I've been visiting their website regularly in the past few months, but they haven't added anything new.
I really thought they would have a special eneloop 10th anniversary edition, but nothing. The latest edition is just a 2bay charger for eneloop lites,no new batteries.
The 10th Anniversary of Eneloop is later this year. November 2005 was the launch month of the original HR-3UTG series. I’ve been reliably informed that Panasonic will be doing global 10th Anniversary promotions for eneloop. Kind of ironic since Panasonic dont dont own the technology or the factory eneloop is made in (except the Chinese made eneloop that are actually using Panasonic Evolta technology, not Twicell factory technology the Japan made cells have always used).
Here’s the shortform history of the Twicell factory consumer NiMH battery line from even before the LSD days:-
April 2013 AA-AAA type low self-discharge type Ver.4 (UTGC) begin shipping. (2100 cycles)
October 2011 AA-AAA type low self-discharge type Ver.3 (UTGB) begin shipping. (1800 cycles)
January 2010 Transfer of Twicell factory to FDK Co,. Ltd (Majority owned by Fujitsu Ltd) from Sanyo Electric Co,. Ltd. Renamed to FDKTWICELL.
October 2009 AA-AAA type low self-discharge type Ver.2 (UTGA) begin shipping. (1500 cycles)
September 2008 Single, single-type two low self-discharge type begin shipping.
September 2009 Minister of Health, Labour and Welfare Award as the employment of persons with disabilities excellent office.
January 2006 AAA type (HR-4UTG) low self-discharge type begin shipping. (1000 cycles)
November 2005 AA type 2700mAh (HR-3UG) begin shipping.
November 2005 AAA type 1000mAh (HR-4UG) begin shipping.
November 2005 AA type (HR-3UTG) low self-discharge type begin shipping. (1000 cycles)
July 2005 Commendation award from the Japanese Red Cross Society.
March 2005 OHSAS18001 certification.
August 2004 AA type 2500mAh (HR-3UF) begin shipping.
November 2003 ISO14001: 2004 certification.
September 2003 AA type 2300mAh (HR-3UB) begin shipping.
September 2002 AA type 2100mAh (HR-3UA) begin shipping.
August 2002 ISO9001: 1994 certification.
March 2002 AA type 1850mAh (HR-3U) begin shipping.
April 2001 Transfer to Sanyo Electric Co,. Ltd from Toshiba Battery Co,. Ltd
May 1993 Building 2 new building construction and operation 6 floors.
October 1991 Nickel-metal hydride battery production start.
Product numbers of the actual cells have not been changed as far as I could tell.
Is this far fetched? Maybe.
Could this be a prelude to a “5th generation”? Who knows!
accumulator mentioned a couple of weeks ago, that he had found an unopened package for 1st generation AA eneloops with an April 2006 date code. His findings of the two cells from the package showed 72% and 73%
I also recently got a pair of 1st generation AA eneloops with a February 2008 date code. It came with the NC-MQH03 charger set from Singapore. I don’t have the fancy ZTS battery tester yet nor do I have the good Maha or La Crosse chargers to check this accurately yet. But, my cheapie Delkin tester showed 3 out of 5 lights. Not bad at all! I’ve decided not to touch them yet and will wait to test these for real on my friend’s La Crosse BC-1000 charger to get definitive results.
Still the same cells, but updated numbers, probably after testing 10 year old cells
Codes are still same.
So, no, they aren't the 5th generation. If you look at it, the Chinese envelops are the fifth generation...
And by the way, special anniversary editions have usually come to the market before the anniversary rather than after! (Disney)
Still looking forward to some new stuff, but I will probably not be in Japan anymore by then.
With Panasonic's ownership of the Eneloop brand, they've been doing some weird things to it over the past couple of years... who knows what will happen later this year?
I can't believe I missed Uniqlo's Eneloop t-shirts a couple of years ago!
I am just emerging from a dark age, having purchased my first high-power LED flashlight last month. It runs on 18650 batteries, but since the charger I bought, a Nitecore D4, can charge NiMh in addition to Li-ion, I decided to buy some Eneloop Pros. I selected the Pro, because I want the longer runtimes it offers in AA flashlights. I have 16 AAs and 4 AAAs arriving next week.
Since placing my order, I have learned that capacity and number of cycles are not the only differences between regular and Pro batteries. The Pro model is also better for devices that draw high current.
That's fine. My reason for posting, however, is this. The same post where I read about high-current draw said that regular Eneloops are better in low-current applications. I understand that they may be more cost-effective, but are they really better? Is there any reason I should not run my TV remote on Eneloop Pros? What about the AA flashlights I anticipate buying? Frankly, those will also be run on low-output settings most of the time.
