【convoy】17mm SST40 driver with biscotti firmware and temperature protection will be available
2162 posts / 0 new
Barkuti
Barkuti's picture
Last seen: 15 min 15 sec ago
Know what? In Italian language biscotti is the plural form of biscotto, which means cookie/biscuit. Thus…
 Biscotti!
https://www.bbcgoodfood.com/recipes/1580654/millies-cookies-recipe
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Simon Mao
Simon Mao's picture
Last seen: 2 hours 38 min ago
everydaysurvivalgear wrote:
Hey Simon when will the new biscotti drivers be for sale?
several days later
d_t_a
Last seen: 2 hours 49 min ago
In Biscotti, the default 5 levels are 0.1%, 1%, 10%, 35% and 100%
On a 7135×8 = 2.8 Amps, this results in approximately: 0.003A, 0.028A, 0.280A, 0.98A and 2.8A.
For the SST40 version, what is the 100% Amps value? 5 Amps or 6 Amps?
Also, from what I understand, the original “Biscotti” driver does not have temperature protection (unlike “Bistro” firmware), so my question is this “Biscotti” for SST40 an adaptation of the original “Biscotti” driver — what I mean is, it tries to follow the similar brightness levels of the original Biscotti driver, but is not the same “Biscotti” driver?
Sorry if my question sounds confusing.
Yokiamy
Yokiamy's picture
Last seen: 9 hours 27 min ago
The firmware called biscotti is just flashed into that driver, so same functionality, other current output.
The max output differs from the 17 mm and 22mm, the 22 standard delivers upto 6A, where the 17mm maxes out on 5A. Also a 6A might be available.
Playing with sense resistors might help allowing to change the max desired output current (up to 8A)
oweban
oweban's picture
Last seen: 8 min 38 sec ago
I’m also wondering how it’ll go re: reflashing – I wouldn’t mind making some custom levels for it.
extremesquared
Last seen: 1 month 1 week ago
All the links to item pages are broken.
Edit: Never mind, it is an aliexpress problem. All item pages are broken.
Jerommel
Jerommel's picture
Last seen: 4 days 21 hours ago
Simon’s shop is closed for about a month.
Iirc he did this before, taking down everything.
(not this time though)
Happy holidays, Simon. Thumbs Up
Lightbringer
Lightbringer's picture
Last seen: 1 hour 18 min ago
Simon Mao
Simon Mao's picture
max 5A, it still has temperature protection
oweban
oweban's picture
There were some C8+ on neals briefly with white flat 1 and I’d assume 5A driver – missed them, damn! Would be good to make one with either WF1 or WF2 (WF2 can handle more current IIRC, could do a resistor mod…)
Yokiamy
Yokiamy's picture
Owen
It really depends what you’re looking after, a larger diameter head will give you a lot more throw, i have used a white flat in a C8 and placed it in a L21A later on, but the L21A gives a lot more throw with the same emitter (it is also driven harder now)
oweban
oweban's picture
I really should make a mock-up of how big those lights are…
Barkuti
Barkuti's picture
Question and suggestions (for Simon and/or anyone else).-
What are the actual (modder and tinkerer) differences between the classic 26650 L2 and the 21700 L21A? As far as I know, the L2 fits all 26650s, including the slightly wider, market leading Power Long Battery cells. However, I heard somewhere that the L21A has problems with some 21700 cells, i.e. the tube is too tight. If this is so, I would ask the machine shop to slightly widen the internal diameter of the L21A tubes (to ∅21.8 - 21.9 mm), modifying the drawings in the process, this way the L21A would be more appealing and trouble-free. Tip: Lishen cells are the widest I believe, at ∅21.7 mm with a single wrap, see just below:
Both fit ∅22 mm drivers with a little bit of filing, ∅21.5 - 21.6 mm driver bay. Don't know how deep is it but I guess very powerful buck or boost drivers can be used. 21700 extension tubes may appeal to someone.
zeremefico
zeremefico's picture
Last seen: 2 hours 41 min ago
I had problems with rewrapped 21700 cells like Sofirn, with L21A. 50E cells fit fine.
