17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
731 posts / 0 new
pilotdog68
pilotdog68's picture
seben
seben's picture
Last seen: 3 years 6 days ago
Reading the datasheet, vF is about double the vF of the NSR0320. On the other hand its half the price.
Looks appropriate to me.
Sorry for highjacking this thread:
I’m currently fighting one(now 3 of these drivers) to get them running at >4V input.
Maybe some of you can take a look? http://budgetlightforum.com/node/37820
pilotdog68
is 0.58v at 1amp an acceptable rating for D1?
Rufusbduck
Rufusbduck's picture
The diode doesn’t pass that much current to the mcu.
Scott
pilotdog68
I know, but that’s the only Vf level that the mouser specs list.
Rufusbduck
It does seem on the high side. What’s it for? Many of the drivers listed in the Oshpark thread have carts listed or share similar parts lists.
Scott
pilotdog68
It matches the Vf of a diode that wight recommended but at 1/3 the cost. It sounds high, but it’s in the lower Vf range of the diodes mouser has for sale.
RMM
RMM's picture
Last seen: 1 year 6 months ago
With 3.67V on the driver input (while running) I measured 3.51V at the FET gate full on.  At 2.99V I measured 2.833V.  This is with the "ultra low vF" diode.  It was pretty consistent at around 0.16V difference from input voltage to gate voltage.  I need to swap in one of the cheap S4 diodes from the 105Cs and see what kind of drop I get from that.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
zeremefico
zeremefico's picture
Last seen: 4 hours 19 min ago
Hi, these days I tried to study about A17DD-SO8. I find single side design a great feauture. I have some questions though.
How much is cost of this board, compared with classic 17mm fet blf fet driver? Except it’s single side design, does this board have advantages compared with blf fet?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
finges
Last seen: 1 week 6 days ago
it is zener ready
RMM
RMM's picture
zeremefico wrote:
Hi, these days I tried to study about A17DD-SO8. I find single side design a great feauture. I have some questions though. How much is cost of this board, compared with classic 17mm fet blf fet driver? Except it's single side design, does this board have advantages compared with blf fet?
The cost is pretty much equivalent. It is easier to build and fits in more lights.  The performance is equivalent.
Finges: there was already a specific zener mod FET driver.  You could also easily modify the earlier revisions as well (but not the v1.0 versions without some modification).
scottyhazzard
scottyhazzard's picture
Last seen: 2 years 3 months ago
I don’t do Windows. I was looking at cheap Windows laptops to program drivers and wondering what are the minimum requirements to program these and other boards. If you guys could suggest what is needed that would be a big help, thanks.
"Those who hammer their guns into plows will plow for those who do not."
pilotdog68
It wouldn’t take much at all, a $50 (used) netbook could probably manage it. They are very simple programs. Most of the tutorials are for windows, but a few people here do it in linux as well. That could be a cheaper option.
RMM
RMM's picture
Any Windows laptop from the past ten years will do everything you need to program these drivers.
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 6 min ago
I don’t do Windows either. You can flash stuff from Linux if you like, and I have instructions available for setting it up in Ubuntu. You should be able to run it on pretty much any computer with USB, though on older ones you may need a lightweight version like Xubuntu.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 3 months ago
I wonder if it would work in WINE in Linux?
ToyKeeper
ToyKeeper's picture
AVRStudio might work in WINE, but why would you want to?
WarHawk-AVG
true
Because you don’t need it Wink
http://www.atmel.com/tools/atmelavrtoolchainforlinux.aspx
http://www.ladyada.net/learn/avr/setup-unix.html
would probably work on a Raspberry Pi…just take a while to compile
My buddy compiled some software for his ham radio for a relay…said it took over 6 hours!!!
Thank God for screen Smile
P.S. I like using checkinstall instead of make install…it creates a binary for later installation
seben
seben's picture
I Recently was unable to get a v44 with Zener to work. RMM saved my day with the suggestion to place the input cap directly on the Zener pads.
Wight. If you find the time it would be great to have another layout with additional 0805 pads by the Zener. Right where the v44 silkscreen is now?
ToyKeeper
ToyKeeper's picture
Checkinstall is nice if you need to build unpackaged stuff from upstream… but in this case, it’s much easier to just install the existing packages: sudo apt-get install gcc-avr avr-libc binutils-avr avrdude avrdude-doc
Those are all the necessary tools.
Then, to build and flash most attiny13a-based firmware from inside my repo, it’s just “cd person/project ; ../../bin/build.sh foo ; ../../bin/flash.sh foo.hex”.
And, of course, use whatever you like to edit the sources and manage files.
scottyhazzard
Thanks guys. I don’t know Linux but I used to know windows. Probably go with the evil I know.
ToyKeeper
ToyKeeper's picture
Oh, do you normally use a Mac? If so, this might help:
http://www.ladyada.net/learn/avr/setup-mac.html
Or maybe this:
http://www.meoworkshop.org/how-to-avr-with-osx/
Afterward, you should be able to use everything in my firmware repo, including the build and flash scripts, with no need to muck with Windows or AVRStudio. This stuff is all designed to run on unix systems, so it’s basically native on Linux and OSX but it’s a little awkward on Windows.
Mitko
Mitko's picture
Last seen: 9 months 1 day ago
Can it be used 1mf 16v instead of 25v cause i have like zounds lying arround in the office?
RMM
RMM's picture
Yes
seepeli
Last seen: 5 years 8 months ago
I have a problem with the Offtime memory. The driver change the mode with first clic even though I cut off the power for a few minutes.
I changed already OTC capacitor, just to be sure it is right value.
Other features seem to be working correctly.
I am using layoyt v0.24 and flashed with star offtime v1.2.
DB Custom
DB Custom's picture
Last seen: 2 days 17 hours ago
seepeli, can you take a pic and show us your driver? Makes it a bit easier to figure out what’s going on…
seepeli
I’ll take a picture when I get home.
sinner
sinner's picture
Last seen: 1 week 3 days ago
Sounds more like a bad/dead capacitor, Do you have a DMM with capacitance option , measure the capacitance individually.
If not, remove both capacitors, put fresh ones, preferably from a different batch.
contact(at)sinnercustoms.com
seasam
Last seen: 5 years 2 months ago
has anyone been able to use any version of wight’s boards with a zener mod as was intended with the design layout? or has everyone had to stack c1 and the zener diode together? does only RMM/MTN’s board work with a zener layout as intended?
seepeli
I measured both the capacitors capacitances and they were OK. I installed capacitors back and I got OFFTIME memory to work. I may have originally installed the capacitors the wrong way?
In any case, the driver works, so thanks to all!
