Review: XinTD C8 SC-82/V4 (3C neutral white)
78 posts / 0 new
Foy
Foy's picture
Last seen: 5 years 1 month ago
XinTD SC-82/V4: C8 Classic At It's Very Best
Anyone having consumed flashaholic Kool-Aid in meaningful quantities has at least one C8 torch of this very familiar genre.  It is instantly recognized, with the base of the head deep cut into thirds, repeated again on the tail cap and one of probably a dozen or more brand names screened on the flat surface amid the knurling.  Just about every emitter has found its way under the 40mm SMO.  The design accommodates many different roles and is so forgettable, Foy skims right past the inevitable offerings when perusing various sites.  As a beginner, my very first C8 was an R5 Palight that at a glance, save for its black finish, seems an exact twin of the SC-82.  It is not.  In fact, without checking to see if I'm right, I am willing to bet this particular iteration is better in every way than any like design there is.  Period.  It's been a while since Foy has felt this strongly about a new light and however overused the notion is, of relevance or importance, the XinTD SC-82/V4 is a very important flashlight.
Foyapproved +
Bottom line: Maybe it's because I'm late to the XinTD C8 party but at $29.95, (1C tint) version 4 has to be the lumen bargain/mini-thrower value of the century.  I am absolutely astounded by the level of quality and sizzling output one gets for the price.  In a single stroke, the SC-82 has altered my belief of what $30 should represent for a flashlight.  I cannot imagine anyone ever again being satisfied with anything less.  At $50, I would have been thrilled to own such a high quality torch.  At $32 (3C tint) I want to shout from the rooftops that precision manufacture and Goliath-slaying performance can be had for less than a decent P60 kit.  The SC-82/V4 is a remarkable flashlight . . . at any price.
What I like:
- bright, bright (bright)
- tint
- quality feel, fit and finish
- unique silver anodization
- threaded reflector
- large, screw-in brass pill
- UI
What I do not like:
- GITD boot
- mode memory sometimes forgets
- could do with a few more tail cap threads
- lame lanyard
- not sure what its actual model name is (until otherwise corrected, Foy is calling it the SC-82)
XinTD C8 SC-82/V4 XM-L2/T6/3C Flashlight
$31.94  Int'l Outdoor Store  http://intl-outdoor.com/xintd-c8-v4-xml2-t6-18650-flashlight-p-308.html
ordered:  4-22-13
received: 5-20-13
Cree SC8 technology XM-L2/T6/3C neutral white emitter
40mm diameter SMO aluminum threaded reflector
designed for a single 18650 lithium-ion rechargeable battery
ascending 3-mode user interface with mode memory: low (2%) medium (25%) and High (100%)
6061-T6 aluminum construction
"hard anodize" finish
square threads on head end of tube
tail standing, reverse clicky tail cap switch with one lanyard hole and 16mm GITD boot
large brass screw-in pill
AR coated glass lens
IPX-8 waterproof  (immersion beyond 1 meter)
selected manufacturer specifications:
1,050 lumens
50,000 hours LED
Nanjg 105C (7135*8 380mA) constant current circuit
reverse polarity protection
exterior dimensions:
155mm length
25mm body
45mm head
185 grams without battery
what you get for $31.94:
- SC-82/V4 flashlight
- silver lanyard
Foy also received this holster but I think Hank threw it in as a courtesy.
tail cap draw: with unprotected Tenergy 18650/2600 charged to 4.23 volts
low:         .04 amp
medium:  .71
high:      2.91
Right up front, let's talk output.  As in, this flashlight will mop the floor with just about any C8 torch you care to compare.  It is at least 30% brighter than my 980L and brighter than the T60/Cyclone/JM07/E1320 modified F15 by about the same amount.  It even measures higher than my E1320 modified JM05/2 x 26650 and seems to out-throw it too.  A T6/3C neutral white emitter puttin' the hurt on middle heavy weights such as these is simply amazing, as far as I'm concerned.
Spectacular output from a light this handsome is a beautiful thing to have and to hold.  In super macro, my camera can find one and if you're real anal (like Foy) perhaps a couple of near microscopic metal imperfections.  Not sure what anodization type it is; forced to choose, I'd call it type II.  It seems rather resilient, showing no signs it ever rolled atop a block wall.
Foywall exterior finish torture test: passed
Light shipped with this GITD boot.  Foy likes to think he has grown out of his previous inclination to green.  Blue, now, is the color du jour.
The silver finish is unlike any I've ever seen and is absolutely gorgeous.  Tube thread feel is so-so and the threads overall are the only hint that this is a budget torch.  The SC-82 looks and feels otherwise expensive.
Knurling is attractive, if a little smooth.  Lathe work is exceptional and there's a good amount of mass around the pill.  It seems to wick away heat fairly well; I measured a toasty 130°F directly above the cooling fins on the angled under side of the head.
