A Perfect Dedome?
1003 posts / 0 new
Lightbringer
Lightbringer's picture
Last seen: 2 hours 34 min ago
LightRider wrote:
Thanks for the reply. I forgot an important part of my post. Facepalm so, ya, I can get MEK. actually that’s what I’ve been using with ok results but nothing like this thrower potion I am reading about Wink
Quote:
muxture ot medical beznine, trimethylphosphate, kerosene, and coresiline
Ah, that witches’ brew…
Before anyone goes ordering anything, get the spellings right!! -phosphate vs -phosphite is a huge difference, and goggle doesn’t have a clue what’s “coresiline”. And I’m assuming benzene?
LightRider wrote:
Ya… da UP eh! How you know a’boot dem dare Yoopers?
Eh, you just pick it up on the street…
Tom E
Tom E's picture
Last seen: 1 month 6 days ago
Think'n for those type of chemicals, might be best to get the names right.
Really didn't think we could get MEK in NY - thought it would have been banned. NY and Cal are pretty tough on these things...
Long Island used to be known for potatoes, now it's breast cancer - good rule on LI: don't ever buy a home built on an old potato farm, and don't drink the local water. Sometimes there's good reasons for bans. So off to buy some MEK smile. It's at my local homedepot here.
Thom2022
Just thought i would add this in about dedoming the new style Cree LED’s. They will dedome completely with MEK, however be careful not to aggravate the phosphor. It becomes very soft and I’ve just ruined one by smudging it. If you slice about half the dome off before you soak it, it should only take 20-30 minutes until it swells, at the point it will pop off with the slightest nudge, unfortunately when I did one today I pushed the dome across the phosphor slightly and it ruined it. I’d recommend giving it about an hour to harden again before trying to scrape the excess of the surface.
Just an idiot with a soldering iron.
Sledgestone
gchart wrote:
For the few dedomes that I have done (all of them successful; XP-G2, XP-L, XM-L2), I’ve used heated gas and it has done the trick in about 15 minutes.
I don’t mix gas and flame though… sounds too risky. Rather, I fill an old 2 cup measuring container half full of boiling water. I then float a small jelly jar (containing a small bit of gasoline and the LED) in the boiling water. Usually the gas itself will begin to boil. I suspend the LED upside-down and wait for the dome to come loose. Quick, easy, and no risk of going BOOM. Thumbs Up
How is the tint shift after this method?
gchart
gchart's picture
Last seen: 9 hours 45 min ago
It’ll warm up the tint a bit. If I know I’m going to dedome, I’ll start with a 1A tint or so and it usually comes out pretty neutral. But then again, I’m colorblind so I may not be the best judge Sad
Sledgestone
Thanks! So you can’t tell if it shifts to green?
Lightbringer
Tom E wrote:
Really didn’t think we could get MEK in NY – thought it would have been banned. NY and Cal are pretty tough on these things…
The Lowes near RFM (just off the Meadowbrook and OCR) has gallon cans of MEK, xylene, toluene, acetone, whatever your chemical-craving heart desires. Lots of contractors use that stuff as solvents and for cleaning, and for good reason, because they work.
Tom E wrote:
Long Island used to be known for potatoes, now it’s breast cancer – good rule on LI: don’t ever buy a home built on an old potato farm, and don’t drink the local water. Sometimes there’s good reasons for bans.
The problem is irresponsible companies and illegal dumping, that made half of LI one big Superfund site. All that stuff leached into the top-level aquifers, to the point where they’re polluted coming out of the ground. You gotta drill past those into the deeper aquifers to get any kind of potable water.
I’m in Queens, but haunt Nassau and Suffolk fairly regularly.
Lightbringer
Yeah, just what I need… another green flashlight. Silly
Tom E
Tom E's picture
I used to work at a plating, anodizing, and testing/inspection factory in Farmingdale, which later became a super fund site frown. Those old leaking vats were nasty... Was fun in my young days, glowing green under the black lights at the disco bars (I worked with spraying Zyglo for testing for cracks in aircraft parts, struts, etc. - black lights used to find where it bleeds out from the cracks).
Thom2022 - I'll have to try the MEK then on the new LED's - thanks for the tips though! Does anyone have #'s for the fully dedomed XP-G3's compared to the XP-G2's? If I can get one dedomed, would love to try it in my BOSS1.
Interesting about how the phosphor softens up. That was my impression from saabluster's picture - phosphor looked softer than normal.
gchart
gchart's picture
Nope. That’s usually a bad thing, but I guess it’s good for flashlights – if I happen to get a green tint I’ll probably never know (and therefore, care).
