Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
17432 posts / 0 new
manithree
manithree's picture
Last seen: 3 hours 48 min ago
My second Q8 from banggood was delivered today. It was ordered on 17 Sep. Looks perfect, and seems to function great.
I still have one on order from elfelend.aliexpress.com. I ordered from them at $44.99, then after a brief stint at $117.63, they’re back down to $99.99.
Tom E
Tom E's picture
Last seen: 4 hours 7 min ago
"You can have my MC3000 when you pry it from my cold, dead fingers"
There's nothing even close to compare it to.
The Miller
The Miller's picture
Say whatever happened to the Elfeland orders?
Did any arrive fast?
manithree
manithree's picture
Calmaja wrote:
Zulumoose wrote:
You shouldn’t be carrying the Q8 around in a pocket, any fool can see that with the correct D ring installed it is meant to be a keyring light.
Sorry, I can’t agree with you about this. I try in my keyring, but don’t feel it is the right size as keyring light Blushing
Some of you are just closing your minds to the most obvious, realistic uses of this magnificent light. For example, pistol mounted:
Also available for the ninja glock:
fuzun
Last seen: 6 months 5 days ago
ToyKeeper wrote:
fuzun wrote:
Definitely not an issue but I am hearing sound while it is operating at approximately %70 %80 level.
I am 20 years old and sound is 19000~ hertz. You probably will not notice this Big Smile
And it is not special for Q8. I am also hearing it from s2+.
S2+ frequency is like 15000 hZ.
The Q8 should be getting about 15 to 16 kHz (I’ve measured 15.3 to 15.7 kHz). S2+ should be 12 to 15 kHz, or ~36 kHz, depending on which batch the driver is from.
Generally these have tried to get a frequency which is as low as possible while still being too high for most humans to hear. Slower uses less power and improves stability, but can look or sound bad, so the sweet spot seems to be as close to 20 kHz as the hardware will allow. For attiny13/25/45/85, the closest it can easily do is about 16 kHz.
Hmm I thought it was 18000 to 19000 hz for Q8 but it seems I am wrong. I do not have a measuring device. I used my ears and brain to measure it Smile
I probably failed because Q8’s sound is quieter to the ear than S2+. And S2+ is definitely 12 to 15 khz. I thought they were at same volume but being Q8’s quieter, it would be higher frequency. It turns out to be Q8’s sound is quieter and at near frequency.
S2+ is quite louder if Q8 is really 15 to 16 kHZ. Like 5 dB more at least.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 48 min ago
The S2+ uses a tiny13a, which has a much greater clock speed variation from piece to piece. It’s quite likely slower than the Q8, which uses a tiny85 with tighter tolerances.
In theory, the PWM speed should be “MHz * 1000 / 256” for the tiny13a / S2+, and “MHZ * 1000 / 512” for the tiny85 / Q8…
  • tiny13a: 4.8 * 1000 / 256 = 18.75 kHz
  • tiny85: 8.0 * 1000 / 512 = 15.625 kHz
… but in practice, the actual clock speed isn’t exactly at spec:
  • tiny13a: 3.0 to 4.4 MHz * 1000 / 256 = ~11.7 to ~17.2 kHz
  • tiny85: 7.8 to 8.1 MHz * 1000 / 512 = ~15.2 to ~15.8 kHz
At least, this is what I’ve found by measuring PWM frequency on my Fluke and estimating clock speed based on that. The Q8 should be within about 3% of its spec’d clock speed, but the S2+ is typically anywhere from 8% to 37% slower than spec. And one batch of S2+ drivers ended up running overclocked by 2X so it was about 36 kHz.
The Q8’s PWM would probably be louder on high levels, but it uses a PWM method which reduces noise and visibility by oscillating between two power levels instead of turning completely off between pulses. If you listen to it during strobe mode though, it’s likely pretty audible.
I don’t have a Q8 yet, but hopefully in a few days I’ll find out if its behavior matches the other tiny85 lights I’ve measured.
patmurris
patmurris's picture
Last seen: 3 weeks 1 day ago
Night time with the Q8…
The Miller
Checked finally the difference between 30Q and Panasonic protected cells
My production Q8 and my son’s
I can’t really tell the difference.
If there is a difference I don’t know if it is imagination or real so close
Checking proto now, pressed against my ear, don’t hear whine, unleas on strobe yes then I can hear something coming from inside
Nice pic Patmurris!
stephenk
stephenk's picture
Last seen: 15 hours 56 min ago
!{width:100%}http://patrick.murris.com/photos/Lights/BLF%20Q8%2001_1024.jpg!
