Luminus SST-20-W 4000 K CRI95 color and output test
I got this emitter from Kaidomain on a 20 mm MCPCB.
Mounted on a CPU heatsink with a nice splash of thermal paste and over the top 16 AWG wires.
Purchase link: http://kaidomain.com/Luminus-SST-20-J4-FB4-Neutral-White-4000K-LED-Emitter?search=Luminus%20SST-20
Data sheet.
Exact order and bin code: SST-20-W40H-A120-J4FB4 VH
Where
SST-20=self explanatory
W=white LED
40=4000 K
H=CRI 95
A=solder pad configuration (3.25 x 3.25 mm)
120=viewing angle, 120°
J4=flux bin, 107-114 lm at 350 mA at 85°C, >118 lm at 350 mA at 25°C
FB4=tint bin, 4000 K above BBL
VH=forward voltage bin, 2.5-2.7 V at 350 mA at 85°C
CRI data measured from the hotspot with a
Bare emitter
Yajiamei 10° beaded optics at 1000 mA
Small op reflector from the Reylight Pineapple
Medium sized smooth reflector from the Eagle Eye X7
CRI data with increasing drive current with the Yajiamei optics measured from the hotspot
Tint shift with Yajiamei 10° beaded optics with increasing drive current
Tint shift is quite linear all the way to the max output current.
Output measured in a 50 cm integrating sphere
At 350 mA I measured 121.6 lumens at 126.5 lm/W.
Emitter died shortly after being run at 7 A. I can’t see anything visibly wrong with the dead emitter.
Is sst20 and xpl the same?
Buying a 2700k Convoy s2+, 7135x4 vs 7135x6?
Convoy S2+ new firmware (biscotti) memory mode jammed
Powerful hand lamps with high R9
Lumintop FW1A discussion and review
Lume1-FW3X: Constant Current Buck-Boost & FET Driver with Anduril1/2 + RGB Aux
Sofirn C01R deep red [sold out, discontinued]
I Lowered Duv with a custom paint!
[♛ FreemeGB] Fireflies PL47 Gen II 4*XP-L/ Nichia/ SST20 Hi CRI 21700 Right Angle Flashlight - ENDED
✌ FREEME- ASTROLUX MF01 Mini 7*SST20 CRI95 26650 ANDÚRIL Flashlight Group Buy - $45.99
Test of a Luminus SST-20-W 3000K 95CRI led
Safe current for SST20(WxH J4) hiCRI 4000k and Nichia 219c d240 hiCRI 4000k and Samsung LH351D 4000k hiCRI?
TK's Emisar D4V2 review
Comparing sst-20 4000k
✌ FREEME - ASTROLUX MF01S 15000lm Flashlight Group Buy - ENDED
Are there any long throw high CRI lights at all?
Appropriate driver for SST-20?
TK's Emisar D18 review -- 3x18650 photon grenade
Dental Loupes Headlight DIY help
Greenish SST20
Emisar D18 introduction
FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public
NIGHTWATCH Seeker NS22 (XHP50.2/SST40 and SST20): discount code posted in op (XHP70.2 now available too)
2x18650 with high CRI?
The XP-G3 and the mystery of the disappearing luminance
Looking for the impossible….
【convoy】
[Optisolis/E17A/E21A] Jetbeam Jet-µ
Olight S1 Mini High CRI and Utorch S1 Mini NW, now w N219b and E21A
New Luminus SST-20 (3535 size)
4000K dilemma
LED direct drive current calculator
D1K with new color option and SMO reflector for F150R
【convoy】
【convoy】
【convoy】
Luminus 4000K phosphor upgrade
Opple Light Master 4 discussion thread (new 2023 model)
"TINT-SNOB LIGHTS": Convoy S21D & M21H w/ legendary Nichia 219b sw45k. Versus: Firefly Rosy FFL351A, Nichia 519a, B35AM, etc. (Summary p1) LATEST: DA1K w/ beautiful Rosy :+1: NTG50 4200k & Lume X1 (Test: Duv -0.0095, 2700 lm)
What is the smallest host that could drive a single 219B effectively at max output (3 to 4A)?
“REVIEW”: Lumintop FWAA – 14500 – Anduril 2 – Triple Nichia 4000K & 5000K [Pic Heavy]
Emitter swap and output differences using same stock driver?
Is there anything better then XP-G3's in 3535 LED's now?
Sadly I wasn’t able to do any real world testing inside a flashlight, since the emitter broke during the output test. What little I observed during testing seemed very good. The tint is at least as good as with most Nichia 219Cs I’ve tested. With a smooth reflector the shift is even a bit less severe in the corona.
Thanks for the test. The led performs nicely up to specifications. I’m sure that many people will complain that the tint is above the BBL but I care a bit less about that.
so what niche does this LED fulfill that others do not? maybe good on AA sized/keychain lights or high CRI triples? Not really sure
1000 very high CRI lumens from a single small die emitter with small tint shift is pretty good in my book.
Thank you for this thorough measurement :+1:
There seems to be a noticeable drop in the cyan and cobalt blue area of the spectrum - but the high R12 value is still very impressive - and R9 is nearly at Nichia E21A level.
How this LED compares to Nichia 219C and Samsung LH351D high CRI offerings with the same CCT in regards of tint shift, output, and Vf?
Do all of these Yajiamei optics consistently push CCT into warmer direction, and a bit above BBL (this latter is no problem for me)?
I was very happy for a brief moment, when I read your bare emitter CCT measurement (43…K), so I wonder, if there are TIR optics available, which don’t - or just marginally alter CCT.
Yep. It’s very efficient. About on par as other small die 4000k 90+CRI LEDs, with a lower forward voltage.
This would make a very nice LED array in a 6A LD-A4 Sofirn C8F build. It would be gorgeous.
Back a few months, I ‘snapped’ two C8F hosts for a very good price, but I was hesitating to put Nichia 219C in those hosts because the rather low Vf - I guess, this LED will be a good choice for triplets or quads.
The difference is not great but this SST-20 starts getting a slightly higher voltage than the 219C, when going over 3A, so yes it will draw a bit less current and heat in high current direct drive triples or quads.
Thanks for the test!
It’s certainly an interesting LED. The light quality is very high and the efficiency thus low. It’s advantages over other LEDs with high-light quality are the XP solder pad layout, the single-die design (compared to the Luxeon MZ) and that it tolerates high currents (compared to the Nichia E21A and 219B-V1).
So…. where to get a 5k low cri version to dedome….?
Could that be a XP-G2 killer?
http://kaidomain.com/Flashlight-DIY-and-Tools/Luminus-SST-20-L3-DA-Neutral-White-5000K-LED-Emitter?sort=p.date_available&order=DESC
The dedoming will be the challenge, no leds dedome so nicely as the old-school Cree’s
Thanks Djozz.
I’ve been away from BLF for some months, so i have some catching up to do. :slight_smile:
Yeah, i bought 1 Liter of 99.5% Toluene for those SST’s, still a challenge though, but i’ll get some anyway.
I’ve still got a B158 waiting for a high intensity LED, for example.
I’ll try some of these high CRI ones too.
Slicing is the way to go with SST…
Now I’m impatient to get mines, they will go straight in the D4 :-p
Amazing testing maukka. Thanks.
Thanks for this test :+1:
Does nobody else see the burned place under the top bond wire? Is that just a slightly darker connection area? Was it that dark before the test?
There’s the before image at the top of the OP.
Thanks Maukka, Im always interested to see your reviews. This one would have been the perfect 219b replacement if the tint bin was below tbe bbl.
