Noctigon DM11 high CRI middle range thrower available
4370 posts / 0 new
Hank Wang
Last seen: 5 hours 26 min ago
Pavlo wrote:
Hank, when will the DM11 be released?
Hopefully, it should be before November, 15.
The LEDs options are SST-20, XP-L HI, Osram W1/W2, XHP35 HI, SST-40, SFT-40 (not LED stock for now), B35AM R9080 (2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K)
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Scallywag
Scallywag's picture
Last seen: 37 min 30 sec ago
ToyKeeper wrote:
Depending on how things go, however… I might have to add a chimney. This would allow the DD FET to be used by itself on one channel for a special 1-channel turbo mode. Ironically, this would also be the mode most likely to produce smoke.
Thanks for the laugh.
Changes are looking great, I gotta get some pogo pins now.
Gunga
Gunga's picture
Last seen: 2 hours 3 min ago
So when will the tint ramping D4v2 be available?
Hank Wang
It’s up now, you can also request the same configuration for other D4V2/KR4 materials.
https://intl-outdoor.com/tint-ramping-instant-channel-swiching-led-flash...
Gunga
Gunga's picture
Thanks! I ordered it! Wooo!
Btw. Does one control the switch LED with anduril too?
Hank Wang
Thanks, the swich LED is controled by UI as well, just like the one in the D4V2 TI.
RamBull
Last seen: 3 days 8 hours ago
Any chance you will make a dual channel for the DT8?
Is it possible to go W1 on one channel and LH351D 5000k on the other? Thanks, Hank!
Pavlo
Last seen: 5 hours 19 min ago
The LEDs options are SST-20, XP-L HI, Osram W1/W2, XHP35 HI, SST-40, SFT-40 (not LED stock for now), B45AM R9080 (2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K)
Looking forward to this, thank you.
What kind of driver will the 3V LED’s be using?
DrDevil
DrDevil's picture
Last seen: 1 hour 54 min ago
ToyKeeper wrote:
John Deez wrote:
Has this changed?
  • User can choose tint-ramp or tint-toggle. It’s in the hardware-specific config menu (Advanced mode Off 9H).
So it seems this new function is implemented in the new D4V2 and KR4 – right?
From the description: “Anduril 2 firmware, user choose the tint ramping or instant channel switching, Advanced mode Off -> 9H, first menu item: 0C: tint-ramping (smooth) 1C: instant channel switching 4 LEDs can be on at the same time with full power.”
https://intl-outdoor.com/new-emisar-d4v2-with-tint-ramping-and-instant-channel-switching.html
ArtieT59
ArtieT59's picture
Last seen: 2 hours 57 min ago
Hank Wang wrote:
Hopefully, it should be before November, 15. The LEDs options are SST-20, XP-L HI, Osram W1/W2, XHP35 HI, SST-40, SFT-40 (not LED stock for now), B45AM R9080 (2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K)
nice!! I'm much more exited now for this!
also- b45am ?? Oooohh, is that 4 x e21a?? Sorry all of these Nichia models  are new to me.
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
thefreeman
thefreeman's picture
Last seen: 5 min 49 sec ago
Yes, same die size as E21A but 4 of them on a 3.65×3.65mm package, with less phosphor around the dies so less angle tint shift (more uniform beam), limited to 4A (6V).
Edit : didn’t see the typo, it’s B35AM.
trakcon
trakcon's picture
Last seen: 1 hour 33 min ago
No B35?
tactical_grizzly
tactical_grizzly's picture
Last seen: 3 hours 48 min ago
No B35?
B35 is the whole last 2 lines of that post
ArtieT59
ArtieT59's picture
tactical_grizzly wrote:
trakcon wrote:
No B35?
Above, i asked about this and The Freeman responded, it's a typo. I thought the B45AM was another, different Nichia LED i had not heard about. Just a typo from Hank apparently. LOL
Pavlo
A DT8 with 2000k + 5000k e21 tint ramping model would be so cool!
cowboygg
Last seen: 4 days 17 hours ago
Thumbs Up
John Deez
Last seen: 2 days 23 hours ago
TitaniumDust wrote:
John Deez wrote:
I like my KR4 e21a. I wish it had a lower low, and slower ramping, especially at lower lumens. I struggle to get a good lower setting for reading because it ramps too fast. Has this changed?
Did you set your lowest ramp to 1? It’s a default of 3 out of the box, and needs to be set to 1 to enable the moon light level. I don’t think it’s possible to go lower than the light level of 1 on this driver. Although I actually find the level 1 setting to be very nice on the e21a LEDs.
Are you talking about the original KR4 driver or Anduril 2?
Rayoui
Rayoui's picture
Last seen: 2 hours 49 min ago
The driver hardware is the same and the default ramp settings are the same between the A1/A2 versions. Newer A2 versions have dynamic PWM to slow down the ramp speed at lower levels but you still need to manually set the ramp floor to level 1.
LifeXventure
Last seen: 1 day 14 hours ago
What are the differences of these 2?
anduril.2021-11-03.emisar-d4sv2-tintramp.hex
anduril.2021-11-03.emisar-d4sv2-tintramp-fet.hex
tactical_grizzly
One has FET drive enabled for channel 1. It’s for K9.3, where there are enough emitters on channel 1 that FET drive won’t fry them.
The other one doesn’t have FET drive enabled on channel 1, and it’s for the 2 channel variants of D4V2, D4SV2, and KR4.
Edit: I am wrong. TK has weighed in below.
LifeXventure
Thanks but both the above firmware are listed for D4SV2 tintramp model where else the K9.3 have its own FET and non-FET variants.
