I got these two 100W 0.5Ohm resistors in the mail yesterday, so I could make me a test-load to do current tests now, I wanted that for a while. I screwed them down on a MCU-heatsink with fan, and wired them parallel, now it is a maximum of 200W test-load, it should handle currents up to 28A.
This thread about a new 6A switch that I found on ebay made me want to test a few switches, I asked other BLF-members how a switch test should look like (the concensus was that long periods on high amps is what kills a switch, not the number of clicks), and tonight I started some testing on three switches that I had and will destroy for some greater good, I hope... For completeness I would have liked to include the Tofty switch, but I don't have one, and Scaru did some pretty tough testing on that one already, actually more thorough than I am doing with these.
This is the test-rig (oven tray science!):
The circuit goes from powersupply to the test-load to the three switches in series back to the power supply, all thick copper wiring, almost everything soldered thoroughly together. The three switches are on a ceramic tile, not that I expect fire or anything serious when a switch blows, but it will run for many hours so I can not continuously guard the test.
The three switches are: a small Omten switch, a larger Omten switch, and the ebay-6A switch.
I started the test tonight at 3A (the power supply will give 3A regardless of any resistance changes, up to 16V), I think all three switches would survive lower currents than that. I have run the switches for four hours now and they all live. Tomorrow I will do four hours on 6A and four hours on 10A. Any switch surviving that will get 16A sometime this weekend.
Measuring the voltage over the switches at 3A already shows differences: the bigger the switch, the lower the voltage (and thus the resistance), I also measured the voltage over a piece of the copper wire:
Actually the voltage (resistance) varies after each switch-on, and after each switch-on it also changes a bit, usually it starts a bit higher, and it settles at a bit lower voltage after 10-20 seconds. Here's some voltages, at 3A I did 10 switch-on cycles on each switch and noted the voltage reading (you can calculate resistance and power generated in the switch yourself!
*small Omten switch: 25 23 17 20.5 18.7 15.9 15.9 15.9 18.1 23 mV
*large Omten switch: 17 15 14.9 18 16 15.5 15.3 15.3 15.3 15.3 mV
*6A ebay switch: 5 5.5 6.4 5.4 7 7.5 6.2 5.2 5.8 6.3
After the 4 hours at 3A, I did another 10 clicks to see if the resistance had changed:
*small Omten switch after 4 hours at 3amps: 37.5 18 26 26 16 17.4 15.6 14.5 12 13.5 mV
*large Omten switch after 4 hours at 3amps: 13.2 13.5 12.3 18.6 15 14.4 13.5 11.5 13.2 12.9 mV
*6A ebay switch after 4 hours at 3amps: 6.2 5.3 5.2 5.6 5.1 6.1 4.9 6 5.2 5.5 mV
Nothing exiting yet, I thought that the small Omten had gotten a higher resistance, but after a few clicks it was back to what it was before the four-hour test.
6A test tomorrow! It was fun to build up the test-thing, but the testing itself turned out to be pretty boring to be honest
Update: 6A results in post#14
Update: 10A results in post #17
Update: 16A results in post #25
), the housing of the two bigger switches are luke-warm, the small switch is a bit warmer, all the leads, including the copper wires are pretty hot, but not 60degC+ hot.
