BLF Community Battery Pulls Overview Thread (Laptop packs and Tool Packs)
374 posts / 0 new
ChibiM
ChibiM's picture
Last seen: 11 hours 39 min ago
Thanks Downlinx for doing that.
I know it can be time consuming once everyone is pouring down their data in this thread Wink
anyway, I ordered another pack (same as last time).
and today I bought a Dell pack (they said it was new, but voltage was very very very low) now charging
Illuminaria
Last seen: 4 years 9 months ago
very very very low? My NOS Sony 2200 were at 2.xxxx volts but charge with capacity very near rating.
ChibiM
ChibiM's picture
Yes, below 1v.
They quickly climbed and after some minutes they were above 3v
Almost finished charging.
Tomorrow I will do a discharge and check capacity, and keep an eye on them.
aoeu
aoeu's picture
Last seen: 3 weeks 6 days ago
The price for these are good and they’re listed as genuine and new. Only thing that concerns me is they’re for a model which is very dated now. It’s for an Acer TravelMate 3200 which is from 2004. So these batteries are at beast from around 2005/6? That would make them pretty old. What do you guys think?
http://www.ebay.com.au/itm/201049142717?ssPageName=STRK:MEWAX:IT&_trksid...
Dru_dragon
Dru_dragon's picture
Last seen: 1 year 3 months ago
9 Sanyo 2400mah? , I think the 8 Samsung 2800mahs are a better deal.
I’ve pulled out packs from laptops released in ’06 and they still show 90%, so I wouldn’t worry too much about age.
Andrew
aoeu
aoeu's picture
Yeh that’s probably the case. I was going to go pickup but realised Kingswood is about 8 days walk from my place.
Illuminaria
Were the 2800’s local or internet buy?
Cheers
aoeu
aoeu's picture
Australian seller unfortunately. I assure you the US has 100x better laptop deals. You’re not missing out.
ChibiM
ChibiM's picture
I got another pack as my first one, and the same batteries were inside, about the same capacity as well.
The other pack, DELL had about 2000 in them. They were sanyo green tops, called ...xx18650x........I forgot the name.
downlinx
downlinx's picture
From Dchomak’s post Here with his permission i posted in this thread and also updated the list.
dchomak wrote:
This is my biggest find yet. A 40V Ryobi power tool pack.
This pack looks brand new, and it could very well be. I find lots of new packs in the bins that are probably placed there because they sat on a shelf too long and self discharged to a point that a charger would not “see” them. Another reason could be that it contained a defective cell, or maybe a defect in the protection circuit built into each one of them.
This battery has a charge indicator built into it.
Pressing the test button will indicate the state of the charge.
In this case, the pack is half full!
I wonder what kind of cells are inside? Some of you may have already noticed the sticker in the first pic and have done the math.
Boy, this thing sure does look brand new!
4 screws and the top comes right off
There they are, Samsung IMR 18650s, but what capacity and how many?
Turns out they are 13Qs, (1300 mAh)
Count them if you can, there are 20!
I don’t know what to do with this pack. Normally I would check it out and perhaps put it into service. If that was not possible I would harvest the cells that are good. In this case I have no way to test the pack. It could be that it will not accept a charge or it could be that it will not output to a tool. As I neither have the charger or the tool, I can’t test it. The cells are good, that I know, but it would be a shame to destroy a good pack just to harvest the cells. So for now I will just put it aside.
It just happens that I do own a 24V version of this line, but that doesn’t do me any good here. That pack contains the same cells, only there are 12 of them in the pack instead of 20.
BTW, here is another example of this 40V pack torn down by someone else and they opened it up to find 10 – LG LGDAHB21865s. 10 – 21865s not 20 – 18650s. Go figure.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
LanWolf
LanWolf's picture
Last seen: 1 year 6 months ago
Just pulled appart a Fujitsu Siemens pack BTP-C1K8 , 11.1v 4400 mAh
It came from a defect lapop, probably main board defect. (wouldn’t turn on)
it contains 6 cells, Sanyo UR18650FJ, they are 2200mAh
The sanyo labeling is very difficult to see at first, the clearly printed info on the cells lead to nothing
All 6 read 3.8v after separating.
Kept 4 out of 6, 2 of them were dented on the side and bottom.
Have them in the Nitcore charger now
/ Just a Byte /
dchomak
Last seen: 1 year 2 weeks ago
This was a new, never been used pack that I was able to tear open with my bare hands. Either I’m turning into a monster or this was an exceptionally easy pack to open. Smile
All 6 Samsung 26D cells were sitting at 2.9V and are charging now. I have no reason to think that they won’t charge up to just slightly lower than their rated capacity of 2600 mAh.
downlinx
downlinx's picture
I love the dell pc764 packs, almost always produce good 2600 or 2550 cells. I will get both of your pulls on the list. Thanks guys.
grantman321
grantman321's picture
Last week I got a Dell battery back (here: http://www.amazon.com/gp/product/B000WDRXL4/ref=oh_aui_detailpage_o00_s0...)