From what I read, using high(er) capacity cells in low draw devices is bad because the cells sit mostly unused and internal resistance eventually increases until you go through a “refresh” cycle on a good charger. Not only that, using high(er) capacity cells in a low draw device is counter productive… they will self discharge before you even used up the cells. In other words, it’s not worth the cost!
For remotes and clocks, I’ve ended up getting a bunch of Eneloop Lites as they’re better suited for these applications. They are low capacity cells meant for low draw devices. Nevermind the fact that they have way more number of cycles than any one can practically use lol… At the very least, I feel it’s better to use regular Eneloops instead, which is what I’m using now in my DVR remote because that thing takes AAAs and sucks down batteries like none other
Other than high power flash lights, something that is better suited for Eneloop Pros are things such as camera flashes, hand warmers, cell phone battery booster packs, and electric shavers
Not sure just what I should do now. I am the proud owner of 20 Eneloop Pros, but most of my AA needs are for low-draw devices. I can either buy some regular Eneloops or Eneloop Lites or else abuse the Pros I now have...
Guess I'll just have to buy a few AA flashlights like the ThruNite TN4A (NW)! More likely, I will buy some lights that use 1 or 2 AAs. For applications where the TN4A might be useful, I am inclined towards Li-ion solutions.
Not sure just what I should do now. I am the proud owner of 20 Eneloop Pros, but most of my AA needs are for low-draw devices. I can either buy some regular Eneloops or Eneloop Lites or else abuse the Pros I now have…
Guess I’ll just have to buy a few AA flashlights like the ThruNite TN4A (NW)! More likely, I will buy some lights that use 1 or 2 AAs. For applications where the TN4A might be useful, I am inclined towards Li-ion solutions.
Kouryu has got it pretty much correct. Ostensibly it’s a waste of a good high capacity using the high capacity, high current cells for low drain applications such as TV remotes. They’ll work fine but the longer cycle life 2000mAh white cells will do a better job over the years & even better if you can find them are the high cycle life ‘Lite’ cells. These are half the capacity of the standard white cells but capacity is not important in low drain use as you’re almost never going to use anywhere near the whole charge anyway. Cycle life plus of course the low self discharge characteristic is the key factor for these cells.The lite batteries are designed for low drain long life use being rated at 5000 full cycles. They’re also made to handle continuous charge so appliances that sit on a low rate charge all the time when not in use such as shavers, cordless toothbrushes and solar charged garden lights are perfectly matched to the ‘lite’ batteries. Just like the the other two models the Lite cells are manufactured at the FDK Twicell factory in Japan so whether you buy Eneloop Lite model BK-3LCC (formerly HR-3UQ) or Fujitsu Lite model HR-3UTLA you are buying the same battery.
Lots of info in this thread, but a qouple of questions:
I want to buy some eneloop batteries. Both AA and AAA. Not many 8 pcs of each, maybe 16.
1. What is the best buy now, any link to safe sellers? (that send to Norway)
2. Going to use them for my Nikon blitz, in remote controls, and if it’s better, maybe 3 x in a 18650 flashlight.
3. Do I need to buy a separate charger? Or can one of my Opus BT-C3100 v2.2, LiitoKala Lii500 or Nitecore D4 chargers be used?
4. Do I need Pro or Normal? For my use?
Lots of info in this thread, but a qouple of questions: I want to buy some eneloop batteries. Both AA and AAA. Not many 8 pcs of each, maybe 16. 1. What is the best buy now, any link to safe sellers? (that send to Norway) I would suggest looking at eu.nkon.nl who are trustable, relatively cheap, and EU based (Netherlands)
2. Going to use them for my Nikon blitz, in remote controls, and if it's better, maybe 3 x in a 18650 flashlight. Question?
3. Do I need to buy a separate charger? No Or can one of my Opus BT-C3100 v2.2, LiitoKala Lii500 or Nitecore D4 chargers be used? Yes
Nikon blitz? is that a strobe? than the Pro would be a wise choice (although Standard ones are also good Remote controls... if you can find some Lite eneloops, they might be better for the remote control. If you can`t find them just use standard. Replace a 18650light? depends on what light etc..
Remote controls… if you can find some Lite eneloops, they might be better for the remote control. If you can`t find them just use standard.
It’s a Nikon SB-400 blitz for my D80 and D3100 SLR.
Ok, on remote control. But it don’t hurt to use normal eneloops on a remote control?
Was thinking maybe 3 x eneloop 2100mAh+ was lasting longer then 1 × 18650 3200mAh? But of course, the eneloops has only 1.2v, but the 18650 has 3.7/4.2
I have been at the store to look before I posted here, but some days ago I found a store/seller with better prices, but I can’t find it again.
No, it wont hurt to use standard eneloops in remote controls. but if Lites are cheaper, I would go with the Lites. I honestly dont really care which brand/batteries I use in remote controls that I use daily.
