FW3A Troubleshooting / FAQ
1465 posts / 0 new
Atom00
Last seen: 3 weeks 6 days ago
Anyone play around with the Group 2 – Strobe mode.
I can only go into the strobe mode for 1 time only after i received this light. I cycle from candle > bike flasher > party strobe > tactical strobe > lightning storm > off.
Problem : after that i click, click, hold it just respond by dim flash once and turn off by itself.
reinsert the battery still the same problem. dim flash once and turn off by itself.
Phaze13
Light Arrived but does not work.
Had to leave home and took it with me.
Order with battery, assuming the battery arrived with partial charge. Will try another battery when I get home.
Removed tape from negative side of battery and reinserted.
When screwing on the head the light blinks twice, after first blink there is about a full rotation and it blinks again. At this point it is fully closed with no gap.
Retaining ring seems to be in place, will not budge with pliers either direction.
Tail cap is screwed tight no gap. Button click feels good.
Symptoms:
Light doesn’t turn on.
Click tail button does nothing.
Hold tail button for 3 or more seconds, light blinks upon release.
Haven’t seen these symptoms posted yet. Any ideas? Besides verify battery.
Thanks
teacher
teacher's picture
@ Phaze13
Try cleaning the threads.
Go HERE . Read it, do what is says again, also look at the driver to make sure it is seated correctly. Thumbs Up
Phaze13
Cleaned threads, nothing to find. Driver seems seated however I can’t budge the retaining ring. Certianly not loose.
Still same symptoms, not working. Sad
teacher
teacher's picture
Sad ….. Take the tailcap apart & see it there is a ‘nubbin’ in it.
If you need it, you can go HERE and find info on tailcap disassembly & ‘nubbins’. Thumbs Up
Phaze13
The nub is there, tail switch feels like its working.
teacher
teacher's picture
Sad .. Wow…. Sad
The only other thing ‘I’ can think of is…. take off the head & look at the end of the black inner tube. It should be clean & shiny with no anodization. Give that end a good wipe with a rag, put the head back on & try it.
Phaze13
Guess the low operating voltage of the FW3A is higher than the Emisar D4.
Battery that worked (emitted light) in the D4 didn’t work in the FW3A.
The battery ordered with the flashlight (Sony VTC6) didn’t come with enough of a charge.
Coincidentally the battery (LG HG2) that was working in the D4 was low enough not to work in the FW3A.
Charged batteries over night, all good now.
Only other batteries I had charged last night were protected cells which as stated don’t work.
Thanks for the help.
teacher
teacher's picture
You had not charged the battery?? Facepalm
For future reference… batteries do not come charged. They usually arrive around 3.4 V to 3.6V
Nev
When my fw3a was working it worked right up to when the lvp kicked in ,it should work with a cell at 3.2-3.4v.
Phaze13
When I put it on the charger it read 3.2 & didn’t work.
hank
hank's picture
Last seen: 1 hour 13 min ago
Quote:
it can turn on an off without me.
RFI? Set an AM radio to the noise between stations and walk around your house listening for noise sources, many LED and CFL light bulbs are great producers of Radio Frequency Interference. You may have a “buzz” signal from something nearby. And you may also pick up a burst of electronic noise when a flashlight driver operates, if it’s not well designed to avoid creating RFI.
Electronic waves are simiar to ocean waves in that several waves can combine to create a “rogue wave” or a strong electronic signal spike momentarily.
I’ve noticed fairly often that using a ham or GMRS/FRS “walkie talkie” radio triggers various motion sensor lights around the house, and I once had a neighbor’s car alarm trigger just as I walked past it while using the radio.
It’s not just me: https://www.google.com/search?client=firefox-b-1-d&q=ham+radio+motion+se...
https://www.reddit.com/r/amateurradio/comments/7qg9ta/motion_sensing_lig...
It might be worth reviewing the FCC’s “shall not cause interference/shall not be overly sensitive to interference” testing for the electronics.
teacher
teacher's picture
Not surprised it didn’t work. But all’s well that ends well. You’ve now got a super clean, checked out, & working FW3A out of the deal.
All for the price of charging the battery…. Wink . Thumbs Up
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 17 min ago
FWIW, the light should work until the battery gets down to 2.9V or so, because that’s where LVP activates. It technically should still light up even as low as 2.6V, but it’ll shut itself off pretty quickly to avoid hurting the battery.
Brightness gets lower and lower as the voltage drops, in a pattern which should almost exactly match the Vf curve of the emitters being used. Everything used in the FW3A should light up at least a little at 2.9V though.
teacher
teacher's picture
Phaze13 said his would not work at 3.2 V, any idea why? Just curious… ??
Nev
It wasn’t the battery that was causing the problem probably.
teacher
teacher's picture
Good point. Quite possibly the correct answer. Either the battery was not really at 3.2 V, it was much lower; or during the multiple takedowns he inadvertently ‘fixed’ whatever was not tight or lined up properly.
cabfrank
Last seen: 10 hours 42 min ago
The inadvertent fix is my favorite fix.
“How did you fix it?”
“I took it apart, put it back together, and it worked.”
“Great!”
Firelight2
Firelight2's picture
Last seen: 3 hours 19 min ago
Maybe a combination of the battery and the 1×7135 channel chip being bad?
