OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
1173 posts / 0 new
Tom E
Tom E's picture
Last seen: 3 hours 5 min ago
Jerommel wrote:
luminarium iaculator wrote:
*I also don't see any issue using WF1mm with FET DD single 18650 setup.*
And then you go on describing the somewhat ambiguous solution to resolve the issues... I mean, you choose to over drive the LED up to 5.5.Amperes on a freshly charged cell, which doesn't even add output anymore. Sorry, but i just don't get it. It's not as if there are no proper CC drivers out there.
Where can I get a 21 mm or 28 mm CC driver at 5.5 amps running decent e-switch firmware like NarsilM or Anduril with as low, or lower parasitic drain? I do really want to know because I can't keep up with all the goin's on.
I'm confused because since when is a 17 mm power switch driver the only one we need? Granted, it's the most popular but for my usage, it's still in the small minority of flashlights I have or am interested in.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 min 6 sec ago
I have (2) 2S 3v17mm 4-4.5amp Mtn. Max drivers and a 22mm 2S 3v 5.5amp Mtn.Max driver I’m looking for a Push Button Host(s) for…any Ideas?
KB1428 “Live Life WOT
contactcr
Last seen: 7 min 2 sec ago
blueb8llz
Last seen: 2 days 14 hours ago
contactcr wrote:
https://maxtoch.com/maxtoch-x-pro-p0025.html
Ooh nice! Awesome host. I wish it had the choice to choose small tube for single 21700 like the size of acebeam t27.
Jerommel
Jerommel's picture
Tom E wrote:
I also don’t see any issue using WF1mm with FET DD single 18650 setup.
And then you go on describing the somewhat ambiguous solution to resolve the issues… I mean, you choose to over drive the LED up to 5.5.Amperes on a freshly charged cell, which doesn’t even add output anymore. Sorry, but i just don’t get it. It’s not as if there are no proper CC drivers out there.
Where can I get a 21 mm or 28 mm CC driver at 5.5 amps running decent e-switch firmware like NarsilM or Anduril with as low, or lower parasitic drain? I do really want to know because I can’t keep up with all the goin’s on.
I’m confused because since when is a 17 mm power switch driver the only one we need? Granted, it’s the most popular but for my usage, it’s still in the small minority of flashlights I have or am interested in.
Yeah, you’re right.
Limited choice.
Not sure what Lexel has to offer though.
As for diameters, you could use an adaptor ring of some sorts.
Either way, i’m looking for e-switch 17mm FET CC drivers.
I don’t care too much for elaborate UI’s though.
3 modes usually suffices for me.
LouieAtienza
Last seen: 1 year 3 months ago
Wow, 995 available at only $9999…. I better place my order soon….
contactcr
I mean those are nice drivers he mentioned. It wouldn’t be right to recommend something less than $9,999
KawiBoy1428
Nice 2×21700’s hope they come out with it soon… robo…
Pic stolen from the Maxtoch site… by me…
erik
erik's picture
Last seen: 6 months 4 days ago
@BobbyMk: What driver are you using
BobbyMK
BobbyMK's picture
Last seen: 3 days 7 hours ago
Qlite 3.04A with added 3 7135 chips and biscotti fw.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
erik
erik's picture
Thanks!
Anthon
Last seen: 12 hours 12 min ago
I’ve built a C8+ with ld-A4 at 5A and white flat 1mm
I need to tune the centering ring heigh but at the moment I’m getting 211kcd nearly 920m
Is there any similar build? I’d like to compare them and also know how many cd should I expect
Lexel
Lexel's picture
Last seen: 1 month 4 days ago
I will work on D1S and likely some other sizes CC FET drivers, but this will take 5-6 weeks at least to get to production if first design works out well
Jerommel
Jerommel's picture
I’ll start saving money for you, Lexel.
There are some other drivers i want from you too.
netprince
Last seen: 36 min 1 sec ago
Same, I’ll buy one or two for sure.
Nicolicous
Nicolicous's picture
Last seen: 8 hours 43 min ago
Did you measure the beam with a lux meter at what distance then convert to candela?
Nico -.-
Anthon
Yes, 3300lux at 8 meters
Tom E
Tom E's picture
What CC FET driver design? Think someone (TA?) did one? Wondering, not sure, if parasitic drain was considered.
Bo4ka
Last seen: 2 months 2 days ago
I’m very impressed. My C8 (BLF A6 DD, NCR18650B) is easily hitting houses at 800m distance(measured with Google maps). That’s the holy grail of LEDs for throwers.
Can’t imagine how the D1S will perform.
190kcd for the c8 measured at 10m.
EasyB
Last seen: 39 min 39 sec ago
Put a white flat 2mm^2 in an Emisar D1S. I wanted to add some resistance to the circuit so I could use the FET driver and limit the current to 6-8A. Switching the springs to high resistance steel would work if you had the right size springs. The battery compartment length is very tight on this light so it would have to be the right spring. I chose to add a separate resistor in the head of the light. I figured I would need to add about 0.1Ohms to limit the current enough with a 30Q cell. The resistance would dissipate around 4W. There is a good amount of room in the head to put the resistor. One could probably use the right combination of 1W resistors in parallel, possibly using thermal adhesive to sink them to the head so they don’t overheat. I chose to use something I had around, some 16 gauge nichrome heater wire. Two inches or so of the nichrome wire has about 0.1Ohms. A difficulty with this wire is that you can’t solder to it. To attach the stranded copper wires I lashed them together using fine gauge magnet wire.
