* Updated 11-01-22
Two - 3 " x 6" sheets of the "Famous Dc-Fix" only $3.50
Add $1.50 for extra sheets
$1 - US shipping
+$ 2 - international shipping
Dc-fix will take a really bad beam and turn it into soft buttery smooth delight with amazingly low light loss (3.2% ) I've found myself using more and more diffuser film to soften artifacts, cancel out ugly rings and create a floody smooth beam. If you've wanted to try it ...
PM me with your address,..hit my paypal and I'll ship you some. Thanks !
#1- The original Dc-fix single sided adhesive . 3% loss...Selfbuilt on CPF measured it at only 3% loss..Great stuff ****
#2- /// soft frosted matte finish .Has adhesive . visually very close to #3 allowing more of the hot spot ///Single sided , fine frosted texture . produces a softly diffused beam yet still leaves softened hotspot .(identical to #3 ) Very good !!!! ****
#5- a non adhesive thin material that flattens out the beam so it can be positioned horizontally or vertically . my thoughts are use as a bike light to spread out the beam left and right and cutting off beam that needlessly blinds oncoming traffic.***
#6-///Sold out // non adhesive double sided pattern that is about twice as thick as Dc fix . flexible ****
#7- Non adhesive double sided very fine frosting similar to #2 or #3 but more flexible .works great 4 stars****
#8- Thickness is close to #4 no adhesive,two sided (pattern on both sides) a little bit better than original # 4.****
#9- " " Same but different /two sided non adhesive " " " .... ****
#10- Same but different /two sided non adhesive " " " .... ****
#11- Same but different /two sided non adhesive " " " .... ****
#12- Close to same thickness but again a different pattern and different diffusion ( #8 thru #12 are going to be very similar to each other)
#13- Twice as thick as a playing card .Could be used as a lens.
>>>> NEW <<<<<
*** Now offering 3x6 sheets of some of the more common Lee Filters
#F1 1/8 Minus Green filter ... to reduce green tint.
#F2 - 1/4 Minus Green filter .. reduces green in your beam
#F3 - 1/2 Minus Green... Maximum reduction of ugly green tint
#F4 - LEE FILTERS 205 SHEET 1/2 C.T. ORANGE CONVERTS 6500K TO 3800K
#F5 - Red Colored filter.
*** We also carry ZIRCON - minus green filters >>
Zircon sheets take high temperature better than regular Lee filters advertised as 200x tougher /definitely thicker
Z1- Zircon Minus Green - slightly less than a 1/8th minus green. ****
Z2 - Zircon 1/8th minus green filter. *****
Z3 - Zircon 1/4 minus green filter. *****
R4- Rosco 1/4minus green in their Cinigel tough filter series // supposed to be a tougher filter yet isn't thick like the zircon .. ... For people wanting to try a different brand then Lee Filters. ****
#F1 ~ #F5 - $3 sheet
#Z1 ~ #Z3 + #R4 - $4 sheet
Continental U.S. shipping - $1
International -$2 0
OK .... How about a few Pics
Here is a light using an XPL emitter with a yellow hot spot and ugly green in the corona with bad tint shifting all thru the beam.
Before
AFTER
with dc-fix added
Shot on an iPhone and very closely resembles what your eye sees.
Here's an excellent video from Cheule that needs to be watched by everyone who is considering diffuser film or minus green filters .
YouTube&ab_channel=Cheule