With a depleted battery the light should turn on in low. I assume if the battery is low enough only the 1×7135 channel is activating. If that 7135 chip is not functioning, perhaps you end up with a situation where the light stops working at slightly higher voltage than it should.
teacher
teacher's picture
“Great!”
I agree, in some situations…. lucky trumps good. Wink . Thumbs Up
Alumenator
Alumenator's picture
I received my FW3A yesterday. Fortunately everything seems to be working well. The UI took a bit of playing with to get figured out. It definitely has some awesome features (candlelight and lightning storm)
Mine does have one odd thing though. When in smooth ramp mode, starting at moonlight, it seems that it has more blinks than it should. It blinks just above Moon, at Max Regulation, a bit before Max Ceiling and at Max Ceiling or Turbo. So 4 times, although just after Moon is very subtle.
If I have the Max Ceiling at 130 instead of 151 it will only blink once at the top of the ramp to signify Max Ceiling.
This doesn’t bother me, and it might be normal. Just haven’t seen it mentioned.
I know my D4 blinks only at Max Reg and at Turbo.
Pending
clip.
Last seen: 1 year 4 months ago
Finally received my two XP-Ls, and am sorely disappointed. One doesn’t work at all, and the other is stuck on turbo from the second the threads make contact. I’ve tried swapping components between the two, tightening the tail first and then head, loosening and retightening the driver retaining rings.
hank
hank's picture
Quote:
I’ve tried …
Don’t forget to try compressed air, to blow out any chips of metal left in delicate spots.
clip.
Just completely disassembled and reassembled each light and took my time swapping a single component at a time between each body. It looks like the problems follow the heads – the neutral white always goes on instantly to very bright/very hot and the warm white hasn’t turned on at all. In addition, I compared the two switches. One seemed a uniform brassy/yellow color and the other looked silver with a bit of Kapton tape to insulate. The Kapton tape version definitely sucks, with an almost undetectable click whereas the brassy color has a nice tactile click and a little more movement.
Very unhappy with Lumintop’s QC at the moment.
teacher
teacher's picture
@ clip.
Can you please post a picture of your two switches side by side??
I love to get a look, especially at the “brassy color one”. By what you said it does not have the Kapton tape??
TIA….
JasonWW
JasonWW's picture
Last seen: 3 hours 30 min ago
Default – as you ramp up from moonlight, the first blink signals the change between the single 7135 channel and the 7 × 7135 channel (about 125-130 lumen).
Then the next blink signals the change between the 7 × 7135 channel and the FET channel which is also the top of the normal ramp (about 1000 lumen).
If you have changed the top of the ramp to full power, then I guess you will get an extra blink to signal the end of the ramp. I don’t think most folks have changed the ramping levels, I haven’t, and that’s why no one has mentioned it.
Hopefully TK can confirm all this.
BTW, TK ran a poll for the FW3A to see how many blinks people wanted and where. This is why it’s unique.
Keep in mind the D4 uses a very different UI and was custom made for Emisar.
Henk4U2
Henk4U2's picture
Last seen: 1 hour 35 min ago
I can read you already checked a lot, but ….. have you checked if the drivers were properly aligned?
And not inconsequential: my FW3A only works properly if I screw in the body into the head with mild force.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
clip.
Henk4U2 wrote:
I can read you already checked a lot, but ….. have you checked if the drivers were properly aligned? And not inconsequential: my FW3A only works properly if I screw in the body into the head with mild force.
I’ll double check the driver alignment but I did back the rings out, confirm the driver flats hit the notches, and tighten the rings again. I have noticed the driver on both lights looks to be printed slightly off so the switch contact ring isn’t concentric with the head, but it looks similar to others I’ve seen and the switch tube will still make contact at two points at least.
joechina
Last seen: 1 week 4 days ago
Alumenator wrote:
I received my FW3A yesterday. Fortunately everything seems to be working well. The UI took a bit of playing with to get figured out. It definitely has some awesome features (candlelight and lightning storm) Mine does have one odd thing though. When in smooth ramp mode, starting at moonlight, it seems that it has more blinks than it should. It blinks just above Moon, at Max Regulation, a bit before Max Ceiling and at Max Ceiling or Turbo. So 4 times, although just after Moon is very subtle. If I have the Max Ceiling at 130 instead of 151 it will only blink once at the top of the ramp to signify Max Ceiling. This doesn’t bother me, and it might be normal. Just haven’t seen it mentioned. I know my D4 blinks only at Max Reg and at Turbo.
Every thing is fine with your light.
1th blink
right at moonlight is a little timing hint to release the button to stay in moonlight.
Many have a hard time to notice it.
2th blink
signals the change between the single 7135 channel and the 7 × 7135 channel . At level 65
3th blink
signals the change from the 7 × 7135 channel to the FET channel. At level 130
4th blink
end of ramp blink. You see this when you set the ceiling higher than level 130
The reason 3th and 4th blinks are so close together is the ramp is very steep at the end.
The Emisar D4 Firmware is based on NarsilM and blinks different than Andúril
Atom00
Help needed here. I can’t go into strobe mode now. PM Neal already, while waiting his reply maybe someone in here have the solution.
