【convoy】S21E TYPE-C 21700 flashlight available
8426 posts / 0 new
Azirine
Last seen: 18 hours 15 min ago
Simon Mao wrote:
I’m ready to use FET 12A driver for S21D
What are the differences between S21D 519A 10° flat and bead? And how does it compare to M21B GT FC40?
LTC
Last seen: 8 hours 45 min ago
Hi Simon,
Can you add in the details in your listing for 519A 2700K LED? Details as in sm27*M***LR9080… Thanks.
519A Listing
max
max's picture
Last seen: 1 day 14 hours ago
Hi Simon,
Is there any new discount working code now?
The previous one ESW5KOXA1572 is no longer working.
Thanks.
 max
Simon Mao
Simon Mao's picture
Last seen: 17 hours 29 min ago
lotari wrote:
Simon Mao wrote:
tactical_grizzly wrote:
Simon Mao wrote:
lg.tech wrote:
@Simon, any idea when the SFT40 5000-5700K and the new 17mm 6V boost driver will be available?
LUMINUS may not produce 5000-5700k sft40,
I got 17mm 6V 4A driver sample , But I’m not sure which LED to apply it to, what about XHP50.3 HI ?
I think XHP50.3-HI is an excellent choice. Will you stock it in multiple CCT’s? I would love to install it in a C8+ in 4000K.
I don’t know why XHP50.3 XHP70.3 has been on the market for so long, but we can only buy white light.
Simon, there are versions of the 5700K XHP50.3 and XHP70.3, with 95+ CRI and 95+ TLCI (Television Lighting Consistency Index). Are those available to you?
They are specially made for broadcast use, thus would probably be of interest for the many photography and video users of your products.
https://cree-led.com/applications/broadcast
CTRL+F: broadcast
https://cree-led.com/media/documents/XLamp-XHP50.3.pdf
https://cree-led.com/media/documents/XLamp-XHP70.3.pdf
Order codes:
XHP50.3 HI: XHP50D-H0-B001-AD0ZG20E2
XHP70.3 HI: XHP70D-H0-B001-AD0ZK20E2
Although the official data is released, only the 6500K white light of Ra 70 can be purchased on the market.
Simon Mao
Simon Mao's picture
The effect of 10deg TIR LENS is similar to that of the M21B FC40, while the concentrating effect of 10deg is slightly better.
Simon Mao
Simon Mao's picture
max wrote:
Hi Simon,
Thanks.
The discount rules of the AliExpress platform have changed, I need time to think about how to set the discount.
Simon Mao
Simon Mao's picture
LTC wrote:
Hi Simon,
519A Listing
sm305M350L6R9080
sm275M350L5R9080
LTC
Thumbs Up Thumbs Up Beer Beer
Simon Mao wrote:
LTC wrote:
Hi Simon,
519A Listing
sm305M350L6R9080
sm275M350L5R9080
code2142
Last seen: 1 week 6 days ago
Those MAO S2 and S21 look great. Any ETA on when they will be available?
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 52 min ago
@simon, is there a specific date for when the MAO M21B will be released?
Early August/mid-August?
Simon Mao
Simon Mao's picture
About three or four weeks.
Simon Mao
Simon Mao's picture
BlueSwordM
Thank you for the information Simon.
I will hopefully be able to buy a MAO M21B GT-FC40 4-4.5k as soon as it releases Big Smile
Simon Mao
Simon Mao's picture
MAO C8 sample and B35AM 5700K
lg.tech
Last seen: 5 hours 19 min ago
!https://live.staticflickr.com/65535/52192445781_4e9cd67999_b.jpg!
Very nice, and love the 5700K B35AM option too, but why the old style C8?
Simon Mao
Simon Mao's picture
Just a sample ,i will produce MAO C8+
lg.tech
Excellent.
I think I’ll stick with the S2+ in MAO and Ti, M21B in MAO, but I may have to order a C8+ in MAO for my dad. Smile
Maverick1947
Maverick1947's picture
Last seen: 1 day 3 hours ago
Hello Simon! I really want a S21D but with the 8A driver. When will it be available again?
There’s no replacement for displacement.
Hoop
Hoop's picture
Last seen: 2 hours 16 min ago
Does the S21A host include an AR window or is it uncoated?
Barkuti
Barkuti's picture
Last seen: 27 min 54 sec ago
kokosnh wrote:
Is there only 4-6V trigger for LVP? What about the Ni-MH? Won't it just drain them to 0V
Can somebody test LVP with external lab power supply on the T4?
Since the boost driver needs a minimum input voltage to operate, this effectively results in a LVP for low voltage cells.
If I end up buying a T4 I may end up testing the minimum driver input voltage; but this won't happen anytime soon.
Simon Mao wrote:
korpzgrinda wrote:
Hi Simon, do any of your TIR lens fit in Convoy T4 or T3? Thanks
suitable for T4, not for T3
This is interesting. I have a few TIR lenses bought long ago, when I started doing DIY flashlight builds. One of these builds is an early S2+ clone I got from Fasttech, built with a host and other custom components, a very handy home flashlight for close up work because I equipped it with a TIR lens and a high CRI emitter. Always by my side over my repair table.
I still have a bunch of these Convoy S2+ compatible TIR lenses carefully stored.
So, is the T4 reflector the same size as the S2+ reflector? Or to say it otherwise, can I install an S2+ compatible TIR lens inside a Convoy T4?
To finish, I have a technical question. I recently discovered the Convoy T3. When at first I saw the T3 for sale at MH-lighting Store, the price was good, I had some payment bonus and frankly, couldn't resist  buying one. On top of this the seller also sent my orange 3500K 519A version almost inmediately, so how could I complain?
