ago
Thanks once again Richard!
eebowler
eebowler's picture
Last seen: 3 weeks 1 day ago
Wow that looks like a tough build!! Smile
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
ImA4Wheelr
Hey folks.  RMM added a parts kit for the 4-layer board.  Pretty excited about this little buck that could so I had to order.
pilotdog68
Remember if you order the parts kit it isn’t an SOIC8 Attiny, so it’s a little harder to flash. I made the mistake of ordering the mcu bare
KawiBoy1428
KawiBoy1428's picture
Last seen: 9 hours 3 min ago
What would one’s “Ideal build” be with this driver? Host? LED? Battery config? Looking for some idea’s?
KB1428 “Live Life WOT
RMM
RMM's picture
KawiBoy1428 wrote:
What would one's "Ideal build" be with this driver? Host? LED? Battery config? Looking for some idea's?
UF 1405.  That light rocks with a good driver in it. 5A constant current until the two 26650s are dead.
KawiBoy1428
Thanks Richard, sounds like a winner!! Wink
kyfishguy
kyfishguy's picture
Last seen: 1 week 21 hours ago
This driver is awesome in the 1405.  I've been playing with one of RMM's four layer buck drivers set at five amps in a 1405 for a couple months now and the driver has held up flawlessly.  The four layer MTN MAX combined with a dedomed XM-L2 in the 1405 lights up the treeline out back of my house at 500 yards easily.  I'm guessing it will do twice that range but I haven't confirmed that.  I've also put one of RMM's two layer MTN MAX drivers at 3.5 amps into a mini mag running triple XP-Ls.  That was a cool little light.
KawiBoy1428
SOLD! Wink Got one on the way! :bigsmile: Tend to dig lights that ROCK!!!! 8) Oh it should really ROCK with the XP-G2 S4 2B de-domed!!!
Kloepper Knife Works
Last seen: 5 years 5 months ago
You should see about 480kcd out of a 1405 with an S4 2B at 5 amps. Ask me how I know. Wink
bibihang
bibihang's picture
That’s cool! I am waiting for my parts from Richard to arrive but I am going to push the dedomed S4 2B at “only” 4.5A for reliability concern. How much candela would you expect at 4.5A?
I don’t know, maybe 425-450kcd.
johny723
Last seen: 1 week 3 days ago
could you take some long distance beamshots of that white laser ??? I would love to see what this driver can do in a 1405!
I’m using a different, lesser quality 5A buck driver. I have yet to do one of the MTN-MAX drivers, but performance should be the same/similar.
pilotdog68
I’m building my kit now. I think I’ve figured it out by process of elimination, but “CMAX” is the Buck IC bypass, right?
RMM
RMM's picture
pilotdog68 wrote:
I'm building my kit now. I think I've figured it out by process of elimination, but "CMAX" is the Buck IC bypass, right?
Correct.  Make sure you get the thermal pad on the buck IC reflowed fully.
pilotdog68
oh…
lol wish I had read this before I just soldered the thing into the pill
pilotdog68
I think I’ve got it working, but next time I’ll just order the completed driver. I can deal with all the caps and tiny resistors, but I hate these components that have the pins under them.
shrick
shrick's picture
Last seen: 3 years 2 months ago
I have the c682 coilcraft inductor. At the bottom it has 2 contact plates on each side and a black pad in the centre. I presume the black pad is the termal pad? Richard mentions one has to reflow the thermal pad? On the pcb underneath the black/thermal pad theres silkscreen, no place for reflowing? What is meant by reflowing the thermal pad of the inductor to the pcb?