It had six light-blue/green colored cells in it, no brand name on the wrapper - just a bunch of numbers. Look similar to the LG's in #2 in the OP.
All six tested to 3.88-3.89 volts on my multimeter. I have no means of testing capacity at the moment. I figure the cells have to be pretty new to test with that high of a voltage right?
“We are all worms, but I believe that I am a glow-worm.” – Winston Churchill
dchomak
It had six light-blue/green colored cells in it, no brand name on the wrapper – just a bunch of numbers. Look similar to the LG’s in #2 in the OP.
That is a pack for a Dell not a Dell branded pack. The cells inside could be of lesser quality. I must say the price is right if it is to be used to replace an old worn out pack. There is no sense in spending $100+ for an original replacement for an old laptop that is on it’s way out anyway. It is probably not a good idea to buy these to harvest the cells, for that any NOS (new, old stock) genuine laptop pack from any of the major manufacturers would be better. They can be had for about the same price and will contain name brand quality cells.
grantman321
The amazon description is all kinds of wrong (says it’s for an Acer?)… the battery pack that arrived was in Dell-branded packaging and the pack itself had a Dell label on it. I figured at $11.xx with Prime shipping, it seemed worth the risk.
downlinx
downlinx's picture
That is def. a dell battery, i have torn down a quite a few of that exact model. whether it is an original dell or clone, that i do not know.
Boaz
Boaz's picture
Last seen: 11 hours 23 min ago
Asus AA2-uL50   uL5La a23
5600mah 84wh
samsung 2800  irc18650 28A sdi
4.3v light purple
                                  https://www.gty.org/
    Still selling diffuser film  >…  http://budgetlightforum.com/node/42208
izzie
I’m new to the site, but I have a bunch of these Philips packs (M4605A) out of medical equipment. They get replaced every 2-3 years regardless of use. They contain 9 CGR18650CG (MH12210) each and were exceptionally easy to pull compared to the drill packs I’ve done. Cadex charger primed the cells and all of them reached at least 90% of the rated capacity. As back up batteries they probably haven’t been cycled at all and arrive at full charge to be recycled.
downlinx
downlinx's picture
Thanks guys, list updated
downlinx
downlinx's picture
Not bad for a free battery pack on this one.
Laptop Battery
Toshiba PA3612U-1BRS
18650 Battery
6 x NCR18650 @ 2900Mah
Illuminaria
pictures of new un-welded cells. Is your pack used or old stock?
Forgot to add I have not seen this pack for less than $5 per cell…
downlinx
downlinx's picture
yea, i forgot to get pictures of the cells, I will get pics when i get home. it is old stock, i salvaged it from work.
EDIT
Wife sent me the image, i just didn’t read my email. image of cells updated
Dru_dragon
Wow they look a lot cleaner then mine :_( So much glue I had to bin the wrappers.
Taken out of Panasonic CF-VZSU46U 9xNCR18650
Andrew
downlinx
downlinx's picture
wow that does look pretty bad, but i will get the info updated in post one thanks dru_dragon
dchomak
Sorta like the picture of the BigMac and what it is you actually get!
kronological
kronological's picture
Scored these 4 battery packs at Best Buy a few weeks ago:
Here are the details on them individually:
Lenovo Thinkpad
FRU P/N 45N1027
ASM P/N 45N1026
EU Min 7740mAh
9 orange batteries, UR18650ZT R1122
Other codes on battery: Q26C, QF3ZTBD, 065413
All tested at 4.29v right out of the case! :bigsmile:
Toshiba PA3793U-1BRS
10.8V 4200 mAh
6 green batteries with black tops, CGR18650CE, MH12210
Other markings: A19 LXI, B9808, 949 (or 919) 67P EE9
Made in Japan
2 batteries at 3.78v, 2 at 3.80v and 2 at 3.81v Smile
Dell FK890
11.1V “Japan Cell”
9 Lavender batteries with black tops, CGR18650E, MH12210
Other marking: E7810
3 batteries at 4.05v, 3 at 4.06v and 3 at 4.06v :bigsmile:
Dell Ky265
11.1V
9 Pinkish/Lavender batteries
Samsung ICR 18650-26D SDI 972
3 cells at 0v, 3 at 1.4v and 3 at 2.15v Sad
Are the last 3 salvageable at 2.15v???
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
downlinx
downlinx's picture
Wow, awesome pull, you got some nice cells in there kronological.
I will get the 1st post updated.
How tough was the Lenovo battery to open?
I really like the UR18650ZT cells, only have a few of them myself.
kronological
downlinx wrote:
Wow, awesome pull, you got some nice cells in there kronological. I will get the 1st post updated. How tough was the Lenovo battery to open? I really like the UR18650ZT cells, only have a few of them myself.
The lenovo was not that bad…maybe a little tougher than the others.
The nightmare pack was an HP pack that I tore apart awhile back…sheez!
Oh…and are the CGR batteries Panasonic?
My Reviews: Ma
downlinx
downlinx's picture
Yea HP packs are a bear and the CG18650E are Panasonic’s
