*BLF LT1 Lantern Project* (Awaiting for updates on Colored versions)
10779 posts / 0 new
anycolourfloyd
Last seen: 4 months 1 week ago
DBSAR wrote:
ToyKeeper wrote:
From off:
  • 1 click: Turn on at memorized level.
  • Hold: Turn on at lowest level. Keep holding to get brighter.
  • 2 clicks: Turn on at ceiling level. Repeat to go to full turbo, if it’s higher than the ceiling. Once at full turbo, repeat to go back to memorized level.
  • 2 clicks, but hold second click: Turn on at ceiling, then keep holding to get dimmer.
While on:
  • 1 click: Off.
  • Hold: Increase brightness. Release and hold again to decrease.
  • 2 clicks: Toggle between turbo and memorized level.
  • 2 clicks, but hold second click: Decrease brightness.
  • 3 clicks: Toggle between smooth ramping and mode group.
  • 4 clicks: Configure current mode — floor, ceiling, and (if relevant) number of steps.
The default can be moon/low/med/high, and regular use can be explained in just 8 words: Click for on/off, hold to change brightness.
That mode set up is good. As long as the default is the 4-modes, ( which seems to be the most used mode-type i have tested and used in the field in a lantern) I’m not sure if a “turbo” mode is practical with a lantern as with lanterns they are usually continuous-run lights, and turbo would overheat the LED heatsink head after some time. (unless the turbo mode can be set to drop to the default high mode after a maximum of 1 minute.) i found during tests that even a XM-L2 run at 1.07 amps for 30 minutes continuously or more heats up the large solid aluminum heatsink head to 60 plus degrees C. (which is somewhat hot to the touch for a child if one did touch the lantern.
Definitely agree with keeping the default modes simple!
Also while I think USB charging is really important in a lantern, I don’t think the ability to act as a power bank is that important if increasing cost and complexity. Actual power banks with quick charge are so readily available, light and compact that probably most people take one tramping, letalone car camping.
Neomis
Interested
Splott-Light
Splott-Light's picture
Last seen: 1 week 3 days ago
Hi,
Interested in 1 (depending on price).
Good to see this suddenly taking off and taking shape with a Team now.
Thanks for your hard work.
Appreciated.
Cheers,
S-L Smile
Ouchyfoot to a New Member: Welcome CJ. Now you have to learn about buying an inexpensive flashlight and modifying it until it either blows up, or starts small fires on the moon…………
Hugh Johnson:
I, too, once lived a tragic and empty life. Then I found [portable] light.
You forgot to mention clothes. I sold most of my clothes to fund my light collection. This is actually fine, since I only go out after dark, and most people can’t see me.
Finally, I got my priorities straight.
ToyKeeper
ToyKeeper's picture
Last seen: 3 hours 27 min ago
At the moment it’s mostly DEL doing all the work, designing a circuit which will handle light and USB in a SRK-style form factor. It may well be the hardest part of this project.
Physical host design seems like it’ll be a fair amount of work too, due to the USB port(s) and all the lantern-style adjustments to the head.
Since I’m doing firmware, I’ve got the easy job… all I have to do is port my FSM toolkit to the new driver and tweak the calibration and settings. Most of the work there was done months ago.
Blazer296
Last seen: 6 days 5 hours ago
Ok, I thought I already joined this one……..but I dont see it so,
Put me in for at least 1, more than likely 2-4 if the price is not too high.
Thanks,
Jim
DBSAR
DBSAR's picture
Last seen: 1 day 14 hours ago
I am working on doing a modification to the prototype to make the head of the lantern more stronger, (using a center bolt to hold the head & globe/shade together) but testing with two LEDs. Also will revise the drawing design to show the change that works with o-rings. Also adding tripod mounts to the bottom as some mentioned that would be as good option, (for lighting up a campsite or back yard are on a tripod.
Mr.Scott
Last seen: 12 hours 39 min ago
Please add me to the list for 1.
Thanks!
object_in_space
This project has me excited!
Please add me to the interest list
DavidEF
DavidEF's picture
Last seen: 1 week 1 day ago
If the LED will not be in the center, and instead a bolt will be there, I’d rather see three (or four) LEDs used, so the light doesn’t become bi-directional with shadow lines between the outputs of the two LEDs.
But you’re testing it, so I’ll trust you to come up with what works. Big Smile
- The YKK Philosophy
MtnDon
MtnDon's picture
Last seen: 1 hour 27 min ago
DBSAR wrote:
………. (using a center bolt to hold the head & globe/shade together) but testing with two LEDs
Rather than a center bolt, how about a center tube to use as a wire chase?
Caleb
Caleb's picture
Last seen: 14 hours 26 min ago
Brilliant!
DBSAR
DBSAR's picture
That was an option to test. ( a hollow bolt/tube to run the wires to the LEDs.
d_t_a
Last seen: 2 days 10 hours ago
Pardon if I wasn’t able to check the earlier messages, but around how much would be the approximate price of this BLF lantern?
I’d be interested, depending on the price..
Lazy-R-us
Last seen: 1 month 1 week ago
The specs have not been completely nailed down yet, so we don’t have a complete BOM yet, or a commitment from a manufacturer, so no final cost. The Q8 that this is hopefully going to be similar to had a group buy price of $40, “MSRP” of $80, and a coupon that brings it down to around $45-50 currently.
There are a lot of folks on the list under the heading “interested, depending on price”. Chances are good that it will be a great value though.
Lazy-R-us
JJMcGee83
Last seen: 6 days 12 hours ago
Add me to the list. I have a Fenix CL25R I have in case the power goes out and this looks way better.
Norddeutscher
Last seen: 2 months 4 hours ago
Interested for a second on.
aremihc
I am interested
cujo255
cujo255's picture
Last seen: 5 days 21 hours ago
thought I had commented on this one already, but I guess not.
please put me down as interested in one.
Moomoomao
Interested in one!
Xebrecito
I am interested.
FlashMax
FlashMax's picture
Last seen: 3 weeks 6 days ago
Hi, I am interested in one. thanks
Max
noboneshotdog
Last seen: 6 hours 33 min ago
Looks great! Please add me to the list.
Thier ain’t no bones in a hot dog. F. York
Joat
I’m interested.
A 1/4” tripod mount on the bottom would be very useful, more than 3/4 of the run time my Q8 has on it has been attached to a tripod.
DBSAR
DBSAR's picture
Joat wrote:
I’m interested.
a tripod mount in the base is planned.
Andyman
Andyman wrote:
Looking great so far! …Keep it up! … At least for me, this may be progressing from “interested depending on price” to “hurry up and take my money”. Wink
Just checking in, exactly 9 months after this post – all still true! Still very interested! Cool
DBSAR
DBSAR's picture
like most detailed projects, they take time to develop. Smile
Andyman
I understand! I wasn’t trying to express impatience, just excitement. Smile Very glad to see this is happening!
congo
Hi, please add me to the list for one. Thanks!
Sonofspectrum
Sonofspectrum's picture
Thanks
It's moments of madness that keep us sane.
xray291
xray291's picture
count me in for 1!
