OSRAM CSLNM1.TG 1mm, CSLPM1.TG 2mm, CULNM1.TG 1mm
930 posts / 0 new
likevvii
Last seen: 2 hours 51 min ago
If you have one of maukka’s calibrated lights (he sells them), he also includes the lux measurement. I asked him and he says he places it on a mount 1m away from his lux meter. So you could compare your lux meter to a calibrated light at 1m too!
My lux meter reads 3% lower than maukka’s readings.
Yokiamy
Yokiamy's picture
Last seen: 7 hours 7 min ago
I have comparable lights which are similar to maukka’s lights, we have conversated about it before, my readings are very close.
But still, let’s say it has a deviation of 10%, @5540 Lux on 10m would still make it 5000 Lx or 500kCd
  BLF
The_Fat_Controller
The_Fat_Controller's picture
Last seen: 6 hours 18 min ago
Yokiamy wrote:
The_Fat_Controller wrote:
well for an Extra 5$ jax will supply you a bare pill with it… Either way its done now White flat & 14× 7135.. fitted Its ok but it still cant rival the crelant Sad
Beam size is the tiniest smidgen tighter than a nightmaster nm400 but the lens is way better quality
A picture is worth more than a thousand words Wink
Beamshots (tonight) please
Sorry it took so long….
Mod’s
66mm Lens (takes shimming to focus) but has a shorter 25mm FL
Driver (requires 20mm to 22mm adapter)
You do have to drill & tap the body, as stock emitter is just pasted with a plastic retainer
DavidEF
DavidEF's picture
Last seen: 1 week 3 days ago
Shocked Shocked Shocked
- The YKK Philosophy
Yokiamy
Yokiamy's picture
Thanks FC! Very nice build, impressive and beautiful beamshots!
  BLF
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 5 hours ago
TFC that is 500 plus KCD light for sure Thumbs Up
The_Fat_Controller
Thanks guys , I’ve done my best with it, maybe someday i will get my paws on a collar for it Evil
it’s certainly worth keeping an eye out for these older crelant models there are still some floating about new.
That said I’d really like to see Convoy produce some aspheric hosts Love
Sirius9
Sirius9's picture
Last seen: 6 hours 6 min ago
I have several Crelant lights (5 or 6) and have always considered them of good quality.
If you can get your hands on 7T40 with white flat you can get a really good small form factor thrower light.
The_Fat_Controller
Sirius9 wrote:
I have several Crelant lights (5 or 6) and have always considered them of good quality. If you can get your hands on 7T40 with white flat you can get a really good small form factor thrower light.
Not seen that one, but it looks pretty similar to the V6CS that i just grabbed with the SCH86 head basically a small version of the one above the stock driver also puts down nearer to 3.5A which is nice
Sirius9
Sirius9's picture
7T40 has about 15% deeper reflector, produces very sharp beam.
The_Fat_Controller
Anyone tried a Green Flat in one of these?
Sirius9
Sirius9's picture
I have this one in C8+.
If you shine it on the wall you notice that led is rectangle and not square but I also have the one you mentioned just didn’t put it in the host.
trailhunter
Last seen: 5 hours 36 min ago
Is 6A for CSLNM1.TG too high?
djozz
djozz's picture
Last seen: 5 hours 50 min ago
In a flashlight build almost certainly yes. Led4power found a maximum at 6A but it was a bare led with maximum active cooling. My bare led test did not even find 6A max but 5A.
So my best advice would be 4.5A, in a very well cooled build maybe 5.
Btw, see the OP of this thread, interesting read.
trailhunter
Thanks! I need to add a lot of resistence to get down to that
The_Fat_Controller
I’ve found no detectable gains after 4.5amp for either CSLNM1.TG or CULNM1.TG in a flashlight, neither turn angry blue nor do they get any visibly brighter to the eye either IMO you’re just wasting amps after that point
There maybe a VERY TINY increase between 4.5 & 5 in a chunky host like the L2 with a CULNM1 but im not sure if it is just wishful thinking on my part
A lux meter may say different but you certainly won’t see it with your eyes
trailhunter
Thank you, need to go with a battery that can add more resistence I think. I’ve extended the wires considerably and went with a longer spring and it dropped some but not by much.
Is it common to go with a 22-24 guage wire from driver to mcpcb to get more resistence?
The_Fat_Controller
What driver are you using?
trailhunter
MTN-17DDM
http://www.mtnelectronics.com/index.php?route=product/product&product_id...
djozz
djozz's picture
You could add an actual resistor in the circuit. I never used them yet but I bought some 2512 resistors for that purpose that can be glued somewhere inside the driver cavity with arctic alumina adhesive. Link.
The_Fat_Controller
MTN-17DDM
Im not certain but you maybe able to turn that down a little . could be worth dropping them an email
Edit: just looked at the manual and it looks like if its attiny13a you can program custom levels
trailhunter
MTN-17DDM
Ah interesting, they are at25. I’ll keep mucking with resistence then, thanks for dropping in!
Sirius9
Sirius9's picture
We really need to find better names for this leds, when you say XPL HI 4B you know exactly which led is that but CSLNM1 and CULNM1! are we talking about whit leds, green!!!
Yokiamy
Yokiamy's picture
Generally they’re known as ‘white flat 1mm2’ and ‘white flat 2mm2’
  BLF
Sirius9
Sirius9's picture
White flat 2mm2 is CSLPM1.TG, and was not mentioned above!
CSLNM1 and CULNM1 are both 1mm2 if I am not mistaking!
The_Fat_Controller
CULNM1.TG is a higher power version of CSLNM1.TG (3.2A vs 3A) its still 1mm2 but they are now discontinued and getting tricky to find. I’ve also not been able to find them in the higher bins only 5q which im not convinced is better than a 6n CSLNM1.TG.
CSLNM1.TG 6N at 3a makes 840 – 945Lumens
CULNM1.TG 5Q at 3a makes 710 – 800Lumens
But CULNM1.TG can stand higher currents when overrun , there are detailed tests on the start of this thread.
I’d really like to get my hands on some CSLNM1.TG 7N’s or CULNM1 6QF’s if anyone knows a guy please drop me a message Smile
Yokiamy
Yokiamy's picture
Drat, it even confuses me.
Maybe we should mention the footprint when talking about white flat.
  BLF
trailhunter
Do they all have the same power requirements?
Yokiamy
Yokiamy's picture
The 2mm can handle more current and performs best at 8~9A. the 1mm performs best between 4,5~5A
As said, the 4040 version can handle more heat because of its surface.
  BLF