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
Amiran
Last seen: 1 month 1 day ago
Got this driver on c8+ and just swapped sst40 for flat white andforgot to apply the led gasket when screwing the reflector bit so might have shorted the driver… now led comes on and off only 0.01 % brightness or something you can only see if you look at it…
Anyone experienced this? Can you reset the driver after shorting the output?? I ordered one from big but don’t want to wait to test the c8 light sabre with flat white.
Thanks
polarweis
polarweis's picture
Last seen: 1 week 2 days ago
Amiran wrote:
Got this driver on c8+ and just swapped sst40 for flat white andforgot to apply the led gasket when screwing the reflector bit so might have shorted the driver… now led comes on and off only 0.01 % brightness or something you can only see if you look at it… Anyone experienced this? Can you reset the driver after shorting the output?? I ordered one from big but don’t want to wait to test the c8 light sabre with flat white. Thanks
Sounds like shorted driver. It can be fixed by replacing parts but thats pretty difficult.
"It wouldn’t be so bright if there wasn’t a shadow every once in a while." - Jason Mraz
d_t_a
What are the actual (modder and tinkerer) differences between the classic 26650 L2 and the 21700 L21A? As far as I know, the L2 fits all 26650s, including the slightly wider, market leading Power Long Battery cells. However, I heard somewhere that the L21A has problems with some 21700 cells, i.e. the tube is too tight. If this is so, I would ask the machine shop to slightly widen the internal diameter of the L21A tubes (to ∅21.8 – 21.9 mm), modifying the drawings in the process, this way the L21A would be more appealing and trouble-free. Tip: Lishen cells are the widest I believe, at ∅21.7 mm with a single wrap, see just below:
Both fit ∅22 mm drivers with a little bit of filing, ∅21.5 – 21.6 mm driver bay. Don’t know how deep is it but I guess very powerful buck or boost drivers can be used. 21700 extension tubes may appeal to someone.
Regarding which batteries fit… my experience:
The Convoy L2 won’t fit the Keeppower protected 6000mAh 26650, as per my test. Some 26650s are also tight (may fit when battery is pushed into the tube, but the battery won’t slide out when turning the tube upside down – so it’s that tight).
The Convoy L21A battery tube seems to suffer the same somewhat tight 21700 (it won’t fit the Sofirn 21700, Liitokala Lii-40A, nor iJoy 3750mAh 21700, as per my testing). Genuine Samsung 21700 and LG 21700 appears to fit.
Simon Mao
Simon Mao's picture
new batch has 22mm inner diameter ,dont worry
Simon Mao
Simon Mao's picture
6000mAH has unconventional size
Yokiamy
Yokiamy's picture
I can confirm that, the new tube diameter is 22mm and now a Shockli cell fits.
Also the tailcap is shorter
Anthon
Last seen: 2 days 8 hours ago
What about the S21A? Is there a new batch with more diameter?
Blggg
Last seen: 4 hours 21 min ago
The S21A from the later batch (at least the one I bought about a month ago) can accommodate the Lishen batteries now.
id30209
id30209's picture
Last seen: 9 hours 24 min ago
Simon, is there a possibility to buy just the pill with mcpcb screws and driver retaining ring for S21A?
WTB  Jetbeam TCR1  &  Titanium 47 2xAA Quark
Yokiamy
Yokiamy's picture
Send him a message on AE after CNY, he will help you.
id30209
id30209's picture
Cheers
whatsthepoint
Last seen: 2 hours 29 min ago
I've been interested in seeing the SST40 driver with biscotti firmware making it to the Convoy Store for ordering
The Convoy Store on AE has message that it planned to open on or about  February 10th,that's tomorrow.
I think the odds are on it getting delayed further,maybe a couple more weeks
It doesn't look good in China yet.
never underestimate the power of stupid people in large groups
Nooner
Last seen: 4 hours 57 min ago
Hi Simon.
Any news on the Biscotti 5 amp (sst40) 17mm driver?
Thank you.
oweban
oweban's picture
I don’t remember if it was posted before and it’s difficult to search on my phone – is it possible to get that flat-top adapter for the 4×18A by itself? Would be hugely helpful and far better than me trying to solder little copper things onto batteries.
Hope all is well over there.
FlashPilot
FlashPilot's picture
Last seen: 6 hours 26 min ago
+1 on that! Id like to buy a few of those plate adapters as well.
oweban
oweban's picture
Would be super helpful for other lights like the BLF Q8 Wink