Shallow scalloped bezel is perfect for night-stand duty.  Light is rated IPX-8 and a dynamic test in the shower with Foy found no ingress.
Reflector diameter is 40mm at the bezel.
One of the few issues I have with the SC-82 is its mode memory function.  Problem is, I can't really nail down where I'm not waiting long enough for retention to occur and that is exactly the problem.  Proper mode memory is organic and the light simply comes on in the last mode used.  I have several not-inexpensive torches with the same issue, if you can call it that.  Truth is, it's hardly an irritant at all on an otherwise impressive package.  It has been suggested the 105C board might be inclined toward this deviant behavior but Foy prefers to see it as the V4 exercising its free agency.  We humans rarely come on in the same "mode" from day to day or even minute to minute.  The SC-82 is merely trying to say, "pay attention to me, within the vast universe . . . I matter."
This form factor has been around for a while, bearing many different brand names.  This is my Palight from March of 2011 with its XP-G emitter and awful flickering issues since day one . . .
And here's what your SC-82 would look like declawed.  This was near the birth of what became the sprawling Foybezel™ empire and I remember being quite proud of my newly defenseless C8.  This one would have been better left alone.  Don't do this to your V4.
No budget reflector this . . .
Cree describes the new XLamp XM-L2 emitter as having up to 20% more lumens than the original XM-L.  They claim 1,198 lumens @ 3 amps and use the term "SC8 technology platform."  Whatever it is, as installed in the SC-82, Foy believes.  Can I get a hallelujah!  No?
One thing that particularly impressed me was the aluminum reflector.  It threads onto the pill . . .
A fairly upscale feature for a $30 light and the pill looks like a nice hunk of brass . . .
Nanjg 105C board with clean soldering.
As many of you might know, nothing sours me faster than poor machine work and I find little to carp about with the SC-82 . . .
Only on a near microscopic level do we find the smallest of nicks.  Nothing escapes the Foymacro.
I know "square" is the wrong term but they appear to be cut flat on top on the head end of the tube only.  At the other end, a Foypetpeeve are the limited number of tail cap threads.  I don't think three threads are enough and they feel awful too.
Another interesting thing is the rather deep tail cap . . .
Making necessary a tall solution, including a long spring upon which a brass contact plunger sits.  I usually remove these because I've consistently measured less current with them on.  This button has to remain however; the spring will not touch the battery otherwise . . .
And here's the whole thamn ding . . .
And the rest of it.
This isn't my first happy experience with XinTD.  In March of last year I reviewed the L2 . . . http://budgetlightforum.com/node/8251
I called it "Flashlight Xanadu" and although not budget, like the SC-82, the L2 was chock full of quality extras.  Displaying the same exquisite machine work and build quality, I have to assume XinTD to be among the handful of Chinese manufactures interested in producing world class flashlights . . .
All beam shots were taken with a 1/4 second shutter speed @f2.8 . . .
Shadow JM05 with 2 x unprotected King Kong 26650.
LXP (XM-L/U2/1B) with 2 x unprotected King Kong 26650.
XinTD SC-82/V4.
JM05 on the left and the XinTD C8/V4 on the right.  Does not appear you're giving up any output for the NW tint.
XinTD C8/V4 (with its 3C tint) from about 25 feet.
At the risk of offending many, there are many poor attempts to copy and sell a successful design.  The ZY-T08 may indeed be an affordable alternative to the UltraFire UF-T60, but unlike Small Sun, XinTD took an existing design and created their own classic.  And in the process, in this humble writer's opinion, becomes the de facto "original."
The SC-82 certainly didn't invent this long produced form factor.  What they did was show every Chinese flashlight maker how to properly copy an existing design.
thisishowitsdoneFoy
No referral links and nothing embedded . . . ever.
                      &nbsp
Edited by: sb56637 on 08/26/2014 - 17:19
MRsDNF
MRsDNF's picture
Last seen: 16 hours 38 min ago
Thanks Foy for another fantastic review. I was lucky to have a loan off Suncoasters V3 and as soon as I turned it on it blew me away. Like you Foy l believe this light is a bargain. Just try and convince others though. Maybe Foycan.
ryansoh3
ryansoh3's picture
Last seen: 1 month 2 days ago
Aww man, you’re killing me here!
That light looks fantastic, especially the screw in reflector. I wonder if that helps heatsinking…
BLF ≠ B-grade Flashlight Forum
Spasmod
Spasmod's picture
Last seen: 7 months 1 day ago
Awesome review Foy with fantastic pics, and a great light too except... It beats me why they fit a 1500mA rated switch to a light fitted with a 3040mA driver Sealed
Steve_the_Chief
Steve_the_Chief's picture
Last seen: 1 year 1 month ago
I just parked this review in a separate browser tab to enjoy it later with a cup of tea :bigsmile:
Finished. Great review, awesome pictures. The blue switch boot looks like it was made for it!
