This is about programming a driver yourself with all the modes you want; just like Tido's thread "How To Build a Flashlight With Perfect Modes (picture heavy)". It got quite lengthy, so I started a new one for my driver program.
I finally found the time to program my own driver. After playing with the three pocket XM-L lights in the last week I found it good enough to publish it here.
It has less features than Tido's, so it leaves room for improvements (meaning that there's indeed quite some free space left to do so). It doesn't have any battery monitoring yet.
It implements sixty545's UI(post #254), which after some testing I found very nice. Gives you lots of modes without the need to cycle through all of them when switching between the favourites. Leaving the light on for only a short time (<2s) and the switching it off again will bring you to the next mode when you switch it on again. Leaving it on for longer will memorize this mode for the next time; but if you change modes again it will start from the first mode in the mode order. If you put your favourite modes to the front, this is a quite nice UI I think.
Current modes are moon-medium-high- 6 levels of brightness -strobe-beacon-timer.
As a special mode I added a 5-minute timer - partly for fun, but I do need a 5-minute timer relatively often.
One of the PROs of this driver is the wide EEPROM wear leveling; writes are spread over 32bytes, and only 1-3bytes are written each time the light is switched on. A ramping mode might be feasible that way.
It is supposed for/tested on the NANJG 105C (2.8A) and NANJG 101-AK (1.05A+) drivers using AMC7135s and the ATtiny13A micro-controller.
Tido's thread mentions everything you need, so here's a short version:
- Driver: NANJG 105C or NANJG 101-AK or similar
- Programmer for flashing the program to the controller: there seem to be some available for 4$ on ebay (search for "avr programmer").
- a clip for contacting the controller, search for "soic8 clip" at ebay
- Software: I use AVRstudio4 with WinAVR
The driver program is just a C file; you could create a new project for the ATtiny13A using the wizard and then just copy&paste the contents into that projects C file.
Since I am very sensitive to PWM (I easily notice 2kHz PWM...), I meanwhile use a CPU frequency of 4.8MHz with a PWM frequency of 9.4kHz, difficult to notice even if I want to That means a low fuse of 0x75 (and I use a high fuse of 0xff) and the lowest usable PWM value is 5. Shorter PWM pulses are too short to activate the AMC7135s.
UPDATE: luxdrv 0.22 with ramping
I implemented ramping, have played with it for a while and found it nice, so here's the new version officially:
Standard modes are now (can be easily changed of course):
moon - medium - high - ramping - use selected level - strobe - beacon - timer
Tapping the switch while ramping will select that level. The ramp is actually 25 levels 'only', so you can see it stepping up&down. Brightness doubles about every 5 steps (the darkest levels are spaced a bit wider).
I also implemented sixty545's idea of skipping the 1st mode when starting over after already being in 1st mode. Also changed the wear leveling method; it writes even a bit less bytes now, but it does write 25 bytes per ramp, so you probably shouldn't use that for hours (~700 writes per EEPROM cell per hour).
UPDATE: luxdrv 0.30 - added battery monitoring
I implemented battery monitoring:
- When the battery (under load) goes below ~3.0V, the light automatically steps down in brightness (halves the output); the reduced load usually gets the battery voltage above 3V again. When it falls below that threshold agan, output will be halved again - and so on.
- Beacon mode has a battery indicator: Before actually starting beacon mode, a number of (low intensity) blinks indicates battery level (without load), ~12 blinks is full, ~5 blinks is nearly empty. It's about one blink for every 0.1V over 3.0V (cell voltage *without load*).
- Note that those values are not accurate due to production variances in the microcontroller's internal voltage reference.
Update: luxdrv 0.30b - improved config, const progmem, no dummy any more, timer removed, 4 main modes as default
Driver download links:
luxdrv 0.1
luxdrv 0.30b, added battery monitoring
