【convoy】L6 GT-FC40 high CRI on sale now
4600 posts / 0 new
id30209
id30209's picture
Last seen: 1 hour 12 min ago
I could swear i saw SS switches with lighted transcent plastic around the switch...
I hope somebody can confirm and add some info as well
WTB Titanium 4sevens 2xAA tube
oweban
oweban's picture
Last seen: 3 weeks 1 day ago
The metal switches have a bit of transparent plastic around them, but it requires a lot more light to shine through.
id30209
id30209's picture
This is what am talking about.
https://youtu.be/YevADDmBQ48
And that guy has lighted SS switches in every Convoy 0_0
Lightbringer
Lightbringer's picture
Last seen: 9 hours 21 min ago
Umm, like I said… LOL
stephenk
stephenk's picture
Last seen: 3 weeks 3 days ago
ferrat_val wrote:
1stein wrote:
id30209 wrote:
Vietnamese FB group showed S21A colored…
Available @ Simon’s Ali store
Actually, I don’t see any point in S21A since S21B became available – it beats S21A in both looks and functionality.
Can someone explain the difference between the S21A and S21B?
id30209
id30209's picture
Lightbringer wrote:
Umm, like I said... :))
Sorry if am asking again but English is not my first language...so about what part you were talking about exactly?
Lightbringer
SS tailswitch, like on colored S2+es.
oweban
oweban's picture
That seems to have extra plastic around it though. Not a standard S2+ switch…
id30209
id30209's picture
Ok, lol, that i am aware of. Have it here...
Guy in video have some kind of a plastic around the SS switch that shows some light which my S2+ doesn’t have...
And i’m still confused with your answer.
id30209
id30209's picture
oweban wrote:
That seems to have extra plastic around it though. Not a standard S2+ switch...
Exactly. Thx oweban for pointing it out
Lightbringer
Point being, might be possible to undo any retaining ring, swap the switch-board for a lit switch-board if it fits (might need a washer or something if not), and let the light leak through.
darosk
darosk's picture
Last seen: 1 week 3 days ago
What’s the difference between the s21a and S21b?
My Lights (Updated: Feb 5, 2021)
Serlite
Last seen: 8 hours 5 min ago
Based on the pictures, the S21A is like the S2+, whereas the S21B is like the S11.
Other than that, they seem to have the same UI options and similar emitter options. (The S21B does have some OSRAM variants though.)
The S21A also has an OP reflector while the S21B has a smooth one, but that might be customizable if you placed the order with Simon.
darosk
darosk's picture
So the difference is just the host shape? They both use the same battery, and I guess either can use any of the choices of emitter and reflector that Simon offers.
Just trying to clarify.
Would be nice if someone could come up with a chart for all the different convoy hosts and what their names mean Big Smile
oweban
oweban's picture
I tried that a while ago. It was….. painful.
JaredM
JaredM's picture
Last seen: 1 hour 4 min ago
Generally, I think Simon meant S, M, and L names to represent small, medium, and large. The numbers in the early days used to be random/sequential according to their design and/or release date. Now, it appears the numbers refer to battery configuration mostly and suffix letters are now the version indicator based on time of design/release. It’s confusing when legacy names / models are still popular (S2+, M2, L6 etc.).
For example, the M21 series are all “medium” sized lights, and use a 21700. The “A” was released first, and there are B and C variants that came after. Unfortunately for those trying to associate the name to a design, they are not in order of size. Small to large goes B to A to C.
Blggg
S21B accepts 22mm driver and its PCB base is integrated shelf instead of pill, while S21A accepts 20mm driver and uses pill.
darosk
darosk's picture
Yeah I’ve been able to figure it out mostly based on the photos and random forum posts. In some of the previous models in his Shop he even writes it in the picture/listing (for e.g. M21A – C8+ 21700 version). Would be convenient if that were done on all the relevant models but is probably a lot of work.
darosk
darosk's picture
Awesome! That helps a lot – thanks Smile
Simon Mao
Simon Mao's picture
Last seen: 3 hours 12 min ago
m47mu74nt wrote:
Hello Simon,
Since I modded my Z1 with a 4 LEDs 10W IR emitter … so now I’d like to “know” when it lighten up or turned off (without looking directly at the LEDs which emit a dim red when ON) : could it be possible to get a lighted switch that would fit the Z1?
thank you
I am producing a lighted switch with a diameter of 20mm
Di_Joker
Di_Joker's picture
Last seen: 1 hour 51 min ago
Someone tried to put the 21700 battery in the Convoy S11? It works? Will the positive terminal of the battery not deform?
Sorry for my poor english.
contactcr
Last seen: 57 min 5 sec ago
It’s generally not worth lighting the stainless switches. it requires so much current to even be visible that it’s just a battery drain IMO.
m47mu74nt
Last seen: 10 hours 31 min ago
Simon Mao wrote:
m47mu74nt wrote:
Hello Simon,
thank you
excellent ! I’ll order one as soon as it is available Party
1stein
1stein's picture
I tried with Samsung 50E and 40T – both work fine. Although I’ve put things together by myself but I assume stock version will take 21700 as well. Some “protected” 18650 are 5-7 mm longer so most of producers take it into account. Just pay attention your 21700 is 70mm long, not more. Which means it must be unprotected which (IMHO) is better. But I would recommend to use it with the adapter. S11 can take 26650 which means 21700 may rattle inside. The difference between 26650 and 21700 is 5mm, while between 21700 and 18650 is 3mm. When you bump your flashlight – this may make a difference.
darosk
darosk's picture
Does anyone have beamshots of the lh351d 3500k or 2700k?
sochi111
sochi111's picture
I would be interested to see these as well.
id30209
id30209's picture
To everyone owns M21C-U, does your light after switching on high in 4mode setting step down from HIgH to moonlight within 10seconds?
Caramba just asked me about it if i have this problem he is experiancing and i just checked mine and it does this within 10s when set to MAX.
Weird...
LTC
Last seen: 1 week 1 day ago
Weird…
Yes, I noticed this on my M21C-U for 4 mode. This happened on high mode turn off(memory) and turn on again. It also happened for from off, double click to high.
I did some testing. This happened when battery is 3.8 volt and below. With a fresh battery, everything is fine.
I’m using P42A and 40T for M21C-U.
id30209
id30209's picture
My combo exactly.
It shouldn’t step down from 100% to 0.1% at 3.8V
merlot
Last seen: 7 hours 8 min ago
I’ve got an lh351d in 2700k coming in the post, I’ll post pictures when it arrives
id30209 wrote:
My combo exactly.
I’ve just tested mine (with the xhp70.2) and it doesn’t do that, maybe the cell in yours isn’t providing the required voltage for that current.
