Cree XP-L V6 2C led, tested against XM-L2 T6 3C, edit23/7: I repeated the test and measured a dedomed XP-L
I tested the output of the new XP-L led (XP-L V6 2C tint, from illumn.com) compared to a XM-L2 I had in the spare leds box (XM-L2 T6 3C, from Fasttech). Both were mounted on a 20mm copper Sinkpad, the XP-L on a xp-type and XM-L2 on a xm-type.
The introduction to this test is a bit longer than usual, to explain the altered method, up to now I did ceiling bounce light measurements, from now on I will use an integrating sphere.
I built the sphere a while ago, and after quite some testing and characterisation I am confident now to use it for measuring led output. The integrating properties of the sphere proved very good, I solved the serious variation caused by the relative big measurement hole (by building an adjustment light into the sphere), I solved why I got inconsistent readings from the sphere (a moving piece of tape ), and now I think it really works, so from now on I will use the sphere for flashlight/emitter tests (if only because the measuring has become easier and more comfortable:I can do the tests sitting on a chair at the table now :-) ). Further reading about me building the sphere can be done here, although I still have to update the OP of that thread with how the integrating sphere was corrected and characterised.
The set-up for led-testing looks like this (last week I did another check on the current read-out of my power supply, it seems accurate at least within 0.1A):
The XP-L ledboard mounted on the copper pillar (soldered on a converted all-copper CPU-cooler):
During the measurements it is inserted into the sphere like this:
The ledboardwires that I use are pretty thick (can't remember the official thickness) but must be longer than when I did these kind of measurements using the ceiling bounce method, the two wires together are 12cm, so I needed to know the voltage drop over 12cm of this wire. Here's the result at 5A:
So it is only 17 mV at 5A current (0.017 V), that is pretty low IMO, for the graph numbers I will not substract that from the measured values. Whoever wants the voltage at the ledboard solder joint can easily calculate it (so that is a drop of 3.4mV/A), but in that case: you are probably also bothered with the voltage drop over the board traces, Relic38 showed to us that that is also not negligible .
There is a magic conversion factor that I came up with, to convert the uncalibrated integrating sphere readings to lumen, it is 1.58. It is an estimated number, it came out of 'calibrating' the sphere with several flashlights with 'known' outputs, and previous measurements of leds using the ceiling bounce methods. It came pretty close to the official output of the high setting of my Sunwayman D40A: 550lm, so I decided to define the output on high of my D40A to be the official 550 lumen, the resulting conversion factor was 1.58. There is of course an annoying uncertainty in this number (and every D40A will be a bit different), it will not be way incorrect, but it can easily be 7 or 8% off the real value. To get that percentage down, I could use many more flashlights with official but still uncertain outputs, but the best way is to have a constant light source measured in another, calibrated sphere (and that will cost me 340 euro's and that is not going to happen). So 1.58 will be the conversion factor for at least the coming period.
The XM-L2 T6 bare led output was measured before, by match. He measured it lower than I have here, about 7% lower. The calibration of his sphere was done the same way as I did now, using flashlights with known outputs that vary per unit, so I see no reason to adapt my calibration to his, also because the T6-bin is not exact, the emitters we tested could be at two ends of the T6 bin spectrum. (Texaspyro used home led lightbulbs for calibration because there's multiple leds in them, averaging out the differences between them, that could be a bit more accurate but is still not exact).
Ok, you get the picture of the method now: I think the measurements have gained a lot of consistency now that I am using the sphere, they can be compared very well to my future measurements and to any other measurements out there because I measure bare led lumens now, but if you ask for the true lumen numbers I can still not guarantee it within 1% , like I aimed for when building the sphere :-(
On to the tests: XP-L compared to the XM-L2 !
I first tested the XM-L2 up to 8.5A (the XM-L2 in my crashtest last year blew at that current, I am lucky with this one :-) ) . I did not go higher now because I still want to use the led (those XM-L2's do not come cheap). I measured by starting at low current and turning it up half an amp everytime, slowly, no rush. Although I did not let the output fully settle after each current increase, the output drop was so slow that in the graph you would not see the difference if I used fully settled outputs. To illustrate this: at 8.5A the measured output after 20 seconds was 2149 lumen, I let the output settle, and after 3 minutes it settled at 2127 lumen. The results match reasonably with what I measured last year, but the voltages are measured better (lower) now because last year I measured it using the (not so good, switching-mode) power supply voltage reading, not with a separate DMM close to the led.
