NarsilM - configurable e-switch firmware for Multi channels, v1.3
513 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 1 week 1 day ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
joechina wrote:
Lamp list round up, to what I know:
This is like a todo list of people/projects to follow up with to make sure the code remains open.
Tom E
Tom E's picture
Last seen: 10 hours 8 min ago
Yeah, I emailed Neal to please post source code links for the GT and GT Mini. Sounds like he's gonna do it right away. There's definitely more. Even Hank at IOS should have links on each flashlight page - think he has it only on 2 of the 5 pages.
This is crazy it's taken off, took a while though. Haven't been keeping up with it, but Andúril should probably be used in place of it. Not sure though, don't think you got the switch LED support in there? But after all, Andúril was the one that saved Middle Earth from the Dark Lord smile.
ToyKeeper
ToyKeeper's picture
Tom E wrote:
Not sure though, don’t think you got the switch LED support in there?
Switch LEDs and front-facing aux LEDs are both supported, though not at the same time. Just one or the other. The only difference is whether it should be on at the same time as the main emitters.
During standby, the aux/switch LED can be high, low, off, or blinking. And for a Q8 or GT, with a lighted button, it also goes high/low/off during use, in sync with the main emitters. Usually I set the low-high threshold at the same point as the 7135-to-FET transition, so it indicates which power channel(s) are active.
Tom E
Tom E's picture
Ohhh, dang! Forgot bout that, think I heard or saw it posted. Wow! Not sure then if NarsilM does anything at all better... crysmile
I got some flexibility in it now to support combos of output channels, but Andúril probably has that covered better.
ToyKeeper
ToyKeeper's picture
From what I recall, Narsil was originally built around its mode group UI, giving the user a configurable and carefully-chosen set of discrete levels which hit the sweet spots of each host light, and a fast way to click through them. That is the core; everything else was added later.
Anduril doesn’t have anything like that. There’s a stepped ramp, but it’s totally different than how Narsil works.
ImA4Wheelr
Last seen: 4 months 1 week ago
ImA4Wheelr wrote:
Thanks WTF.  Saw that too, but the 7135 channel isn't working.  I'm think I have eliminated potential hardware issues (faulty 7135, connections, etc).  So I wondering if the hex file may be using different channels than what the documentation indicates. I'll reexamine hardware again tonight.  I may have to build my own hex file if I still can't find a hardware problem.
After several driver rebuilds, changes, fuse changes, etc, I just about gave up when I found the problem.  The LED I was using to test the driver was the problem.  It was an old, abused MGT2 that wouldn't turn on until current hit about 720mA.  Once on, I could ramp down all the way.  Once I swapped in 2S XPG3's, the driver worked great.  So much time spent trying to fix a perfectly fine driver.  Oh well, lesson learned.
MRsDNF
MRsDNF's picture
Bugger. Glad you found the problem. Beer
WTF
Last seen: 12 months 1 day ago
ImA4Wheelr wrote:
ImA4Wheelr wrote:
Thanks WTF.  Saw that too, but the 7135 channel isn’t working.  I’m think I have eliminated potential hardware issues (faulty 7135, connections, etc).  So I wondering if the hex file may be using different channels than what the documentation indicates. I’ll reexamine hardware again tonight.  I may have to build my own hex file if I still can’t find a hardware problem.
After several driver rebuilds, changes, fuse changes, etc, I just about gave up when I found the problem.  The LED I was using to test the driver was the problem.  It was an old, abused MGT2 that wouldn’t turn on until current hit about 720mA.  Once on, I could ramp down all the way.  Once I swapped in 2S XPG3’s, the driver worked great.  So much time spent trying to fix a perfectly fine driver.  Oh well, lesson learned.
I understand that frustration completely. I’ve become pretty good at killing Lexel’s new high performance fets, those things don’t like voltage spikes. Accidentally deleting a comma in the Narsil ramping table has the same effect. So much time wasted when you guess wrong and focus on the wrong thing.
Things like this are why I’m going to wire four 5mm leds to a programming clip. One for power and one for every output channel, plan to bring the switch pin out as well as a test point. Easy to put a meter on an output to check for shorts.
Once you see each led turn on dim and go up to maximum intensity you know the Attiny is working correctly and you’re down to a few output devices to troubleshoot.
ImA4Wheelr
WTF wrote:
. . .I understand that frustration completely. I've become pretty good at killing Lexel's new high performance fets, those things don't like voltage spikes. Accidentally deleting a comma in the Narsil ramping table has the same effect. So much time wasted when you guess wrong and focus on the wrong thing.
Things like this are why I'm going to wire four 5mm leds to a programming clip. One for power and one for every output channel, plan to bring the switch pin out as well as a test point. Easy to put a meter on an output to check for shorts.
Once you see each led turn on dim and go up to maximum intensity you know the Attiny is working correctly and you're down to a few output devices to troubleshoot.
Clever.  That is a great idea!
d_t_a
Last seen: 8 hours 26 min ago
I have a question about the stepped ramp for Anduril.
