BLF A6 FET+7135 Light Troubleshooting and Mod thread
1004 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 3 hours 1 min ago
Grab a Noctigon MCPCB with an XP-L or XM-L2 emitter already installed, probably from somewhere like intl-outdoor.com, and it should be pretty easy to replace the emitter and the board it’s soldered onto. Just get one matching the original MCPCB size, and it should work fine. This will require unsoldering the +/- contacts though, then soldering those wires onto a new board.
BTW, if you want it more throwy, try XP-L HI.
My favorite for this light is XP-L 3D or XM-L2 3D. They give a nice wide hotspot in a neutral tint. I don’t recall offhand which one fits the centering ring better though.
moderator007
moderator007's picture
Last seen: 1 day 1 hour ago
MCPCB http://www.mtnelectronics.com/index.php?route=product/product&path=60_10...
Thermal compound under the MCPCB http://www.mtnelectronics.com/index.php?route=product/search&search=comp...
As your from greece this may not be a good shipping option but this is what you’ll need for the swap.
16mm copper board with led and thermal compound to transfer the heat to the flashlight.
Fasttech, or Kaidomain, may be cheaper on you from your location.
The swap will require soldering as Toykeeper explained. Not very high on the difficulty scale.
iliad13
Last seen: 2 years 6 months ago
Thank you both for your suggestions!
iliad13
Hey guys, I need an other advice. It is not possible to unscrew the head of the lamp. And I mean, I cannot unscrew the tube that contains the driver & the LED from the tube that contains the reflector. Anyone who had similar issues? Any suggestions? I don’t want to damage the tubes, thus I did’t use any tools, but for sure I tried very hard, it’s just not possible. Thank you!
Phlogiston
Phlogiston's picture
Last seen: 1 day 12 hours ago
If you have a pair of rubber gloves lying around, that might give you a bit of extra grip. Otherwise, you could try a pair of strap wrenches, although you might be just as well buying a new light for the cost of the strap wrenches and the spare parts.
iliad13
Rubber gloves made the job! That was I great idea! Thanks a lot Phlogiston! Cheers!
Phlogiston
Excellent! I’m glad it worked Smile
lohtse
lohtse's picture
We have an A6 each and are waiting on the tools mentioned in this thread http://budgetlightforum.com/node/36216 to arrive… But my question is this what else can we do with regards to modding/flashing the firmware? what othe firmwares are there?? I have the the 11mode(think its that) and partner has the 7/4 mode firmware.. Could we flash the 11 mode version on her A6? if so where do I get it etc?
looking forward to pushing the A6 further
regards
Lohtse
Problemes d'erection [url=https://www.viagrasansordonnancefr.com/]viagrasansordonnancefr.com[/url] meilleure pharmacie
ToyKeeper
ToyKeeper's picture
Click the Link in my signature for more information about these things.
lohtse
lohtse's picture
Already watch/reading them…but a lot to go through so was hoping for quick answers to point me in the right directions
ToyKeeper
ToyKeeper's picture
The INDEX file has a list of firmware projects sorted by various criteria. I’d suggest looking for projects which list support for dual PWM, attiny13, and clicky switches.
lohtse
lohtse's picture
ok and thank you….Can i flash the 11 mode firmware on partners A6 is so which is it?
ToyKeeper
ToyKeeper's picture
I don’t even know what the 11-mode firmware is. It doesn’t sound familiar, unless “11” means “7+4”.
On mine, I run something a little different… cypreus2. It’s similar to blf-a6 in the 7-level mode, with no memory and no config options. But in the hidden blinkies, it has a lot more modes:
(the current version is rearranged a little, but this shows the general idea)
lohtse
lohtse's picture
I believe you once mentioned that ( http://budgetlightforum.com/comment/1137484#comment-1137484) that I had Bistro flashed on mine when I one asked why it didn’t match the advertise setup.. Where as my partners had the stock/first firmware… SO does that mean I can flash the bistro firmware? and s the currrent one in the index same as the one flashed on mine?
ToyKeeper
ToyKeeper's picture
It has been a while. However, if there is a question about what type of MCU is on the driver, you should probably look at the chip to find out. It should be either tiny13 (blf-a6) or tiny25 (bistro).
Or it should be pretty clear which is which any time you turn it on at a medium level. BLF-A6 lights up at the target level immediately, while Bistro has a soft start effect which glides from zero to the target level over about a third or a quarter of a second. Or you could tell by entering config mode. BLF-A6 blinks twice, pauses, blinks twice, pauses, then exits. However, Bistro has a much longer config menu.
lohtse
lohtse's picture
I know that my partners is the original BLF A6…and on spring side says a17dd_l and blf,
thank you for answering my questions and your patience..