Concerning this:
I have only one flashlight with a nanjg driver, and it's memory behaves different than most others. It sets in after two seconds of ON time, not OFF time as usual. This was very confusing to me before I learned what was going on. Maybe the Xint C8 is the same?
MRsDNF
MRsDNF's picture
Concerning this:
I have only one flashlight with a nanjg driver, and it’s memory behaves different than most others. It sets in after two seconds of ON time, not OFF time as usual. This was very confusing to me before I learned what was going on. Maybe the Xint C8 is the same?
Yes you are correct with what you said on the memory off these drivers. Had me fooled for awhile.
RedForest UK
RedForest UK's picture
Last seen: 6 months 4 days ago
Yeah, it’s not my favourite way of implementing memory, but I’m used to it now with so many homemade NANJG drop-ins in solarforce hosts (12 now I think!). It actually feels a lot more intuitive with a forward clicky imo.
It looks really good, thanks again for a review full of great pictures as well. Have you tried other lights with high current NANJG drivers before, how does output compare to those?
Also, if you take it outside on a cold night, have you noticed any misting after a few minutes on the inside of the lense. This happens on a lot of my larger head lights (even high output P60s) and annoys me if it interferes with the beam. But often lenses with a coating don’t mist as much, or at all. If that’s the case then its another bonus Smile
Dale
Dale's picture
Last seen: 2 years 5 months ago
Foy is correct, excellent build quality on this light. Talking to Hank, I guess the difference between the V3 & V4 is 70 lumens…. Drats!! I don’t wanna order the V4, but it’s one of those things thats gonna happen. Oh well, everyone needs a matching set.
Pilchman
Pilchman's picture
Last seen: 1 month 1 week ago
Foy I love the reviews that you do
I think this will be my next torch to buy
what a handsome light Big Smile
vas
vas's picture
Last seen: 4 weeks 20 hours ago
Could not resist it after such a praiseworthy review. So now I’ve ordered one. :bigsmile:
gords1001
gords1001's picture
Last seen: 1 year 11 months ago
I suspect I’ll be soon adding this to a cart too, thanks for the review foy, you do realise that a solder blob on the riggt hand star to ground ring will give you moonlight as well as your current modes? even better for not disturbing mrs foy.
Haterade
Last seen: 4 years 3 months ago
Thanks Foy. Glad you are on board the xinTD bandwagon. Smile
I like copper
troisanh
Last seen: 8 months 4 weeks ago
Very nice and information packed review.
light junkie
light junkie's picture
Last seen: 1 week 7 hours ago
Run out buy one any chance of getting to see some comparison beamshots?
Lj
jerrod
Last seen: 1 month 8 hours ago
I got my v4 3C today. I already had a v3 3C. Here are the differences I have noticed so far:
v4 is about 17%-20% brighter on my light meter / ceiling bound test.
v4’s reverse clicky needs a lot less force toggle it.
The finish on my v4’s tail cap was discolored (kind of spotty). I decided to swap the tailcaps so the v4 would look nice.
v4’s moonlight mode looks like it will work pretty well.
v4 has no pwm noise vs v3 does on low and medium.
Now that I have seen foy’s blue boot, I really want to swap out the green one. Can anyone comment on how hard it is to do the swap and where I can buy other colors?
gords1001
gords1001's picture
intloutdoor does the blue tailcaps, in 14 and 16mm, you’ll have to measure. swapping is just unscrew, note assembly, fit new boot, reassemble.
rdrfronty
Last seen: 2 years 3 months ago
Brother (manxbuggy1) just got the CW XM-L2 V4 XinTD in a couple days ago. Between the two of us we’ve had perhaps 20 C8’s. The quality of this one is certainly the best I’ve seen. The output is high – not quite as much as we expected – but again the best I’ve seen from any stock C8. His tested at 916 lumens at 30 seconds. And a nice lux of 36Kcd. The best thing about the power is it kept it well, only dropping from roughly 935 or so at start up to the 916.
For sure this C8 is worth the $30 it cost.
ChiggerPepi
ChiggerPepi's picture
Last seen: 2 hours 30 min ago
Thanks for the awesome review Foy, I’ve always loved the XinTD V3, and happy to see the V4 is even better!
Foy
Foy's picture
Thank you for the kind word and yes, beam shots are coming.  Have family coming for a couple of days so, it will probably be Monday evening.
Red Forest - I'll have to try my refrigerator as it rarely gets cold enough in Las Vegas to mist anything.
gords - I did not know that and would love a moonlight mode . . .
