Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17431 posts / 0 new
Flintrock
Last seen: 2 years 3 months ago
hank wrote:
That's a lot of options/combinations/modes And an 8-switch board offers a heckuva lot more. You know how to "count to 1024 on your fingers"fingers, right?
Yes, but it all gets mess up when I forget which way around I had my hands turned.
AlexGT
AlexGT's picture
Last seen: 20 hours 49 min ago
I have to report that both my switch leds have randomly decreased in intensity to about half as bright as when I first received it, and sometimes they go back to the original full brightness for a few seconds then return to this lower level, I like the lower brightness level that it has now, looks more acceptable for a switch now, but I’m wondering if they will fail later on… Sad
If they do, I will probably just solder some new resistors and leds to the board, for the people that have successfully modified the switch leds and/or resistors, where did you buy them? Interested in trying different color…
So what was the consensus as to what was causing the issue, was it the resistors or the leds?
Thanks!
Flintrock
Anyway, why symmetric?  If the light is off, what could any click possibly mean other than that you would like it to come on?  The only question being exactly how you'd like it to come on.  My computer also uses short click on, and long click off, well ok, short click is  also off, just not as brutal.
justanotherguy
Last seen: 10 hours 29 min ago
mine are all now marked shipped, but tracking gives no real info
Flintrock
Does double click to turbo work from mode lock-in?  If so, or if not, that would be a nice compromise that helps.
edit: If it doesn't already, to the extent this would then be maybe a potential feature, I'd probably make it double click to advance, but either is good.
FreeMagenta
Last seen: 1 year 6 months ago
Mine, ordered Sept, 8th, was ‘shipped’.. But I didn’t get the tracking number.
boostedsubie
Last seen: 3 months 4 weeks ago
Your order number might be your tracking number. Plug it into here: https://www.aftership.com/couriers/flytexpress
FreeMagenta
Well, the number appeared after 3 hours Smile Going via Turkey post.
Tally-ho
Tally-ho's picture
Last seen: 1 week 5 days ago
Tom E wrote:
Ok, checked & verified on 3 protos and 1 production light. All of them light up the LED’s, yes, all of them on moon level 1. How are you guys checking it? In room light or are you goin into a dark place? Very obvious what’s goin on in the dark on moon mode level 1. It works, it ain’t bright… smile
Flashlights are for the dark. Oh, and is setting 1 useful for anything? No, not really. laughing
Thank you for taking the time to check it on your 3 protos.
I checked mine in room light.
The timing is perfect for me. Out of the box, no problem to turn it ON or OFF like expected. The only timing that was a bit picky at first was to turn OFF the light switch = too short between the two clicks (first to turn ON, 2nd to turn OFF the Q8 and the light switch) turns the Q8 into turbo. Big Smile
But once you get it right by trials and errors, it’s not hard to remember the right timing.
Your Narsil UI is really growing on me and I’m starting to really appreciate it, but as I’m really got used to flashlights with fixed modes that are more predictable concerning runtime, I would appreciate a Narsil modification in ramping mode to always turn it ON at 100% 7135 and 0% FET, without memory.
An option to reverse the ramping in the configuration UI settings would be awesome. With 100% 7135, to preserve your vision adapted to this brightness, I would prefer to go a bit lower first with a click & hold, and have the option to go higher with a short click & hold followed by another click & hold.
Setting # : 1 :: Function : ramping mode :: Clicks : 1=disable, 2=enable, 3=reverse ::
LEDtec
yesterday I ordered my third Q8, today it is already shipped.
very strange.
The Miller
The Miller's picture
Last seen: 4 months 1 week ago
g_sintornillos wrote:
Those who are nervous because the tracking on 17track does not work can try http://flytexpress.com/Index_En.aspx
Just relax, don’t get sucked into checking shipping status, it really does not make it come faster, but it will make it feel a lot slower f you or anybody does it.
Wait a few weeks and by the time you want to check it they have arrived Smile
Tally-ho wrote:
Before the factory reset, when I was doing a click & hold at the same time on both flashlights, the D4 was turning ON on moonlight almost instantly and after the “moonlight + pause” it was ramping up. The Q8 was turning ON after a longer delay directly to ramp up without “moonlight + pause”.
I probably disabled the moonlight (but there is no way to do it in the manual) so I probably set it to the lowest level by mistake. It seems that the emitters weren’t even emitting light at this lowest moonlight.
D4 firmware is based on Narsil, first written by Tom, then TK worked on it, they are not the same so do not expect them to behave the same Wink
alternety wrote:
snip And I may also be seriously over reacting.
snip I am not sure if I will be able to use it every so often (or never) without having to read the manual.
snip One aspect of an emergency light is that people other then myself may need to use it.
snip I would like to ask if someone with the skills might consider making a set of firmware that makes the Q8 dead simple for an untrained user.
