KEYGOS M10 26650 FLASHLIGHT-Quick and dirty review
168 posts / 0 new
dchomak
Last seen: 3 years 5 months ago
I comes with the required adapter
MarioSS
MarioSS's picture
Last seen: 6 years 4 weeks ago
Thanks for your reply buddy!
Guess buying it from keygos website is my best bet.
dchomak
I just looked it is 19.99 at their site. I paid 20 something on ebay. It is a very nice light.
BTW if a manufacturer has retailers selling their products, buying direct from the manufacturer will usually mean you are paying full list price. The manufacturer will not want to undercut their retailers. For some reason this time they are discounting it at 19.99. Maybe they are discontinuing it?
jonhobart
Last seen: 2 years 8 months ago
MarioSS wrote:
Guys can the M10 fit a 18650 cell with an adaptor?
I got the Ultrafire version from MF some time ago and it did not come with the adapter, but a 18650 will fit in and work fine, BTDT.
MarioSS
MarioSS's picture
Thanks all can’t beat it at 19.99
cainn
I considered buying this light, but then I decided that I didn’t want a gross lie laser etched into the body :/
Metalophile
Last seen: 2 years 5 months ago
I ordered a Keygos M10 XM-L T6 directly from their web site on special for $19.99. It arrived in about 2 weeks. When I took it apart I discovered that the pill was just hanging loose. It screws into place easily enough. Good thing I decided to check before I ran it on high power for a long time. Good thrower. There is a little sharp burr on one edge of the knurled portion in the middle of the light, but other than that looks well made for the price.
The Metalophile —-
Make hay while the sun shines. After it sets, get a good flashlight.
gords1001
gords1001's picture
I’m just adding this mod link here, making it easier for people who search the light. Smile
http://budgetlightforum.com/node/15937
Details of how easy it is to add a 17mm driver and new emitter to this light.
JackCY
JackCY's picture
Last seen: 6 years 6 months ago
nekdo12 wrote:
Difference between Keygos M10 and Keygos M10a?
http://www.ebay.com/itm/1600-Lumens-26650-18650-CREE-XM-L-XML-T6-LED-Flashlight-Torch-KEYGOS-M10a-/140726841237?pt=US_Flashlights&hash=item20c3f92f95
http://www.ebay.com/itm/1600-Lum-26650-18650-CREE-XM-L-XML-T6-LED-Flashlight-Torch-Lamp-KEYGOS-M10-/190656004543?pt=US_Flashlights&hash=item2c63fbc1bf
Finally found it, anybody has other input on the M10 vs M10a?
Just run it through translator.google.com as it’s in german.
Keygos M10 vs M10a.
M10a seems to have deeper reflector and an U2 where is M10 has shallower reflector and an T6.
There are some internal dimensions as well and stuff, overall quite detailed, pictures seem to be hidden behind registration. Might get them out for you.
Beamshots, reflector comparison, U2 printed MCPCB, and more.
BLightSam
Last seen: 2 years 11 months ago
Thanks for the links.
Just point out that the newer M10 may come with U3, according to the translated page:
Quote:
Here, the two differ in the LED lamps, the M10a has seen a U2 as in the picture (if this is true?), The M10 has a normal T6 LED, but which was now replaced with a U3 S0.
JackCY
JackCY's picture
Hmm, I thought they moded the light and changed the emitter.
Might have to ask there or read more, though the translation… I don’t speak German either. The pictures showed up to me only after I registered there.
I think it was a swap. And that the XM-L U2 mark on the board is just on the board and the emitter is actually T6 and not an U2.
Modding Keygos M10a.
German original.
He did a “dedome”, removed the dome from the emitter itself, you know, the protective “translucent” dome that covers it. And fitted an KD driver 8*7135 2.8A.
Added 9 pictures to the gallery.
BLightSam
German original.
Nice pics. Puzzling, though, M10a is less brighter/thrower than M10 despite deeper reflector and possibly with U2. That 7T6 impressively swamps both M10 and M10a. Hope the German page posts some more and clarify these. Thanks again for the links.
JackCY
JackCY's picture
It’s all about the XM-L bin used and the driver that feeds it the Amps.
M10a seems tighter yes and also hes this soft spill ring, where as M10 seems like the cree is too far and there is no soft spill ring.
Yes, M10a came with a board that had U2 printed on it, but probably is just T6 from what I read around there.
M10 came with T6 that he swapped for U3 at home.
I could guess that from the German text too, it translates the same.
The thing with 7T6 is it’s not at all comparable to the M10 0:)
Great… tried to ask there and I can’t even see my post, hopefully they won’t filter it out or at least will translate it for me XD
Quote:
Thank you for your contribution. Your post will be published until it has been approved by a moderator. You will be redirected to the forum.
With the reflector pictures you have to keep in mind that the M10 is already moded.
It has U3 vs the probable T6 in M10a, and also the drivers give different Amperage, higher for the M10 with U3.
Quote:
M10a
high mode 3,10V 1,73A
mid mode 3,10V 0,61A
low mode 3,10V 0,21A
INR26650 Kingcell
Lux-Werte auf 3m high-mode:
3050lx; auf 1m hochgerechnet 27450
Quote:
M10
high mode 4,10V 1,92A
mid mode 4,10V 0,72a
low mode 4,10V 0,25A
INR26650 Kingcell
3620lx; auf 1m hohgerechnet 32580lx
Tried to ask there if he could do a beamshot with one light and only swap the reflectors.
Hopefully he also knows how to set up the camera and not use the automatic mode.
Then the brightness will be useless anyway.
BLightSam
All in all can’t help but feel that the differences between M10 and M10a are minor. Still my preference is M10a for deeper reflector and the soft spill ring. Thanks for following up.
JackCY
JackCY's picture
Same here, plus it depends on the seller if they can even tell the difference XD
Already read somewhere that they received M10 instead of M10a.
I’m now a happy camper waiting for my M10a to arrive.
And some other bits like an AVR programmer, 105c driver, ML-102, 26650 TrustFire 5000(4200)mAh. Total of $45, not bad for a light, 2x battery, charger, custom driver with a programmer for it :bigsmile:
BLightSam
See that you had a good Christmas! Please tell us what you get M10/M10a and what T6/U2/U3. Enjoy.
Bort
Bort's picture
Last seen: 10 hours 12 min ago
This light is no longer the excellent quality it used to be, here are my list of shortcomings
-the glow in the dark boot has splotches of glow
-the pill is made from some metal i can just cut with an exacto knife, and would be nice if it were a bit thicker
-the driver spring fell off after 2 days (i’m replacing it anyways)
-the glass has the small chip in the corner
-the star is glued on, and has dirt all over the top of the pill, the LED is dirty and slightly scratched as well
-the light overall has a cheap feel, the anodizing aint bad but its not great either.
Current draw was 1.61A
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
