OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
1422 posts / 0 new
Sunnysunsun
Sunnysunsun's picture
Green and Red CSLNM1s from Simon. Unfortunately I already ordered green ones from Shenzhen silver ingot and who charged a bit more for them.
https://www.aliexpress.com/item/4001334305387.html
https://www.aliexpress.com/item/4001334292126.html
ZILZAL
Simon newly listed bare KW CULPM1.TG BIN1:8RF-fcbB46-B5-6000 ,
Which is 1690-1900 Lumens and 3.25v-3.5v voltage.
https://www.aliexpress.com/item/4001352708356.html
Funtastic
Funtastic's picture
Last seen: 1 hour 18 min ago
Quite a bit higher priced, I’m waiting for djozz to test it
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
SKV89
Last seen: 2 days 3 hours ago
Does anyone remember the flux bin of the CULPM1.TG sold by Led4power? The 8RF Simon is selling is the 3rd highest bin so wondering how it compares with tbe ones already tested.
Barkuti
Barkuti's picture
Last seen: 22 hours 34 min ago
SKV89 wrote:
Does anyone remember the flux bin of the CULPM1.TG sold by Led4power? …
Flux bins for the CSLPM1.TG sold by led4power: 5P at first, then 6P.
Mon, 08/17/2020 - 09:25
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Scallywag
Scallywag's picture
Last seen: 10 hours 19 min ago
I’m wondering how it will compare to the few CULNM1.TGs laying around for lux.
ZILZAL
Not sure if there is 5P & 6P. there is ?
polarweis
polarweis's picture
Last seen: 2 weeks 2 days ago
The convoy Z1 zoom flashlight is new I think. Might be interesting with 1mm²
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
Funtastic
Funtastic's picture
I plan to install one when my stock arrives
luminarium iaculator
luminarium iaculator's picture
Last seen: 7 hours 21 min ago
Without precoolimator lens that will be very tiny die projection. But it should throw…
Barkuti
Barkuti's picture
But did led4power sold a CULPM1.TG (Boost HX)? As far as I know I could only get 3030 CSLPM1.TGs from them, and the bins I posted above are for the 3030.
Yokiamy
Yokiamy's picture
Last seen: 15 hours 12 min ago
I don’t think so, he announced them and published them, but they were never available, since they were very hard to get.
For now they are available and when Simon sells them on a copper board and has the 4040 gaskets available, i will definitely get some and swap it for the LED4Power DTP with 3030 W2 in my L21A, should be awesome!
contactcr
Last seen: 3 days 7 hours ago
Mystery bin Boost HX from Aliexpress (seller also claims to not know bin). They came loose in static bag. Not “cut from reel” like most places.
SKV89
I vaguely remembered L4P did sell the CULPM1.TG at one point but it was a very low flux bin so it did not perform much better than the CSLPM1.TG. The one Simon is selling is a pretty high bin so hopefully it will beat the CSLPM1.TG by a good bit.
djozz
djozz's picture
Last seen: 1 day 20 hours ago
I can not remember that, but you may refer to my story that I had a CULPM1.TG from Hank (intl-outdoor) for testing that did not perform overwhelmingly.
Btw, I ordered a few from Simon now, hopefully I will do a test when it arrives.
SKV89
Thumbs Up Thumbs Up Beer
Barkuti
Barkuti's picture
The last CSLPM1.TGs available at led4power were 6P flux bin, which theoretically are at least 10% brighter than 5P. But guess this doesn't matters now.
At least 4040 boards are available at Kaidomain, for example. Gaskets, though…
Scallywag
Scallywag's picture
djozz doing a few more tests. Thanks, I know it is no small task (and probably most of it quite tedious)
contactcr
The sketchy ali vendor HX actually has 5500-5600K color temp under a TIR. The lowest of any of these osram LEDs I have seen (actually measured, I don’t count kaidomain “specs”). Not to say it’s some amazing tint just an observation
led4power
led4power's picture
Last seen: 1 day 21 hours ago
I had CULNM1.TG which is 4040 1mm2 version, I did not have CULPM1.TG for sale.
ZILZAL
So what are drivers that should work with the CULPM1.TG ?
Will it work on the convoy drivers like the C8+ 12groups driver or the M21A 4 Modes driver that runs the sst40 ?
Scallywag
Scallywag's picture
You pretty much want any regulated driver. I think the SST-40 drivers tend to top out at 5-ish amps though? Have yet to see for sure, but you can probably push more with CULPM1.TG. The 5A is pretty perfect for CULNM1.TG though, pity it’s discontinued.
Yokiamy
Yokiamy's picture
the C U should be able to run on higher currents, i have got a LED4Power C S LNM1.TG happily running on 5A
MascaratumB
MascaratumB's picture
Last seen: 9 hours 35 min ago
I managed to “perfect” (in the possible way) the beam in my Eagle Eye X3R with an Osram W1.
(Previous posts on it: 1 & 2 )
I took the gasket out (to lower the reflector near to the PCB and led, and to erase the ringy around the hotspot), and applied some electrical tape and GITD tape over the pcb (for insulation and GITD effect).
Not pretty, but better than it was before.
I managed to get that small clear light circle in the hotspot, that was not happening before Party
Besides this I also put an Osram W2 on the On The Road Z821 zoomable flashlight! The beam is awkward, but I am waiting for the night to test it outside and check how it behaves Wink
The mod is here: http://budgetlightforum.com/node/73990#comment-1687170
Sunnysunsun
I was thinking of running the CSLNM1.TG using the convoy sst40 driver in an S2+, but Djozz’s test showed that it peaked at 4.5-5A and I’m worried about frying it with prolonged 100%
How does yours behave at 5A?
Coyote2710
Last seen: 2 years 2 weeks ago
hello, best driver for osram 1mm red (CSLNM1.23) around 1.5-2A using single 18650? continuous use on C8+.
Sunnysunsun
5 or 6*7135
Coyote2710
Sunnysunsun wrote:
5 or 6*7135
thanks, but what do you think about the heat with the low Vf?
Scallywag
Scallywag's picture
Coyote2710 wrote:
Sunnysunsun wrote:
5 or 6*7135
I’d use a buck driver.
Coyote2710
Scallywag wrote:
Coyote2710 wrote:
Sunnysunsun wrote:
5 or 6*7135
which one do you recommend?