Jerrod - I used a 16mm blue boot from Int'l Outdoor Store and for whatever reason, it was a tighter fit getting it in the hole than the GITD boot it came with.  Actually, almost gave up but I finally powered it in.  The down side I failed to mention is the inside nub on the blue boot is a little short so, it requires a firmer push to activate and switch feel suffers a bit.  The price of vanity I suppose.  Like gords said, a boot swap with this cap is a breeze.
vainFoy
                      &nbsp
comfychair
comfychair's picture
Last seen: 4 years 2 weeks ago
That reflector looks like it might be well suited for a... well, something entirely inappropriate but very interesting. Think there's a chance these will ever be available as empty hosts? Does Hank do one-off requests like that, for half a dozen or so?
Also, I'm pretty sure all the IOS XinTDs are using the Qlite driver which is slightly different code than a standard 105c, Qlite star assignments are:
1st  Star  : 2% - 25% 100% (Default)
2nd Star : 5% - 30% - 100% - Strobe - Beacon
3rd  Star : 15% - 100%
4th Star :  5mA - 2% -25% -100%
RaceR86
RaceR86's picture
Foy, dont ever stop doing reviews! Such a pleasure to read and look at.
You even got me tempted on one of these! And I have said to myself. No more C8s, I dont really like them that much, and I only have 1. Silly
My crappy quality C8 (cheapo light from Aurabuy) now with Qlite Love (with extra 7135 chip) and de-domed XP-G2 on Noctigon combined with AR coated lens and new improved switch is a good thrower, for the size. But when I see the XinTD, the light/host it selves is just in a complete different league compared the most other C8s out there. Especially compared to my crappy version. Silly
I want one, dont need one, but I really want one! 0:)
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Rusty Joe
Rusty Joe's picture
Last seen: 5 hours 58 min ago
Excellent review. As always, I love your writing style.
BanglaBob
Last seen: 11 months 2 weeks ago
Doggone it, Foy. I’ve got the V3 and it’s a cracker. But now you’ve got me thinking again (very dangerous), and well…
I just might pull the trigger on this one, although I promised myself I wouldn’t Silly
Lights out! That's when things get interesting...
Toppel
Last seen: 1 year 12 months ago
I’m thinking of getting a V4 too.
The CW should be much brighter, although the colours wont be so natural right?
C-channel
C-channel's picture
Thank you for the great review. I should get one and be happy…
How bright is bright enough...
Runtime VS Lumens...
bibihang
bibihang's picture
Last seen: 1 week 3 days ago
Thanks for another great review Foy. But I wonder isn’t aluminum has better heat transfer ability than brass?
Foy
Foy's picture
Okay comfy, I was wondering the same thing.  In my notes I have the following but cannot remember where I got it.  I went back to IO's site and it still says Nanjg . . .
Here are my notes from where? that I didn't take the time to verify, that perhaps list the upgrade from version 3 to 4 . . .
XM-L to XM-L2 LED upgrade
AR lens
Qlite driver Rev. A 7135*8 multiple modes
380 mah chips, different modes
5mA firefly
18 KHz PWM
If true I will make the changes . . .
followthroughFoy
                      &nbsp
comfychair
I only mentioned it 'cause I don't know of any plain Nanjgs that will do 3-mode without any stars connected (other that #1, which is connected by a trace in the PCB). Default/no-stars is usually 5 mode. BUT, default on the Qlites is 3 mode.
Though I could be wrong. After all, who really knows how many variants of these things there are.
Foy
Foy's picture
I sometimes randomly copy notes when I come across information on a light I plan on ordering/reviewing and I simply don't know where I got this.  When you then say the same thing, it can't be mere coincidence.
I'll ask Hank . . .
thanksfortheheadsupFoy
                      &nbsp
sesgum
sesgum's picture
Very nice review Foy. Thank you.
I got my V4 on 24th. Have been enjoying for the last couple of days. It is a fun and quality light. The stock form of moonlight mode and extremely high PWM are worth the $30 I paid.
I like that blue boot cap you have there. Is it good as GLTD? (I mean bright and long lasting?)
About mode memory, I was also surprised a couple of times when I turned on the light, because I left it on high and it turned on in moonlight. Feels like it forgets the mode and just goes to default after a long period of rest or something. Definitely not because it remembers after 2 sec on instead of 2 sec off.
Again thank you for the review.
And thanks to rdrfronty for the lux and lumen numbers. I was wondering about those.
sesgum
sesgum's picture
Just checked out the blue cap at intloutdoor, which is not GITD.
I found one on fasttech, though reviews are not very favorable.
http://www.fasttech.com/products/0/10001928/1138301-glow-in-the-dark-sil...
Guess I will order these anyway next time.
