*BLF LT1 Lantern Project* (codes going out for more LT1s, second batch shipping!)
10591 posts / 0 new
derfyled
derfyled's picture
Last seen: 17 hours 42 min ago
DBSAR wrote:
a snap on place base may be in the works for added to the accessory-kit that is planned once we get the lantern into production.
that’s agreat news ! Thumbs Up
thijsco19
Last seen: 10 hours 17 min ago
DBSAR, what are the dimensions of the diffuser cup? For making a more accurate design.
DBSAR
DBSAR's picture
Last seen: 17 min 13 sec ago
The lens/globe part? ( i can get the measurements for that when i get home.
thijsco19
Yes the lens/globe part.
joechina
Last seen: 3 days 10 hours ago
DBSAR wrote:
derfyled wrote:
Two random ideas: -Would be great if the lantern could be used with 21700 to get close to 20000 mAh. A little sleeve could be used for 18650. - Foldable legs so the lantern could be more stable on a uneven surface (which happens often in camping)
  If there is still enough metal left in the tube its possible, but not sure if the Q8 body design has enough metal to allow the bigger cell size. a snap on place base may be in the works for added to the accessory-kit that is planned once we get the lantern into production.
Kit sounds good I posted here http://budgetlightforum.com/comment/1364528#comment-1364528 an idea for an reflector, if you want light only in one direction instaed of 360 degree.
Dannyboyy
Last seen: 1 month 1 week ago
I’m interested put me on list please
sbslider
sbslider's picture
Last seen: 2 hours 2 min ago
Dannyboyy added to the interest list at number 952.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
DBSAR
DBSAR's picture
*Ok some updates: Barry contacted me earlier and they are in need of a base driver circuit design, and asking about the UI (i’m guessing the firmware for the lantern, which i believe Toykeeper is working on that) I don’t know who designed the circuit board for the Q8, but we are in need of something for the planned two-channel tint ramping, Their engineers are held up on these components at this time, for them to continue they need some basis for what were looking to achieve for the tint ramp & charging system. Without a board design or someone who can help us with that.. the only other option is to revert back to using the Q8 board modded with 4-7135s and no tint ramping or charging feature or USB feature. Any input on this form anyone here woudl be greatly appreciated as it seems were held up without a finalized driver board design to incorporate the tint ramping feature, charging feature, & USB power bank feature.*
joechina
RobertB
RobertB's picture
Last seen: 7 hours 18 min ago
I’d forget about the tint ramping and just put some nice 3 or 4000k emitters in it, and call it a day. Strayed too far off the original plan from two years ago IMO. Nice ramping UI, some nice quality emitters and get on with the project.
dealgrabber2002
Last seen: 4 hours 42 min ago
What he said.
DBSAR
DBSAR's picture
That could be the option right now to get this into production faster. Then maybe down the road a version-2 could be designed with more options.
nkresho
nkresho's picture
Last seen: 5 days 3 hours ago
Or an aftermarket driver upgrade like most of us usually do anyway.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 43 min ago
joechina wrote:
What’s about DELs driver? From here http://budgetlightforum.com/comment/1219607#comment-1219607
It’s about 90% done but no one seems to know how to do the other 10%.
If the lantern uses a Q8 driver as the base, it needs these changes at minimum:
  • Replace the FET with 4×7135 chips. (or 5×7135)
In order to get tint ramping, it also needs these changes:
  • Replace the original 1×7135 chip with 4×7135 chips. (or 5×7135)
  • Split the LED- pad in half so there is one pad per power channel.
And to get USB charging, using an external board, it should also have some other small changes:
  • Add BAT+ and BAT- pads (CHG+ and CHG-) which connect the charge circuit directly to the batteries.
These are all fairly straightforward changes, so I’m optimistic that they can happen.
shirnask
shirnask's picture
Last seen: 2 hours 6 min ago
Thumbs Up Simple is best
Coscar
Coscar's picture
Last seen: 1 day 4 hours ago
Seems we have too many Indians and not enough Chiefs ~~~~~~
Im not a Pessimist …. just an Optimist with a lot of experience
verge
Last seen: 8 months 3 weeks ago
I’m interested on this lantern, please put me on the list.
DavidEF
DavidEF's picture
Last seen: 1 hour 36 min ago
I’m not any good at designing the driver circuitry, but if anyone has Eagle or KiCAD schematics already of the relevant circuit parts, and measurements for the driver board, I could layout a PCB for it.
- The YKK Philosophy
DavidEF
DavidEF's picture
Just followed that link to the DEL board. What else needs to be done with that? I looked at his OSH Park drivers collection, and that one isn’t present. Does anyone have a copy of it or know how to get a copy? Where is DEL anyway? He’s been gone for almost a half a year? What happened?
sbslider
sbslider's picture
No one can find a copy of that board, or we would have been done ages ago. Not sure what happened to DEL, but he is MIA for now.
I am designing the driver presently, and it is near completion. I am using Eagle. I am not terribly good at this, so if you have Eagle and would not mind checking out the present state I would appreciate it. PM me your email if you are interested.
DavidEF
DavidEF's picture
PM sent! Thanks!
DBSAR
DBSAR's picture
Toykeeper maybe forward that information to Barry so he can inform the engineers who are working on the lantern production prototype that it can be modified that way. I already sent them the LED pad 2-channel design for that part.
Lexel
Lexel's picture
Last seen: 12 hours 41 min ago
I got my right hand today hurt bad
But I can try to get it, hopefully the antibiotics wirk or they ha e to cut my right pointer ng finger open and I will be handicapped a lot longer
Problem is what is U3 for?
No files to start wirh so modding my Q8 driver
DavidEF
DavidEF's picture
Lexel, DEL describes the driver board a little bit in post 736. After the images, at the bottom of the post, it tells what U3 is among other things. Here’s the relevant text:
DEL wrote:
U3 is a precision DC opamp and does the closed-loop current control for the LED driver (driving a meaty FET in linear mode). A sense resistor creates the feedback signal. The MCU (a venerable tiny85) generates the reference signal. Driver dropout should be < 150 mV, giving regulated control down to about 3.2 V.
joechina
From here:
U4 is an all-in-one power-bank chip from TI’s BQ24 or BQ25 series (currently looking at the BQ25895, it is also used in the higher end Xiaomi power banks).
RobertB
RobertB's picture
That sucks Lexel. must be really frustrating. hope you get better soon.
thijsco19
DBSAR, did you had the time to measure the lens/globe/diffuser cup?
DBSAR
DBSAR's picture
not yet, but will as soon as i can.. ( been overloaded with errands & work the last week.
Dodge62
I’m interested in this – please add me to the list.
atbglenn
atbglenn's picture
Last seen: 6 months 3 weeks ago
Same here Lexel. I hope it’s nothing serious.
Boycott Nike
