Could we perhaps come up with a different config list of mode groups for Convoy’s 12 group firmware, most of it is groups no one would use.
I’d especially love that 50% level in with the 100%, sure it may not be a big visual difference, but it allows for longer runtime and longer bursts than 100%
Also each blink in config represents each group, it’s way too slow as it is currently
How I would love a group where the low, med, high could be configured by the user. Like a ramping menu to set the brightness.
Personally I think the 0.1%, 1%, 10%, 35%, 100% spacing works well. 35% on the 5A versions is approximately where the lights balance due to thermal limiting, so I set it on 35% and know that the brightness will be relatively stable for night photography. The only improvement I would like to see is a constant frequency strobe instead of the terrible alternating/two frequency strobe.
I guess it depends on what it’s being used for. I’m a dealer and stock the C8+, L21A & L21B for hunting, so 50% allowing a longer duration is far better than a short burst on 100%. For example the 5A driver paired with the NM1 gets 3 minutes at 100%, where 50% gets quite a decent amount longer and when you’re out searching for animals you need the extra range than what 35% provides.
At the moment I’ve discussed with Simon to get the SST40 ramping firmware on the Osram red model. The 100% level is too bright for closer range and it’s spooking the animals, and 20% is far too dim to be useful. Having adjustable levels is going to be awesome. Currently the 100% level is 280 lumens and the 20% level is only 20 lumens, so it’ll be great to have access to everything in between.
I get that the 35% suits general use, but it has been brought up quite a few times for others also. It’s not always about the maintained temperature, it’s also about runtime
Gents, wouldn’t be better if you could set each level of output to your own liking?
We have such a driver already in Simons store, now all it needs is a bit tuning and that’s it.
Ramping driver just calls for v.2 upgrade and to be imported in aa/liion, boost and buck options that Simon has.
Yes, but it would be great if it was an additional UI on the 12 mode groups so people have a choice as to what they prefer. That would be the ideal driver I reckon.
Have 3 levels that are user configurable, I reckon that would be quite popular.
Some improvements can be made on the modes on the 12 group driver, but what i really wish for is battery check with 4 or 5 quick half clicks. I have 4 of these installed and always use group 5 no memory. Temperature step down should be able to be disabled or adjusted.
Ramping driver is quite nice for “tactical” use even with reverse switch. It can be improved with two way ramping and 4-5 click special mode access.
Funtastic, some interesting UI suggestions! Definetly agree a review of the various modes would be nice.
I’ve just received a M21B GT FC 3000-3200K and S2+ sw30k, really loving the warm tints + hi cri.
Have been running the UI on the default mode with memory mode turned off. I find this very usable and I can get into battery check easily enough (after a short epileptic episode) which is a nice feature.
- the best way to predict the future is to create it -
I've just received a M21B GT FC 3000-3200K and S2+ sw30k, really loving the warm tints + hi cri.
Nice! i just ordered the same M21c, my first GT FC40 light, and i ordered some sw30 bare leds as well on a "whim". I also ordered that AWESOME m21e in 4000k, but still am wondering if i shoud've went 3000k like my gut was telling me to do..
Haven’t been on in a couple weeks and randomly discovered these new lights in Simon’s store. Man, they look great! The T3 looks interesting, and the IR lights. Also saw that he was able to source the ring magnet for the T2 tail cap in a proper 4mm height, and they’re at a good price, too. I had to source some thinner 2mm from a store on ali and glue them together, and paid more than I wanted for ten of them. I messaged four vendors and none of them could source a thicker ring in that size…Simon’s got the connections!
Simon and Convoy CONTINUES to have THE YEAR! all of the new releases (4x18 sbt90, 3x21a, L7, new gt fc40 variations, and sft40 variations!) are awesome so far, and then he comes out with the M21E!. so awesome. Very exciting for us Convoy and flashlight fans, Simon. Thank you!
What I’d love to see is the M21E, M21D etc use the SFT40. Yes, I know it would require a new driver, but currently Convoy have nothing for longer reach using a side switch, except the SBT90.2 models. Need something a wee bit more compact
Needs to have a bit more grunt to compete with most out there now.
Sofirn now have the IF22 & IF22A. Convoy doesn’t have anything much in terms of longer range. There’s other brands I could stock, but I just love Simon’s pricing and customer service, unbeatable I reckon
driver for M21E with KW CULPM1.T/SFT40 in production now
How do you put in for the t3 preorder? Why is $999 ??
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
That is just a placeholder. When they are ready Simon will let us know.
This space for let.
We’re gonna need the info on that T3. Is that using the new 17mm 12 group AA/14500 driver?
Piercing The Darkness YouTube channel – https://www.youtube.com/c/PiercingTheDarkness
For this new T2 driver I’d like to keep a real 0.1% mode (sometimes it seems bit higher in my S2 + driver)which is useful indoors and close spaces
Recent Reviews: Best Flashlights for Light Painting Photography 2022 // Battery and Charger Buying Guide 2022 // Olight Array 2S Headlamp // Acebeam E70-AL CRI95+ // XTAR VC4SL Charger // Sofirn D25LR Headlamp // Convoy T4,S21D,M3-C // Sofirn IF22A // Ants on a melon RGB Critter
Affiliate links: Olight AU // Olight USA // Acebeam
Instagram: @stephenk_lightart
Gents, wouldn't be better if you could set each level of output to your own liking?
We have such a driver already in Simons store, now all it needs is a bit tuning and that's it.
WTB Titanium 4sevens 2xAA tube
USB power meter/tester thread
Temp cannot be adjusted when most of the drivers rely on the NTC. Temp can be disabled by removing it
I don’t know how certain it’s measure beam rebounce from wood color table but still quality emitter
the reflector of M21E and C8 are the same
yes
Cool. I’m gonna need one of each color and like 5 of those drivers for other AA sized lights I have sitting around.
Simon, do you run the “Dongguan Kangwoyi Electronic Co.,Ltd” store on Amazon US or is that a reseller? Thank you.
Reddit | Grizzly’s Reviews | YouTube | Convoy Guide
It’s my company.
The pronunciation of “Kangwoyi” in Chinese is similar to the English word “convoy”.
Hi Simon,
Curious and will be nice to know…
I thought Chinese name for Convoy is 毛裤?
毛裤 is my nickname
googling 毛裤 turns up some interesting images
Yup.
I'm seeing people wearing pants that look like very hairy legs.
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread
Hairy pants for the win!
M4U not suitable?
https://fundrazr.com/osturaband
No affiliation, just a fan.
