[Big news, see OP!] Sofirn SP10S "BLF edition" with Andúril 2
945 posts / 0 new
Tom E
Tom E's picture
Last seen: 26 min 39 sec ago
Though it may be safe for the cell, still seems weird not to have any notification because if the boost chip drops out, I would think the light just turns off with no notice.
lukehale
Last seen: 4 days 22 hours ago
Intersted. Definitely want a “non-ano” version.
JermsMalibu
Last seen: 1 day 9 hours ago
If it has nimh support and not just li-ion, I’m interested.
moderator007
moderator007's picture
Last seen: 4 months 6 days ago
gchart wrote:
Tom E wrote:
I see on other AA boost designs that LVP is supported only for the 14500, not the lower voltage batts, so could be a technical limitation, maybe?
Most boost chips only operate down to 0.9V (typical) or 0.7V. So LVP is probably only needed for the 14500.
If I remember right the PAM2803 boost IC that alot of these AA lights use drops out about .7v shuting off the light. It does kind of give a warning at around .7v where the light output is getting really dim before shut off.
I’m kind of wondering if going that low might be a problem for the mcu.
cri baby flasher
Last seen: 1 year 1 month ago
Interested. Would love to see Andruil ui or some kind of ramping os in a blf version of this light. Would be the ultimate carry if it could also work on nimh AA, but I would still buy if only 14500.
Tom E
Tom E's picture
Just fyi, Lexel and gchart are actively discussing and working on a design that's Atmel based so we can run Anduril on it.
JaronRH
Last seen: 3 days 14 hours ago
Tom E wrote:
Just fyi, Lexel and gchart are actively discussing and working on a design that’s Atmel based so we can run Anduril on it.
Awesome!
hodor
hodor's picture
Last seen: 17 hours 6 min ago
Thanks for the update Tom E. I presume this will be li-ion only then.
MascaratumB
MascaratumB's picture
Last seen: 3 min 51 sec ago
Hum, not knowing anything about electronics, wouldn’t that go “against” the whole concept of this “project”? Oops
gchart
gchart's picture
Last seen: 1 hour 16 min ago
No, the design being discussed retains AA compatibility.
MascaratumB
Thank you for clarifying gchart! And thanks for your efforts (= all the people involved in this project!!!) !!
hodor
hodor's picture
Oh Thumbs Up
OldSkol
Last seen: 8 hours 55 min ago
Interested really depends on what cells it accepts.
Love my Anduril lights
moderator007
That’s great news gchart and thank you for helping carry on the project. Do you know if the boost ic has been picked?
Is it the PAM2803 or something different?
gchart
gchart's picture
moderator007 wrote:
That’s great news gchart and thank you for helping carry on the project. Do you know if the boost ic has been picked? Is it the PAM2803 or something different?
There’s been a bit of talk back and forth on the overall design. As it currently stands, I think the plan is to keep most of the driver the same, just replacing the PIC with an AVR and a little rewiring to make the new connections. A couple minor tweaks are being looked at. Things like the boost IC don’t have any planned changes to my knowledge.
moderator007
Thumbs Up
If it isn’t broken why fix it, compatiblity though is a good thing.
roostre
Last seen: 10 hours 17 min ago
I am curious if the design will retain Andúril's (three clicks from off) "battery voltage blink-out" or Andúril's (built-in) "low voltage protection for Li-ion batteries".
All the "AA/14500" compatible lights I am aware of do not have built-in low voltage protection in order to allow operation with the lower voltage AA batteries and recommend only using protected 14500 Li-ion batteries because of this.
I do not mind using protected Li-ion batteries, but would sure miss being able to check the Li-ion battery's voltage while the battery is still in the light in order to determine the approximate remaining capacity.
Thanks to all those advancing this project towards a successful reality.
How many flashlights does a "real man" need?
None, real men are not afraid of the dark.
Lexel
Lexel's picture
asdqqq wrote:
If possible, it would be great if the driver had the flashing pad things like on the Emisar lights. It’s great to be able to easily keep the firmware up to date.
early design process putting it together, still not final design or prototype stage now
oto
oto's picture
Last seen: 3 weeks 17 hours ago
Interested!
RD
Interested.
Sorry for my bad English.