Is it linearly spaced (numbers percentage) or more like the visual brightness spacing (like in the BLF A6 which has evenly-spaced modes, which I believe were adjusted manually) ?
ToyKeeper
ToyKeeper's picture
This thread is for NarsilM, but there is an answer in another thread:
http://budgetlightforum.com/comment/1369731#comment-1369731
ImA4Wheelr
Does the GT version hex file drive 2 PWM channels in tandem or is there a difference between the two channels?  Twp pins individually produce moonlight and appear to ramp fully from low to high, tubo, etc.  Are both channels producing the same PWM signal?  If not, what is the difference between the 2 channels?
Separately, really love NarilM.  So much genius in it.
ToyKeeper
ToyKeeper's picture
The GT driver has one pin to control the constant current circuit’s current level, and one pin to turn it on and off. For the top 90% of its power range, it’s set to “on” (255/255) while varying the power level. For the bottom 10%, it’s PWM’d at 10% power.
ImA4Wheelr
Thank you TK.  Very good info.  Was looking at the circuit for the GT driver just a bit ago and saw both pins feeding the buck converter.  One via a voltage divider with a cap and the other directly connected.  Might be able to use the hex file for a FET only driver for the time being.  Having trouble building a solution on my own and want to move on with the build.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 months 4 weeks ago
I have recently translated Sofirn's manual for the new SP36 into German language. This flashlight comes with NarsilM 1.2. Since more and more native speakers ask for a German version I thought it might be good idea to share the translation of NarsilM here and on TLF (German flashlight forum). Sofirn agreed upon this plan, too. Before actually releasing it to the community - are there any constraints like copyright, licensing agreements etc. I need to consider. What would be the best format to share it? I could provide it directly into this or a new thread or I could also provide a link to a pdf-file.
Let me know what you think. Smile
Cheers,
Thomas
P220C
Last seen: 10 months 3 weeks ago
With NarsilM on the Lumintop GT Micro, is there a way to leave the e-switch locator led on while the main LED is on? It can be hard to find in the dark.
Tom E
Tom E's picture
Sorry, no unfortunately. I really wanted to get it implemented as a feature though. My GT Micro's switch LED is pretty dull though - not sure how well it would show up with the main LED on.
WTF
What is the latest version of Narsil?
Where can it be downloaded?
Tom E
Tom E's picture
WTF wrote:
What is the latest version of Narsil? Where can it be downloaded?
Still V1.3 - I've still be using it often.
I just posted my latest v1.3 source code here: https://drive.google.com/open?id=1i42GnkD6LBvxEK3_fiZVdrZsFkNuLZsU
Let me know if you can access it ok. If you are used to building NarsilM, I got a ton of Setups.h files that Iv'e used. You have to carefully go thru things and make sure you pick a proper setup config to use, then tweak as you like. Please check the Rev History.txt file carefully for the most recent changes.
WTF
Thanks Tom, got a message about a network error but it downloaded fine.
P220C
Thanks, Tom!
It’s pretty stellar UI.
Tom E
Tom E's picture
 laughing cool
ToyKeeper
ToyKeeper's picture
Tom E wrote:
Still V1.3 – I’ve still be using it often.
Thanks. I updated the copy in my repository to this version.
d_t_a
ToyKeeper wrote:
10/15/2017
That OTR M3 is an awesome light to put Narsil on. I’m hoping that someday we can make a BLF clone of the Olight S-Mini with one of our custom drivers. It’s like the OTR M3 but even smaller, and getting it to run a BLF driver with fancy e-switch firmware would make it one of the best EDC lights ever made.
Was just reading random parts of the message thread and came across this. Is there some already some Olight S-Mini clone with e-switch firmware?
JasonWW
JasonWW's picture
Last seen: 10 hours 5 min ago
There is Olight S1 clone with e-switch firmware, but not S-Mini.
L4M4
L4M4's picture
Last seen: 1 day 13 hours ago
Hey hey people
Just got my Astrolux FT03 today – the end of the ramping is not the maximum brightness – but I don’t want to have a turbo-mode, I want that light to ramp up to it’s full power like I can with Anduril.
Since this is my first NarsilM driver – is it possible, too?
didn’t find it in the manual though
Thanks!
ZozzV6
ZozzV6's picture
L4M4 wrote:
Hey hey people
Thanks!
No you can’t change ramping floor and ceiling in Narsil
L4M4
L4M4's picture
OK thanks.
WalkIntoTheLight
Last seen: 11 months 6 days ago
I think older versions of Narsil had the ramp ceiling equal to max output. My BLF Q8 seems to work like that. But the FT03 uses a more recent version of Narsil. I guess they changed it for some reason.
ToyKeeper
ToyKeeper's picture
NarsilM had the ramp ceiling separated from the turbo level during development of the BLF GT. The GT works really well at 2.0A, but not at the full power of 2.5A. It can’t keep the output flat for very long at full power. So the ceiling was set to 2.0A, with an extra 2.5A turbo level.
This is configured at compile time though… it’s not a user-configurable option.