Great night shot. I’m itching to get some night beam shots but it’s pissing it down with rain here (and looks like it’s going to continue all week).
Tom Tom
Last seen: 2 years 6 months ago
Nice pic Patmurris!
With x4 decent cells, feeding x4 decent emitters, the Q8 is hardly over-stretched.
No more than e.g. an olde worlde BLF A6. Actually less so, pretty much the same driver as the A6, except the FET has to cope with the current from 4 similar emitters, not one, so that is probably the bottleneck.
Sonic whine, for those with bat-ears I suspect is mainly generated by movement (maybe simplistically think of it as inductive repulsion) of loose LED wires, (Lenz’s law) maybe could be minimised by twisting them tightly or otherwise physically damping their movement.
Dirt
Last seen: 6 months 3 weeks ago
Well, well. My Q8 showed up today. No issues, small nick on the ano. Clean and mean. 30Q’s from Illumn are charging rite now. Nightfall is here, and I got the flashaholic shakes!
patmurris
patmurris's picture
jmoots
Last seen: 11 hours 11 min ago
Just tried out my Q8 (came yesterday but didn’t get a chance to check the mail till about an hour ago). What stands out the most to me is that, in addition to the fantastic output, ramping, etc., this thing is gorgeous. I’d seen all the pictures of course, but there’s something that just doesn’t translate until you’re holding it in your hand. Thanks for all the hard work and patience!
-joel
stephenk
stephenk's picture
ToyKeeper wrote:
sac02 wrote:
TK, that was a really nice writeup you linked to. Do you put DC fix on many of your lights, or was that somewhat unique to the mixed tint light (to get better mixing)?
I put DC-Fix on lots of lights. For example, the golden SRK on the front page of BLF? That one is mine, and it has DC-Fix on its lens. It’s a happy light:
The Q8 is, incidentally, originally intended to bring back the old good-quality SRKs, like that one. The old ones were pretty nice but newer ones had so much quality reduction that they were mostly junk. However, the Q8 went well beyond that original goal and became something better than all its predecessors. It doesn’t just bring the old SRK back, it leapfrogs the old lights entirely to give us something totally new.
Has anyone DC-Fixed their Q8 yet? Interested in trying myself? Dumb question, but how do I remove the lens?
JasonWW
JasonWW's picture
Last seen: 13 min 54 sec ago
I think it just sticks on, doesn’t it? Do you have to take the lens out? I wish there was more info on this stuff, like how much output you lose, before and after shots, etc…
Doesn’t the stainless bezel just thread off?
gregfortune
Last seen: 2 years 4 months ago
Mine came in today and looks good. The inside of the barrel for the batteries had a few spots I smoothed down and the threads are a touch gritty, but that’s easily fixable. Not dark yet, but still fun to play with. I like the ramping UI more than I thought I would as I’m used to being conservative with battery life (backpacking), but I realized I really don’t care about efficiency for this light and the ramping is just so much fun. Double-click from off is fun too Smile
For the config UI, I’m not a fan of it advancing automatically through the options as a new user. With the blinks being the only feedback you get and not knowing what you’re looking for, I’d far prefer that it just blinked the number of the current setting (or maybe even the value of the current setting?) every 3.5 seconds rather than advancing. I’m sure I’ll get used to it and I probably won’t spend much time in config. Not being able to see the current value of a setting (if there is a way, I haven’t found it yet) makes it tougher to know if you have the config set the way you want. This is just some feedback and in no way diminishes the function or value of the light. Heck, might even get me into the firmware side of things Smile
I wanted to check out that bike mode strobe and after awhile, I finally got myself into Strobe 1, but from there, a click just turned off the light and a click/hold caused it to ramp. I tried explicitly setting the strobe mode to 3 in case it was just set for 1 strobe rather than all and I think I did it right, but not sure. It was probably set that way by default, but again, can’t tell. I’m sure I’m doing something silly and I’ll get it figured out eventually. I don’t think I’ll ever mount this light to my bike, but a preview for the FW3A will be cool!
LEDs are centered, switch LEDs look great, screws I can see are panhead and look fine (didn’t take head apart), and children are terrified. All in all, I’m happy Smile Thanks all for the hard work that went into this!!!
stephenk
stephenk's picture
My only previous application of D-C-Fix was on the inside of the lens (on a P60 drop in I wanted to make floodier). Light loss is minimal (<5%). I’m assuming the bezel unscrews but my feeble attempts have so far been unsuccessful.