Cereal_killer
Cereal_killer's picture
You MUST read the actual tattoo on the 8-pin chip. Either chip can be on that same driver board and trying to flash the wrong file can lock the driver up.
She’s trying to help you out, telling her what the DRIVER says doesn’t answer the question she asked in order to better answer your questions. It’s like you’re not reading her posts, just the first line of each…
lohtse
lohtse's picture
ok so how do I get to it??? I have unscrewed the brass rig but can’t seem to get further! without desoldering Both blfs look to have the SAME driver and looks like this one https://www.aliexpress.com/item/For-Astrolux-S1-For-BLF-A6-A17DD-L-FET-1-2-8-4-35v-7-4/32838237732.html my firmware is def Bistr and partners is def BLFa6 Ui
d_t_a
Last seen: 20 hours 17 min ago
I’m wondering, the driver on my Astrolux S41S (quad-Nichia 219B or 219C) seems to be malfunctioning (Moon mode doesn’t light up, the 2nd and 3rd brightness mode are exactly the same brightness). I notice the Astrolux S41S uses the exact same user interface as the Astrolux S1 (BLF A6).
Would it be OK to just buy a BLF A6 firmware driver (the one from Banggood) to replace the malfunctioning driver on the Astrolux S41S? Or is it a different driver that’s designed for quad-LEDs?
ToyKeeper
ToyKeeper's picture
Yes, that should work fine. It is the same part that Astrolux uses.
Grappler
Last seen: 11 months 5 days ago
After a month, my most recent BLF A6 started rattling when shaken because the lens is loose and taps the sides of its housing. It’s tightened down as much as it will go.
Any suggestions on a fix would be appreciated.
Phlogiston
Do you have a spare O-ring to put between the lens and the bezel?
Grappler
That worked. Thank you!
Although my other A6 does not rattle, I’m going to do the same thing to it to prevent debris from getting under the lens.
Phlogiston
You’re welcome Smile
BLF A6 / Astrolux S1 quality control is very flaky, hence the variation. I have an A6 whose bezel only screws down properly if the O-ring is between the lens and the reflector (which compromises the water resistance).
I need to experiment with some spare parts to see if I can fix that. Alternatively, I might transplant the LED and driver to a Convoy S2+ host I have lying about.
Tc418
New member here. This light was my first purchase. My is rattling after only 2 days.. So if im. Reading this correctly, oring above the lens and another around the reflector in the groove? This won’t put too much pressure on the pcb? Or the reflector? Just wondering.
Grappler
Yes, there should already be an o-ring between the reflector and the lens. Now add one of your spare o-rings above the lens to hold it firmly in place. I don’t know about the pressure issue you mentioned. But it seems to me that if the lens is shifting, there should be enough give for the additional o-ring. I’ve done this to my EDC A6 with no issues so far.
Tc418
Ok. Great. That’s what I’ll do. I love this little light. It’s a perfect put in your pocket everyday and tell friends, look how bright this light is for its size. Will this affect any dust ingress?
Grappler
Agreed. Great pocket power light. This should keep all dust out that may otherwise enter due to the loose lens. If you touch the lens in the process, you’ll want to wipe it clean. Be sure you use a LINT-FREE cloth, or you’ll end up placing micro lint particles on the inside of the lens.
Umpi2000
Last seen: 16 hours 3 min ago
So I got a pretty difficult request.
Does anyone on here have the CAD drawing for the BLF A6, and the Astrolux S41? Even just the head and bezel.
Sorry in advance if this is way out of line to ask for
Flitsmal
Flitsmal's picture
Last seen: 5 days 29 min ago
Hi all,
I just received a BLF A6 driver from banggood, and I just have a couple of user questions, as I think my driver is not working properly. It seems to be in the 4 mode at the moment, so Low,Medium,High, Turbo.( Comes on in low I think, not moonlight) I can’t seem to access the config modes with 15 clicks, the light just keeps changing modes, I have tried both full clicks( ON/Off), and half clicks, but I never get to those 2 blinks that signifies config mode, am I doing something wrong?
If I do the medium press from the first Low, I get Turbo, and subsequently Strobe,Battery Level,Bike Flasher. Battery Level doesn’t blink, just constant low, so I guess it doesn’t work properly?
Any help/advice will be appreciated, thanks!
Hi, my name is Anton, and I’m addicted to flashlights.
