I have built quite a few drivers from this thread and everything went well. But I do have a question: Which is the best DIY driver for a Convoy S2+ build with *KW CSLNM1.TG* ? I read many times that a FET might kill the LED. I have plenty of spare parts, just need some inspiration which *17mm board* to order at OSHPark. Thanks.
Dunno if we have a bare BLF driver that fits this, because the W1 is optimal at 4-5 amps, so it's higher than any 7135 based driver and too low for FET based drivers. So you need a good regulated driver in the 17 mm size that preferably can run the firmware of your choosing for a power switch light.
If we had this, I'd be very interested in getting a bunch. The problem would probably be real estate, unless maybe you can use both sides, say some low profile parts on the spring side.
Unless, of course, you are willing to run the W1 at lower amps, because at 2-3 amps, there should be 7135 based drivers, like this one: https://oshpark.com/shared_projects/JEp3Wx4B, but it's ATTiny13A based.
I wish there would be a BLF version of the linear FET drivers that Simon sells. I still wonder if their components can be harvested, transplanted on a new pcb with an attiny whatever running a FOSS FW.
It should be possible to make an adapter board just like Gchart did for the SP10S. Looking quickly at the pictures there are :
An op-amp enable pin (led enable) , PWM pin for brightness, probably a battlevel pin (voltage divider), an OTC pin.
They would need to be rewired to the MCU on the adapter board.
That said there are a bunch of resistors and caps which I’m not sure what there’re for.
Which is the best DIY driver for a Convoy S2+ build with KW CSLNM1.TG ? I read many times that a FET might kill the LED.
I have plenty of spare parts, just need some inspiration which 17mm board to order at OSHPark.
Thanks.
Led4power offers 17mm boards with customizable linear output. Unfortunately it is proprietary and only uses his firmware, but his firmware isn’t bad.
I would like to see basically all the basic BLF drivers (fet+AMC) redone in linear-fet (or linear-fet + direct drive fet) style. Bonus points for compatibility with the popular BLF firmwares (FSM for e-switch, bistro and such for clicky)
I’d like to see Simon just work with ATTinys… But yeah, would love BLF versions. When I want to toss SST40, Luxeon V, or the white flat series in a light, I’d love to be able to just have drivers “in-stock” that I can build and throw whatever firmware on that suits the current whim.
Is the 17mm Texas Avenger driver still the best/latest driver to order for FET+AMC drivers?
Meant for several Convoy S2+ with 1) triple 219B and 2) XHP50.2 3V and maybe another C8 with Osram 1mm2.
And what is the latest firmware for the TA driver? there are so many new firmware releases… hard to keep up. But thanks for all the hard work y’all putting into this. Quite impressive how much has happened in the time I wasn’t on here.
I recently ordered the TA driver in 17mm, I think it is still an up to date driver to be used in flashlights. Not sure which firmware to use, but the firmware repository will have all of them and the help section on there is really good.
https://fundrazr.com/osturaband
No affiliation, just a fan.
20mm FET+1; Aux Led;
Amutorch E3 – E3S FET+1; Aux Led;
D10 headlamp Buck-Boost
Are the 7135 regulators at fasttech still good quality? The 100 pack is only $1.24 more than 50 pack
https://www.fasttech.com/products/1007/10001705/1124300