Tom got you covered already, the use is dead simple and if your wife wants only a few modes and is used to click to switch modes, set it up ike that once and be done with it. Ramping is so intuitive you probably will not need to (but remember the first time somebody uses it they may invoke config and doing some random clicks there may change settings, not bad, but well good to know. So in our first day of playing with it, keep that manual at hand and set it up how you want, there is no need for new firmware, almost everything can be set up to personal or spouses taste Smile
DB Custom wrote:
FWIW, I ordered my 3 on Sept 8th, 12th and 26th. All 3 show backorder status on banggood as of about 1 minute ago.
Clearly, there is no favoritism on this site as I have ordered in excess of $3000 worth of goods from them since I came to BLF. Wink
Yeah sorry that is me, the hold yurs till you report your arm is not longer in pain so we know modding of them will not hurt you Smile (kidding)
snip
Thanks!
Keep an eye out, and report if they do go off please, so I can add you to the OP list.
No exact reason, still thinking it is a combination of 3 things
1 some poor soldering or not enough flux like stuff used
2 unmatched LEDs
3 resistor issues
When all three are present and over a not clear threshold the switch leds stop working after a day, maybe the heat and microscopic epansion and shrinking puses the switch assembly just over the edge.
Cool to read more movement, but please I cant say enough, order and forget is the best thing to do Smile
The Miller
Oh and about moon setting 1
come on, meybo one doesn’t use it (nobody forces you to) it is very cool to set it up at 1 and just see the LEDs fainly shine. A moon or low mode that is too bright seems like a point of real annoyance, but LOL being able to set up a moon so faint as in the Q8 is just flipping awesome, lumens Q8: from 0.01 all the way up to 5000 to 6000, just plain cool, and then after seeing it, just make it 2 or 3 and have 0.1 as moon.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 10 hours 45 min ago
My Q8 ordered around #1040 Preorders was shipped.
Ether they produced more than 500 in the second batch or there were some order cancelations.
djozz
djozz's picture
Last seen: 2 min 26 sec ago
@Alex, an easy and cheap source for 0603 leds is Fasttech:
https://www.fasttech.com/search?0603%20smd%20led
teacher
teacher's picture
Last seen: 8 months 2 days ago
DavidEF wrote:
teacher wrote:
For those of you in the USA that do want to check Tracking of you Q8, but DO NOT know how… here is the proper procedure.
This procedure is only valid for USA orders that were shipped Priority Air Mail. The FREE Shipping option for this light. (It ‘might’ work for other counties… but I have no idea about this & cannot address that.)
  • 1. Get the Tracking Number of your order either from your Banggood Account or the Shipped email they will send you.
  • 2. Go here https://www.fedex.com/apps/fedextrack/ and enter the Tracking Number from step 1. Click Track. At this point it will probably say LABEL CREATED.
  • 3. Scroll down to SHIPMENT FACTS & get the Reference. This number will most likely begin with YT
  • 4. Then go here http://www.17track.net/en and enter the Reference from step 3. Click Track. Scroll down to see movement.
Once the package actually ships, movement will show in the tracking information on 17Track.
Do not be alarmed if your package sites in one place for 1 to 3 or 4 days, this just happens sometimes. It is just the way it is. Nothing to worry about.
DO NOT worry about what it says on the FEDEX Tracking. It will not show there until Fed Ex actually has the package, if then even.
17Track has been very reliable for these packages sent to the USA… all of mine have been 100%. More accurate then FedEx tracking by far.
While writing this I checked my last 2 Pre-Orders…. both above #1680… AND much to my surprise & shock they both actually show movement. It appears they have actually shipped, as in “left the building shipped”….. Shocked .. Wink
Will know for sure in a couple of day though.
So there it is if anyone likes to see where their package may be……
Enjoy.
Smile
Oh yeah. You guys talked about this before (500 pages back?) but I forgot. I just checked mine this way, and it says that it has departed the facility in Shenzhen! Woo-Hoo! It’s really moving! Party
Meanwhile, Fed-Ex still says “Shipping label has been created. The status will be updated when shipment begins to travel.” Flat Stare
Yep…. the journey of your Q8 has definately began David. Next stop will be Hong Kong…. Smile
Remember… pay no attention to what FedEx Tracking says at this point. Nothing will show on it until they have actually received the package in hand. And even then mine have not been 100%.
BUT 17Track has been 100% right to my mailbox.
Below is what one of my PreOrders shows a few minutes ago (the other was the same too)…. So these bad boys, as well as yours; are definatly on the move. Wink
Origin Country – China
HONGKONGHONG KONG, Arrived at Sort Facility HONG KONG INTERNATIONAL AIRPORT
2017-09-30 15:00
SHENZHEN, Departed Facility in SHENZHEN
2017-09-30 02:50
SHENZHEN, Arrived at Sort Facility SHENZHEN
2017-09-30 02:50
Shipment information received
2017-09-27 22:28
PLEASE NOTE
This above information is only valid for USA orders that were shipped Priority Air Mail. (The default FREE Shipping option for this light.)
