Cree XHP70 up to 4022 Lumens and XHP50 up to 2546 lumens - Multi-die leds.
997 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 day 21 hours ago
I only bought 3. Killed one.
Just because an emitter goes in a light and gets tested doesn’t mean it’s got live in there forever, does it? Silly
I have 2 working XHP70 lights, the X6 and JM26. See? I left ya’ll a few emitters. Big Smile
Edit: Just for that, I’m not gonna share how I put the XHP70 on the XP footprint in the middle of an 32mm Noctigon.
Old-Lumens
Old-Lumens's picture
Last seen: 3 years 5 months ago
DBCstm wrote:
Edit: Just for that, I'm not gonna share how I put the XHP70 on the XP footprint in the middle of an 32mm Noctigon.
You'dbetterorI'mcommintovisit.Tongue Out
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
DB Custom
DB Custom's picture
You and Foy’s army huh? Big Smile
Old-Lumens
Have you stippled any reflectors yet? Interested to see the result.
DB Custom
DB Custom's picture
When I tried stippling the reflector I seemed to have gotten carried away. It might surprise y’all to hear that I tend to overdo things. Shocking, but true.
wight
I’m filled with disbelief. Wink
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
DB Custom
DB Custom's picture
I raised the reflector above the emitter and it’s got a decent beam profile. I did this by putting a silicone o-ring down for the reflector to sit on, then I can tighten or loosen the bezel to squash the o-ring to whatever height I want (to a point) Sitting just above the substrate gives a decent result in this big pretty smooth reflector, there is some garbled bright spots in the hot spot but not an x like before or the nasty dark donut.
Too dang cold for a beamshot but …
I didn’t want to cut on this big nice reflector any more than necessary, so I just notched it for the corners. In the end, I didn’t even have to do that as it would have sat above the substrate anyway. Live and learn.
So, with different reflectors coming as well as an optic, I’ll need to get another XHP70…this one’s found a home. Smile
Jubeldum
Jubeldum's picture
Last seen: 4 years 2 months ago
Too cold for a beamshot? Can’t be that cold in Texas. It’s only 3 degrees here in Michigan. Silly
Bort
Bort's picture
Last seen: 2 months 1 day ago
I’ll take your 3 degrees and raise you -15 windchill
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
pilotdog68
pilotdog68's picture
And I’ll raise you -21 windchill! (-35 yesterday).
Old-Lumens
For Texans, or anyone who has lived here for a while, it's damned cold! Long lasting cold spells here do lot's of damage and no one is ever prepared for it here. Especially the ice storms.
I haven't gone back to work in the shop since the first 21 degree night and I ain't gonna go in there till it thaws. Tongue Out
Bort
Bort's picture
We don’t get that cold very often here, thank goodness
Hi-Beam
Hi-Beam's picture
Last seen: 4 years 7 months ago
Old-Lumens wrote:
For Texans, or anyone who has lived here for a while, it’s damned cold! Long lasting cold spells here do lot’s of damage and no one is ever prepared for it here. Especially the ice storms.
I haven’t gone back to work in the shop since the first 21 degree night and I ain’t gonna go in there till it thaws. Tongue Out
Funny, It could have been me who made this statement.
DB Custom
DB Custom's picture
I just got the Ledil Iris optic from Mouser. It comes with a black housing and looks like it’s a perfect fit right into an Eagle Eye X6, no modification necessary! With Cree about to get copper MK-R 20mm stars for the XHP70 (this coming week) this is a fantastic way to bump an X6 into the 3000 lumen range. Smile Hot spot is decent, only the very slightest hint of a dark spot in the elusive white wall hunt, and it looks like it was made for this set-up!
Ledil Iris, Cree MK-R 20mm copper star, and the XHP70, perfect combination.
The Ledil Minnie fits with it’s holder using the triple spacer. It’s a nice beam profile as well, maybe even a bit nicer than the optic. But it adds the cost of the spacer or on the other hand it allows more heat sink mass. Win win.
I was born here in Temple, 111º the day I was born and I’ve liked it hot ever since. Me and cold disagree with each other. 36º and raining, with the threat to drop into freezing and have sleet and snow later today. YUCK! Everything will be ice coated and then peppered with sleet. Wrecks all over the place.
DB Custom
DB Custom's picture
I test fitted the Iris into a X6 host. With a 20mm Noctigon sitting on the shelf and the optic removed from the housing it fits perfectly. No lens in the bezel. The oring sits on the optic shelf and the bezel screws down tight. Easy answer for the XHP70 in an X6.