Using a clamp meter I measured 6.0A with a charged (but old) 30Q. Ideally I would have wanted closer to 7.5A, so I might shorten the resistor. I used a XM sized “butterfly” style centering ring that fit the emitter hole of the reflector, then I just fiddled around closing the bezel until it finished centered. I had to add two layers of Kapton tape under the centering ring to get the focus right. I measured 221 kcd. This intensity measurement is consistent with the measurement of this LED at the same current in the EE X6 (111 kcd). This reflector has right around 2x the frontal area (I estimate 1270mm^2) of the EE X6 reflector (~620mm^2). It’s always satisfying when things make sense. Smile
luminarium iaculator's picture
Last seen: 12 min 35 sec ago
EasyB,
That all is if you insist on using high current cell with fet and WF1mm… Low current cell like LG 18650D1 even in mod with classic bypasses wont pas 5.7A and without bypasses wont pas 5.5A
But of course very creative idea.
Samsung 30Q and other high current cells are only good for old G2 S4 2B (which is still one of my favorite emitters).
Edit: Just saw that is WF2mm… OK… Not bad idea indeed Thumbs Up
DavidEF
DavidEF's picture
Last seen: 6 hours 2 min ago
Yikes! EasyB, please be careful with that thing! Shocked
- The YKK Philosophy
F.i.l.a.s
F.i.l.a.s's picture
Last seen: 4 weeks 1 day ago
EasyB,
what light meter do you use? Generally I have read about inconsistency of cheap light meters, so I don´t know still what to buy.
Henk4U2
Henk4U2's picture
Last seen: 3 hours 40 min ago
IF member A, and member B, and you, and me all had identical lights (model, cell, led, driver) and held this in fromt of the same model luxmeter we would have four different outcomes. Because there are too much variables to consider. Fresh cell’s, topped-off cell’s, waiting 30sec (yes/no), distance from light to meter, etc.
The only outcome that is reasonably accurate is the difference before/after mod of each individual member.
If you say it is +15%, that can be 13% as wel as 17%, but it is still more reliable than comparing the outcome of member A after his mod with that of member B before his mod.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Djozz once measured that UNI-T UT383 in comparison with mobilux one and told me that uni-t under reads for about 15 % de domed XP-G2 S4 2B and I think Djozz or someone said that same light meter could easily over read White flat emitters because of tint or hue I am not sure…
If that is true than theoretically except better tint of WF1 (well for mine use kinda greenish warm tint of G2S42B is better), no need for de dome, better run time there is no much difference between them. G2 is still more suitable for FET drivers and has larger die so greater hotspot in aspherics.
But if I just check side by side same light with different emitters(g2 vs wf1) without lux meter it seems that WF1 throws further but I can’t give real values (around 15% for sure).
I just want to say that even cheap lux meter like UNI-T UT383 will serve well to tell you where you are with your build.
EasyB
Ha, well actually it was not the safest setup. I was not thinking quite enough and put the resistor on the positive side of the LED which left the possibility of shorting the battery if the anodization wore through at the head and at the battery tube-to-head threads.
I shortened the resistor some and put it on the negative side to reduce the shorting risk. Start current with the same charged 30Q is now 7.0A which should get me an extra 8% or so of output. Ceiling bounce test puts it at very approximately 1400 lumens OTF (83% of a dedomed XPL V6 at 6A from a EE X6).
I use a Tondaj LX 1010B lux meter.
Lexel
Lexel's picture
1700 OTF lumens from a dedomed XPL cant be right
Agro
Agro's picture
Last seen: 4 days 11 hours ago
I’ve been thinking about this recently….
Member A to member B comparisons are really bad. We’re all over the place.
See this:
http://budgetlightforum.com/node/63397
GT Mini is 106-170 kcd (without outliers 106-145)
Manker U21 is 79-127 kcd (without outliers 96-127)
Utorch UT02 is 60-105 kcd (without outliers 75-105)
Thrunite Catapult V6 is 151-195 kcd (there are no outliers)
I wonder if the recent djozz’s research into lux meters and maukka’s calibration sets will improve the state of affairs….I surely hope so.
nottawhackjob
Unless an inexpensive luxmeter is cross-verified by other more expensive (read currently calibrated/certified/industrial/commercial/professional grade luxmeter’s) I don’t trust the reading by anyone’s single luxmeter to be accurate. Not even my own inexpensive single luxmeter.
Of course I might be more inclined to believe any poster’s reading if let’s say three different brand luxmeters were used identically during the test and then their results were compared and THEN were averaged. I might kinda have more trust in that averaged reading. Grad
Just too many people using different apparatuses, distances, setups, and other sundry uncertified tweaks and inherent nuances in the instrument itself, much less the skill/competence of the operator, for true accuracy reliance on my part. JMO. Shocked
“In many things in order to truly understand the small picture you have to understand the big picture first.”
EasyB
You’re probably right. Maybe it’s more like 1500-1600 djozz lumens. In any case the performance of this CSLPM1 is great.