I have eneloops in my remote shutter for my camera, but thats the only "remote" I use eneloops in. The remote controllers I use daily probably have alkaleaks in them. Its the ones that get stored away, that I prefer to use proper batteries.
No, 3 times 2000mAh in series is still 2000mAh. The voltage becomes 3x, (about 4.2-4.5V)but not the capacity. (someone else will be better in explaining this, but you can search for Series vs Parallel batteries for more info)
Depending on the use of your strobe. if you need the capacity (shooting weddings etc) you should go with teh Pro. If you "just shoot" with strobes occasionally, the standard eneloops will do just fine!
I have eneloops in my remote shutter for my camera, but thats the only “remote” I use eneloops in. The remote controllers I use daily probably have alkaleaks in them.
If you “just shoot” with strobes occasionally, the standard eneloops will do just fine!
tnx, for the info.
If someone has a better/cheaper store/seller tell me, or I will order some from Nkon.
When charging Eneloops (or IKEA Ladda) AA and AAA batteries. Is it best to use the lowest setting, 300mAh, or can I charge them with higher current then that?
Got the test results now, Ikea Ladda AA 2000mAh gives from 2200-2270mAh and the AAA 750mAh gives from 770-801mAh. So seems like a good battery, like you say in your test. And they are cheap, just $4.6 for 4pcs of either AA or AAA.
Sorry for that I ordered Eneloop Pro batteries also from Ebay, they was expensive, and in terms of mAh not much higher.
But Ikea do not give any info about how long the charge hold on the batteries, like Eneloops, but most likely, 70%+ after a year.
Where can Americans buy Eneloop lites? Wouldn’t they be best for our solar yard/garden/walkway lights?
other than going on an overseas trip… ebay or amazon… unfortunately, the price isn’t that great for low quantities, unless you wait for an auction
I bid sniped a couple of packs of AAs already… as long as you stay $6 or less per pack, then the price is reasonable
Thanks for the tip, I just paid a little too much to buy two of the AA at Ebay after reading your post, but I wanted them for a nice solar light that I have. Now that I have those two, I will now shop for a few more, at better prices.
My understanding is that they are the ultimate battery for those AA solar yard lights.
Not what we have but what we enjoy, constitutes our abundance.
Just finished charging my disney eneloops and after 20 and something circles the still rock so thought to say thank Chibim for supplying them, it is really pity you are not in Tokyo anymore so I could get another 8-pack
Thanks for the link! Interesting guy!! Lots of useful info in his videos.
The Eneloop 2005-2022 info thread
Hey ChibiM, no new models from Panasonic (I hoped they will have something new for mid 2015) or you just stopped updating this thread?
Hmm, kinda disappointing, 10th anniversary i nice round number, should be celebrated accordingly
Panasonic announced recently Eneloops can now hold a charge of 70% for up to 10 years. http://shop.panasonic.com/about-us-latest-news-press-releases/05132015-e...
Packaging has already been updated to state this and we should see this slowly trickle to US retailers over the next few months. Panasonic Japan’s website still does not show this “increase”.
http://panasonic.net/energy/battery/us/eneloop/
yeah, a friend of mine has one! he got one from a "lucky bag".
and it was one of the few shirts that were actually his size
Im not such a eneloopy fan though.. maybe I should just get one, just to say I have one.
this link might interest you as well.. a lot of eneloop stuff
http://budgetlightforum.com/node/24806
I just happen to like many out of the ordinary things, and a Eneloop or Kewpie (missed that one too) t-shirt counts
I’ve seen that thread before. It’s very informative, but there are actually some slightly newer versions of some of those Eneloop universe products
Thanks, Kouryu, for a great explanation!
Kenneth Myhre
Kenneth Myhre
tnx, for the info.
Kenneth Myhre
other than going on an overseas trip... ebay or amazon... unfortunately, the price isn't that great for low quantities, unless you wait for an auction
I bid sniped a couple of packs of AAs already... as long as you stay $6 or less per pack, then the price is reasonable
Kenneth Myhre
300mA should be okay..perhaps
Eneloop charge better at 1000mA, or even 2000mA. That's what they advise.
I usually charged them at 700 on my Lacrosse/Voltcraft bc700 though.
And eneloop chargers charge also at various speeds.
Just don't set the charge rate to low and you should be good.
300mA on a AA cell will not really give you a -dv/dt termination signal.
So 1A then on the AA battery? And 300-500 on the AAA? Or 1A there also?
Kenneth Myhre
Yes, that is good values.
Have you any info on that?
Kenneth Myhre
I'm still in Tokyo for the next 36 hours
, then I'll be flying back.
Been very busy lately, not fun moving overseas!