JasonWW
JasonWW's picture
Have you seen my videos? This one https://youtu.be/rdwah7HJAJA shows me going into the blinkies. It’s dbl click, short pause, dbl click, then single clicks to go up through the 5 different ones. Your timing might just be a bit off. Once in blinkies you have to advance through them before 1.2 seconds each click. If you stay on a blinky mode longer than 1.2 seconds it locks in.
I also have a video showing the config menu. Once you get the hang of it, it’s easy. The cheat sheet shows the default settings, so just try changing one thing at a time and verifying it worked.
DBSAR
DBSAR's picture
Last seen: 1 day 3 hours ago
Still waiting to get mine to find out if there are issues or not. Tired
goshdogit
goshdogit's picture
Last seen: 24 min ago
A while back, I took some beamshots of an EagleEye X6 and a Convoy S2+ triple comparing d-c-fix and a holographic diffusion film from Luminit.
In that same thread, ‘saabluster’ mentioned the layers of diffusion material used inside newer TVs. I haven’t tried any on a flashlight but I’ve had several TVs apart for repair and the material looks promising. It’s also cheap if you keep an eye out for TVs on trash day. Wink
JasonWW
JasonWW's picture
I think what I had in my head was a very light blending of the beam. The 40° diffusion film probably cuts your beam distance to less than half. That’s not what I was wanting. The 10° looks promising.
Is the DC FIX stuff available in different amounts of diffusion? That looks closer to what I wanted.
Where do you buy it?
ToyKeeper
ToyKeeper's picture
Beam shots before/after DC-Fix? I have some for the BLF-A6… not the greatest shots, but it might at least give some idea what to expect.
It’s worth noting that it does not change the tint. It just blends the various parts of the beam together for a more consistent tint. Usually the hotspot is one color and the spill is another color, but a diffuser reduces that by blending them. In case anyone was wondering why the light on the right looks warmer… it’s not; it’s just more consistent.
JasonWW
JasonWW's picture
Yeah. ^^^^ That looks pretty good. The last time I googled DC fix I got all kinds of colored films and such and no decent places to buy it from.
gregfortune
Sureeeee…… Now it works exactly as expected. My timing on the single clicks might have been too slow. The bike mode is nifty Smile
goshdogit
goshdogit's picture
I think the stuff in my beamshots is the ‘sand’ variant. A listing on Amazon seems to call it ‘milky/sand’ and d-c-fix’s site calls it just ‘milky.’
Have you tried the ‘Scotch tape method?’
Here is the manufacturer’s page with their diffuse self-adhesive variants.
joechina
Another trick, go backwards in strope:
Strobe Modes:
The normal way (RAMPING: 2x, 2x, Y clicks [Y= 1…4] ) is time sensitive because of the lock in modes. And I got PMs people are not quick enough for the Y clicks, because the Y have to be done right after the second double click.
If navigation is hard, try:
RAMPING from off/on: Double click, double click, 4 clicks in a row. Now you are in the 5th strobe = 10 sec beacon.
MODES from off/on: Longhold (over 1,2sec), 4 clicks in a row. Now you are in the 5th strobe
Now you can go back via click&hold. You can go back 4 times, then comes OFF.
If you go backwards you have time to do this.
JasonWW
JasonWW's picture
I’m glad you got it sorted. Thumbs Up
Norddeutscher
Last seen: 1 year 9 months ago
Moin moin
I got two Q8 yesterday and work so far both perfectly.
Thanks to all those who have made this project possible.
greeting
Jens
bwl123
bwl123's picture
Last seen: 4 months 9 hours ago
To remove bezel, place on tyre inner tube(free from tyre repair shops).
Hold head, press down hard and turn anticlockwise.
MAD777
MAD777's picture
Last seen: 7 months 1 day ago
Here are a few detailed pics of my near perfect Q8. I've found nothing to complain about with the workmanship or performance. Comparing this by eye to the performance of a few other lights with similar specs, my sample somewhat exceeds the factory specs given, without any modifications. I'm using Sony VTC6. I plan to bypass the springs.
I disabled the strobe and all functions of the indicator light. I do miss the double-click from turbo to get back to the previous setting, like the D4.
Thanks again to Miller and the team for the best bang for the buck I'll ever get in a flashlight!
BLF-Q8 Details
Mike