I removed the mounting device from the sphere and estimated the temperature in the sphere by sticking my fingers in the hole: it was nice and warm, say 35 degC. I let it cool down to room temperature, and started a crash-test on the XP-L. It went all the way up to 10A before the bond wires were toast:
What striked was that the output was not that much higher than the XM-L2 T6, it had a clear maximum at 7.5A. and that the Vf is considerably higher than the XM-L2: as much as 0.3V at 6A current. There is of course a variance between different specimens of equally spec'ed leds but I think these differences are too significant for that.
This is what I measured in a graph:
The more measurements I do, the less certain I am if what I am measuring is true (Confucius? ). So I hope they make sense and are useful, I appreciate feedback if my numbers are at all in line with other experiences with this led. Thanks for reading!
EDIT 23/7/2014 some further testing of the XP-L in post#38
Best 18650 battery for torch with CREE XP-L V5
Wurkkos HD20 Review ($40, LH325D, 5000k, USB-C PD, 21700, Headlamp)
Can an XP-L handle big li-ion direct drive?
Xp-l hd w2 How hard can it be driven?
LED Package/ Die Sizes - WIP -
Review: ThorFire TK4A 4xAA Flashlight 1100 Lumens XPL (Mother Approved)
Review: ThorFire TK4A XP-L 4AA Flashlight (Pic Heavy) - * TF Coupon Added *
Power conservation analysis of linear and PWM brightness regulation methods
Testing a Cree XHP50.2 J4 3A led
testing a Samsung LH351B series 5000K 70CRI led
Cree XP-G3, testing a R3 4000K 90+CRI emitter
Cree XP-G3, testing a S5 3A emitter
Three ProLight Opto PK2N series 3535 colour leds tested, and a Cree XP-E2 PC-amber
3rd generation Oslon Square, a 5000K 70CRI led tested
Nichia E17A/E21A series (April 19th: updated with output tests in the OP)
Three Oslons tested: 1) latest gen. Oslon Black Flat 2) SSL80 4000K 92CRI latest gen. 3) SSL80 4500K 96CRI 1 gen. before latest
emitter test: Nichia 219B V1 4000K 93CRI
XP-L Hi, and would-be-XP-L featuring in recent SRK-clones, two emitter tests
Nichia 219C, testing a 5000K 83CRI emitter, comparing with a XP-G2 S4 2B and other leds
New Osram Oslon Square, testing a 4000K 92CRI typ. emitter
SOLD Quad XP-L 3C Mag for sale
4 emitters tested: Cree XP-E2, JR 3535, small die Nichia 219B, Luxeon Rebel lime colour
New Convoy C8 – Clearly better
Active feedback on PWM to current-regulate with FET?
how many lumens from a Triple XPL Sinner
GB Interest ///OFFICIALLY CLOSED 11/8 @ 9pm CST/Maxtoch M24 Sniper with XP-L HI /// 250K lux @ 4.3 Amps!!!
[MOD] Courui D01 build for MauiSon
XM-L2 U3 available at IOS ~ The real McCoy
WTB: XP-L V6 2D or a XM-L2 2D tint
Frankenlight V0.2 - XHP35 meets Seanna
First MOD with Courui and XPL-HI
XP-L vs XM-L2 OTF Tests
New: Noctigon Meteor M43 ; in production New color added: Tan
my thrower project- work in progress
Big Aliexpress sale coming up again!!
Fasttech - interesting new products - Flashlights, chargers, batteries and DIY and knives - please no discussions.
Place to buy a ZY-T13, TMart?
Carclo not going to make triple XP-L optics (possible group buy for custom TIR)
who is buying me a XP-E2 Torch led? Update: DBCstm did, test is in post#81
Why should I buy XP-L? Need some basic pointers.
triple xp-g2 vs triple xp-l
Cree XHP70 up to 4022 Lumens and XHP50 up to 2546 lumens - Multi-die leds.
