【convoy】17mm SST40 driver with biscotti firmware and temperature protection will be available
2126 posts / 0 new
oweban
oweban's picture
Last seen: 1 hour 48 min ago
Fantastic as always Smile
Will this be my first 21700 light? Wink
VaKo
Last seen: 1 week 6 days ago
Will the new 22mm XHP35 driver fit in this light?
Simon Mao
Simon Mao's picture
Last seen: 1 week 3 days ago
the size is suitable ,but i think there is no need to use XHP35
sst20 and xpl hi are enough
Chatika vas Paus
Last seen: 1 hour 32 min ago
Why bezel isn’t stainless steel?
80T
80T's picture
Last seen: 16 hours 12 min ago
Simon Mao wrote:
VaKo wrote:
!https://live.staticflickr.com/65535/48090902952_d5bae1a96a_b.jpg! Will the new 22mm XHP35 driver fit in this light?
the size is suitable ,but i think there is no need to use XHP35 sst20 and xpl hi are enough
Now that's a winner flashlight there Smile
I'll take some XP-L HD or Luxeon V's thank you Big Smile
oweban
oweban's picture
Planning on having it by itself, or in a light+battery combo?
Sivy
Hi Simon
Would it be possible to have this driver… https://www.aliexpress.com/store/product/17mm-Driver-for-SST40-4-modes-0... ….. without memory , always starting on low?
VaKo
If I was a reasonable man I would agree Wink
Noctiluco
Noctiluco's picture
Last seen: 1 day 12 hours ago
Nice those AAA titanium! What kind of led? Number of modes? Neutral/warm led options? Does it support 10440?
I have a SS Convoy AAA and it eats 3.7V very well…
jasontheguitarist
Last seen: 1 month 1 week ago
Sivy wrote:
Hi Simon
Someone asked before, and Simon doesn’t think there’s enough demand, he believes everyone just loves mode memory and can’t get enough of it. The only convoy drivers worth buying if you don’t always want memory are the biscotti drivers since they give you choices, but they only go up to 2.8a.
His new drivers are a huge step back software wise.
oweban
oweban's picture
Yeah, on my biscottis I have memory turned off. On my Anduril/ramping firmwares it’s on, but that’s because there’s shortcuts to other modes. If it’s just on/off and change, then I always want to start at the lowest mode. Don’t want to blind myself because I either forgot to set to low the last time I used it, or to have to cycle through.
Ryzbor
Ryzbor's picture
Last seen: 43 min 55 sec ago
The ability to turn the mode memory off and/or having the ability to cycle backwards by doing a long click or double click would be a welcome addition to this medieval U still keeping it more then muggle friendly.
Bt, Biscotti doesn’t have immediate mode memory, or does it?
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
Nicolicous
Nicolicous's picture
Last seen: 12 min 47 sec ago
sorry for being off topic…. im looking to buy couple NCR18650BD (3200mAH) from Simon store and wanting to know if ithave circuit board protection ?
also the capacity is actually 3200mAH?
Nico -.-
oweban
oweban's picture
You can enable it – option 2 in config mode IIRC.
http://i.imgur.com/sNXV4tt.jpg
Although that probably should be rewritten, it’s more like 16 taps instead of 10 to get into config, at least that’s what I’ve found.
Nico, looks like that NCR is 10A continuous discharge; I don’t know of any protected batteries OTOH that do that much. Usually ~2C from memory.
gchart
gchart's picture
Last seen: 6 hours 49 min ago
Those AAA titanium lights look nice! I’m not a big fan of the keychain attachment sticking out like that, but it probably won’t stop me from getting one.
patmurris
patmurris's picture
Last seen: 15 hours 37 min ago
I love those Ti AAA lights!
Any specs and numbers?
ETA?
Phlogiston
Phlogiston's picture
Last seen: 4 hours 8 min ago
The NCR18650GA is rated for 3500mAh, 10A maximum discharge current. Keeppower and EagTac both do protected cells with those ratings, and they’re believed to be using the GA cell.
In my experience, Keeppower cells tend to be fat – mine don’t fit into all of my lights. EagTac cells are slimmer and fit all of the lights I’ve tried them in, although one or two were a tight fit – rotate the cell until it slides in type stuff.
The other side of that tradeoff is that the Keeppower cells are significantly cheaper.
oweban
oweban's picture
Interesting, thanks Smile learn something new every day.
Simon Mao
Simon Mao's picture
This is just a sample ,it will be stainless steel
Simon Mao
Simon Mao's picture
you can order the flashlight and the battery, then close the payment page ,leave me a message ,i will caculate the amount and adjust it
Simon Mao
Simon Mao's picture
Sivy wrote:
Hi Simon
it can be produced ,but few people need it
Simon Mao
Simon Mao's picture
this is just host ,
I can design the corresponding driver
Simon Mao
Simon Mao's picture
i have protected NCR18650BD, i will add it in my store soon
mortuus
mortuus's picture
Last seen: 17 min ago
this is just host ,
thats a nice looking host.
...where Frugal meets with Flashlight!
Tally-ho
Tally-ho's picture
Last seen: 1 week 4 days ago
Yes this keychain attachment should be made differently, at best like the sofirn C01, at least like the jetbeam jet-u or DQG AAA (I don’t have much AAA flashlights to compare with).
Agro
Agro's picture
Last seen: 1 min 48 sec ago
Myself I prefer centrally placed attachment points and while I can’t say I like the current one, for me it’s better than C01 or Jet-µ or DQG AAA. But worse then DQG Fairy or Astrolux A01.
Chatika vas Paus
Simon.
I received your driver for “M3” today and put it in the JKK70 with the xhp70.2.
Thermal protection works very fast. Too fast.
The flashlight is not even warm and after about 50 seconds the brightness decreases. It seems to me that you should increase the temperature protection.
amishbill
amishbill's picture
Last seen: 3 weeks 7 hours ago
SKV89 wrote:
For small lights, I like start in moonlight since I use my flashlights in the middle of the night and dont want a blinding light. It would be good if theres an option to enable or disable moonlight mode like in the Reylights.
With the exception of gun/combat lights, my perfect light would always start in low or moonlight, then ramp up and down. I suspect I’ll have to learn to modify and flash firmware to get this.
DIY LT1 battery wrap image. "PDF on Google Drive":https://drive.google.com/open?id=1IHIEOi1NXu868IYNCzIM7D2Ulpxchmww
Fresh Sanyo NCR18650GAs already wrapped "for sale HERE":http://budgetlightforum.com/node/69120 if you like.
RelakS
Last seen: 4 days 22 hours ago
Simon. I received your driver for “M3” today and put it in the JKK70 with the xhp70.2. Thermal protection works very fast. Too fast. The flashlight is not even warm and after about 50 seconds the brightness decreases. It seems to me that you should increase the temperature protection.
Yes, something is definitely weird. The M3 itself also not even warm when the temperature protection kicks in, but it almost burnt my hand when I took it apart and touched the driver retainer ring Shocked At least it was very hot to touch.
KevinZA1988
KevinZA1988's picture
Last seen: 1 min 51 sec ago
The temp sensor obviously gets triggered by the hot driver. If you can add a copper or aluminum spacer with silicone sheets it should perform a lot better. Try and conduct as much heat as possible away from the driver into the host.
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
