SALE: Low-cost copper pills, spacers, optics, drop-ins.
1848 posts / 0 new
kiriba-ru
kiriba-ru's picture
Last seen: 1 hour 8 min ago
I mean what quantity do you need.
All parts are made on manual lathe so abilities are restricted. For example I dont want to make driver retaining version of convoy single pills.
Prices of S2 pills can be similar to S2+ pills – $16 triple driver retaining, $12 single driver solder/press fit.
Kenjii
Kenjii's picture
Last seen: 8 months 4 weeks ago
Hi,
the M2 Quad kit came in some days ago. Perfect packaging. The spacer fits into the Convoy M2 (from BG) perfectly. Light is not finished yet because the driver is still in the mail.
Regards
Kenjii
djburkes
djburkes's picture
Last seen: 3 years 10 months ago
I ordered the following yesterday…and it was shipped this morning. That’s excellent service and fast turn around time…thank you very much!!
1 x BLF X5 Carclo quad copper spacer+ss liner
1 x Convoy M2 Carclo quad copper spacer+brass liner
3 x Carclo 10622 24mm quad Narrow Spot Plain TIR
3 x Copper spacer for Ledil Cute-3 triple X6 8.6mm height
LEDtec
Last seen: 5 months 1 day ago
interested for 1 BLF X5 Carclo quad copper spacer + ss liner, is available?
Thanks
kiriba-ru
kiriba-ru's picture
If first post is saying that item is in stock, this means that it is so with 99% probability.
I can post current stocks photo every week if this is more presentable.
imagebam.com
Texas_Ace
Texas_Ace's picture
Last seen: 15 hours 26 min ago
Now to get the funds for a pair of X6 triple “kits”, been wanting to do this for awhile. Hopefully after Christmas.
Gerrh
Last seen: 1 month 4 weeks ago
Bought a bunch of spacers from him and wow amazing customer service and fast shipping. Great to work with Smile his products are best I've seen!
will34
will34's picture
Last seen: 11 min 56 sec ago
I received a M1 quad kit long time ago but haven’t started my build yet due to a small design flaw, the MCPCB “pocket” is 20mm and because the optic is larger there is no room for it to sit its legs. I think it can be an easy fix using a dremel and cutting disk attachment but I lend mine to a friend, so I’ll probably start the build some time later.
kiriba-ru
kiriba-ru's picture
Yes I know about this problem. I had several request from users that wanted to have kit for Khatod quad but didnt had optics and havent realized that it requires “rooms” for optics legs.
imagebam.com
You need to mill black marked areas.
Anyway you have got some rare part for good price. Ive made 15pcs only and think that this is all.
KawiBoy1428
KawiBoy1428's picture
Last seen: 8 hours 30 min ago
A little file work! Wink Thumbs Up
KB1428 “Live Life WOT
WillyD
Last seen: 1 week 14 hours ago
kiriba-ru, received my F13 copper spacer and it fits like a glove! Great doing business with you. Sorry…that kinda sounded like ebay feedback. Anyway, this beats the heck out of trying to sand down half a dozen copper disks on my end. Thanks.
emarkd
emarkd's picture
Last seen: 11 months 2 weeks ago
I also got my order over the past couple of days. Mine came in two packages and they got split up along the way, but only by one day. Not a big deal at all, and very fast shipping overall. The parts are very nice and a great deal for the money I think, but I haven’t had time to assemble anything but my P60 shell. I’ll report back as the builds come together.
Thanks.
kiriba-ru
kiriba-ru's picture
Quad kits for Manker U11 are ready.
vwpieces
vwpieces's picture
kiriba-ru wrote:
Still wondering about small amount of feedback from blf community. You have purchased more than 50pcs of X6 Cu spacers and Im sure that more than one of them was used for X6 SS triple build. And defenetly some of you have realized that SS version requires different spacer. But nobody contacted me with this problem. Good news: Im subscribed for “What did you mod today?” thread and have read vwpieces`s post about X6SS with my Cu spacers Bad news: I had no 32mm cu rod so this few was have 30mm external diameter. imagebam.com 7USD, 44 gramms 3 in stock
I have built 2 SS triples with your X6 Spacers. It works. Just need to understand that the spacer does not touch in the 20mm emitter hole. It touches on the outer edge to the copper body. Here is a pic where it touches, marked in black.
Both of these SS Triples have Glass over optic. One Cute-SS has been sanded and polished smooth which lowered it slightly. Glass is against the smooth optic. The untouched optic has a slight gap between the Bezel and copper Head. Polished optic has no gap.
Texas_Ace
Texas_Ace's picture
What does the simple version mean?
kiriba-ru
kiriba-ru's picture
Aluminium X6
kiriba-ru
kiriba-ru's picture
imagebam.com imagebam.com imagebam.com imagebam.com
1. Disassemble your U11. Remove stock reflector, mcpcb with led. Save stock wires.
2. Use small amount of thermal grease. Put spacer inside (hole should be on the switch side). Pass wires trough hole. Use stock retaining ring to screw it and hold spacer inside, also if you can screw it down near the same level as anodized step in the host means that spacer sits in its place.