ToyKeeper
ToyKeeper's picture
Last seen: 11 hours 5 min ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
For anyone wanting to update or modify the firmware on a light they have… read the README file to figure out which flavor to use. It’s not very long. Here’s a copy of what it says:
|How to figure out which .hex file to use
|1. Use the version check function to find out which flavor of the
|   firmware the light shipped with. It should blink out a date and maybe
|   a 4-digit number after the date -- YYYYMMDDNNNN.  Write this down.
|   Version check is 15 or more clicks from off.
|2. Match up the 4-digit NNNN number in the MODELS file.
|3. Find the newest firmware for that model.  You may need to scroll down
|   to reach the newest files.
|If the version doesn't include a model number, it's older, but you could
|still look up the model in the PRODUCTS file to see which version it
|probably uses:
|  https://bazaar.launchpad.net/~toykeeper/flashlight-firmware/anduril2/view/head:/PRODUCTS
The full list is in the MODELS file. Here’s a quick summary of a few…
Regular single-color lights:
  • 0113 emisar-d4v2: D4v2 with a FET+1 driver (DD FET + 350mA linear)
  • 0114 emisar-d4v2-219: Same, but with DD FET power reduced.
  • 0115 emisar-d4v2-nofet: Same, but with DD FET disabled completely.
  • 0133 emisar-d4sv2: D4Sv2 with a FET+3+1 driver (DD FET + 1.05A + 350mA linear)
  • 0134 emisar-d4sv2-219: Same, but with DD FET power reduced
  • 0211 noctigon-kr4: 5A (or 7.5A or 9A) linear channel plus DD FET
  • 0212 noctigon-kr4-nofet: Same, but no DD FET
  • 0213 noctigon-kr4-219: Reduced DD FET power (Nichia 219C)
  • 0214 noctigon-kr4-219b: Reduced DD FET power (Nichia 219B)
Two-color tint-ramping or tint-toggle lights:
  • 0135 emisar-d4sv2-tintramp: D4Sv2 and D4v2 two-color driver with two independent linear channels (9A+9A or 5A+5A or 9A+5A or whatever is appropriate for the LEDs)
  • 0136 emisar-d4sv2-tintramp-fet: Same, but with a DD FET added to channel 1. Not usually necessary.
  • 0215 noctigon-kr4-tintramp: Like the D4/D4S tint-ramp build, but modified for KR4 hardware. Not compatible because switch is on a different pin.
K9.3 is still being sorted out. It currently uses a tint-toggle-only build which uses some weird custom code, so I need to integrate it into the main tint-ramp code for future maintainability.
  • Tint toggle only:
    • 0261 noctigon-k9.3
    • 0262 noctigon-k9.3-nofet
    • 0263 noctigon-k9.3-219
  • Tint ramp (can also toggle, but doesn’t have single-channel turbo):
    • 0265 noctigon-k9.3-tintramp-nofet
    • 0266 noctigon-k9.3-tintramp-fet
    • 0267 noctigon-k9.3-tintramp
Those last 3 need to be merged into the 3 before them, instead of having 2 complete sets.
LifeXventure
Thanks TK
toobadorz
toobadorz's picture
Last seen: 6 hours 46 min ago
Any plan for stepped tint-ramp? Smooth tint-ramp is interesting, but to more easily reproduce a preferred tint, a stepped tint-ramp mode will be pretty useful too.
SammysHP
SammysHP's picture
Last seen: 20 min 34 sec ago
Already suggested that a few hours ago in the IRC channel. Could be done in the tint ramping config menu. Instead of “ramping or toggle” it could be:
- 0 = smooth ramping
- 1 = tint ramping disabled, always 50/50
- >1 = n steps (2 would be toggle like previously)
tactical_grizzly
I love this idea. I’ve been wanting precisely this on an LT1 for months.
JaredM
JaredM's picture
Last seen: 1 hour 5 min ago
What are the dimensions of the mcpcb?
https://fundrazr.com/osturaband
No affiliation, just a fan.
Slim Pickens
Slim Pickens's picture
Last seen: 43 min 19 sec ago
Any word on whether E21A will be an option for tint ramping? I’d love to do a 3500k / 2000k…
bartekreaper
bartekreaper's picture
Last seen: 1 day 9 hours ago
Hello, any problems with manufacturing? Or delayed because of SFT-40? Maybe you can make SBT90.2 version in meantime Smile
Keys: Flashlight S11 MOD, Lumintop GT Nano, Astrolux LT1, Astrolux K2, Manker E02 II, Manker E03H II
Full: Jetbeam RRT01 XP-L HI, Fireflies PL47MU, Fireflies PL47G2 2021 XP-L HI, Emisar D4V2TI RO1 XP-L HI, D4V2TI RO2, XP-L HI Emisar DT8 XP-L HI, Emisar D4V2 LH351D+W1, Emisar D4SV2 LH351D+W1, Noctigon KR4 XP-L HI+Nichia, Noctigon KR1 SBT90.2, Noctigon DM11 SFT40, Lumintop ODL20C V2, Fireflies E07 XP-L HI, Fireflies E07 2021 XP-L HI, Armytek Wizard Pro Max WW, Emisar D18 X-PL HI, Noctigon K9.3, Niwalker ES2 (lot of modules), Weeltool W4, Fenix LR40R modded XP-L HI tint mix+W2, BLF LT1 v6, WildTrail WT90, Amutorch DM70 4000K, Imalent MS18W
ArtieT59
ArtieT59's picture
I think Hank should release a "s" version of this exact light (DM11s), that has a reflector, and sbt90.2 LED
LOL
