【convoy】17mm SST40 driver with biscotti firmware and temperature protection will be available
2229 posts / 0 new
d_t_a
Last seen: 2 hours 42 min ago
Simon Mao wrote:
Convoylover wrote:
Simon, Great that the 21700 light is coming!
I have put a 21700 in the Convoy BD01 and that fits fine lengthwise, so I expect that this will be fitting in the S11 too.
I hope that you also will have Biscotti drivers for XML2, XPL LEDs for the S11 / S2+ 21700, similar to the 18650 S2. I don’t always want XHP LEDs.
And OP and SMO reflectors similar to the M1/M2 lights Smile
i will launch another version – S11 with SST40 and ramping driver
Hi Simon,
1) Can you give some info about the “ramping” operation that will be used on the S11?
2) I would also like to ask around how many lumens is the SST20 6500K, assuming the 7135×8 version?
(The 7135×8 version of the S2+ with XM-L2 and XPL-Hi 6500K LEDs are usually indicated to be around 1000 lumens, so I wonder if the SST20 might be a bit less, but have a more “throwy/focused” beam pattern due to its smaller LED?)
Simon Mao
Simon Mao's picture
Last seen: 1 day 3 min ago
80T wrote:
I guess it’s fine like so as well, it has the 0.1 and that’s what I was the most interested in.
So how would I order one S11 ?
Thanks.
sorry ,what 0.1?
Simon Mao
Simon Mao's picture
Hi Simon,
1)
1 click – turn on 1st mode 100%
2 taps – 2nd mode 30%
3 taps – strobe or biking or 0.1% moonlight or …etc
when flashlight is on 1st or 2nd mode
5taps – ramping,you can set the brightness of 1st or 2nd mode here .
when flashlight is on 3rd mode
5taps – you can choose one mode from strobe or biking or 0.1% moonlight or …etc
2) brightness the same as cree xml2 and xpl hi
80T
80T's picture
Last seen: 1 month 1 week ago
0.1% moonlight mode.
Nicolicous
Nicolicous's picture
Last seen: 4 min 11 sec ago
Estimate release date for the ramp version?
Nico -.-
Simon Mao
Simon Mao's picture
oh ,i see Big Smile ,driver still needs half a month, Facepalm
Simon Mao
Simon Mao's picture
Simon Mao
Simon Mao's picture
moridin wrote:
Hey Simon, are you going to sell the sst20 LEDs separately?
I add link of SST20 here
djozz
djozz's picture
Last seen: 57 min 22 sec ago
Could you mention the flux bin, colour bin and voltage bin of the SST-20 leds? (i.e. a picture of the package label will show that)
Good price btw when 5 pieces are bought! Smile
80T
80T's picture
That's ok, I've just seen it on the first page and I though it was already available.
Satan@103TFS
Last seen: 3 hours 19 min ago
Simon could you add XHP50.2 K2 3C option for S11 and only led +MCPCB
moridin
Last seen: 1 day 1 hour ago
That’s great, thanks!
Another question: Will the boost-driver of the S11 have mode-memory, and if so, can it be disabled?
Simon Mao
Simon Mao's picture
ok i updated the description
Simon Mao
Simon Mao's picture
what about 3A 3D? i will add link later
Simon Mao
Simon Mao's picture
yes ,it has memory,
so do you want to enter into moonlight directly?
SKV89
Last seen: 37 min 6 sec ago
For small lights, I like start in moonlight since I use my flashlights in the middle of the night and dont want a blinding light. It would be good if theres an option to enable or disable moonlight mode like in the Reylights.
oweban
oweban's picture
Last seen: 1 hour 29 min ago
I like the simple UI of some of the Olights – from off, hold button to enter moonlight mode, a normal press goes to memory, and double press to turbo. When on, holding cycles through L/M/H (or ramping, either or).
Nice and simple, then throw all the config stuff up the top.
djozz
djozz's picture
Thanks, that helps Thumbs Up Bought a few 5000K SST-20’s on 16mm boards!
80T
80T's picture
Amen to that Smile My favorite UI so far would be the Sofirn C8F, pretty much similar to the olights, at least in ramping mode  which is the only mode I'm using on it since I've got it as it's the most intuitive one, the one mode that made the most sense to me. I have the tail click with mechanical on/off (still has the memory of the last used mode) then the side e-switch click for on/off, hold for ramping, hold from off to moonlight, double click from on/off to turbo and triple click from on/off to strobe (which I could very much do without.. I'd rather have a beacon mode instead of any other disco mode on a light)
oweban
oweban's picture
It’s what’s stopped me from buying a bunch of different lights – priority one is emitter temp, priority two is UI. I can’t reconcile the Zebralight UI or I’d consider one Sad
So hopefully the S11 is nice and simple, and we can all enjoy a nice 26650 that just works how it should!
Convoylover
Last seen: 3 months 3 days ago
Simon, do you have pictures or artist impressions of the upcoming ‘S2+ 21700’? Want to see!! Big Smile Big Smile
Simon Mao
Simon Mao's picture
the same appearance as S2+ 18650 ,just a little thicker
about 25.5mm diameter
Ryzbor
Ryzbor's picture
Last seen: 1 hour 6 min ago
Simon Mao wrote:
djozz wrote:
p=.
My opinion: I hoped for a bit more grooves/rings, or it to be slightly narrower at the battery tube, it is very straight/boring as it is now.
But I’m sure there are people who like this plain look.
total 6 grooves ,more like convoy X3
Is this also the new S2+ and S2+ 21700 design Simon?
[WTB]: Thrunite TC20 in EU/Poland
adam7027
Last seen: 2 weeks 14 hours ago
Hello Simon,
A few months earlier I mentioned, that I would happily buy a certain variant of Convoy C8+ (probably repeatedly if I can get some interest locally for it).
Can I tell my wish about it regarding the details?
I would be interested in a C8+, which is:
- Clear anodized
- Has the traditional tail cap, but it has translucent button
- Has support for 21700 battery
- Driver support is also traditional (but if it is larger, no problem – just please keep 17mm driver support as well)
Simon Mao
Simon Mao's picture
Ryzbor wrote:
Simon Mao wrote:
djozz wrote:
p=.
this is 18650
Simon Mao
Simon Mao's picture
adam7027 wrote:
Hello Simon,
- Clear anodized
only clear 18650 C8+ in stock currently ,sorry
the color of 21700 C8+ is black ,and it needs 20mm driver
Convoylover
Simon Mao wrote:
Ryzbor wrote:
Simon Mao wrote:
djozz wrote:
p=.
this is 18650
Now i’m confused. What do I see here then?
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 21 hours 14 min ago
Simon Mao wrote:
[...] the color of 21700 C8+ is black ,and it needs 20mm driver
That's great news Simon! Smile Will there be different versions of the C8+ 21700, e.g. tailclicky only, tailclicky + e-side-switch, e-side-switch only? Do you plan to offer both host version and full flashlight?
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
weklund
weklund's picture
Last seen: 4 hours 36 min ago
I want one 21700 C8+ SST20 4000K … Smile
... Happy Landings ...
MascaratumB
MascaratumB's picture
Last seen: 45 min 44 sec ago
Convoylover wrote:
Simon Mao wrote:
Ryzbor wrote:
Simon Mao wrote:
djozz wrote:
p=.
this is 18650
I guess this is the prototype for the S2+ Copper!
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
