【convoy】17mm SST40 driver with biscotti firmware and temperature protection will be available
2126 posts / 0 new
KevinZA1988
KevinZA1988's picture
Last seen: 11 hours 20 min ago
Kiriba-ru can make spacers. He just needs specs. And his prices are reasonable!
Armytek Prime C1 Pro, Armytek Prime C2 Pro, Armytek Tiara C1 Pro, Astrolux MF01 Mini, BLF Q8, BLF A6, BLF FW1A, BLF FW3A, BLF FW3C, Convoy L6, Convoy C8+ , Convoy S3, Convoy M21A, Convoy S11, Emisar D4, Fireflies E07, Jaxman E2L, Lumintop EDC18, Manta Ray C8.2 long version, Olight S1R Baton II special edition series, S2R Baton II, Nitecore HC65, Olight H1R Nova.
https://photos.app.goo.gl/JaJaDv4V838AEJf39
oweban
oweban's picture
Last seen: 11 hours 10 min ago
https://i.imgur.com/VPExcQ5.png (in inches, though)
Wink
KevinZA1988
oweban wrote:
diameter 28.5mm
height 20.7mm
diameter of bottom hole 7mm
weight 10g
suitable for XML2 XHP50 XHP50.2
I measured it up ages ago when looking for options – I think I found a ledil and a carclo that would be close, but still not 100%.
Edit: from memory, the opening at the head is 25mm, in case you find a TIR with the “shelf” bit.
Thank you!
KevinZA1988
Wink
And thank you too!
RelakS
Last seen: 3 days 12 hours ago
The M21A has the same narrow beam and weak flood light as the C8+?
As far as I can see, if the beam pattern is the same, the brightness is doubled compared to the C8+ (8×7135), which I could be interested in Flat Stare
Yokiamy
Yokiamy's picture
Last seen: 10 min 49 sec ago
RelakS wrote:
The M21A has the same narrow beam and weak flood light as the C8+? As far as I can see, if the beam pattern is the same, the brightness is doubled compared to the C8+ (8×7135), which I could be interested in Flat Stare
Yes, because it is basically the same light with another name (due to the 21700 cell)
The output will be more thanx to the SST40 led and more powerful driver.
RelakS
Thank you!
I was not sure if the mirror is the same.
jasontheguitarist
Last seen: 1 month 1 week ago
Simon Mao wrote:
oweban wrote:
Looks good!
I saw a report on reddit that the current H1 batch has the new UI (similar to Thrunite), is that right?
some are updated
I assume it’s like the biscotti driver situation. Some old, some new, big pile, chosen at random. Who knows what you’ll get.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 4 hours 22 min ago
oweban wrote:
Would love if there was a spacer made to buy…
https://www.reddit.com/r/flashlight/comments/bei7cv/comment/el6xenm
What size is the head? I have some 20mm and some 25mm round stock aluminum i can turn into a spacer. Just need to cut it the right height and drill a hole in the middle.
oweban
oweban's picture
I’ll do some measurements and draw it up tonight.
oweban
oweban's picture
Simon, please feel free to correct anything I have wrong Smile (reflector shape isn’t accurate, though)
The main thing I don’t have in there is the indentation in the pill itself – as noted in this thread on /r/flashlight , he made a spacer with a cutout for the MCPCB and an extrusion to fit in the existing MCPCB “hole”.
Measurements in inches in image below.
VaKo
Last seen: 1 week 5 days ago
Kiriba-ru made me 2 versions of the S11 spacer based on the dimensions posted to the Reddit thread. One was pure copper, the other was a copper core with a brass support ring to keep the optic in place.
oweban
oweban's picture
Dare I ask how much it cost? Smile
Simon Mao
Simon Mao's picture
Last seen: 1 week 1 day ago
2019/8/26
new flashlights
S12
M21B
M4U
hodor
hodor's picture
Last seen: 5 hours 38 min ago
I like the looks of the S12, that tailcap Thumbs Up
How does the beam look versus triple TIR, e.g. Carclo?
Very welcome updates to the other two as well!
1stein
1stein's picture
Last seen: 4 hours 31 min ago
S12… Love
What a beauty
My precious… Evil
KevinZA1988
I would really like to see a beamshot of the S12… Very interested in one!
oweban
oweban's picture
Very interesting MCPCB though… might look into sense resistor mod for it too cause more than 2A per emitter would be good.
Anthon
Last seen: 41 min 39 sec ago
will the S12 fit the Vapcell 4500/ Lishen LS21700SF cells?
Ryzbor
Ryzbor's picture
Last seen: 3 hours 6 min ago
Simon Mao wrote:
2019/8/26 new flashlights S12 M21B M4U
Please add a picture comparing the size to a S2+ and the 18650 equivalent in case of the M21B.
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
oweban
oweban's picture
M21B equiv is M1/M2 (unsure exactly which but will work out soon)
Mocarny
Mocarny's picture
Last seen: 16 min 18 sec ago
Please Simon, add 1mm more room for the cells in your 21700 lights Cash
It says “inner diameter 22mm” so I think it will fit Wink
S12 and M21B don’t have temperature protection?
What do you think is better – SST20 4000K or 219C 4000K?
KevinZA1988
I think they will have temp protection. It’s the new linear Convoy driver.
KevinZA1988
That M4U…. wtf. Side switch light running Biscotti? How?? Unless they have adapted the firmware to be used with an e-switch.
Anthon
any info about the UI on the S12? Would be nice to know if it uses regular attiny and it’s possible to flash Crescendo
oweban
oweban's picture
Equivalent is the M1.
Yokiamy
Yokiamy's picture
The inner diameter of my L21A is 22 mm as well, Samsung cells fit, but Shockli cells did not fit.
Adding 0,6 mm will make a lot of difference, or the cheaper manufacturers could just produce cells that comply with the standard 21700 = 21mm x 700 mm… Facepalm
mortuus
mortuus's picture
Last seen: 1 min 53 sec ago
will new lights be sold on banggood ?
...where Frugal meets with Flashlight!
hodor
hodor's picture
Wasn’t the S12 meant to have Crescendo?
hasddie293
hasddie293's picture
Last seen: 2 days 10 hours ago
Why simon didn’t include the battery option while the store is selling battery?
In search of the most ideal flashlight in town:
1. BRIGHTNESS
2. Durabillity
3. Design
4. Quality
5. Price$$$
