17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
731 posts / 0 new
Rufusbduck
Rufusbduck's picture
Those caps aren’t polarized so something else was iffy.
Scott
seepeli
Last seen: 5 years 5 months ago
I meant that the capacitors may have been on the wrong places, not in the wrong direction.
Sorry for the bad English Wink
pyro1son
pyro1son's picture
Built my first one of these today. Had some issues at first I couldn’t get it to work checked every thing, diode direction, shorts ect… but could find any thing then I thought it might have been the firmware I flashed it with so tried a different one just to find out it couldn’t flash to the ATTiny13a I was using, swapped it and and hey presto it works.
Its now in a C8 with 25R powering two modes just need to get a dedomed XM-L on copper to finish it off J)
Pastebin                                      &nbs
sinner
sinner's picture
Last seen: 1 week 14 hours ago
Good work getting your first one to work, that’s mostly the hardest part.. Cheers!
contact(at)sinnercustoms.com
pyro1son
pyro1son's picture
Would this be a good FET?
Pastebin                                      &nbs
Major
Major's picture
Last seen: 5 years 11 months ago
I tried one Here and it seemed to work ok but I didn’t pursue testing because I didn’t want to accidentally damage an ‘expensive’ fet, while the cheap ebay ones didn’t matter so much. Well, it was expensive, now they are offering free postage grr.
vestureofblood
vestureofblood's picture
Last seen: 23 hours 28 min ago
HI all,
Once again it seems vesture is struggling to tread water in the shallow end.
I have used a lot of these drivers with the zener mod and they seem to work fine, but for some reason I have yet to be able to get a working single cell version.
Here is my board.
With this exact setup I get NO light what so ever.      I built 2 identical boards to make sure it was not a bad component.
If I replace the 19.1K resistor at R1 with the 36K resistor used for the zener mod I do get light, but when I change modes into the higher up ones it stays there for a second or two and then cascades back down to the lowest mode.
I have tried this with 2 different firmwares and the results are very similar with each.
The boards and the FET are from Mountain electronics so they are proven components.
Any stab would be helpful Smile
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
Bob Loblaw
are the capacitors in the right place? C1 should have the bigger one, hard to tell from the pic
vestureofblood
I agree it is hard to tell from the pic.    Yes I did at least have that right Smile
RMM
RMM's picture
Last seen: 1 year 3 months ago
Hard to see, but are you sure that the C1 capacitor is the correct value?
Mountain Electronics : batteries, Noctigon, and much more! What's new?
Tom E
Tom E's picture
Last seen: 4 hours 40 min ago
How bout the diode - is it in the correct direction? A reversed diode would kill it. Also for LVP, I don't use the 19.1K, I use the 22K's as listed in the OP.
vestureofblood
No, I'm not certain.    The smaller one came from you, but the big one is mine from a batch of custom 7135 boards.    That, the 19.1K resistor and also the diode were mine.   Here is a pic of the PN.
Tom E
Tom E's picture
Ahhhh- why is this board layout you have completely different from v024 in the OP? What is the board you are using?
What is this mystery board??? Anyone?
sinner
sinner's picture
try using stock components for your first working board, it will also serve as control and only then you can experiment further.. It may be a little too much troubleshooting otherwise.. Just a suggestion, i had a few failures in a very similar way.
vestureofblood
The board is from Mountain electronics.
RMM
RMM's picture
Maybe the Y5V cap isn't cutting it?  Those are the crappiest ones out there...but besides that, everything looks great.  What you're experiencing sounds like what happens when the capacitor isn't there or is too low of a value.  The DC bias derating on those caps is horrific.
Try a better capacitor (maybe from one of my pre-built boards?) and see if that changes how it works.
nickelflipper
nickelflipper's picture
Last seen: 1 month 2 days ago
Vob try bypassing (i.e. shorting) the D1 protection diode and see if that clears it up, then get back to us.
EDIT: Upon further inspection MTN Elec board has the C1 cap placed correctly for 1S DD operation, my bad eyes, sorry.
Kent
FmC
FmC's picture
For what it’s worth, I had similar issues with the single sided boards using components robbed from 105 nanjg’s.
I’ve had to go back to the original dual-sided fet boards until my order from RMM gets here with the better quality caps.