Lightbringer
Want a brandy-new Zanflare F1? Big Smile
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 day 13 hours ago
This is just an observation and I have de-domed a few emitter’s. I like to do the hard ones, the XHP35-50-70’s. I run them up on the heat sink cycle them, getting them HOT, then chemically de-dome them, the phosphorus seems to harden up, I can usually (gently) back scrape with the edge of a razor blade,pick off silicone and eveb rub with a soaked in thinner/pure alcohol Q-tip (again gently) and not disturb the phosphorus. I also hit it pretty close with a couple blast of canned air. All ways being aware of the bond wires.
edit: I also cycle the emitter on the heat sink after de-doming, to burn off any residual chemical or even silicone on the big emitters, saves you from smoking up a reflector! Wink
KB1428 “Live Life WOT
LightRider
LightRider's picture
Last seen: 4 years 5 months ago
Wouldn’t they just cool off once they hit the dedoming solution? Or do you prewarm the solution as well?
I’ve thought of running the emitter while in the solution but then I wised up. I don’t really know if a live emitter could ignite an mek solution but it sure seems like a bad idea…
KawiBoy1428
I think with a new emitter, the phosphorus is wet/mushy “FRESH” if you will and once they are heated up the phosphorus gets hard. Only seen this on the big quad die emitters, normally the single die emitter except for a few XPL’s I never had to remove left over silicone, a blast of canned air takes care of it.
If I’m not going to use any of the emitters I do de-dome immediately I store them in a (plastic) film can, with the fluid I use, till I need them. The phosphorus remains harden, the fluid does nothing to soften it back up. Again just an observation from my personal experience.
Lightbringer
Hmmmm, so it anneals somewhat after heating? Interesting…
I was gonna DD an XP-G2 I just got, right out of the tin. Should cook it a while, I guess…
KawiBoy1428
G2’s are simple, 20-30 minutes in Imron Thinner quick blast of air, done!
Lightbringer
Sounds easy enough. I’m just cheap enough to not want to ruin any “practicing”. Big Smile
LightRider
No kidding! You store them in MEK indefinitely? Can I ask why?
KawiBoy1428
Never used MEK, Big Smile Been wanting to try it though? I use three different chemicals, no heat, agitation.I store them Imron Thinner. Just something I pieced together, thru trial and error, most of the clues coming from MEM! (slower process)
The XHP35-50-70’s are quite expensive, slow and steady works best for me!
LightRider
Ah. Ok… so you have another throw-juice brew as well… but why store them in thinner?
doubleone44
doubleone44's picture
Last seen: 3 years 2 months ago
Does gas dedoming work with terpentine or white spirit? Has anybody tried this yet?
feralcomprehension
Last seen: 11 months 4 weeks ago
Does the whole emitter generally go into the liquid in a solvent de-dome?
Is it done on a mcpcb or?  Conceptually it makes sense but I don't understand how the other is presented to the solvent.
feralcomprehension
Does the whole emitter generally go into the liquid during a solvent de-dome?
Is it done on a mcpcb or?  Conceptually it makes sense but I can't picture how the emitter is presented to the solvent.
I'm new here; never dedomed, reflowed, or even seen a bare emitter.
Thanks!
LightRider
Is it done on a mcpcb or?  Conceptually it makes sense but I don’t understand how the other is presented to the solvent.
Yes the whole emitter soldered to the mcpcb is is submersed in the solvent. I fine reflowing undomed emitters a hassle so I make sure it is soldered to the destination mcpcb. Also. The emitters would just bounce around if not attached to anything. Possibly causing bondwire damage. It usually needs to be cleaned up with a tooth pick afterward so that requires the emitter to be attached as well.
Swib
Is it done on a mcpcb or?  Conceptually it makes sense but I can’t picture how the emitter is presented to the solvent.
I’m new here; never dedomed, reflowed, or even seen a bare emitter.
Thanks!
Yes, the whole emitter mpcb and all go in the solvent. Generally I use a quarter inch of solvent and gently agitate after 15 minutes to remove the bits left behind that are still touching the emitter.
My latest S4 2B
If you don’t like what it looks like on the wall, take it outside.
feralcomprehension
Perfect clear explanations, thanks!
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 hour 20 min ago
NEW” G2 S4 2B Smile Thumbs Up
Dusty
Last seen: 23 hours 54 min ago
Don’t tease us
Bug
Don’t tease us
I don’t tease. Upper de domed emitter is really new xpg2 s4 2b.
Tom E
Tom E's picture
I thought new S4 2B's are frowncry. I'm confused...
