I am new in building flashights by myself, could you please take a picture of how you have soldered driver to a pill?
I did solder a 8x driver to a brass pill for a S2 mod once, and it was a total mess :
As the pill takes all the heat, the solder won’t stick to it, I finally succeeded using open flame soldering, getting the whole pill enough heat that it could melt solder by contact … worked fine but the result is not pretty
I found that the solder on sticks to the top surface of the pill
Texas Ace Lumen Tube calibrated with maukka lights
A heat gun is in any case a very recommendable tool for electronics work.
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
Perhaps opportunistic, but do AliExpress coupons stack with discounts that Simon may give? I’ve got a project I’m working on, and am trying to do it in the most cost efficient way I can.
… do AliExpress coupons stack with discounts that Simon may give? …
Yes it does. Apply your coupons, select some alternative payment method you can discard and then proceed to message Simon. Done.
… hmm looks like I can only do credit card or PayPal. I might have missed earlier in the thread if you do PayPal and then just not pay....?
You must see WebMoney, choosing WebMoney works. Choosing PayPal should also work no problem. Just dismiss the payment page in any case.
Alternatively, you can use AliExpress application 8.4.0 or earlier. With it you can select “other payment methods”, the archetypical way. The app checks for updates just on startup, it counts the number of times it asks you to update and after a number of refusals it ends up forcing you to update (or clear application data). This is solved by launching the app while on airplane mode, while it shows the launching advertisement. As I've found many times, old versions of software can be better.
Sat, 11/28/2020 - 03:32
Can somebody help me please? I had M21B with SST40 for some time then bought S21B with CULPM1.TG and decided to switch leds – install SST40 into S21B and CULPM1.TG into M21B. I have replaced leds, but faced a problem with gaskets – the one from S21B is too small for SST40 and the one from M21B is too big for CULPM1.TG. What gasket should I order for SST40 in S21B and for CULPM1.TG in M21B?
Is it possible to add a backlit button (or something like that) to my convoy c8+ with Biscotti firmware?
Unless you are using it with single mode, or
unless you mod the driver with a resistor, or
unless the new drivers are prepared to be used with a lighted tailcap…
I would say “no”, because it will jam the modes order (wether you have memory configured or not).
Using Biscotti with lighted tailcaps will make it jump when you turn OFF/turn ON the light. Specially if you are used to always start in the lowest/highest modes of the sequence. If you don’t care about it turning ON in a random mode, go for it
Overall impressions of the S2+ with KY CSLNM1.FY – “beautiful” golden/orange beam, with some colour rendering. Warmer than the 2700k SST-20, but not as warm as the XP-E2 Amber. 5A driver is completely over the top for this emitter, and it gets too hot within a few minutes even on 35% output, thus I’ll need to use it on 10% or 20% for night photography. This emitter would better suit a 3 or 4*7135 S2+.
I am glad, that not only me, but other people are saying this. (I already made here a warning few weeks before, as I had experience with a build including this emitter.)
For small bodies like S2+, 4×7135 should be the best (I’d go with the 5-30-100% plain old but good driver).
For a Convoy C8+, I think, 6×7135 would be a sweet spot, maybe 8×7135, if somebody goes for the safe maximum output.
lighted switch is compatible with any drivers except 7135 biscotti
How do I know if I have that driver?
Troubleshooting;
- Can you make a photo of the driver?
- In which light is it installed?
- Do you have the record of where/when you bought it (I mean, the description of the product and if it was on Convoy Store or elsewhere)?
These are the first things. Then you can look into a Biscotti cheatsheet check the operation and see if it responds as it should
Troubleshooting;
I bought it from here , it does have biscotti firmware. Also does the switch work with the SST40 driver running biscotti like the one found in the s21b? link
I bought it from here, it does have biscotti firmware. Also does the switch work with the SST40 driver running biscotti like the one found in the s21b? link
That uses one of the newer, non-7135 MOSFET linear drivers. Compatible. The S21B uses the same driver architecture. Compatible too.
Perfect.
Thanks for the clarification.
WTB Titanium 4sevens 2xAA tube
Much better than what I came up with !!
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
Thank you. I will try this myself.
ferrat_val you can solder to pills with heat guns. I for example own a 650W PG8018LCD, and it rocks:
Bought it here long ago (not affiliated).
List of my reviews over at 1lumen.com
oweban.org
I recently got an M3 from Banggood in a flash sale not realising that a version with ramping (and charging!) had finally been released.
Thanks, will give it a try.
Edit:: hmm looks like I can only do credit card or PayPal. I might have missed earlier in the thread if you do PayPal and then just not pay….?
oweban.org
Yeah, WebMoney doesn’t appear for me.
Looks like it’s a moot point now; the coupon I had was for Black Friday and has now expired, it seems. I’ll send Simon a message at some stage.
oweban.org
Simon, does the M21C tailcap fit on the M21C-U?
To the best of my knowledge, M21B opening is 9mm, and S21B is 7mm. So 9mm 4040 and 7mm 5050.
oweban.org
MY REVIEWS THREAD /// My Flashlight Collection ///
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// GIVEAWAYs: 1 / 2
Thanks,
Troubleshooting;
This is how AMC7135 drivers look.
Someone do an overview of all of the different OSRAM emitters. I’m confused.
Check page 126 of this thread.
Recent Reviews: Light Flashlight Painting Buying Guide 2020 // LumeCube 2.0 // Lumintop FW1A // Light Painting Paradise Lightpainter // KDLITKER E6 // Sofirn SP31V2.0 // Convoy S2+
Affiliate links: Neal's Gadgets
Instagram: @stephenk_lightart
OSRAM LED’s for max throw
Color Part # footprint (LED surface) Max/Pulsed Peak Output (A)
White – KW CSLNM1.TG – 3030 (1mm²) W1 3/3.3 A 4.5-5.0 A (W1/NM1)
White – KW CSLPM1.TG – 3030 (2mm²) W2 5/6 A 7.0-8.0 A (W2/PM1)
White – KW CULNM1.TG – 4040 (1mm²) 3.3/4 A ~6 A (Boost HL)
White – KW CULPM1.TG – 4040 (2mm²) 6.6/8 A 9 A (Boost HX)
Red – KR CSLNM1.23 – 3030 (1mm²) W1
Blue – KB CSLNM1.14 – 3030 (1mm²) W1
Green – KP CSLNM1.F1 – 3030 (1mm²) W1 3/4 A 6.5 – 7.0 A
Green – KP CSLPM1.F1 – 3030 (2mm²) W1
Yellow – KY CSLNM1.FY - 3030 (1mm²) W1
More OSRAM Website links
3030 variants
4040 (boost) variants
From oweban:
https://i.imgur.com/5K2rv1k.png
Thanks for that, very useful. The image especially helps boil it down.
My Lights (Updated: Dec 1, 2020)