Mitko
Mitko's picture
I use Samsung caps( they are cheap arround here, 1.3 euros for 100pcs) and i dont have a single issue so far
For those of us, that do have shipping issues with Digikey and Mouser( actualy shipping costs issues)
those A13 controllers are good
- they seem original, the price is only 40 cents – i already bought 30 of those and i dont have issues with them: several i reprogramed many times ( one of them over 30 times, my test board)
Those MOSFETs are fine too
Mitko
Mitko's picture
I got several or those from Nitro, they are branded V030, with two of them have an offtime memory issue, was thinking its caused by capasitors, but after changing them the problem still stays
Tom E
Tom E's picture
Yes, someone answered that above. Technically, this is in the wrong thread because this thread is on wight's boards, not RMM's, but really doesn't matter - VOB is having problems and getting some good help so all is good here. I might have missed VOB's note in the post about being from MtnE.
The MCU link is good - cheap source. I got burned before though by ordering MCU's off of eBay from China where every single MCU could not be programmed. The date code was like from 2011. The seller refused to admit to any wrong doing but didn't understand anything about the MCU's. The batch he was selling were probably pre-programmed in a way to make them not programmable via the normal USB dongle method. Think it was $15 for qty 20.
finges
Last seen: 1 day 17 hours ago
Mitko wrote:
http://www.ebay.com/itm/200990104141
http://www.aliexpress.com/item/PSMN3R0-30YL-115-30V-100A-LFPAK-PSMN3R0-30YL-3R0-30Y-PSMN3R0-30-3R0-30YL-PSMN3R0-3R0/2033377975.html
thanks for the links, looks like a good offer on both, bought some Smile
Mitko
Mitko's picture
Yeah Tom, you are right, but the Digikey US shipping is quite allright, for me its 60$….same with Mouser, Farnell got those at 2.5 euros per piece here( like 3$ )….and sometimes Farnell has hella wierd shipping policy, 2 years ago i ordered 25 cob emitters from farnell, and since they dont have them( in spire they claim they do) in the Uk warehouse they tried sending them from the US- 45$ shipping charge plus 190$ tax for handling and packaging( chips alone costed like 90$ i)…. :bigsmile: …i denied the order ofc
Anyway, same Ali guy has good schottky diodes too
finges
Mitko wrote:
Anyway, "same Ali guy has good schottky diodes too":http://www.aliexpress.com/item/ZLLS410TA-10V-570MA-SOD323-ZLLS410T-410-Z... I bought these and they seem to be alright http://www.ebay.de/itm/200990156954
sinner
sinner's picture
I found this chart on NXP’s website im just confused to say the least. I know 3R0’s are recommended and i have been using those, while there is a debate that 2R4-30YLDX (RMM’s choice) are better , there are even lower resistance ones out there, but they have higher capacitance? not sure if lower is better for our application.
Mosfet Selection Guide: At Page 83
http://www.nxp.com/documents/selection_guide/75017631.pdf
RMM
RMM's picture
We don't care that much about the slightly higher capacitance at our relatively pedestrian 19kHz switching speed.
I don't think that the 2R4 is really better or worse than the 3R0--it just happened to be available in bulk at a time that the 3R0 was not.  The 0R9 is the best out of NXP's line, and the SIR800DP I think is even better than that.  But really, you're just splitting hairs at this point.
hank
hank's picture
Last seen: 4 days 3 hours ago
Quote:
RMM is planning to sell these soon, after he gets time to build them.
Are we there yet? Almost?
pyro1son
pyro1son's picture
Build one of these yesterday for a DD red Convoy S2+ I was building and some how managed to get LED + and – connected which shorted out and melted my switch and soldered the switch spring to the bottom of my 25r. To say I panicked is an understatement. Good news is I’ve fixed it and it’s a BEAST! Just need to tweak the firmware to make it perfect.
Pastebin                                      &nbs
M4D M4X
M4D M4X's picture
Last seen: 5 days 20 hours ago
can the LFPAK FETs be bought anywhere without 20 $ shipping (mouser/digikey) and be payad with paypal (no aliexpress) ?
i am interested in 5 for playing around…
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
Mitko
Mitko's picture
Seen those on Ebay, but havent realy tested them, the ones that i boguth from Ali are originals, at least 100% same as my first Farnell order( that costed me 4 times more)
M4D M4X , if you cant find those i will visit the PO thuesday MSG me if you like some, you are doing great BLF community job( and all those nice codes too), i will be happy to help you
This is a polish company , they can be trusted too, i work with them from time to time and their shipping isnt that high
Can be a good option for EU buyers too
