【convoy】219B R9080 TEST
5990 posts / 0 new
tu_army
Last seen: 1 min ago
Simon Mao wrote:
guys ,who can do me a favor?
i want to know the correct diameter of sofirn soshine LISHEN vapcell 21700
I originally planned to buy these batteries directly in China. What I am depressed is that these Chinese-made batteries are not available in China or very expensive.
Really awkward Facepalm
soshine imr21700 4000mAh
w: 21.5mm
h: 71.0mm
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 5 days 10 hours ago
On a side note: Sofirn's new SD05 diving flashlight has an inner diameter of 21.9mm, so it might accept even too big cells like Molicel M50A and Lishen LR2170SC.
Mocarny
Mocarny's picture
Last seen: 3 min 42 sec ago
Mike C wrote:
Mocarny wrote:
Mike C wrote:
Double press on a clicky for previous mode? Interesting, I’ve actually never heard of that before.
Personally I can’t see that as being superior to long press for previous mode
With double press you can’t go wrong, double press is always previous mode, single is always next. With this long/short press you can press a bit too long, or too short and have wrong mode. You would love it Wink
I have done some rather extensive testing with double press, but for boost mode, not previous mode. It was brought to my attention in a thread I made asking for these kind of things: http://budgetlightforum.com/node/63771 (double tap discussion started at post #123).
So I have to disagree a little. I noticed with double press on a clicky that you can go wrong. There is a timing issue that must be dealt with, and that is you have to have a time difference between double press and two single presses. If I want to go up two modes I need to do two single presses. If I do them too fast they are interpreted as a double press. Too me this timing distinction faces the exact same issues as short press vs long press. I implemented it and settled on 200ms time limit for double press.
Believe me, I have tested this stuff a lot. I don’t get short press vs long press wrong. If the time limits are set fine, and you have hardware to support exact timing (like OTSM), messing up short press and long press is as difficult for me as it is for you to mess up double press vs two single presses. With that said, I now have support for double press so I’ll have a look at making a UI that uses it for previous mode. I have the space for it.
Ryzbor wrote:
It’s this super-customisable UI: https://www.swiatelka.pl/viewtopic.php?t=22154
Also the one Mocarny is talking about. The google chrome translation is very good.
Interesting, thanks for posting. I’ll have a closer look at that, might give me some suggestions.
Anyhow, this is a Convoy thread, I should stop hijacking it.
So what can I say? Just that for me, after week or two I had learned timing perfectly and made no mistakes.
Ps. Double press and all that stuff works much better on tail switch than on side switch
And just to correct, the UI Ryzbor’s posted is not my… “Legendary UI” Big Smile Thin is it:
http://www.solarforce.eu/proghe.html
Lot easier and less complicated, just what you need, perfectly balanced between complexity and simplicity. And about 23-click…you will never us it, or maybe once, more important is ability to have 2 separated mode groups.
Ok, that’s all Silly
If you struggle choosing your perfect headlamp, check my headlamp guide, I compared 15 most popular headlamps there: CLICK
Satan@103TFS
Last seen: 1 day 27 min ago
Any one try Lii-40A in 21700 convoy light ,is it fit ?
Simon Mao
Simon Mao's picture
Last seen: 1 day 13 hours ago
not suitable
Mocarny
Mocarny's picture
Simon Mao wrote:
not suitable
Will it fit in new versions of L21A XHP 35 HI or 3*21700?
Satan@103TFS
Simon Mao wrote:
not suitable
Simon why don’t you make the body of your 21700 a little bit bigger may be 0.5-0.8 mm. to give us more choices of battery ?
Mocarny
Mocarny's picture
And anyone tried to unwrap the Lii 40A out of this yellow plastic foil? Will it fit then?
Simon Mao
Simon Mao's picture
Mocarny wrote:
Simon Mao wrote:
not suitable
currently not
i have to improve this in the next batch
Simon Mao
Simon Mao's picture
Satan@103TFS wrote:
Simon Mao wrote:
not suitable
cause at first there are only LG SAMSUNG TESLA or SONY 21700 in China ,
i dont know other brands have a little large diameter ,sorry
sochi111
sochi111's picture
Last seen: 1 month 1 week ago
Simon,
I am sure you are pretty busy but I wanted to know if
you were able to fix the driver?
ToyKeeper wrote:
maukka wrote:
Simon, I just received two C8+ with 219C 4000K from you. Please fix the driver on them. Toykeeper will explain what’s wrong.
Maukka measured the PWM speed on each mode:
  • 2.25 kHz moon
  • 17.9 kHz low
  • 36 kHz all other modes
The 36 kHz speed means the driver was flashed with the wrong fuse values.
The 2.25 kHz moon means the driver has a very old version of the firmware on it, from 2016, calibrated for nanjg 105d drivers which were never actually used. This was fixed two years ago, along with some other issues.