3. Use quad 20mm pcb. Solder stock wires to it.
4. Put carclo 24mm quad lens, brass ring around, stock o-ring over brass ring.
5. Put over stock glass lens and screw bezel down.
Bezel is little out from head on mine sample. This means you can use thiner pcb, or sand spacers downside a little if you would like to.
I have spent lots of time and money on this project. Im sorry for very long production time and not very budget prices.
MtnDon
MtnDon's picture
Last seen: 3 hours 46 min ago
Kirill, I thanked you a while back for the nice packaging and the speedy shipping. Today I finally assembled the X6 spacer with my noctigon triple and the optic. Everything went together nicely and it sure produces light! Thank you.
I’ll post a picture or two tomorrow in the what did you mod today thread. The host is my brown baked EE X6
djburkes
djburkes's picture
I received my first package from you today…it had one of the copper spacers…for the X5 (I believe), a brass liner, and 3 of the quad optics. My other package hit New York customs yesterday so I’m sure it’ll be here in a few days. Everything was packaged very nicely and very secure…each piece was wrapped in foam and put in a little plastic box in it’s own little section…then the plastic box was shrink wrapped. Thank you very much!! Big Smile
giorgoskok
giorgoskok's picture
Third order i make and receive from Kirill , and I’m very pleased .
Everything new and as promised . Also +1000 on that very good packaging . Thanks man !
kiriba-ru
kiriba-ru's picture
Anyone can help me with pill-less C8 internals measurements?
Texas_Ace
Texas_Ace's picture
I have a convoy host laying around, what measurements do you need?
Is there a triple/quad optic for the C8?
Kenjii
Kenjii's picture
Hi,
my parts came some weeks ago. Took a while to build all lights. Parts fit perfect, thanks kiriba!
Eagle Eye X7
- 3x Nichia 219C D280
- Ledil-Cute-3-SS Narrow Beam
- MTN17DDm Bistro
- 2700 Lumens
Eagle Eye X6
- 1x XP-L HD
- Kathod PL1672 Ultra Narrow Punch Beam
- BLF X6 Bistro Driver
- 60 Klux
Olight M22 Warrior
- 3x XP-G3 S5 3C
- S2 Spacer + sanded Noctigon XP20 soldered on top
- MTN17DDm Bistro
- 3300 Lumens
Convoy M2
- 4x XP-G3 S4 2D
- Carclo 10621
- MTN17DDm Bistro
- 3500 Lumens
Regards
Kenjii
kiriba-ru
kiriba-ru's picture
Great photos Kenjii!
Im not sure that youve got pl1672 from me, anyway what do you think about the beam?
Texas_Ace
Texas_Ace's picture
Ok, here is the best I can figure based on that picture, keep in mind that my calipers are fairly cheap so the accuracy is not super exact.
The MCPCB shelf is – 21.68mm
Depth from top of threads to shelf – 33.68mm
Depth from threads to top of shelf – 31.78mm
PCB depth – 1.9mm
Straight bore side (34.1 in your drawing) – 34.31mm
I am not totally sure what you are wanting with the 15.6 measurement, are you wanting the bore size at that depth? If so it appears to fall just on the edge of the straight bore I measured at 34.31mm. It may be very slightly wider then that due to falling right on the corner.
What optic do you have in mind for a C8 build?
Texas_Ace
Texas_Ace's picture
Kenjii wrote:
Hi,
Eagle Eye X7
- MTN17DDm Bistro
- 2700 Lumens
Eagle Eye X6
- 1x XP-L HD
- BLF X6 Bistro Treiber
- 60 Klux
Olight M22 Warrior
- 3x XP-G3 S5 3C
- X5 Spacer + sanded Noctigon XP20 soldered on top
- MTN17DDm Bistro
- 3300 Lumens
Convoy M2
- 4x XP-G3 S4 2D
- Carclo 10621
- MTN17DDm Bistro
- 3500 Lumens
Regards
Kenjii
Very nice! Any beam shots? Particularly of that Kathod PL1672? How does the beam compare to the stock reflector?
Kenjii
Kenjii's picture
Hi,
no beamshots of the Kathod PL1672 at the moment and i am sure i got it from you, kiriba. I will take beamshots next time. The beam is quiet nice and broad compared to the stock X6. I had some seroius problems centering and focussing this thing. XP-L HD worked, XP-L Hi didn´t work. Ugly spot and less range. The spot is now about 4-5 times bigger than the stock X6 but much less spill. The spill is useable but decreases from the spot to the side. I have a ring in the beam from the centering adapter but this can only be seen on the white wall. It is gone after 3-4 metres distance. I hoped that the datasheet is correct but it wasn´t. The lens should do 150cd/lumen which should be about 200 Kcd, but this can not really be achieved.
Regards
Kenjii
kiriba-ru
kiriba-ru's picture
Much thanks.
I have found much more simple solution for liner so 15.6 dimention is not needed.
It is not very fast to type from mobile, please read upd.2 here: http://budgetlightforum.com/comment/1057501#comment-1057501
kiriba-ru
kiriba-ru's picture
Kenjii, you need to improve your datasheet reading skills. There is just 29kd/lm for xpl there. 150 should be right number for XQ-E Hi.
giorgoskok
Are 20mm quad cutter boards in stock ? Or will in the future ?