Tom E
Tom E's picture
Haven't checked it myself yet, but just went thru the Sofirn listings and written reviews and can't find anything on LVP. I think I've seen LVP for 14500's but not for AA's in other AA/14500 boost driver lights.
Also the clasp seems to have problems as pointed out by "Lick" here: http://budgetlightforum.com/node/71509. We should address this with Sofirn.
asdqqq
Last seen: 11 hours 51 min ago
Tom E wrote:
Haven’t checked it myself yet, but just went thru the Sofirn listings and written reviews and can’t find anything on LVP. I think I’ve seen LVP for 14500’s but not for AA’s in other AA/14500 boost driver lights.
Also the clasp seems to have problems as pointed out by “Lick” here: http://budgetlightforum.com/node/71509. We should address this with Sofirn.
Don’t most boost drivers stop working at a safe voltage for NiMH cells even without any LVP programmed in? Something like .7 to .9 volts? Or is that only for AA only boost drivers?
Tom E
Tom E's picture
I dunno - thought I saw a driver that said it had LVP for the 14500, but not for the AA/NiMH -- not sure where.
asdqqq
Simon said that about the new drivers for the Convoy T2. But I think at least most boost drivers need a certain threshold voltage to work that would serve as a de facto lvp for AA cells. I could be wrong though, and it might depend on the particular components. -edit My kids have an SP10S with a Ladda in it that they use until it stops working. I’ll check the voltage next time before I charge the battery.
gchart
gchart's picture
This is true, most boost controllers only work down to 0.9V or sometimes 0.7V.
So while LVP may technically not be needed to protect a NiMH, it’s still nice to have a warning before things shut down.
As it is currently designed, I don’t see any reason why LVP and battery check can’t work for AA / NiMH. There’s a 300k / 100k voltage divider hooked up to a 1.1V VREF. That means the theatrical effective reading range is 0 – 4.4 volts.
iamlucky13
Last seen: 9 hours 19 min ago
Thanks for sharing the driver layout progress! Glad to see there is serious work happening with this concept.
Tom E wrote:
I dunno – thought I saw a driver that said it had LVP for the 14500, but not for the AA/NiMH — not sure where.
There’s a new version of the Convoy T2 that adds 14500 support. Either the controller can run on AA voltage, or the boost circuit is active all the time, because Simon said its low voltage protection prevents operation from 2-2.8V.
The Armytek Pro UI for their AA lights is a little different. You can choose to turn lithium-ion LVP on or off. If it is on, it will give you approximate lithium ion battery state indications by colored lights in the button (green, orange, red), and low voltage protection. If it is off, I think it gives those indications for AA batteries, but will only show green for 14500.
There is a slight oversight in the fact that you can turn on the Armytek LVP while an AA battery is loaded, and be stuck there until you have a way to give it 3V and turn LVP off again.
lukehale
I would also very much like a magnetic tailcap (at least as an option, like how they now have the deep carry clip available). The sp10s with the LH351D (dedomed/sliced for me), with Anduril, deep carry clip, and a magnetic tailcap, using the Shockli 1000mah 14500s, but with the ability to use AAs if needed, in a Non-Ano (or clear ano), would be my ideal AA size edc light.
asdqqq
Thanks for the heads up on those deep carry clips. I hadn’t seen those and added a couple to my order for the C01R.
I personally don’t like a magnet on my EDC, but a removable magnet or optional magnetic tail cap like they do for the SC31b would be nice.
roostre
asdqqq wrote:
... I personally don’t like a magnet on my EDC, but a removable magnet or optional magnetic tail cap like they do for the SC31b would be nice.
I understand why people appreciate magnets in lights but would also rather have a choice.
I do not carry magnets on my person or in any bag that my wallet may end up being in after one erased some of the magnetic strips on my credit cards (it took a second occurrence before I figured out what was causing the issue) and they also alter the reading and accuracy of your compass even from quite a distance away (but this is only a problem for people who use maps and compasses).
lukehale
Yeah, I certainly wouldn’t demand a magnet be the default, I am 100% fine with that being a separate extra cost when ordering. I just want the option to be there, basically. The deep carry clip I would really just like a choice when ordering since they have them available, instead of having to pay extra for that separately.