However, taking a closer look at this flashlight photograph in AliExpress' Convoy T3 advertisements…
… I can clearly see an overly gross R200 (0.2 Ω) sense resistor in the driver. And please notice that when I say “overly gross” here my intention is to explicitly say that the sense resitor is way too big, causing big power loss (namely in li-ion high mode) and very big voltage drop between battery and led, reducing the effective regulation window. When 1.5A go through this badly big-arse sense resistor, the voltage drop in the “driver sense resistor stage“ reachs a monstrous 0.3 V with a power loss of 0.45 W, while the output voltage is about 3+ V (what the led emitter needs, to be precise). This is rather bad driver design, because of the massive efficiency loss in the sense resistor or regulation stage, with close to 10% power loss and additional heat generation in the driver just for this reason! To put this in context, I use and store spare commercial AC led drivers at home, I know them sufficiently well and have even slightly modified a few to reduce their flickering by adding input capacitors to them. As a rule, these drivers employ a more or less fixed value of 0.225 V as sense voltage, but they are designed to output a lot higher voltages (10 - 100+ V) than a flashlight driver. For this reason, the proportional power loss of the sensing stage in them is a lot smaller, or straight out insignificant in high voltage drivers.
Now, before any comments in this regard, please bear in mind that my only goal here is mostly to make Simon aware, and advice him to raise his standards. I'd very seriously complain to the driver manufacturer of the T3 driver if it is being manufactured with such coarse and innefficient regulation stage. Good flashlight drivers can regulate with much lower sense voltages, typically in the range of 40 to 80 mV or so (the lower, the better).
And now, I see the T3 driver boost/buck driver being sold here by Simon in his store, using a much nicer lower value 0.05 Ω sense resistor, which means it uses a maximum of 75 mV sense voltage with a maximum power loss of 0.1125 W at 1.5 A with li-ion. This is a lot better!
So, what driver is gonna come with my T3 flashlight? I would like to know. Innocent Party
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases! They are better called exosomes, and they are cell cleaners! Watch Virus Theory vs Exosome Theory video and awaken to this truth! Check this article by MD Andrew Kaufman. Read the book “Béchamp or Pasteur” by Ethel Hume for in-depth information.
BlueSwordM
@barkuti
If you had bought your light a few weeks ago when the 4-mode driver was still available, you’d have gotten the innefficient driver with the big 0.2 ohm sense resistor(which is why the driver was rated at 75% efficiency).
Now that all T3s use the 13-mode driver, then you get the more sensible one, giving you 92% efficiency.
Barkuti
Barkuti's picture
Well, thanks for clarifying BlueSwordM.
The seller confirmed my T3 is coming with a 13-groups driver. I feel relieved! Innocent
snfx
Last seen: 5 days 28 min ago
Hi Simon, is it possible to build a MAO S2+ Triple LED with 18350 tube + TIR Lens?
zaxar0580
zaxar0580's picture
Last seen: 9 hours 56 min ago
It would be cool! Simon, think about our offer! I can’t make triplets!
Simon Mao
Simon Mao's picture
It’s already in production, I guess it should be available soon.
Simon Mao
Simon Mao's picture
ar-coated
Simon Mao
Simon Mao's picture
Barkuti wrote:
kokosnh wrote:
Is there only 4-6V trigger for LVP? What about the Ni-MH? Won’t it just drain them to 0V
If I end up buying a T4 I may end up testing the minimum driver input voltage; but this won’t happen anytime soon.
To finish, I have a technical question. I recently discovered the Convoy T3. When at first I saw the T3 for sale at MH-lighting Store, the price was good, I had some payment bonus and frankly, couldn’t resist  buying one. On top of this the seller also sent my orange 3500K 519A version almost inmediately, so how could I complain?
However, taking a closer look at this flashlight photograph in AliExpress’ Convoy T3 advertisements…
… I can clearly see an overly gross R200 (0.2 Ω) sense resistor in the driver. And please notice that when I say “overly gross” here my intention is to explicitly say that the sense resitor is way too big, causing big power loss (namely in li-ion high mode) and very big voltage drop between battery and led, reducing the effective regulation window. When 1.5A go through this badly big-arse sense resistor, the voltage drop in the “driver sense resistor stage“ reachs a monstrous 0.3 V with a power loss of 0.45 W, while the output voltage is about 3+ V (what the led emitter needs, to be precise). This is rather bad driver design, because of the massive efficiency loss in the sense resistor or regulation stage, with close to 10% power loss and additional heat generation in the driver just for this reason! To put this in context, I use and store spare commercial AC led drivers at home, I know them sufficiently well and have even slightly modified a few to reduce their flickering by adding input capacitors to them. As a rule, these drivers employ a more or less fixed value of 0.225 V as sense voltage, but they are designed to output a lot higher voltages (10 – 100+ V) than a flashlight driver. For this reason, the proportional power loss of the sensing stage in them is a lot smaller, or straight out insignificant in high voltage drivers.
Now, before any comments in this regard, please bear in mind that my only goal here is mostly to make Simon aware, and advice him to raise his standards. I’d very seriously complain to the driver manufacturer of the T3 driver if it is being manufactured with such coarse and innefficient regulation stage. Good flashlight drivers can regulate with much lower sense voltages, typically in the range of 40 to 80 mV or so (the lower, the better).
T3 4 modes Efficiency is greater than 75%.
T3 13 groups Efficiency is greater than 90%.
13groups driver costs twice as much as the 4 modes version
Simon Mao
Simon Mao's picture
i dont have 20mm carclo triple lens ,sorry
trakcon
trakcon's picture
Last seen: 37 min 56 sec ago
Will there be MAO S2+ 18350 tubes available?
Josh V
Last seen: 1 month 6 hours ago
Hi Simon, but there will be also old style C8 in MAO finish or just that sample?
I would like an old style C8 in that color.
