BLF GT official support thread [FAQ updated 11 Jan 2018]
339 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 3 hours 42 min ago
johny723 wrote:
OT: Out of curiosity, what can we expect from future LEDs? What could be the throw and lumen output of a BLF GT in 5 years?
I am sure things will continue to march forward, although it seems most development is towards larger high output LED’s and not so much thrower LED’s.
crayton
Last seen: 1 year 8 months ago
Just got my BLF-GT!!!!
So excited… except for one thing: I only received 7 batteries!
Not sure who to talk to about this. The whole point was to get 8 matching batteries to use for this badboy!
Help?
teacher
teacher's picture
Help?
Send Neal a PM about this.
JesperW
Got my BLF-GT a few days ago. As we pretty much have have daylight all the time now in Sweden, i have not been able to test it outside yet. But I’ve tested it indoors and it worked great. A couple of times. Now not so much. I get as much light out of it as a key chain led light. I have tried the factory reset, and I can see that it ramps up from very low to only low in just about 1 second. All batteries are brand new and fully loaded. When i connect the batteries the GT flashes 2 times. What could be wrong?
JasonWW
JasonWW's picture
Last seen: 7 hours 44 min ago
This is really odd, I’ve never heard of this before.
What happens when you double click to turbo?
What battery voltage does it blink out on a triple click?
Click this to go to signature links.
JesperW
Double click gives the same as ramping up to max. Almost no light.
Triple click shows 4,3V.
Here is a smal video clip: https://www.dropbox.com/s/cln41wc3xe2poiq/IMG_2207.TRIM.MOV?dl=0 (disregard from the cat noise Smile )
Texas_Ace
Texas_Ace's picture
That is a very strange issue indeed. I would try removing the retaining clip on the driver and maybe pulling the driver out and making sure everything looks ok.
Then clean all the contact points really well and put it back together and see if the problem persists. If so then it looks like the driver is bad for some reason, it appears that the 2nd channel is not working for some reason. No idea why this would happen.
JasonWW
JasonWW's picture
Yes to what TA said. The emitter, battery and switch all look good. It seems to be driver related. I typically mess around with the driver retaining ring on lights that have “an issue” and sometimes that fixes it.
In your video I think I see the slight blink indicating the top of the ramp even though it’s not at the 2A rate.
If this where a Q8 driver with a single 7135 and FET, I’d say the FET channel wasn’t working. This is a buck driver, though so I don’t know exactly how it’s channels are divided. So I will leave all that to TA.
The fact that it was working fine and now it does this, kind of makes me think something on the driver got fried or a component came loose.
JesperW
Now I have removed the retaining ring and put it back several times. I have also looked for burnt components and bad soldering, but all seems fine, but the problem remains.
Here are some pictures of my driver:
https://www.dropbox.com/s/20zsucznhd71m1i/BLF%20GT%20Driver-1.JPG?dl=0
https://www.dropbox.com/s/ejwmz6e8yf9lu6s/BLF%20GT%20Driver-2.JPG?dl=0
JasonWW
JasonWW's picture
My best guess is that a replacement driver will fix your problems. Have you ever replaced a driver before? You already know how to remove the driver, it’s just a matter of soldiering 5 wires to install a new one.
This is the cheaper fix for lumintop and the one I’m sure they would prefer. Otherwise they may have to ship out that entire middle section of the light which costs a lot more and probably takes longer to ship.
Let’s see what Neal or TA says.
JesperW
I have not replaced a driver in a flashlight before, but I have quite good soldering skills, so I can’t see any problems (except for the short wires) doing it.
JasonWW
JasonWW's picture
Now that I think about the pictures Neal posted a long time ago, the drivers already come with the switch soldered in place. Once you loosen the switch retaining ring, there are notches that allow the switch to slip through the hole quite easily.
So it’s really just the two emitter wires that need to be soldered.
JesperW
Thanks!
It should not be any problems soldering it like this Smile
Edit: Fixed the URL for the picture.
JasonWW
JasonWW's picture
Yeah. Let’s see what TA or Neal says.
Texas_Ace
Texas_Ace's picture
I am guessing a new driver is the best option for you, there is a small possibility that the LED could be the issue but it is small.
Do you have a bench power supply by chance?
Anthon
Last seen: 1 hour 58 min ago
is it possible to buy a glass lens for my GT? mine is damaged
JesperW
No bench power supply, but I have a lot of other power supplies. What voltage and amps do I need to test the led?
Texas_Ace
Texas_Ace's picture
It was not the last I checked as it is very hard to ship them without them breaking. If you are in the US, there is a place that makes custom sized lenses for a reasonable price. I forgot the name though. Maybe someone else knows?
Texas_Ace
Texas_Ace's picture
Not ideal but you could try a 12V power supply, amps should not really matter for the second you will actually use it. Just be careful to get the polarity right, it will kill the LEd if you get it backwards.
I would just manually put voltage to the LED / LED wires to ensure that the LED is not the problem. There is a small chance it could of died, I have seen them act kind of like this but it is very rare.
Anthon
I’m in Spain. EU
Well protected inside a hard box, it should arrive in good condition…
Texas_Ace
Texas_Ace's picture
Anthon wrote:
I’m in Spain. EU
You can contact Neal about it, he should be able get you a replacement since yours is damaged. I have tried to get them to offer the lenses for sale to the public but they said shipping was too hard for that.
AlexGT
AlexGT's picture
Last seen: 18 hours 13 min ago
For the glass you might want to try
https://www.flashlightlens.com
But it may be expensive to ship to Spain.
AlexGT
AlexGT's picture
What is the size of the GT lens?
By the way, I noticed that in the specs post at the beginning of this thread there is no specified diameter for the GT lens, can someone update that information please?
Thanks!
I found this glass that might fit the GT (Not sure about the size)
https://lwgx.en.alibaba.com/product/60520097833-803746005/Diameter_125mm...
djozz
djozz's picture
Last seen: 19 min 38 sec ago
I plan to eventually replace the glass lens for a polycarbonate lens (cut out a round from a sheet from the DIY shop). Close to the same light transmission (when it is new at least Wink ) and no need to be careful with the GT after that Smile
Luisr170
Luisr170's picture
To team giggles: interested in buying the giggles flashlight...! The BFL - GT
LUIS RIVERA
JasonWW
JasonWW's picture
Luisr170 wrote:
To team giggles: interested in buying the giggles flashlight…! The BFL – GT
It is for sale on Lumintops website.
Sale link
There are many options.
M4D M4X
M4D M4X's picture
Last seen: 2 hours 10 min ago
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
BC4Lyphe
Last seen: 1 year 1 month ago
I got my GT awhile back but havent used it much since its 24/7 light out in Alaska nowadays. Anyways theres a blemish on the reflector. Is there any way to get it fixed?
Texas_Ace
Texas_Ace's picture
Is it just a small bump? It should not effect the performance of the light so I would not worry about it personally.
If you really want a replacement they should be offering a limited time option to buy a spare reflector from the GT70 group buy
http://budgetlightforum.com/node/61334
Although it is not clear if the reflectors will only be available with the purchase of a GT70 or not.
Newlumen
Newlumen's picture
Last seen: 1 month 1 week ago
No need to worry.. I just got my blf gt cw.. I found two tiny ding on the reflector.. it’s not a big deal and doesn’t effect the beam quality…
I don’t like the new lumintop box.. so fragile..