Old-Lumens
Who is going to have Copper MK-R stars?
pilotdog68
can’t wait for beamshots of that. I assume the optic will do better at removing the cross/donut?
JaredM
JaredM's picture
Last seen: 4 min 36 sec ago
+1
DB Custom
DB Custom's picture
There’s a $75 minimum order, which is good for about 40 stars. They’re due in this coming week, supposed to call me when they see em. I’m really into this so I’m willing to put the $75 on the table to get stars. I certainly don’t need 40 of em, and will sell off most if anyone wants em. Or use em as spacers in days to come if no one else buys em up.
The cross in the beam is gone. The pictures I posted of the modified Mirella? The Minnie has similar vertical fluting but it’s under an orange peel layer. Shiny the last 1/8 inch or so. But it’s sized properly to begin with and doesn’t take all the work I put into the Mirella. I’ll get some pics in a little while of both it and the Iris, charging up my little 18350’s for a lightbox reading so I’ll be able to see how it compares to the modified Mirella.
I still have a Fraen coming from Cutter, totally different way of dealing with it in the Fraen reflector. Couldn’t find the Fraen optic anywhere in the world.
DB Custom
DB Custom's picture
They both come with black plastic holders, the Minnie’s holder already has an adhesive tape on the bottom. The Iris fits in the X6 beautifully without the holder…the holder is tapered at the wide end and would probably go in with a small amount of sanding at that leading edge, that would probably be the ideal way to use it. The large opening in the optic fully surrounds the entire die, sitting on the substrate without the holder.
The Iris is almost $10 from Mouser, the Minnie-M is a little over $5.
Ahhh, how could I forget to post this? 3550 lumens, up from 3298 with the Mirella. 3305 at 30 seconds. Smile And a nicer beam to boot! This is with Wights PZL driver, a 7135 regulated chip driver. I, uh, might’ve stacked a few extry…
Edit: It’s pulling 5.45A at the tail.
Old-Lumens
LinusHofmann
LinusHofmann's picture
Last seen: 10 months 2 weeks ago
Wow you certainly don’t hang around when it comes to testing new emitters in various configs. Cool to see the emitter in so many different setups already.
That minnie m reflector looks like a great option for getting smooth flood beams out of quads.
DB Custom
DB Custom's picture
The Seanna is huge, I’d already looked hard at that one.
The Mirella works well, I have it cut down to fit the 35mm X6. Wink Pics are up above somewhere.
The other two Mirellas you linked are essentially the same with different mounting mechanisms.
The Mirella would be a very good bet if fitment looks good for the available size. The only reason it is beat by the Minnie in my X6 is because I had to cut it down so much to fit.
Edit: Still trying to figure out if the Seanna would be a good stand alone, sticking out the front of a battery carrier. Wink
wight
Old-Lumens wrote:
Here, try this one next. 4.3 degree spot http://www.ledil.com/node/2/p/14226
More to come…
3 to try for Maglites?
http://www.ledil.com/node/2/p/14142
http://www.ledil.com/node/2/p/14248
http://www.ledil.com/node/2/p/14286
The Mirella is a “system” reflector. Those last 3 links all refer to the same actual reflector, just with different accessories. It’s the Mirella S, the Mirella S w/ base (socket), and the Mirella S w/ base & diffuser lens (DL).
Here are the two accessories by themselves:
C13083_PF-SOCKET
C12479_MIRELLA-DL
blueb8llz
Last seen: 50 min 51 sec ago
excellent work! thanks for reporting and experimenting with this new emitter. i cant wait to see beamshots. if you could, could we see a comparision shot against the triple?
wight
While we’re on the subject of the MIRELLA, note that it’s also got a “mixing lens” available – C13723_MIRELLA-RZL. The MIRELLA family page on Ledil’s website shows an example of the intended application for RZL at the bottom: it’s approximately a 10mm+ diameter circle of 16x Luxeon Z LEDs setup for 4-way color mixing.
DB Custom
DB Custom's picture
With an XR-E they show a projected 30’ circle of light at 480M! Very tight, designed for long throw. Sweeeeeet!
Ledil Seanna
FlashPilot
FlashPilot's picture
Last seen: 2 hours 5 min ago
Nice find Wight. The possibilities and convenience are beginning to seem endless.
wolfdog1226
wolfdog1226's picture
Last seen: 12 months 1 day ago
And I will raise you -29F actual temp. w/ -46 chill factor last Wednesday/Thursday when I was in Lake Placid, N.Y.!!! Shocked
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
pilotdog68
I knew someone from up north would 1-up me…