What is the smallest host that could drive a single 219B effectively at max output (3 to 4A)?
Convoy S2+ from Mountain Electronics
djozz tests
ENEDED
Need help deciding....
[ GXB172 - 50W Single Cell 17mm Boost Driver! ]
Q8 modding
Q8 modding
TK's Emisar D4 review
New Courui D01 XP-L V6
Q8 modding
Testing my modded lights
Need a bit of Help Understanding VF and Amps
SunLike 3500K 95+ CRI midpower led from Seoul Semiconductors tested
Test of a Luminus SST-20-W 3000K 95CRI led
Output and voltage test of 5000K and 3000K Nichia Optisolis leds
Lumileds Luxeon V, test of a 4000K 70CRI emitter
Luminus SST-40, a N4 BA bin tested
Yuji VTC-series D50 5730-size midpower led tested
great info! thanks!
You have a link to a supplier of these new XP-L emitters ?
mine were from Illumn.com, they have 2A, 2C, 2D and 5B4 tint: http://www.illumn.com/leds-drivers-optics-mcpcbs.html?cat=124
where I got mine.
Great Tests! Just want to be sure - it's the V6, not the V5 XP-L? The graphs say V6 but the title and opening says V5. Actually both are available in a 2C tint from Illum, and I hope it's a V5.
The higher Vf makes sense, according to the CREE specs, but should still be lower than the XP-G2's. Also, peeking at 7.5A makes sense (I think) because of the smaller mount, maybe?
I got two of the V6's - one in a P60 pill and the other in a "slim" mini cheapo AA zoomie with a BLF15DD driver, copper pill top press fit in... Wink
Great testing. Love your work Jos
Nice setup djozz and thanks for all the testing. I always use reference threads like these especially for voltages at different currents.
Incredible job djozz! Your crash-test threads are always so informative. :smiley:
XP-L and XM-L2 both have the exact same die size (2mm x 2mm) right?
Whoa, this has to be the most accurate, disciplined emitter testing ever done by a "hobbist". I bet if the engineers a Cree see this, they will be saying, "why didn't we think of that on a couple points.
I am not near anything like your level, but I agree about not needing to adjust to Match's (another great maverick) numbers. The T6 designation was used for everything at the time. Some vendors now keep good track of the chain of custody, which is such a great improvement.
A far as this statement:
The more measurements I do, the less certain I am if what I am measuring is true (Confucius? ). So I hope they make sense and are useful, . . .
I can only imagine that the more precise you get, the more you are aware of more little potential error inducing issues. All I can say, is that no one that I'm aware of, has ever implemented such disciplined, diligent emitter output testing.
Correct (most likely) or not, it is the best we have here at BLF and probably any other forum by far. Thank you.
Given the smaller footprint, I say your results are impressive on the side of the XP-L.
Thanks for the testing, it is a great resource!
Thanks for the tests, this is great work
I am very disappointing with the XP-L, i expected a much stronger showing especially below 1.5A. If you used an XM-L2 U2 i can imagine them being neck and neck, in fact it may start out at a higher lumens then the XP-L which makes no sense because the XP-L is supposed to have 200 lumens at 1W instead of approximately 140 lumens.
great test
Nothing in the preliminary or published data indicated the XP-L would be anything other than a XM-L2 die stuck onto a smaller substrate. Unrealistic expectations based on false assumptions do tend to result in disappointment... :)
200 lumens per watt, compared to a XM-L2 U2 under the same conditions does something like 194 lumens per watt. Unremarkable.
source?
Cree's very own 'Product Characterization Tool' thingie.
Awesome…shows the XP-L is slightly outperforming the XM-L2…wow!
So much light in a teeny little footprint…how sweet it that!
Those suppliers on the XP-E/G type sinkpads better gear up :stuck_out_tongue:
of it's lower vf - meaning that a Liion for power the XM-L2 will produce full brightness for longer as the voltage drops, especially at high amps.