If at all possible, I would strongly recommend updating to a newer type of driver, perhaps one with two power channels and an attiny25v or attiny85v chip. This would improve performance and allow for a nicer UI. If not though, it would be a good idea to at least update the firmware on the existing drivers.
Lux-Perpetua
Simon Mao wrote:
Satan@103TFS wrote:
Simon Mao wrote:
not suitable
Simon why don't you make the body of your 21700 a little bit bigger may be 0.5-0.8 mm. to give us more choices of battery ?
cause at first there are only LG SAMSUNG TESLA or SONY 21700 in China , i dont know other brands have a little large diameter ,sorry
No worries Simon. It's not your fault but the "others" do not follow the 21700 standard size. Actually, Lishen and Molicel only achieve better specs by increasing cell diameter (21.6 - 21.7mm). However, a minor increase of the tube's inner diameter might be a nice option for future batches.
Inkidu
The diameter of the (2) Molicel P42A 21700 batteries from Li-ion warehouse wasn’t that large. Granted the spec sheet does say 21.7mm Max.
VaKo
Last seen: 5 days 19 hours ago
So for those us with existing drivers that include the bad values in the firmware, it’s just a matter of flashing the latest build from the code repo yes? Or would this require tweaking the fuse values prior to this?
Convoylover
Last seen: 1 day 8 hours ago
Hi Simon,
Any plans to bring out colored versions of the S21A?
To all others: are you interested in this, and which color(s) do you like most?
My color preference (hi to low): Purple, Red, Green, Gold/Yellow, Blue, Silver, Orange, Cyan.
With metal switch Crown
Lux-Perpetua
Concerning body colours:
Urban camo or olive green (natural anodization colour).
I prefer non-reflective rubber caps but metal caps might be a nice option for later modification.
passive101
Last seen: 5 months 6 days ago
Convoylover wrote:
Hi Simon,
I would be interested, but I have a question.
I see the S2+ comes in colors, but it’s only a host. I’ve never taken a flashlight apart before. How easy is this to do to swap the parts into a new color? The LED and circuits scare me a bit. I don’t want to damage anything or break the waterproofing.
Also. Is a metal switch as waterproof as the rubber? What are the pros and cons?
Convoylover
passive101 wrote:
Convoylover wrote:
Hi Simon,
S2+ colored is also available as a complete flashlight. Look at Simon’s Convoy flashlight store. Plenty of options. So, if you’re hesitant to do it yourself…
Assembling a host is not difficult if you’re used to holding a soldering iron and know about blue=minus red=plus Wink
Convoylover
Convoylover wrote:
passive101 wrote:
Convoylover wrote:
Hi Simon,
Metal switch is maybe a bit less waterproof, I don’t know. It will stand a few drops of water as long as you stay above sea level Thumbs Up
passive101
Convoylover wrote:
Convoylover wrote:
passive101 wrote:
Convoylover wrote:
Hi Simon,
I was looking for red or orange fully assembled but I didn’t see them at the time I placed an order. I might have missed them.
If it requires soldering I’ll definitely just get a full light. I’ve never soldered anything before.
Is the metal switch just without a rubber cover?
Simon Mao
Simon Mao's picture
sochi111 wrote:
Simon,
  • 2.25 kHz moon
  • 17.9 kHz low
I have tried a lot, but it has not been solved yet.
I want to introduce other firmware, such as bistro, crescendo
Simon Mao
Simon Mao's picture
Lux-Perpetua wrote:
Simon Mao wrote:
Satan@103TFS wrote:
Simon Mao wrote:
not suitable
No worries Simon. It’s not your fault but the “others” do not follow the 21700 standard size. Actually, Lishen and Molicel only achieve better specs by increasing cell diameter (21.6 – 21.7mm). However, a minor increase of the tube’s inner diameter might be a nice option for future batches.
yes ,but anyway it’s better to change it to 22mm inner diameter
thanks for your understanding
Simon Mao
Simon Mao's picture
Convoylover wrote:
Hi Simon,
oh ,i think i will launch more color version in the future
Nicolicous
Nicolicous's picture
Last seen: 9 months 2 days ago
is it hard to make different colours?
i also hate black too because all my flashlight are black and it’s boring look.
think i have over 100 flashlights now
Nico -.-
Tally-ho
Tally-ho's picture
Last seen: 1 month 5 days ago
Excellent, can’t wait ! Thumbs Up
Caleb
Caleb's picture
Last seen: 2 days 20 hours ago
+1
LarryLumens
Last seen: 6 months 5 days ago
+1 for color variety.
I prefer the dull rough finish in OD green.
Give me thrower or give me pizza.
Simon Mao
Simon Mao's picture
It’s easy, but it depends on the market. If producing too much, but the sales are not good, this is very embarrassing.
andr3w
I bought ready-made orange S2+ couple of months ago, plus the nice tweaking options Simon kindly provides. It has separate page in the store. Red is there too.
Metal switch there has no rubber cover, correct.
passive101
Do you have a link? Does it have the brightest LED option?
