【convoy】GT FC40 1800-2000K R9050
6481 posts / 0 new
Sari33
Last seen: 6 hours 21 min ago
seems to be with pill.For single emitters I prefer the design of the Blf A6 where it’s very easy and quick change lenses
Pilotboy
Pilotboy's picture
Last seen: 9 hours 3 min ago
Simon shows the optics for his upcoming quad – the S21c
photo and info credit: u/kanakana2
u/kanakana2 says: “According to Simon on FB, the host is still in production, 2 months out”
Simon Mao
Simon Mao's picture
Last seen: 21 hours 26 min ago
Sari33 wrote:
Simon Mao wrote:
Sari33 wrote:
Simon,can GT FC40 manufacture made 1800k~2000k Led high Cri 3535 and 5050 size at 3V?
no problem to produce 1800-2000K LED ,but the voltage is 12V
Can’t find these CCT at 3V in high Cri and standard sizes.Let me know if you find others source
I would use them on small host, maybe the boost driver is too large
what’s max input current?
Simon Mao
Simon Mao's picture
Correllux wrote:
Simon….when you’re not busy…:)
Can you find a better spring solution for the M3 light?  I think others have noticed it also but with the single spring in the tail it just isn’t strong enough to keep the weight of the 26650 cells in contact with the brass button on the driver when set down on the tail, so the light cuts out.  I notice with mine that if I’m on moonlight and set it down gently, it will cut out and actually shut off the light.  On any normal/higher mode it will blink but not shut off.  I’ve tried stretching the spring but of course that wasn’t enough.  It seems like at the base of the spring coils there is about 2-3mm of space that the spring will lower into as weight is put upon it, reducing the spring length maybe extra than was designed?  But with the brass button on the driver instead of a spring, there is no give/support for when the battery moves in the tube.  The spring quality is excellent, maybe just needs to be longer or made of thicker wire?  Someone posted a photo here where they cut a small piece of rubber tubing to put below the spring to limit its travel/compression but that seems less than ideal solution.  It’s a minor but important small defect in an otherwise wonderful flashlight design.
And what’s this S15 photo…?!!  I like that.
i asked the factory to shorten the middle tube of flashlight ,it will be changed in the futurn ,
currently Users can use 26mm board to fill the gap
Simon Mao
Simon Mao's picture
darosk wrote:
More shots of this ‘S15’. I’ve never heard of this model. Is it a knock-off? Prototype? Really old stock?
Simon, can you comment on this?
From the Shopee listings it comes in SST20 but only 5000K or 6500K. Roughly $12 converted to USD.
As a low-cost flashlight, S15 is only used for my salesperson to sell on shopee LAZADA
Simon Mao
Simon Mao's picture
Yes ,you found it Big Smile
Simon Mao
Simon Mao's picture
At the same time, I plan to launch a S21A SST20 flashlight, the price will be low, suitable for ordinary users.
Sari33
2.5~3 Ampere would be enought with Duv below BBL at very low current
JizzusCrust
Last seen: 4 months 1 week ago
Hey Simon. I noticed that the T2 with 219b is not available anymore. Have you stopped production?
captainkirk
Last seen: 5 days 7 hours ago
Perhaps he is updating that batch with the 12 mode driver. I know that is what I am waiting for. ;0)
This space for let.
jasontheguitarist
Last seen: 1 day 6 hours ago
It might end up having different mode groups than the regular 12 group driver, I don’t think he ever posted what the final modes are going to be. The 0.1% mode wasn’t going to be included because it wouldn’t work for some reason.
darosk
darosk's picture
Last seen: 1 day 19 hours ago
I dm’d him on AliExpress, he says they ran out of T2 drivers.
My Lights (Updated: June 20, 2021)
d_t_a
Last seen: 18 hours 48 min ago
I also noticed the Convoy S15 in Lazada, Shopee and Taobao.
It appears to have SST20 and SST40 LED options.
I’m guessing your Lazada/Shopee store name is MaoMinHui and MH-Lighting Store?
Alen
Last seen: 21 hours 17 min ago
Simon there is coupon on your Ali store?
For orders over 10$.
Tangra
Last seen: 2 weeks 1 day ago
Review of L7.
4700 lumen instead of claimed 5900 lumen.
100% for 80 seconds in room ambient.
Not good.
https://1lumen.com/review/convoy-l7/
will34
will34's picture
Last seen: 7 hours 33 min ago
To be fair the SBT90.2 was never meant to produce 5,900lm with that buck driver… not sure why the exaggerated claim.
100% for 80 is plenty good and the review says it got to 77°C, if anything it’s the lack of cooling or mass that’s stopping it from higher output, not the driver. It still gets 3000+ lumens for almost 1 hour of regulated output which is impressive and better than most SBT90.2 lights out there.
yasenf
Last seen: 44 min 30 sec ago
While most of the review was focused on the Turbo, I can add, that I found level 2 and 3 particularly useful for work or walk, while still providing a lot of runtime, throw and spill. Of course I wouldn’t bother with 700 grams in the hand for lower levels only, but you still have the goodies of the turbo if you need it. Overall just like the reviewer I find it a good upgrade of L6. And L6 also gets toasty Big Smile
Tangra
L7 modes are % of current over LED. And they are not relevant to output lumen.
Good to mention.
Convoy L6 can hold 100% or 4300 lumen nonstop in outdoor condition. Except tropical areas.
Simon Mao
Simon Mao's picture
Chip out of stock.
I am trying a new chip, unfortunately the efficiency has dropped from the original 85% to 70%
Simon Mao
Simon Mao's picture
12 groups in design ,there will be two kinds of driver
Simon Mao
Simon Mao's picture
My sales staff’s shop, I have limited energy , I can’t manage so many shops Big Smile
Simon Mao
Simon Mao's picture
Alen wrote:
Simon there is coupon on your Ali store? For orders over 10$.
leave me message on ali ,i will tell you the discount code
MascaratumB
MascaratumB's picture
Last seen: 27 min 22 sec ago
I’ll be looking for them Wink
Simon Mao
Simon Mao's picture
Maybe i can order NVSLE21A from nichia directly
dthrckt
dthrckt's picture
Last seen: 1 week 3 days ago
SFT40s expected back in stock?
Techno
Last seen: 1 day 5 hours ago
Does the Convoy S15 sold on Lazada work with standard S2+ accessories?
magnet, TIR lens, pocket clip
X
Deluminator
Last seen: 5 hours 45 min ago
Any chance you will be stocking 219b sw40?
Techno
F, my hand slipped and I ordered the Convoy S15.
Once it comes in, will take photos of the gray S2+ and gray S15 side by side.
X
d_t_a
from left to right:
Convoy S6 (XM-L2, 5/3-mode group, ~2.8 Amp)
Convoy S15 (SST40, 4-mode driver ~ 4.5+ Amp)
Convoy S15 (SST20, 4-mode driver ~ 2.8 Amp)
Convoy S2+ (Nichia 219C, original Biscotti, ~2.8 Amp)
I’d say that the S15 reflector looks the same as the S2+ (side note: S6 has a much deeper reflector, probably similar to the S2 reflector)
JaredM
JaredM's picture
Last seen: 25 min 3 sec ago
The S6 was my first love in Convoys. That deep reflector didn’t pair as well back in the day xml2s were all the rage, but nowadays with Osrams and the like, I hope to see it again.
https://fundrazr.com/osturaband
No affiliation, just a fan.