It might work for some other countries… but that is an unkown.
PBWilson
Last seen: 2 hours 57 min ago
I’m resisting the urge to keep checking tracking. It’ll save me a few grey hairs.
It says that my two lights should arrive by October 22nd and I’m hoping I’ll be pleasantly surprised if it takes less than three weeks.
Regardless, it’ll be fun blasting mischievous trick-or-treaters up to no good with a double-fisted wall of light!
“Drop the eggs and toilet paper and get the heck out of my yard!” Crazy
PBWilson
Oh, and a request: I’d love to see a side-by-side comparison of a Q8 from the first batch and one from the next. Just curious about the subtle changes they are making after the halt.
kahvitahra
kahvitahra's picture
I got my Q8 today. Very solid and awesome light for this price. Just cleaned some dust (there was very little of it) and drilled screw holes a little bigger. Threads where lubed, but adding a little extra is always a good idea. Basically perfect light right out of the box.
Big thanks to hole team! I might order couple more as a gift. Wink
CJ Avlis
Last seen: 18 hours 1 min ago
Got no hairs to spare Smile … I ordered, got shipping notification,I’ll check the PO box couple of times a week for the next few weeks.
Tom E
Tom E's picture
Last seen: 14 min 22 sec ago
Ramping and mode set operation are completely different UI's. A multi click sequence in mode sets would get confused with fast single clicks, so it's avoided. Ramping is all about press&hold or single clicks so 2X and more fast clicks is not so easily confused, unless you wanted to very quickly do ON/OFF's or OFF/ON's and make up your own strobe or something.
Captainvideo
Q8 s on the move from Banggood. I ordered 9/7, shipped 9/29. Thanks to the BLF team that made this possible!
desmondkun
desmondkun's picture
Last seen: 1 day 19 hours ago
Yeah! Mine is shipping! Big Smile
Take care of your flashlight and your flashlight will take care of you.
RapidLux
RapidLux's picture
Last seen: 6 hours 39 min ago
Just a tip on how one can make Q8 a little bit more comfortable to use. The underside area where you hold index finger can feel a bit sharp when operating the flashlight. If the 3 furthest fins had stopped halfway only to go half the circumferences, that underside area would be smoother. Olight Sr Mini Intimitator seems to be designed that way. The cooling fins stop there to make a smooth area.
As a quick fix for that I used a 17 cm long x 2.5 cm wide strip of Gorilla tape.
dekozn
Last seen: 5 days 16 hours ago
Banggood told me mine has shipped, order date 09/09/2017 09:00:44
Idiot proofing something only creates improved idiots.
justanotherguy
How does everyone track? I tracked at Fedex.com and I get a generic ‘information received’ for a few days now.
Assuming it has left their facility, I feel comfortable expecting them in two weeks…
emarkd
emarkd's picture
Last seen: 2 months 5 days ago
hank wrote:
I’ve always wondered why nobody making flashlights builds tailcaps with 4 or 8 DIP switches.
I think the answer to that is probably “space”. That’s a big component. What would you do with all those switches in there anyway? There is a tailswitch board with a single switch on it though, designed to allow you to turn the taillight off. It mounts inside the spring.
JasonWW
JasonWW's picture
Last seen: 3 hours 16 min ago
Even if you found a micro sized dip switch, you would still need to run several tiny wires from the driver near the head, to the tail cap. Then how would you be able to twist the cap and keep the wires connected? There is no way. That’s why you don’t see them in tail caps.
dekozn
justanotherguy wrote:
How does everyone track? I tracked at Fedex.com and I get a generic ‘information received’ for a few days now. Assuming it has left their facility, I feel comfortable expecting them in two weeks…
I just received an email, haven’t tried tracking. I actually ordered without tracking (free shipping)
sparkyDK
Last seen: 22 hours 53 min ago
Soon flashlights will need to have a locking key like some lasers Smile
This way you can go from 0 to some lumens, then turn the key and unlock insane mode.
When ramping mine up its like when i reach the top there are 1 “larger” and a smaller flash of the beam, dunno what it is but it dont bother me that much, just saying.
garrybunk
garrybunk's picture
Last seen: 1 week 1 day ago
I got a shipping notice from Banggood! Ordered on 9/9. Tracking number doesn’t show up in 17Track.net at first, but then if I click the FedEx link it does come up. BG order says it’s “Priority Air Mail” with an ETA of 10/22 (How is that “priorty air mail”? Though I expect it will deliver sooner.) We’ll see if I win the Chinese lottery in regards to all of these reported issues.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
